Software Archive
Read-only legacy content
17060 Discussions
Music not played after XDK v2496 update. But Sound files play
Samuel_Roshan_A_
I recently had to fix an important bug for my game "Last of the Survivors". This game is created using Construct 2. Before building, I updated to the latest Intel XDK v2496. It automatically linked all the plugins in the background.
However after this, the music totally stopped working! Neither on Emulator nor on the Android device. When I run the same game from construct 2, everything works normally. Every other sound effects (like gunshot, explosion etc) plays fine. There has been no changes on the Music function and the music files (.ogg) are present in the expected folder.
You can try my game from the below link and see what I am talking about (yes I made the update without background music and its not great! :( )
https://play.google.com/store/apps/details?id=com.gamessolidrock.lastofthesurvivors
PaulF_IntelCorp
The iOS build system was recently updated to use Xcode 7, and that has been reported to resolve some issues similar to what you are describing. Please try a new build to see if you are still experiencing this problem.
Pamela_H_Intel
There is a known issue with the audio and video playback in Crosswalk builds that is the result of an updated build system. We are still trying to resolve the issue. If you switch to using the shared mode build or update your project to a CLI 5.1.1 and then build with Crosswalk 15 you will resolve the music issue. The CW15 suggestion requires that you update to the latest release of the Intel XDK: 2496.
Champika_S_
I have a problem with CLI 5.1.1. I am using Construct 2 files for build a apk, CLI 5.1.1 can't build apk but CLI 4.1.2 is ok.
Samuel_Roshan_A_
Thanks for the response Pamela. The App I have on Google Play Store right now was built using CLI 5.1.1 and uses Crosswalk 15. It still has music issues. I will however try again.
What is Shared Mode build (it is the one saying "Beta"?  Is there any risk or advantage of using this option over regular build?
Pamela_H_Intel
@Samuel - yes, Shared is the one that says "beta". Here is a good explanation of Embedded vs. Shared: https://software.intel.com/en-us/xdk/docs/choosing-crosswalk-build-options-shared-or-embedded
Anusha_M_Intel1
You mean with CLI 5.1.1 build fails while it is okay with 4.1.2? There are a lot of things that have changed with CLI 5.1.1. Is there a build log you can provide? Or your project zip with .xdk file? Will help us look into the problem.
Amrita_C_Intel
Can you update the XDK version from 2496 to 2548 ? Which may resolve this issue.
Samuel_Roshan_A_
HI Amrita,
Thanks for the update. I installed the new XDK version and used the Plugin Management screen to add all my Plugins (removed them all from Addition.xml file)
When I build my game I get this error . I have pasted the Error Log too. Please help me!
The build failed.
An error occurred while building the application. Verify your build assets are correct and try again.
Calling plugman.fetch on plugin ".../cachedPlugins.3S97UO.tmp/cache.Mjqhfo.pl/cordova-plugin-splashscreen"
Copying plugin ".../cachedPlugins.3S97UO.tmp/cache.Mjqhfo.pl/cordova-plugin-splashscreen" => ".../LastoftesurvivorsV4/plugins/cordova-plugin-splashscreen"
Calling plugman.install on plugin ".../LastoftesurvivorsV4/plugins/cordova-plugin-splashscreen" for platform "android" with options "{"cli_variables":{},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.3S97UO.tmp/cache.Mjqhfo.pl/cordova-plugin-splashscreen":{"filepath":".../cachedPlugins.3S97UO.tmp/cache.Mjqhfo.pl/cordova-plugin-splashscreen/plugin.xml","dir":".../cachedPlugins.3S97UO.tmp/cache.Mjqhfo.pl/cordova-plugin-splashscreen","_et":{"_root":{"_id":35,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","id":"cordova-plugin-splashscreen","version":"2.1.0"},"text":"\n    ","tail":null,"_children":[{"_id":36,"tag":"name","attrib":{},"text":"Splashscreen","tail":"\n    ","_children":[]},{"_id":37,"tag":"description","attrib":{},"text":"Cordova Splashscreen Plugin","tail":"\n    ","_children":[]},{"_id":38,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":39,"tag":"keywords","attrib":{},"text":"cordova,splashscreen","tail":"\n    ","_children":[]},{"_id":40,"tag":"repo","attrib":{},"text":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-splashscreen.git","tail":"\n    ","_children":[]},{"_id":41,"tag":"issue","attrib":{},"text":"https://issues.apache.org/jira/browse/CB/component/12320653","tail":"\n\n    ","_children":[]},{"_id":42,"tag":"engines","attrib":{},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":43,"tag":"engine","attrib":{"name":"cordova-android","version":">=3.6.0"},"text":"","tail":"\n    ","_children":[]}]},{"_id":44,"tag":"js-module","attrib":{"src":"www/splashscreen.js","name":"SplashScreen"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":45,"tag":"clobbers","attrib":{"target":"navigator.splashscreen"},"text":"","tail":"\n    ","_children":[]}]},{"_id":46,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":47,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":48,"tag":"feature","attrib":{"name":"SplashScreen"},"text":"\n                ","tail":"\n        ","_children":[{"_id":49,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.splashscreen.SplashScreen"},"text":"","tail":"\n                ","_children":[]},{"_id":50,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":51,"tag":"source-file","attrib":{"src":"src/android/SplashScreen.java","target-dir":"src/org/apache/cordova/splashscreen"},"text":"","tail":"\n    ","_children":[]}]},{"_id":52,"tag":"platform","attrib":{"name":"amazon-fireos"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":53,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":54,"tag":"feature","attrib":{"name":"SplashScreen"},"text":"\n            ","tail":"\n        ","_children":[{"_id":55,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.splashscreen.SplashScreen"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":56,"tag":"source-file","attrib":{"src":"src/android/SplashScreen.java","target-dir":"src/org/apache/cordova/splashscreen"},"text":"","tail":"\n    ","_children":[]}]},{"_id":57,"tag":"platform","attrib":{"name":"ubuntu"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":58,"tag":"header-file","attrib":{"src":"src/ubuntu/splashscreen.h"},"text":"","tail":"\n        ","_children":[]},{"_id":59,"tag":"source-file","attrib":{"src":"src/ubuntu/splashscreen.cpp"},"text":"","tail":"\n    ","_children":[]}]},{"_id":60,"tag":"platform","attrib":{"name":"ios"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":61,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n\t\t    ","tail":"\n\n        ","_children":[{"_id":62,"tag":"feature","attrib":{"name":"SplashScreen"},"text":"\n\t\t\t    ","tail":"\n        ","_children":[{"_id":63,"tag":"param","attrib":{"name":"ios-package","value":"CDVSplashScreen"},"text":"","tail":"\n\t\t\t    ","_children":[]},{"_id":64,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n\t\t    ","_children":[]}]}]},{"_id":65,"tag":"header-file","attrib":{"src":"src/ios/CDVSplashScreen.h"},"text":"","tail":"\n        ","_children":[]},{"_id":66,"tag":"source-file","attrib":{"src":"src/ios/CDVSplashScreen.m"},"text":"","tail":"\n        ","_children":[]},{"_id":67,"tag":"header-file","attrib":{"src":"src/ios/CDVViewController+SplashScreen.h"},"text":"","tail":"\n        ","_children":[]},{"_id":68,"tag":"source-file","attrib":{"src":"src/ios/CDVViewController+SplashScreen.m"},"text":"","tail":"\n\n\t    ","_children":[]},{"_id":69,"tag":"framework","attrib":{"src":"CoreGraphics.framework"},"text":"","tail":"\n    ","_children":[]}]},{"_id":70,"tag":"platform","attrib":{"name":"blackberry10"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":71,"tag":"source-file","attrib":{"src":"src/blackberry10/index.js","target-dir":"SplashScreen"},"text":"","tail":"\n        ","_children":[]},{"_id":72,"tag":"config-file","attrib":{"target":"www/config.xml","parent":"/widget"},"text":"\n            ","tail":"\n    ","_children":[{"_id":73,"tag":"feature","attrib":{"name":"SplashScreen","value":"SplashScreen"},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":74,"tag":"platform","attrib":{"name":"wp8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":75,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":76,"tag":"feature","attrib":{"name":"SplashScreen"},"text":"\n                ","tail":"\n        ","_children":[{"_id":77,"tag":"param","attrib":{"name":"wp-package","value":"SplashScreen"},"text":"","tail":"\n                ","_children":[]},{"_id":78,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":79,"tag":"source-file","attrib":{"src":"src/wp/SplashScreen.cs"},"text":"","tail":"\n        ","_children":[]},{"_id":80,"tag":"source-file","attrib":{"src":"src/wp/ResolutionHelper.cs"},"text":"","tail":"\n\n    ","_children":[]}]},{"_id":81,"tag":"platform","attrib":{"name":"windows8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":82,"tag":"js-module","attrib":{"src":"www/windows/SplashScreenProxy.js","name":"SplashScreenProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":83,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":84,"tag":"platform","attrib":{"name":"windows"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":85,"tag":"js-module","attrib":{"src":"www/windows/SplashScreenProxy.js","name":"SplashScreenProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":86,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":87,"tag":"platform","attrib":{"name":"tizen"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":88,"tag":"js-module","attrib":{"src":"src/tizen/SplashScreenProxy.js","name":"SplashScreenProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":89,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":90,"tag":"platform","attrib":{"name":"browser"},"text":"\n        ","tail":"\n","_children":[{"_id":91,"tag":"js-module","attrib":{"src":"src/browser/SplashScreenProxy.js","name":"SplashScreenProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":92,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"cordova-plugin-splashscreen","version":"2.1.0","name":"Splashscreen","description":"Cordova Splashscreen Plugin","license":"Apache 2.0","repo":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-splashscreen.git","issue":"https://issues.apache.org/jira/browse/CB/component/12320653","keywords":["cordova","splashscreen"]},".../LastoftesurvivorsV4/plugins/cordova-plugin-splashscreen":{"filepath":".../LastoftesurvivorsV4/plugins/cordova-plugin-splashscreen/plugin.xml","dir":".../LastoftesurvivorsV4/plugins/cordova-plugin-splashscreen","_et":{"_root":{"_id":93,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","id":"cordova-plugin-splashscreen","version":"2.1.0"},"text":"\n    ","tail":null,"_children":[{"_id":94,"tag":"name","attrib":{},"text":"Splashscreen","tail":"\n    ","_children":[]},{"_id":95,"tag":"description","attrib":{},"text":"Cordova Splashscreen Plugin","tail":"\n    ","_children":[]},{"_id":96,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":97,"tag":"keywords","attrib":{},"text":"cordova,splashscreen","tail":"\n    ","_children":[]},{"_id":98,"tag":"repo","attrib":{},"text":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-splashscreen.git","tail":"\n    ","_children":[]},{"_id":99,"tag":"issue","attrib":{},"text":"https://issues.apache.org/jira/browse/CB/component/12320653","tail":"\n\n    ","_children":[]},{"_id":100,"tag":"engines","attrib":{},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":101,"tag":"engine","attrib":{"name":"cordova-android","version":">=3.6.0"},"text":"","tail":"\n    ","_children":[]}]},{"_id":102,"tag":"js-module","attrib":{"src":"www/splashscreen.js","name":"SplashScreen"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":103,"tag":"clobbers","attrib":{"target":"navigator.splashscreen"},"text":"","tail":"\n    ","_children":[]}]},{"_id":104,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":105,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":106,"tag":"feature","attrib":{"name":"SplashScreen"},"text":"\n                ","tail":"\n        ","_children":[{"_id":107,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.splashscreen.SplashScreen"},"text":"","tail":"\n                ","_children":[]},{"_id":108,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":109,"tag":"source-file","attrib":{"src":"src/android/SplashScreen.java","target-dir":"src/org/apache/cordova/splashscreen"},"text":"","tail":"\n    ","_children":[]}]},{"_id":110,"tag":"platform","attrib":{"name":"amazon-fireos"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":111,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":112,"tag":"feature","attrib":{"name":"SplashScreen"},"text":"\n            ","tail":"\n        ","_children":[{"_id":113,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.splashscreen.SplashScreen"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":114,"tag":"source-file","attrib":{"src":"src/android/SplashScreen.java","target-dir":"src/org/apache/cordova/splashscreen"},"text":"","tail":"\n    ","_children":[]}]},{"_id":115,"tag":"platform","attrib":{"name":"ubuntu"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":116,"tag":"header-file","attrib":{"src":"src/ubuntu/splashscreen.h"},"text":"","tail":"\n        ","_children":[]},{"_id":117,"tag":"source-file","attrib":{"src":"src/ubuntu/splashscreen.cpp"},"text":"","tail":"\n    ","_children":[]}]},{"_id":118,"tag":"platform","attrib":{"name":"ios"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":119,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n\t\t    ","tail":"\n\n        ","_children":[{"_id":120,"tag":"feature","attrib":{"name":"SplashScreen"},"text":"\n\t\t\t    ","tail":"\n        ","_children":[{"_id":121,"tag":"param","attrib":{"name":"ios-package","value":"CDVSplashScreen"},"text":"","tail":"\n\t\t\t    ","_children":[]},{"_id":122,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n\t\t    ","_children":[]}]}]},{"_id":123,"tag":"header-file","attrib":{"src":"src/ios/CDVSplashScreen.h"},"text":"","tail":"\n        ","_children":[]},{"_id":124,"tag":"source-file","attrib":{"src":"src/ios/CDVSplashScreen.m"},"text":"","tail":"\n        ","_children":[]},{"_id":125,"tag":"header-file","attrib":{"src":"src/ios/CDVViewController+SplashScreen.h"},"text":"","tail":"\n        ","_children":[]},{"_id":126,"tag":"source-file","attrib":{"src":"src/ios/CDVViewController+SplashScreen.m"},"text":"","tail":"\n\n\t    ","_children":[]},{"_id":127,"tag":"framework","attrib":{"src":"CoreGraphics.framework"},"text":"","tail":"\n    ","_children":[]}]},{"_id":128,"tag":"platform","attrib":{"name":"blackberry10"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":129,"tag":"source-file","attrib":{"src":"src/blackberry10/index.js","target-dir":"SplashScreen"},"text":"","tail":"\n        ","_children":[]},{"_id":130,"tag":"config-file","attrib":{"target":"www/config.xml","parent":"/widget"},"text":"\n            ","tail":"\n    ","_children":[{"_id":131,"tag":"feature","attrib":{"name":"SplashScreen","value":"SplashScreen"},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":132,"tag":"platform","attrib":{"name":"wp8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":133,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":134,"tag":"feature","attrib":{"name":"SplashScreen"},"text":"\n                ","tail":"\n        ","_children":[{"_id":135,"tag":"param","attrib":{"name":"wp-package","value":"SplashScreen"},"text":"","tail":"\n                ","_children":[]},{"_id":136,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":137,"tag":"source-file","attrib":{"src":"src/wp/SplashScreen.cs"},"text":"","tail":"\n        ","_children":[]},{"_id":138,"tag":"source-file","attrib":{"src":"src/wp/ResolutionHelper.cs"},"text":"","tail":"\n\n    ","_children":[]}]},{"_id":139,"tag":"platform","attrib":{"name":"windows8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":140,"tag":"js-module","attrib":{"src":"www/windows/SplashScreenProxy.js","name":"SplashScreenProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":141,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":142,"tag":"platform","attrib":{"name":"windows"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":143,"tag":"js-module","attrib":{"src":"www/windows/SplashScreenProxy.js","name":"SplashScreenProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":144,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":145,"tag":"platform","attrib":{"name":"tizen"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":146,"tag":"js-module","attrib":{"src":"src/tizen/SplashScreenProxy.js","name":"SplashScreenProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":147,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":148,"tag":"platform","attrib":{"name":"browser"},"text":"\n        ","tail":"\n","_children":[{"_id":149,"tag":"js-module","attrib":{"src":"src/browser/SplashScreenProxy.js","name":"SplashScreenProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":150,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"cordova-plugin-splashscreen","version":"2.1.0","name":"Splashscreen","description":"Cordova Splashscreen Plugin","license":"Apache 2.0","repo":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-splashscreen.git","issue":"https://issues.apache.org/jira/browse/CB/component/12320653","keywords":["cordova","splashscreen"]}},"_getAllCache":{}},"nohooks":["."]}"
Installing "cordova-plugin-splashscreen" for android
Running command: .../LastoftesurvivorsV4/platforms/android/cordova/version
Command finished with error code 0: .../LastoftesurvivorsV4/platforms/android/cordova/version
Install start for "cordova-plugin-splashscreen" on android.
Beginning processing of action stack for android project...
Parsing android project files...
Action stack processing complete.
Writing out android project files...
Preparing android project
Processing configuration changes for plugins.
Iterating over installed plugins: [ 'cordova-plugin-splashscreen' ]
Writing out cordova_plugins.js...
Install complete for cordova-plugin-splashscreen on android.
