Software Archive
Read-only legacy content
17060 Discussions
More than one PWM doesn't work.
Kirtan_S_
On Intel XDK IOT edition,
I tried:
var mraa=require("mraa");
var mypwm=mraa.pwm(9,-1,false);
mypwm.enable(true);
mypwm.period_us(2000);
mypwm.write(0.5)//half the value
This works fine. But when I bring in another pwm value:
var mypwm2=mraa.pwm(10,-1,false);
This causes an error. I tried building it, uploading it, all sorts of things. Is there a way where I can have multiple PWM outputs without bringing up an error?
Matthias_H_Intel
I tried:
mypwm.enable(true);
I checked: Mraa doesn’t support PWM on IO10,  Only the default “swizzler” states. Libmraa wouldn't know if you modify those hence has to assume the defaults
Matthias_H_Intel
could you pls check which version of libmraa you have installed?
Kirtan_S_
I have the latest version from http://iotdk.intel.com/repos/1.1/intelgalactic
Matthias_H_Intel
I tried:
mypwm.enable(true);
