Software Archive
Read-only legacy content
17060 Discussions
Modules, COMMON, and PUBLIC
Intel_C_Intel
I recompiled a program that had reliably given me 0 warnings and 0 errors on a full build for many months now using CVF v6.5a. I get 251 errors with CVF v6.6. Variables in a COMMON statement in a MODULE are no longer defined in program blocks where I USE the MODULE. I note that some error was fixed regarding MODULEs and COMMON, but I didn't think I was doing anything wrong????
Try the 6.6A update. If the problem persists, send a problem description and example to [email protected]
Steve
Intel_C_Intel
I think this program will demonstrate the problem I was having going from
CVF6.5 to CVF6.6/CVF6.6.A: with 6.5 I had a clean build and with 6.6 I had
over 250 errors (all complaints that variables were undeclared).
------ File A.f ------
MODULE A
USE B ! Goes away if not nested
PRIVATE ! Goes away if not PRIVATE
PUBLIC :: X ! Goes away if no PUBLIC
END MODULE A
------ File B.f ------
MODULE B
INTEGER I
COMMON /C/ I ! Goes away if not in COMMON
END MODULE B
------ File Main.f ------
PROGRAM MAIN
USE A ! Goes away if no nesting or if USE order reversed
USE B
IMPLICIT NONE
NAMELIST /N/ I
STOP
END PROGRAM MAIN
One of the things that I realize now is that I should have redesigned the
use of COMMON when I started learning to use MODULE. But, I don't think
that there is anything wrong about the use here.
Mike__
Intel_C_Intel
In the message I just posted, the Main.f should have two lines that say
USE A
USE B
The lines were run together in the posting.
I get no errors building this with 6.6A. Please send a ZIP archive of your project, along with a copy of BUGREPRT.TXT filled out (you'll find it in the DF98 folder, or use the VF Reporter tool), to us at [email protected] - we'll investigate further.
Steve