Calling plugman.fetch on plugin ".../cachedPlugins.3S97UO.tmp/cache.ny2LNi.pl/cordova-plugin-device"
Copying plugin ".../cachedPlugins.3S97UO.tmp/cache.ny2LNi.pl/cordova-plugin-device" => ".../LastoftesurvivorsV4/plugins/cordova-plugin-device"
Calling plugman.install on plugin ".../LastoftesurvivorsV4/plugins/cordova-plugin-device" for platform "android" with options "{"cli_variables":{},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.3S97UO.tmp/cache.ny2LNi.pl/cordova-plugin-device":{"filepath":".../cachedPlugins.3S97UO.tmp/cache.ny2LNi.pl/cordova-plugin-device/plugin.xml","dir":".../cachedPlugins.3S97UO.tmp/cache.ny2LNi.pl/cordova-plugin-device","_et":{"_root":{"_id":35,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:rim":"http://www.blackberry.com/ns/widgets","xmlns:android":"http://schemas.android.com/apk/res/android","id":"cordova-plugin-device","version":"1.0.1"},"text":"\n    ","tail":null,"_children":[{"_id":36,"tag":"name","attrib":{},"text":"Device","tail":"\n    ","_children":[]},{"_id":37,"tag":"description","attrib":{},"text":"Cordova Device Plugin","tail":"\n    ","_children":[]},{"_id":38,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":39,"tag":"keywords","attrib":{},"text":"cordova,device","tail":"\n    ","_children":[]},{"_id":40,"tag":"repo","attrib":{},"text":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-device.git","tail":"\n    ","_children":[]},{"_id":41,"tag":"issue","attrib":{},"text":"https://issues.apache.org/jira/browse/CB/component/12320648","tail":"\n\n    ","_children":[]},{"_id":42,"tag":"js-module","attrib":{"src":"www/device.js","name":"device"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":43,"tag":"clobbers","attrib":{"target":"device"},"text":"","tail":"\n    ","_children":[]}]},{"_id":44,"tag":"platform","attrib":{"name":"firefoxos"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":45,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":46,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":47,"tag":"param","attrib":{"name":"firefoxos-package","value":"Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":48,"tag":"js-module","attrib":{"src":"src/firefoxos/DeviceProxy.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":49,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":50,"tag":"platform","attrib":{"name":"tizen"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":51,"tag":"js-module","attrib":{"src":"src/tizen/DeviceProxy.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":52,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":53,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":54,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":55,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":56,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.device.Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":57,"tag":"source-file","attrib":{"src":"src/android/Device.java","target-dir":"src/org/apache/cordova/device"},"text":"","tail":"\n    ","_children":[]}]},{"_id":58,"tag":"platform","attrib":{"name":"amazon-fireos"},"text":"\n        ","tail":"\n    \n    \n    ","_children":[{"_id":59,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":60,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":61,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.device.Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":62,"tag":"source-file","attrib":{"src":"src/android/Device.java","target-dir":"src/org/apache/cordova/device"},"text":"","tail":"\n    ","_children":[]}]},{"_id":63,"tag":"platform","attrib":{"name":"ubuntu"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":64,"tag":"header-file","attrib":{"src":"src/ubuntu/device.h"},"text":"","tail":"\n        ","_children":[]},{"_id":65,"tag":"source-file","attrib":{"src":"src/ubuntu/device.cpp"},"text":"","tail":"\n        ","_children":[]},{"_id":66,"tag":"js-module","attrib":{"src":"src/ubuntu/device.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":67,"tag":"merges","attrib":{"target":"device"},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":68,"tag":"platform","attrib":{"name":"ios"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":69,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":70,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":71,"tag":"param","attrib":{"name":"ios-package","value":"CDVDevice"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":72,"tag":"header-file","attrib":{"src":"src/ios/CDVDevice.h"},"text":"","tail":"\n        ","_children":[]},{"_id":73,"tag":"source-file","attrib":{"src":"src/ios/CDVDevice.m"},"text":"","tail":"\n    ","_children":[]}]},{"_id":74,"tag":"platform","attrib":{"name":"blackberry10"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":75,"tag":"source-file","attrib":{"src":"src/blackberry10/index.js","target-dir":"Device"},"text":"","tail":"\n        ","_children":[]},{"_id":76,"tag":"config-file","attrib":{"target":"www/config.xml","parent":"/widget"},"text":"\n            ","tail":"\n        ","_children":[{"_id":77,"tag":"feature","attrib":{"name":"Device","value":"Device"},"text":"","tail":"\n        ","_children":[]}]},{"_id":78,"tag":"config-file","attrib":{"target":"www/config.xml","parent":"/widget/rim:permissions"},"text":"\n            ","tail":"\n    ","_children":[{"_id":79,"tag":"rim:permit","attrib":{},"text":"read_device_identifying_information","tail":"\n        ","_children":[]}]}]},{"_id":80,"tag":"platform","attrib":{"name":"wp7"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":81,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":82,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":83,"tag":"param","attrib":{"name":"wp-package","value":"Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":84,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":85,"tag":"Capability","attrib":{"Name":"ID_CAP_IDENTITY_DEVICE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":86,"tag":"source-file","attrib":{"src":"src/wp/Device.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":87,"tag":"platform","attrib":{"name":"wp8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":88,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":89,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":90,"tag":"param","attrib":{"name":"wp-package","value":"Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":91,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":92,"tag":"Capability","attrib":{"Name":"ID_CAP_IDENTITY_DEVICE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":93,"tag":"source-file","attrib":{"src":"src/wp/Device.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":94,"tag":"platform","attrib":{"name":"windows"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":95,"tag":"js-module","attrib":{"src":"src/windows/DeviceProxy.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":96,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":97,"tag":"platform","attrib":{"name":"browser"},"text":"\n        ","tail":"\n\n","_children":[{"_id":98,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":99,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":100,"tag":"param","attrib":{"name":"browser-package","value":"Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":101,"tag":"js-module","attrib":{"src":"src/browser/DeviceProxy.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":102,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"cordova-plugin-device","version":"1.0.1","name":"Device","description":"Cordova Device Plugin","license":"Apache 2.0","repo":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-device.git","issue":"https://issues.apache.org/jira/browse/CB/component/12320648","keywords":["cordova","device"]},".../LastoftesurvivorsV4/plugins/cordova-plugin-device":{"filepath":".../LastoftesurvivorsV4/plugins/cordova-plugin-device/plugin.xml","dir":".../LastoftesurvivorsV4/plugins/cordova-plugin-device","_et":{"_root":{"_id":103,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:rim":"http://www.blackberry.com/ns/widgets","xmlns:android":"http://schemas.android.com/apk/res/android","id":"cordova-plugin-device","version":"1.0.1"},"text":"\n    ","tail":null,"_children":[{"_id":104,"tag":"name","attrib":{},"text":"Device","tail":"\n    ","_children":[]},{"_id":105,"tag":"description","attrib":{},"text":"Cordova Device Plugin","tail":"\n    ","_children":[]},{"_id":106,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":107,"tag":"keywords","attrib":{},"text":"cordova,device","tail":"\n    ","_children":[]},{"_id":108,"tag":"repo","attrib":{},"text":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-device.git","tail":"\n    ","_children":[]},{"_id":109,"tag":"issue","attrib":{},"text":"https://issues.apache.org/jira/browse/CB/component/12320648","tail":"\n\n    ","_children":[]},{"_id":110,"tag":"js-module","attrib":{"src":"www/device.js","name":"device"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":111,"tag":"clobbers","attrib":{"target":"device"},"text":"","tail":"\n    ","_children":[]}]},{"_id":112,"tag":"platform","attrib":{"name":"firefoxos"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":113,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":114,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":115,"tag":"param","attrib":{"name":"firefoxos-package","value":"Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":116,"tag":"js-module","attrib":{"src":"src/firefoxos/DeviceProxy.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":117,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":118,"tag":"platform","attrib":{"name":"tizen"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":119,"tag":"js-module","attrib":{"src":"src/tizen/DeviceProxy.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":120,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":121,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":122,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":123,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":124,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.device.Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":125,"tag":"source-file","attrib":{"src":"src/android/Device.java","target-dir":"src/org/apache/cordova/device"},"text":"","tail":"\n    ","_children":[]}]},{"_id":126,"tag":"platform","attrib":{"name":"amazon-fireos"},"text":"\n        ","tail":"\n    \n    \n    ","_children":[{"_id":127,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":128,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":129,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.device.Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":130,"tag":"source-file","attrib":{"src":"src/android/Device.java","target-dir":"src/org/apache/cordova/device"},"text":"","tail":"\n    ","_children":[]}]},{"_id":131,"tag":"platform","attrib":{"name":"ubuntu"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":132,"tag":"header-file","attrib":{"src":"src/ubuntu/device.h"},"text":"","tail":"\n        ","_children":[]},{"_id":133,"tag":"source-file","attrib":{"src":"src/ubuntu/device.cpp"},"text":"","tail":"\n        ","_children":[]},{"_id":134,"tag":"js-module","attrib":{"src":"src/ubuntu/device.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":135,"tag":"merges","attrib":{"target":"device"},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":136,"tag":"platform","attrib":{"name":"ios"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":137,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":138,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":139,"tag":"param","attrib":{"name":"ios-package","value":"CDVDevice"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":140,"tag":"header-file","attrib":{"src":"src/ios/CDVDevice.h"},"text":"","tail":"\n        ","_children":[]},{"_id":141,"tag":"source-file","attrib":{"src":"src/ios/CDVDevice.m"},"text":"","tail":"\n    ","_children":[]}]},{"_id":142,"tag":"platform","attrib":{"name":"blackberry10"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":143,"tag":"source-file","attrib":{"src":"src/blackberry10/index.js","target-dir":"Device"},"text":"","tail":"\n        ","_children":[]},{"_id":144,"tag":"config-file","attrib":{"target":"www/config.xml","parent":"/widget"},"text":"\n            ","tail":"\n        ","_children":[{"_id":145,"tag":"feature","attrib":{"name":"Device","value":"Device"},"text":"","tail":"\n        ","_children":[]}]},{"_id":146,"tag":"config-file","attrib":{"target":"www/config.xml","parent":"/widget/rim:permissions"},"text":"\n            ","tail":"\n    ","_children":[{"_id":147,"tag":"rim:permit","attrib":{},"text":"read_device_identifying_information","tail":"\n        ","_children":[]}]}]},{"_id":148,"tag":"platform","attrib":{"name":"wp7"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":149,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":150,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":151,"tag":"param","attrib":{"name":"wp-package","value":"Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":152,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":153,"tag":"Capability","attrib":{"Name":"ID_CAP_IDENTITY_DEVICE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":154,"tag":"source-file","attrib":{"src":"src/wp/Device.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":155,"tag":"platform","attrib":{"name":"wp8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":156,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":157,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":158,"tag":"param","attrib":{"name":"wp-package","value":"Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":159,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":160,"tag":"Capability","attrib":{"Name":"ID_CAP_IDENTITY_DEVICE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":161,"tag":"source-file","attrib":{"src":"src/wp/Device.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":162,"tag":"platform","attrib":{"name":"windows"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":163,"tag":"js-module","attrib":{"src":"src/windows/DeviceProxy.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":164,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":165,"tag":"platform","attrib":{"name":"browser"},"text":"\n        ","tail":"\n\n","_children":[{"_id":166,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":167,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":168,"tag":"param","attrib":{"name":"browser-package","value":"Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":169,"tag":"js-module","attrib":{"src":"src/browser/DeviceProxy.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":170,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"cordova-plugin-device","version":"1.0.1","name":"Device","description":"Cordova Device Plugin","license":"Apache 2.0","repo":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-device.git","issue":"https://issues.apache.org/jira/browse/CB/component/12320648","keywords":["cordova","device"]}},"_getAllCache":{}},"nohooks":["."]}"
Installing "cordova-plugin-device" for android
Install start for "cordova-plugin-device" on android.
