- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Gary,
The evaluation license file (.lic) may still be in the license
file directory path. Can you check the
directory where the license files are kept and remove the evaluation license .lic
file if it still exists? Typically you
can determine the location of the license file(s) by reviewing the value of the
INTEL_LICENSE_FILE system environment variable.
The value typically being the directory path to the license file
directory.
Rob
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Gary,
Can you let me know the exact text of the error message you are
getting or a screen shot showing the error?
This will help me determine other possible solutions. I may need to take a look at the .lic file
but will hold off for now as this would need to be done in a private thread. Just
in case, you may wish to look at the contents of the one .lic file you mentioned
and make sure there is no reference to EVAL and / or a date in the .lic file
that suggests upcoming expiration (typically in the format 2-jun-2011).
Rob
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
c:\Temp>ifort test.for
Intel Visual Fortran Compiler Professional for applications running on IA-32, Version 11.1 Build 20100414 Package ID: w_cprof)p_11.1.065
Copyright (C) 1985-2010 Intel Corporation. All rights reserved.
30 DAY EVALUATION LICENSE
ifort:NOTE: The evaluation period for this product ends on 11-may-2011 UTC.
Is this something that might be stored in the registry?
In the process of getting the screen shot, the engineer noticed that the message does not appear when doing a remote desktop connection from another PC to run the compiler, just when running it from that PC. That seems quite strange to me, but I thought I should pass it along in case it tells you something valuable.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Gary,
I may need to take this forum thread private to gather license
information to troubleshoot the cause further.
However, to clarify, the engineers computer who is experiencing the
warning ifort: NOTE: The evaluation period for this product ends on
11-may-2011 UTC.:
- Is this a floating license with a FlexLM license
server installed / running on the network?
- On the engineers system is the INTEL_LICENSE_FILE system
environment variable defined. If so,
what is this variables value?
Rob
Informational links that may be beneficial to you or others
reading this forum thread:
Getting the product running with my new license
http://software.intel.com/en-us/articles/getting-the-product-running-with-my-new-license/
Setting up the client for a floating license
http://software.intel.com/en-us/articles/licensing-setting-up-the-client-floating-license/
How to set INTEL_LICENSE_FILE Environment Variable
http://software.intel.com/en-us/articles/how-to-set-intel_license_file-environment-variable/
Converting an Evaluation License to a Fully Licensed Product Using
the Intel Activation Tool (IAT)
http://software.intel.com/en-us/articles/converting-an-evaluation-license-to-a-fully-licensed-product-using-the-intel-activation-tool-iat/
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
The value for the INTEL_LICENSE_FILE environment variable is "C:\Program Files\Common Files\Intel\Licenses"
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Gary,
The following article describes the three methods that can be used to set up a client for a floating license.
You may also wish to remove the evaluation / trial license (lic
file) from the client system as this can interfere with licensing depending on
the situation.
Rob
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Gary,
Thank for attempting the other methods. To trouble shoot this further, can you
temporarily remove the value (C:\Program
Files\Common Files\Intel\Licenses)
for the INTEL_LICENSE_FILE system environmental variable on the problematic client? After removing the system variable verify
that it is blank by opening a shell prompt and typing echo %INTEL_LICENSE_FILE%
or similar method. Then attempt to
replicate the behavior. Does the
behavior change? Do you still get the message about the trial expiring or is a new message displayed?
Rob
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
