Software Archive
Read-only legacy content
17060 Discussions
Module will not compile
Intel_C_Intel
The following module will not compile; I am probably missing something simple. Appreciate someone pointing out the error of my ways.
	MODULE command_line_arguments
	CONTAINS
	   SUBROUTINE get_arguments (num_arguments, strings,
     &	                         num_strings, error)
	   IMPLICIT NONE
	   INCLUDE 'flib.fd'          ! include for GETARG and NARGS functions
!        Calling arguments
	   INTEGER, INTENT(out) :: num_arguments	! Number of arguments returned
	   INTEGER, INTENT(in)  :: num_strings		! Number of strings to hold
	   INTEGER, INTENT(out) ::	error			! Error flag:	0 = no error
											    !				-1 = system library error
											    !				> 0 = too many arguments
	   CHARACTER(len=*), DIMENSION (num_strings),
     &	                  INTENT(out) :: strings
!										    	! Array to hold arguments
!	Type local variables
	   INTEGER(2) :: i
	   INTEGER(2) status
!	   Get number of arguments
	   num_arguments = nargs()
!	   Check for too many argumeents
	   IF(num_arguments > num_strings) THEN ! too many arguments
		  error         = num_arguments
		  num_arguments = num_strings
	   ELSE
		  error = 0
	   ENDIF
!	   Get arguments
	   DO i =0, num_arguments - 1
		  CALL getarg(i, strings(i + 1), status)
			IF(status < 0) THEN
			   error = status
			   EXIT
	        ENDIF
	   ENDDO
	   END SUBROUTINE get_arguments
	END MODULE command_line_arguments
Hmm - Replace the INCLUDE with USE DFLIB - but what you have should work. I'll look into this.
Steve