Iterating over installed plugins: [ 'cordova-plugin-splashscreen', 'cordova-plugin-device' ]
Install complete for cordova-plugin-device on android.
Calling plugman.fetch on plugin ".../cachedPlugins.3S97UO.tmp/cache.S_V0aw.pl/cordova-plugin-device-motion"
Copying plugin ".../cachedPlugins.3S97UO.tmp/cache.S_V0aw.pl/cordova-plugin-device-motion" => ".../LastoftesurvivorsV4/plugins/cordova-plugin-device-motion"
Calling plugman.install on plugin ".../LastoftesurvivorsV4/plugins/cordova-plugin-device-motion" for platform "android" with options "{"cli_variables":{},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.3S97UO.tmp/cache.S_V0aw.pl/cordova-plugin-device-motion":{"filepath":".../cachedPlugins.3S97UO.tmp/cache.S_V0aw.pl/cordova-plugin-device-motion/plugin.xml","dir":".../cachedPlugins.3S97UO.tmp/cache.S_V0aw.pl/cordova-plugin-device-motion","_et":{"_root":{"_id":35,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","id":"cordova-plugin-device-motion","version":"1.1.1"},"text":"\n\t\n    ","tail":null,"_children":[{"_id":36,"tag":"name","attrib":{},"text":"Device Motion","tail":"\n    ","_children":[]},{"_id":37,"tag":"description","attrib":{},"text":"Cordova Device Motion Plugin","tail":"\n    ","_children":[]},{"_id":38,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":39,"tag":"keywords","attrib":{},"text":"cordova,device,motion","tail":"\n    ","_children":[]},{"_id":40,"tag":"repo","attrib":{},"text":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-device-motion.git","tail":"\n    ","_children":[]},{"_id":41,"tag":"issue","attrib":{},"text":"https://issues.apache.org/jira/browse/CB/component/12320636","tail":"\n\n    ","_children":[]},{"_id":42,"tag":"js-module","attrib":{"src":"www/Acceleration.js","name":"Acceleration"},"text":"\n        ","tail":"\n    \n    ","_children":[{"_id":43,"tag":"clobbers","attrib":{"target":"Acceleration"},"text":"","tail":"\n    ","_children":[]}]},{"_id":44,"tag":"js-module","attrib":{"src":"www/accelerometer.js","name":"accelerometer"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":45,"tag":"clobbers","attrib":{"target":"navigator.accelerometer"},"text":"","tail":"\n    ","_children":[]}]},{"_id":46,"tag":"platform","attrib":{"name":"firefoxos"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":47,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"                                         \n        \n        ","_children":[{"_id":48,"tag":"feature","attrib":{"name":"Accelerometer"},"text":"\n                ","tail":"\n        ","_children":[{"_id":49,"tag":"param","attrib":{"name":"firefoxos-package","value":"Accelerometer"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":50,"tag":"js-module","attrib":{"src":"src/firefoxos/accelerometer.js","name":"accelerometer-impl"},"text":"\n          ","tail":"\n    ","_children":[{"_id":51,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":52,"tag":"platform","attrib":{"name":"android"},"text":"\n\t    \n        ","tail":"\n    \n    \n    ","_children":[{"_id":53,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":54,"tag":"feature","attrib":{"name":"Accelerometer"},"text":"\n                ","tail":"\n        ","_children":[{"_id":55,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.devicemotion.AccelListener"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":56,"tag":"source-file","attrib":{"src":"src/android/AccelListener.java","target-dir":"src/org/apache/cordova/devicemotion"},"text":"","tail":"\n    \n    ","_children":[]}]},{"_id":57,"tag":"platform","attrib":{"name":"amazon-fireos"},"text":"\n\t    \n        ","tail":"\n    \n    \n    ","_children":[{"_id":58,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":59,"tag":"feature","attrib":{"name":"Accelerometer"},"text":"\n                ","tail":"\n        ","_children":[{"_id":60,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.devicemotion.AccelListener"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":61,"tag":"source-file","attrib":{"src":"src/android/AccelListener.java","target-dir":"src/org/apache/cordova/devicemotion"},"text":"","tail":"\n    \n    ","_children":[]}]},{"_id":62,"tag":"platform","attrib":{"name":"ubuntu"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":63,"tag":"header-file","attrib":{"src":"src/ubuntu/accelerometer.h"},"text":"","tail":"\n        ","_children":[]},{"_id":64,"tag":"source-file","attrib":{"src":"src/ubuntu/accelerometer.cpp"},"text":"","tail":"\n    ","_children":[]}]},{"_id":65,"tag":"platform","attrib":{"name":"ios"},"text":"\n        \n        ","tail":"\n\n    \n    ","_children":[{"_id":66,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n            \n        ","_children":[{"_id":67,"tag":"feature","attrib":{"name":"Accelerometer"},"text":"\n                ","tail":"\n        ","_children":[{"_id":68,"tag":"param","attrib":{"name":"ios-package","value":"CDVAccelerometer"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":69,"tag":"header-file","attrib":{"src":"src/ios/CDVAccelerometer.h"},"text":"","tail":"\n        ","_children":[]},{"_id":70,"tag":"source-file","attrib":{"src":"src/ios/CDVAccelerometer.m"},"text":"","tail":"\n        \n        ","_children":[]},{"_id":71,"tag":"framework","attrib":{"src":"CoreMotion.framework"},"text":"","tail":"\n    ","_children":[]}]},{"_id":72,"tag":"platform","attrib":{"name":"blackberry10"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":73,"tag":"config-file","attrib":{"target":"www/config.xml","parent":"/widget"},"text":"\n            ","tail":"\n        ","_children":[{"_id":74,"tag":"feature","attrib":{"name":"Accelerometer","value":"Accelerometer"},"text":"","tail":"\n        ","_children":[]}]},{"_id":75,"tag":"source-file","attrib":{"src":"src/blackberry10/index.js","target-dir":"Accelerometer"},"text":"","tail":"\n    ","_children":[]}]},{"_id":76,"tag":"platform","attrib":{"name":"wp7"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":77,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":78,"tag":"feature","attrib":{"name":"Accelerometer"},"text":"\n                ","tail":"\n        ","_children":[{"_id":79,"tag":"param","attrib":{"name":"wp-package","value":"Accelerometer"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":80,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":81,"tag":"Capability","attrib":{"Name":"ID_CAP_SENSORS"},"text":"","tail":"\n        ","_children":[]}]},{"_id":82,"tag":"source-file","attrib":{"src":"src/wp/Accelerometer.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":83,"tag":"platform","attrib":{"name":"wp8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":84,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":85,"tag":"feature","attrib":{"name":"Accelerometer"},"text":"\n                ","tail":"\n        ","_children":[{"_id":86,"tag":"param","attrib":{"name":"wp-package","value":"Accelerometer"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":87,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":88,"tag":"Capability","attrib":{"Name":"ID_CAP_SENSORS"},"text":"","tail":"\n        ","_children":[]}]},{"_id":89,"tag":"source-file","attrib":{"src":"src/wp/Accelerometer.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":90,"tag":"platform","attrib":{"name":"windows8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":91,"tag":"js-module","attrib":{"src":"src/windows/AccelerometerProxy.js","name":"AccelerometerProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":92,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":93,"tag":"platform","attrib":{"name":"windows"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":94,"tag":"js-module","attrib":{"src":"src/windows/AccelerometerProxy.js","name":"AccelerometerProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":95,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":96,"tag":"platform","attrib":{"name":"tizen"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":97,"tag":"js-module","attrib":{"src":"src/tizen/AccelerometerProxy.js","name":"AccelerometerProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":98,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":99,"tag":"platform","attrib":{"name":"browser"},"text":"\n        ","tail":"\n","_children":[{"_id":100,"tag":"js-module","attrib":{"src":"src/browser/AccelerometerProxy.js","name":"AccelerometerProxy"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":101,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]},{"_id":102,"tag":"js-module","attrib":{"src":"src/browser/accelerometer.js","name":"accelerometer"},"text":"\n            ","tail":"\n    ","_children":[{"_id":103,"tag":"merges","attrib":{"target":"navigator.accelerometer"},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"cordova-plugin-device-motion","version":"1.1.1","name":"Device Motion","description":"Cordova Device Motion Plugin","license":"Apache 2.0","repo":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-device-motion.git","issue":"https://issues.apache.org/jira/browse/CB/component/12320636","keywords":["cordova","device","motion"]},".../LastoftesurvivorsV4/plugins/cordova-plugin-device-motion":{"filepath":".../LastoftesurvivorsV4/plugins/cordova-plugin-device-motion/plugin.xml","dir":".../LastoftesurvivorsV4/plugins/cordova-plugin-device-motion","_et":{"_root":{"_id":104,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","id":"cordova-plugin-device-motion","version":"1.1.1"},"text":"\n\t\n    ","tail":null,"_children":[{"_id":105,"tag":"name","attrib":{},"text":"Device Motion","tail":"\n    ","_children":[]},{"_id":106,"tag":"description","attrib":{},"text":"Cordova Device Motion Plugin","tail":"\n    ","_children":[]},{"_id":107,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":108,"tag":"keywords","attrib":{},"text":"cordova,device,motion","tail":"\n    ","_children":[]},{"_id":109,"tag":"repo","attrib":{},"text":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-device-motion.git","tail":"\n    ","_children":[]},{"_id":110,"tag":"issue","attrib":{},"text":"https://issues.apache.org/jira/browse/CB/component/12320636","tail":"\n\n    ","_children":[]},{"_id":111,"tag":"js-module","attrib":{"src":"www/Acceleration.js","name":"Acceleration"},"text":"\n        ","tail":"\n    \n    ","_children":[{"_id":112,"tag":"clobbers","attrib":{"target":"Acceleration"},"text":"","tail":"\n    ","_children":[]}]},{"_id":113,"tag":"js-module","attrib":{"src":"www/accelerometer.js","name":"accelerometer"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":114,"tag":"clobbers","attrib":{"target":"navigator.accelerometer"},"text":"","tail":"\n    ","_children":[]}]},{"_id":115,"tag":"platform","attrib":{"name":"firefoxos"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":116,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"                                         \n        \n        ","_children":[{"_id":117,"tag":"feature","attrib":{"name":"Accelerometer"},"text":"\n                ","tail":"\n        ","_children":[{"_id":118,"tag":"param","attrib":{"name":"firefoxos-package","value":"Accelerometer"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":119,"tag":"js-module","attrib":{"src":"src/firefoxos/accelerometer.js","name":"accelerometer-impl"},"text":"\n          ","tail":"\n    ","_children":[{"_id":120,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":121,"tag":"platform","attrib":{"name":"android"},"text":"\n\t    \n        ","tail":"\n    \n    \n    ","_children":[{"_id":122,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":123,"tag":"feature","attrib":{"name":"Accelerometer"},"text":"\n                ","tail":"\n        ","_children":[{"_id":124,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.devicemotion.AccelListener"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":125,"tag":"source-file","attrib":{"src":"src/android/AccelListener.java","target-dir":"src/org/apache/cordova/devicemotion"},"text":"","tail":"\n    \n    ","_children":[]}]},{"_id":126,"tag":"platform","attrib":{"name":"amazon-fireos"},"text":"\n\t    \n        ","tail":"\n    \n    \n    ","_children":[{"_id":127,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":128,"tag":"feature","attrib":{"name":"Accelerometer"},"text":"\n                ","tail":"\n        ","_children":[{"_id":129,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.devicemotion.AccelListener"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":130,"tag":"source-file","attrib":{"src":"src/android/AccelListener.java","target-dir":"src/org/apache/cordova/devicemotion"},"text":"","tail":"\n    \n    ","_children":[]}]},{"_id":131,"tag":"platform","attrib":{"name":"ubuntu"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":132,"tag":"header-file","attrib":{"src":"src/ubuntu/accelerometer.h"},"text":"","tail":"\n        ","_children":[]},{"_id":133,"tag":"source-file","attrib":{"src":"src/ubuntu/accelerometer.cpp"},"text":"","tail":"\n    ","_children":[]}]},{"_id":134,"tag":"platform","attrib":{"name":"ios"},"text":"\n        \n        ","tail":"\n\n    \n    ","_children":[{"_id":135,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n            \n        ","_children":[{"_id":136,"tag":"feature","attrib":{"name":"Accelerometer"},"text":"\n                ","tail":"\n        ","_children":[{"_id":137,"tag":"param","attrib":{"name":"ios-package","value":"CDVAccelerometer"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":138,"tag":"header-file","attrib":{"src":"src/ios/CDVAccelerometer.h"},"text":"","tail":"\n        ","_children":[]},{"_id":139,"tag":"source-file","attrib":{"src":"src/ios/CDVAccelerometer.m"},"text":"","tail":"\n        \n        ","_children":[]},{"_id":140,"tag":"framework","attrib":{"src":"CoreMotion.framework"},"text":"","tail":"\n    ","_children":[]}]},{"_id":141,"tag":"platform","attrib":{"name":"blackberry10"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":142,"tag":"config-file","attrib":{"target":"www/config.xml","parent":"/widget"},"text":"\n            ","tail":"\n        ","_children":[{"_id":143,"tag":"feature","attrib":{"name":"Accelerometer","value":"Accelerometer"},"text":"","tail":"\n        ","_children":[]}]},{"_id":144,"tag":"source-file","attrib":{"src":"src/blackberry10/index.js","target-dir":"Accelerometer"},"text":"","tail":"\n    ","_children":[]}]},{"_id":145,"tag":"platform","attrib":{"name":"wp7"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":146,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":147,"tag":"feature","attrib":{"name":"Accelerometer"},"text":"\n                ","tail":"\n        ","_children":[{"_id":148,"tag":"param","attrib":{"name":"wp-package","value":"Accelerometer"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":149,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":150,"tag":"Capability","attrib":{"Name":"ID_CAP_SENSORS"},"text":"","tail":"\n        ","_children":[]}]},{"_id":151,"tag":"source-file","attrib":{"src":"src/wp/Accelerometer.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":152,"tag":"platform","attrib":{"name":"wp8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":153,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":154,"tag":"feature","attrib":{"name":"Accelerometer"},"text":"\n                ","tail":"\n        ","_children":[{"_id":155,"tag":"param","attrib":{"name":"wp-package","value":"Accelerometer"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":156,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":157,"tag":"Capability","attrib":{"Name":"ID_CAP_SENSORS"},"text":"","tail":"\n        ","_children":[]}]},{"_id":158,"tag":"source-file","attrib":{"src":"src/wp/Accelerometer.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":159,"tag":"platform","attrib":{"name":"windows8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":160,"tag":"js-module","attrib":{"src":"src/windows/AccelerometerProxy.js","name":"AccelerometerProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":161,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":162,"tag":"platform","attrib":{"name":"windows"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":163,"tag":"js-module","attrib":{"src":"src/windows/AccelerometerProxy.js","name":"AccelerometerProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":164,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":165,"tag":"platform","attrib":{"name":"tizen"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":166,"tag":"js-module","attrib":{"src":"src/tizen/AccelerometerProxy.js","name":"AccelerometerProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":167,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":168,"tag":"platform","attrib":{"name":"browser"},"text":"\n        ","tail":"\n","_children":[{"_id":169,"tag":"js-module","attrib":{"src":"src/browser/AccelerometerProxy.js","name":"AccelerometerProxy"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":170,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]},{"_id":171,"tag":"js-module","attrib":{"src":"src/browser/accelerometer.js","name":"accelerometer"},"text":"\n            ","tail":"\n    ","_children":[{"_id":172,"tag":"merges","attrib":{"target":"navigator.accelerometer"},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"cordova-plugin-device-motion","version":"1.1.1","name":"Device Motion","description":"Cordova Device Motion Plugin","license":"Apache 2.0","repo":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-device-motion.git","issue":"https://issues.apache.org/jira/browse/CB/component/12320636","keywords":["cordova","device","motion"]}},"_getAllCache":{}},"nohooks":["."]}"
Installing "cordova-plugin-device-motion" for android
Install start for "cordova-plugin-device-motion" on android.
  'cordova-plugin-device',
  'cordova-plugin-device-motion' ]
Install complete for cordova-plugin-device-motion on android.
Calling plugman.fetch on plugin ".../cachedPlugins.3S97UO.tmp/cache.duURjR.pl/com.google.playservices"
Copying plugin ".../cachedPlugins.3S97UO.tmp/cache.duURjR.pl/com.google.playservices" => ".../LastoftesurvivorsV4/plugins/com.google.playservices"
Calling plugman.install on plugin ".../LastoftesurvivorsV4/plugins/com.google.playservices" for platform "android" with options "{"cli_variables":{},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.3S97UO.tmp/cache.duURjR.pl/com.google.playservices":{"filepath":".../cachedPlugins.3S97UO.tmp/cache.duURjR.pl/com.google.playservices/plugin.xml","dir":".../cachedPlugins.3S97UO.tmp/cache.duURjR.pl/com.google.playservices","_et":{"_root":{"_id":35,"tag":"plugin","attrib":{"xmlns":"http://cordova.apache.org/ns/plugins/1.0","id":"com.google.playservices","version":"21.0.0"},"text":"\n  ","tail":null,"_children":[{"_id":36,"tag":"engines","attrib":{},"text":"\n    ","tail":"\n\n  ","_children":[{"_id":37,"tag":"engine","attrib":{"name":"cordova","version":">=3.0.0"},"text":"","tail":"\n  ","_children":[]}]},{"_id":38,"tag":"name","attrib":{},"text":"Google Play Services for Android","tail":"\n\n  ","_children":[]},{"_id":39,"tag":"platform","attrib":{"name":"android"},"text":"\n    ","tail":"\n","_children":[{"_id":40,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/manifest/application"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":41,"tag":"meta-data","attrib":{"android:name":"com.google.android.gms.version","android:value":"@integer/google_play_services_version"},"text":"","tail":"\n    ","_children":[]}]},{"_id":42,"tag":"source-file","attrib":{"src":"version.xml","target-dir":"res/values"},"text":"","tail":"\n    ","_children":[]},{"_id":43,"tag":"framework","attrib":{"src":"libs/google-play-services_lib","custom":"true"},"text":"","tail":"\n  ","_children":[]}]}]}},"id":"com.google.playservices","version":"21.0.0","name":"Google Play Services for Android"},".../LastoftesurvivorsV4/plugins/com.google.playservices":{"filepath":".../LastoftesurvivorsV4/plugins/com.google.playservices/plugin.xml","dir":".../LastoftesurvivorsV4/plugins/com.google.playservices","_et":{"_root":{"_id":44,"tag":"plugin","attrib":{"xmlns":"http://cordova.apache.org/ns/plugins/1.0","id":"com.google.playservices","version":"21.0.0"},"text":"\n  ","tail":null,"_children":[{"_id":45,"tag":"engines","attrib":{},"text":"\n    ","tail":"\n\n  ","_children":[{"_id":46,"tag":"engine","attrib":{"name":"cordova","version":">=3.0.0"},"text":"","tail":"\n  ","_children":[]}]},{"_id":47,"tag":"name","attrib":{},"text":"Google Play Services for Android","tail":"\n\n  ","_children":[]},{"_id":48,"tag":"platform","attrib":{"name":"android"},"text":"\n    ","tail":"\n","_children":[{"_id":49,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/manifest/application"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":50,"tag":"meta-data","attrib":{"android:name":"com.google.android.gms.version","android:value":"@integer/google_play_services_version"},"text":"","tail":"\n    ","_children":[]}]},{"_id":51,"tag":"source-file","attrib":{"src":"version.xml","target-dir":"res/values"},"text":"","tail":"\n    ","_children":[]},{"_id":52,"tag":"framework","attrib":{"src":"libs/google-play-services_lib","custom":"true"},"text":"","tail":"\n  ","_children":[]}]}]}},"id":"com.google.playservices","version":"21.0.0","name":"Google Play Services for Android"}},"_getAllCache":{}},"nohooks":["."]}"
Installing "com.google.playservices" for android
Install start for "com.google.playservices" on android.
Installing Android library: libs/google-play-services_lib
  'cordova-plugin-device-motion',
  'com.google.playservices' ]
Install complete for com.google.playservices on android.
Updating build files since android plugin contained <framework>
Calling plugman.fetch on plugin ".../cachedPlugins.3S97UO.tmp/cache.rWx_vw.pl/cordova-plugin-ad-admobsdk"
Copying plugin ".../cachedPlugins.3S97UO.tmp/cache.rWx_vw.pl/cordova-plugin-ad-admobsdk" => ".../LastoftesurvivorsV4/plugins/cordova-plugin-ad-admobsdk"
Calling plugman.install on plugin ".../LastoftesurvivorsV4/plugins/cordova-plugin-ad-admobsdk" for platform "android" with options "{"cli_variables":{},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.3S97UO.tmp/cache.rWx_vw.pl/cordova-plugin-ad-admobsdk":{"filepath":".../cachedPlugins.3S97UO.tmp/cache.rWx_vw.pl/cordova-plugin-ad-admobsdk/plugin.xml","dir":".../cachedPlugins.3S97UO.tmp/cache.rWx_vw.pl/cordova-plugin-ad-admobsdk","_et":{"_root":{"_id":35,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:android":"http://schemas.android.com/apk/res/android","id":"cordova-plugin-ad-admobsdk","version":"1.0.23"},"text":"\r\n\t\r\n    ","tail":null,"_children":[{"_id":36,"tag":"name","attrib":{},"text":"Cordova Admob SDK","tail":"\r\n    ","_children":[]},{"_id":37,"tag":"description","attrib":{},"text":"Cordova Admob SDK","tail":"\r\n    ","_children":[]},{"_id":38,"tag":"author","attrib":{},"text":"Sang Ki Kwon (Cranberrygame)","tail":"\t\t\r\n    ","_children":[]},{"_id":39,"tag":"license","attrib":{},"text":"MIT","tail":"\r\n    ","_children":[]},{"_id":40,"tag":"keywords","attrib":{},"text":"cordova,plugin,ad,admobsdk,monetisation","tail":"\r\n    ","_children":[]},{"_id":41,"tag":"repo","attrib":{},"text":"https://github.com/cranberrygame/cordova-plugin-ad-admob","tail":"\r\n    ","_children":[]},{"_id":42,"tag":"issue","attrib":{},"text":"https://github.com/cranberrygame/cordova-plugin-ad-admob/issues","tail":" \t\r\n\t","_children":[]},{"_id":43,"tag":"engines","attrib":{},"text":"\r\n\t    ","tail":"\r\n\t\t\r\n    \r\n    ","_children":[{"_id":44,"tag":"engine","attrib":{"name":"cordova","version":">=3.0.0"},"text":"","tail":"\r\n\t","_children":[]}]},{"_id":45,"tag":"platform","attrib":{"name":"android"},"text":"\t\t\r\n        ","tail":"\r\n\r\n\t\r\n\t","_children":[{"_id":46,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/manifest/application"},"text":"\r\n\t\t\t","tail":"\r\n\t\t\r\n        ","_children":[{"_id":47,"tag":"activity","attrib":{"android:configChanges":"keyboard|keyboardHidden|orientation|screenLayout|uiMode|screenSize|smallestScreenSize","android:name":"com.google.android.gms.ads.AdActivity"},"text":"","tail":"\r\n        ","_children":[]}]},{"_id":48,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/*"},"text":"\r\n\t\t\t","tail":"\t\t\r\n\t\t\r\n\t\t\r\n\t\t\r\n\t\t\r\n\t\t\r\n\t\t\r\n\t\t\r\n\t\t\r\n\t\t\r\n\t\t\r\n\t\t","_children":[{"_id":49,"tag":"uses-permission","attrib":{"android:name":"android.permission.INTERNET"},"text":"","tail":"\r\n\t\t\t","_children":[]},{"_id":50,"tag":"uses-permission","attrib":{"android:name":"android.permission.ACCESS_NETWORK_STATE"},"text":"","tail":"\r\n        ","_children":[]}]},{"_id":51,"tag":"dependency","attrib":{"id":"com.google.playservices@21.0.0"},"text":"","tail":"\r\n    ","_children":[]}]},{"_id":52,"tag":"platform","attrib":{"name":"ios"},"text":"\r\n\t\t","tail":"\r\n\t\r\n    \r\n    ","_children":[{"_id":53,"tag":"framework","attrib":{"src":"src/ios/GoogleMobileAds.framework","custom":"true"},"text":"","tail":"\t\t\r\n \t    ","_children":[]},{"_id":54,"tag":"framework","attrib":{"src":"StoreKit.framework"},"text":"","tail":"\r\n \t    ","_children":[]},{"_id":55,"tag":"framework","attrib":{"src":"AudioToolbox.framework"},"text":"","tail":"\r\n        ","_children":[]},{"_id":56,"tag":"framework","attrib":{"src":"MessageUI.framework"},"text":"","tail":"\r\n        ","_children":[]},{"_id":57,"tag":"framework","attrib":{"src":"SystemConfiguration.framework"},"text":"","tail":"\r\n        ","_children":[]},{"_id":58,"tag":"framework","attrib":{"src":"CoreGraphics.framework"},"text":"","tail":"\r\n        ","_children":[]},{"_id":59,"tag":"framework","attrib":{"src":"AdSupport.framework"},"text":"","tail":"\r\n        ","_children":[]},{"_id":60,"tag":"framework","attrib":{"src":"CoreTelephony.framework"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":61,"tag":"framework","attrib":{"src":"EventKit.framework"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":62,"tag":"framework","attrib":{"src":"EventKitUI.framework"},"text":"","tail":"\t\t\r\n\t\t","_children":[]},{"_id":63,"tag":"framework","attrib":{"src":"QuartzCore.framework"},"text":"","tail":"\t\t\r\n\t","_children":[]}]},{"_id":64,"tag":"platform","attrib":{"name":"wp8"},"text":"\r\n\t\t","tail":"\r\n","_children":[{"_id":65,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\r\n\t\t\t","tail":"\r\n\t\t\r\n\t\t","_children":[{"_id":66,"tag":"Capability","attrib":{"Name":"ID_CAP_IDENTITY_USER"},"text":"","tail":"\r\n\t\t\t","_children":[]},{"_id":67,"tag":"Capability","attrib":{"Name":"ID_CAP_NETWORKING"},"text":"","tail":"\r\n\t\t\t","_children":[]},{"_id":68,"tag":"Capability","attrib":{"Name":"ID_CAP_WEBBROWSERCOMPONENT"},"text":"","tail":"\r\n\t\t\t","_children":[]},{"_id":69,"tag":"Capability","attrib":{"Name":"ID_CAP_PHONEDIALER"},"text":"","tail":"\r\n\t\t\t","_children":[]},{"_id":70,"tag":"Capability","attrib":{"Name":"ID_CAP_MEDIALIB_PHOTO"},"text":"","tail":"\r\n        ","_children":[]}]},{"_id":71,"tag":"framework","attrib":{"src":"src/wp8/GoogleAds.dll","custom":"true"},"text":"","tail":"\r\n    ","_children":[]}]}]}},"id":"cordova-plugin-ad-admobsdk","version":"1.0.23","name":"Cordova Admob SDK","description":"Cordova Admob SDK","license":"MIT","repo":"https://github.com/cranberrygame/cordova-plugin-ad-admob","issue":"https://github.com/cranberrygame/cordova-plugin-ad-admob/issues","keywords":["cordova","plugin","ad","admobsdk","monetisation"]},".../LastoftesurvivorsV4/plugins/cordova-plugin-ad-admobsdk":{"filepath":".../LastoftesurvivorsV4/plugins/cordova-plugin-ad-admobsdk/plugin.xml","dir":".../LastoftesurvivorsV4/plugins/cordova-plugin-ad-admobsdk","_et":{"_root":{"_id":72,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:android":"http://schemas.android.com/apk/res/android","id":"cordova-plugin-ad-admobsdk","version":"1.0.23"},"text":"\r\n\t\r\n    ","tail":null,"_children":[{"_id":73,"tag":"name","attrib":{},"text":"Cordova Admob SDK","tail":"\r\n    ","_children":[]},{"_id":74,"tag":"description","attrib":{},"text":"Cordova Admob SDK","tail":"\r\n    ","_children":[]},{"_id":75,"tag":"author","attrib":{},"text":"Sang Ki Kwon (Cranberrygame)","tail":"\t\t\r\n    ","_children":[]},{"_id":76,"tag":"license","attrib":{},"text":"MIT","tail":"\r\n    ","_children":[]},{"_id":77,"tag":"keywords","attrib":{},"text":"cordova,plugin,ad,admobsdk,monetisation","tail":"\r\n    ","_children":[]},{"_id":78,"tag":"repo","attrib":{},"text":"https://github.com/cranberrygame/cordova-plugin-ad-admob","tail":"\r\n    ","_children":[]},{"_id":79,"tag":"issue","attrib":{},"text":"https://github.com/cranberrygame/cordova-plugin-ad-admob/issues","tail":" \t\r\n\t","_children":[]},{"_id":80,"tag":"engines","attrib":{},"text":"\r\n\t    ","tail":"\r\n\t\t\r\n    \r\n    ","_children":[{"_id":81,"tag":"engine","attrib":{"name":"cordova","version":">=3.0.0"},"text":"","tail":"\r\n\t","_children":[]}]},{"_id":82,"tag":"platform","attrib":{"name":"android"},"text":"\t\t\r\n        ","tail":"\r\n\r\n\t\r\n\t","_children":[{"_id":83,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/manifest/application"},"text":"\r\n\t\t\t","tail":"\r\n\t\t\r\n        ","_children":[{"_id":84,"tag":"activity","attrib":{"android:configChanges":"keyboard|keyboardHidden|orientation|screenLayout|uiMode|screenSize|smallestScreenSize","android:name":"com.google.android.gms.ads.AdActivity"},"text":"","tail":"\r\n        ","_children":[]}]},{"_id":85,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/*"},"text":"\r\n\t\t\t","tail":"\t\t\r\n\t\t\r\n\t\t\r\n\t\t\r\n\t\t\r\n\t\t\r\n\t\t\r\n\t\t\r\n\t\t\r\n\t\t\r\n\t\t\r\n\t\t","_children":[{"_id":86,"tag":"uses-permission","attrib":{"android:name":"android.permission.INTERNET"},"text":"","tail":"\r\n\t\t\t","_children":[]},{"_id":87,"tag":"uses-permission","attrib":{"android:name":"android.permission.ACCESS_NETWORK_STATE"},"text":"","tail":"\r\n        ","_children":[]}]},{"_id":88,"tag":"dependency","attrib":{"id":"com.google.playservices@21.0.0"},"text":"","tail":"\r\n    ","_children":[]}]},{"_id":89,"tag":"platform","attrib":{"name":"ios"},"text":"\r\n\t\t","tail":"\r\n\t\r\n    \r\n    ","_children":[{"_id":90,"tag":"framework","attrib":{"src":"src/ios/GoogleMobileAds.framework","custom":"true"},"text":"","tail":"\t\t\r\n \t    ","_children":[]},{"_id":91,"tag":"framework","attrib":{"src":"StoreKit.framework"},"text":"","tail":"\r\n \t    ","_children":[]},{"_id":92,"tag":"framework","attrib":{"src":"AudioToolbox.framework"},"text":"","tail":"\r\n        ","_children":[]},{"_id":93,"tag":"framework","attrib":{"src":"MessageUI.framework"},"text":"","tail":"\r\n        ","_children":[]},{"_id":94,"tag":"framework","attrib":{"src":"SystemConfiguration.framework"},"text":"","tail":"\r\n        ","_children":[]},{"_id":95,"tag":"framework","attrib":{"src":"CoreGraphics.framework"},"text":"","tail":"\r\n        ","_children":[]},{"_id":96,"tag":"framework","attrib":{"src":"AdSupport.framework"},"text":"","tail":"\r\n        ","_children":[]},{"_id":97,"tag":"framework","attrib":{"src":"CoreTelephony.framework"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":98,"tag":"framework","attrib":{"src":"EventKit.framework"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":99,"tag":"framework","attrib":{"src":"EventKitUI.framework"},"text":"","tail":"\t\t\r\n\t\t","_children":[]},{"_id":100,"tag":"framework","attrib":{"src":"QuartzCore.framework"},"text":"","tail":"\t\t\r\n\t","_children":[]}]},{"_id":101,"tag":"platform","attrib":{"name":"wp8"},"text":"\r\n\t\t","tail":"\r\n","_children":[{"_id":102,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\r\n\t\t\t","tail":"\r\n\t\t\r\n\t\t","_children":[{"_id":103,"tag":"Capability","attrib":{"Name":"ID_CAP_IDENTITY_USER"},"text":"","tail":"\r\n\t\t\t","_children":[]},{"_id":104,"tag":"Capability","attrib":{"Name":"ID_CAP_NETWORKING"},"text":"","tail":"\r\n\t\t\t","_children":[]},{"_id":105,"tag":"Capability","attrib":{"Name":"ID_CAP_WEBBROWSERCOMPONENT"},"text":"","tail":"\r\n\t\t\t","_children":[]},{"_id":106,"tag":"Capability","attrib":{"Name":"ID_CAP_PHONEDIALER"},"text":"","tail":"\r\n\t\t\t","_children":[]},{"_id":107,"tag":"Capability","attrib":{"Name":"ID_CAP_MEDIALIB_PHOTO"},"text":"","tail":"\r\n        ","_children":[]}]},{"_id":108,"tag":"framework","attrib":{"src":"src/wp8/GoogleAds.dll","custom":"true"},"text":"","tail":"\r\n    ","_children":[]}]}]}},"id":"cordova-plugin-ad-admobsdk","version":"1.0.23","name":"Cordova Admob SDK","description":"Cordova Admob SDK","license":"MIT","repo":"https://github.com/cranberrygame/cordova-plugin-ad-admob","issue":"https://github.com/cranberrygame/cordova-plugin-ad-admob/issues","keywords":["cordova","plugin","ad","admobsdk","monetisation"]}},"_getAllCache":{}},"nohooks":["."]}"
Installing "cordova-plugin-ad-admobsdk" for android
Dependencies detected, iterating through them...
Dependent plugin "com.google.playservices@21.0.0" not fetched, retrieving then installing.
WARNING: com.google.playservices has been renamed to cordova-plugin-googleplayservices. You may not be getting the latest version! We suggest you `cordova plugin rm com.google.playservices` and `cordova plugin add cordova-plugin-googleplayservices`.
Fetching plugin "com.google.playservices@21.0.0" via cordova plugins registry
Copying plugin "/home/builduser/.plugman/cache/com.google.playservices/21.0.0/package" => ".../LastoftesurvivorsV4/plugins/com.google.playservices"
Dependent plugin "com.google.playservices" already installed on android.
Install start for "cordova-plugin-ad-admobsdk" on android.
  'com.google.playservices',
  'cordova-plugin-ad-admobsdk' ]
Install complete for cordova-plugin-ad-admobsdk on android.
Calling plugman.fetch on plugin ".../cachedPlugins.3S97UO.tmp/cache.9MvRgI.pl/cordova-plugin-ad-admob"
Copying plugin ".../cachedPlugins.3S97UO.tmp/cache.9MvRgI.pl/cordova-plugin-ad-admob" => ".../LastoftesurvivorsV4/plugins/cordova-plugin-ad-admob"
Calling plugman.install on plugin ".../LastoftesurvivorsV4/plugins/cordova-plugin-ad-admob" for platform "android" with options "{"cli_variables":{},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.3S97UO.tmp/cache.9MvRgI.pl/cordova-plugin-ad-admob":{"filepath":".../cachedPlugins.3S97UO.tmp/cache.9MvRgI.pl/cordova-plugin-ad-admob/plugin.xml","dir":".../cachedPlugins.3S97UO.tmp/cache.9MvRgI.pl/cordova-plugin-ad-admob","_et":{"_root":{"_id":35,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:android":"http://schemas.android.com/apk/res/android","id":"cordova-plugin-ad-admob","version":"1.0.101"},"text":"\r\n\t\r\n    ","tail":null,"_children":[{"_id":36,"tag":"name","attrib":{},"text":"Cordova Admob plugin","tail":"\r\n    ","_children":[]},{"_id":37,"tag":"description","attrib":{},"text":"Show admob banner and interstitial ad","tail":"\r\n    ","_children":[]},{"_id":38,"tag":"author","attrib":{},"text":"Sang Ki Kwon (Cranberrygame)","tail":"\t\t\r\n    ","_children":[]},{"_id":39,"tag":"license","attrib":{},"text":"MIT","tail":"\r\n    ","_children":[]},{"_id":40,"tag":"keywords","attrib":{},"text":"cordova,plugin,ad,admob,monetisation","tail":"\r\n    ","_children":[]},{"_id":41,"tag":"repo","attrib":{},"text":"https://github.com/cranberrygame/cordova-plugin-ad-admob","tail":"\r\n    ","_children":[]},{"_id":42,"tag":"issue","attrib":{},"text":"https://github.com/cranberrygame/cordova-plugin-ad-admob/issues","tail":" \t\r\n\t","_children":[]},{"_id":43,"tag":"engines","attrib":{},"text":"\r\n\t    ","tail":"\r\n\t\r\n    ","_children":[{"_id":44,"tag":"engine","attrib":{"name":"cordova","version":">=3.0.0"},"text":"","tail":"\r\n\t","_children":[]}]},{"_id":45,"tag":"js-module","attrib":{"src":"www/admob.js"},"text":"\r\n        ","tail":"\r\n\t\r\n    \r\n    ","_children":[{"_id":46,"tag":"clobbers","attrib":{"target":"window.admob"},"text":"","tail":"\r\n    ","_children":[]}]},{"_id":47,"tag":"platform","attrib":{"name":"android"},"text":"\r\n\t    ","tail":"\r\n\r\n\t\r\n\t","_children":[{"_id":48,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\r\n            ","tail":"\r\n\t\t\r\n        ","_children":[{"_id":49,"tag":"feature","attrib":{"name":"Admob"},"text":"\r\n                ","tail":"\r\n        ","_children":[{"_id":50,"tag":"param","attrib":{"name":"android-package","value":"com.cranberrygame.cordova.plugin.ad.admob.Admob"},"text":"","tail":"\r\n            ","_children":[]}]}]},{"_id":51,"tag":"source-file","attrib":{"src":"src/android/Admob.java","target-dir":"src/com/cranberrygame/cordova/plugin/ad/admob"},"text":"","tail":"\t\t\r\n        ","_children":[]},{"_id":52,"tag":"source-file","attrib":{"src":"src/android/AdmobOverlap.java","target-dir":"src/com/cranberrygame/cordova/plugin/ad/admob"},"text":"","tail":"\t\t\r\n        ","_children":[]},{"_id":53,"tag":"source-file","attrib":{"src":"src/android/AdmobSplit.java","target-dir":"src/com/cranberrygame/cordova/plugin/ad/admob"},"text":"","tail":"\r\n\t\t\r\n\t\t\r\n\t\t","_children":[]},{"_id":54,"tag":"dependency","attrib":{"id":"cordova-plugin-ad-admobsdk","url":"https://github.com/cranberrygame/cordova-plugin-ad-admobsdk"},"text":"","tail":"\r\n    ","_children":[]}]},{"_id":55,"tag":"platform","attrib":{"name":"ios"},"text":"\r\n\t\t","tail":"\r\n\t\r\n    \r\n    ","_children":[{"_id":56,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\r\n\t\t\t","tail":"\r\n\t\t\r\n\t\t","_children":[{"_id":57,"tag":"feature","attrib":{"name":"Admob"},"text":"\r\n\t\t\t\t","tail":"\r\n\t\t","_children":[{"_id":58,"tag":"param","attrib":{"name":"ios-package","value":"Admob"},"text":"","tail":"\r\n\t\t\t\t","_children":[]},{"_id":59,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\r\n\t\t\t","_children":[]}]}]},{"_id":60,"tag":"header-file","attrib":{"src":"src/ios/Admob.h"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":61,"tag":"source-file","attrib":{"src":"src/ios/Admob.m"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":62,"tag":"header-file","attrib":{"src":"src/ios/AdmobOverlap.h"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":63,"tag":"source-file","attrib":{"src":"src/ios/AdmobOverlap.m"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":64,"tag":"header-file","attrib":{"src":"src/ios/AdmobSplit.h"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":65,"tag":"source-file","attrib":{"src":"src/ios/AdmobSplit.m"},"text":"","tail":"\r\n\r\n\t\t\r\n\t\t","_children":[]},{"_id":66,"tag":"dependency","attrib":{"id":"cordova-plugin-ad-admobsdk","url":"https://github.com/cranberrygame/cordova-plugin-ad-admobsdk"},"text":"","tail":"\r\n\t","_children":[]}]},{"_id":67,"tag":"platform","attrib":{"name":"wp8"},"text":"\t\t\r\n        ","tail":"\r\n\t\r\n\t \r\n\t\t\r\n\r\n\t\t\r\n\t\t\r\n\t\r\n","_children":[{"_id":68,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\r\n            ","tail":"\r\n\r\n        ","_children":[{"_id":69,"tag":"feature","attrib":{"name":"Admob"},"text":"\r\n                ","tail":"\r\n        ","_children":[{"_id":70,"tag":"param","attrib":{"name":"wp-package","value":"Admob"},"text":"","tail":"\r\n            ","_children":[]}]}]},{"_id":71,"tag":"source-file","attrib":{"src":"src/wp8/Admob.cs"},"text":"","tail":"\r\n        ","_children":[]},{"_id":72,"tag":"source-file","attrib":{"src":"src/wp8/AdmobOverlap.cs"},"text":"","tail":"\r\n        ","_children":[]},{"_id":73,"tag":"source-file","attrib":{"src":"src/wp8/AdmobSplit.cs"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":74,"tag":"framework","attrib":{"src":"src/wp8/Silverlight.Md5.dll","custom":"true"},"text":"","tail":"\t\t\r\n\t\t\r\n\t\t\r\n\t\t","_children":[]},{"_id":75,"tag":"dependency","attrib":{"id":"cordova-plugin-ad-admobsdk","url":"https://github.com/cranberrygame/cordova-plugin-ad-admobsdk"},"text":"","tail":"\r\n    ","_children":[]}]}]}},"id":"cordova-plugin-ad-admob","version":"1.0.101","name":"Cordova Admob plugin","description":"Show admob banner and interstitial ad","license":"MIT","repo":"https://github.com/cranberrygame/cordova-plugin-ad-admob","issue":"https://github.com/cranberrygame/cordova-plugin-ad-admob/issues","keywords":["cordova","plugin","ad","admob","monetisation"]},".../LastoftesurvivorsV4/plugins/cordova-plugin-ad-admob":{"filepath":".../LastoftesurvivorsV4/plugins/cordova-plugin-ad-admob/plugin.xml","dir":".../LastoftesurvivorsV4/plugins/cordova-plugin-ad-admob","_et":{"_root":{"_id":76,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:android":"http://schemas.android.com/apk/res/android","id":"cordova-plugin-ad-admob","version":"1.0.101"},"text":"\r\n\t\r\n    ","tail":null,"_children":[{"_id":77,"tag":"name","attrib":{},"text":"Cordova Admob plugin","tail":"\r\n    ","_children":[]},{"_id":78,"tag":"description","attrib":{},"text":"Show admob banner and interstitial ad","tail":"\r\n    ","_children":[]},{"_id":79,"tag":"author","attrib":{},"text":"Sang Ki Kwon (Cranberrygame)","tail":"\t\t\r\n    ","_children":[]},{"_id":80,"tag":"license","attrib":{},"text":"MIT","tail":"\r\n    ","_children":[]},{"_id":81,"tag":"keywords","attrib":{},"text":"cordova,plugin,ad,admob,monetisation","tail":"\r\n    ","_children":[]},{"_id":82,"tag":"repo","attrib":{},"text":"https://github.com/cranberrygame/cordova-plugin-ad-admob","tail":"\r\n    ","_children":[]},{"_id":83,"tag":"issue","attrib":{},"text":"https://github.com/cranberrygame/cordova-plugin-ad-admob/issues","tail":" \t\r\n\t","_children":[]},{"_id":84,"tag":"engines","attrib":{},"text":"\r\n\t    ","tail":"\r\n\t\r\n    ","_children":[{"_id":85,"tag":"engine","attrib":{"name":"cordova","version":">=3.0.0"},"text":"","tail":"\r\n\t","_children":[]}]},{"_id":86,"tag":"js-module","attrib":{"src":"www/admob.js"},"text":"\r\n        ","tail":"\r\n\t\r\n    \r\n    ","_children":[{"_id":87,"tag":"clobbers","attrib":{"target":"window.admob"},"text":"","tail":"\r\n    ","_children":[]}]},{"_id":88,"tag":"platform","attrib":{"name":"android"},"text":"\r\n\t    ","tail":"\r\n\r\n\t\r\n\t","_children":[{"_id":89,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\r\n            ","tail":"\r\n\t\t\r\n        ","_children":[{"_id":90,"tag":"feature","attrib":{"name":"Admob"},"text":"\r\n                ","tail":"\r\n        ","_children":[{"_id":91,"tag":"param","attrib":{"name":"android-package","value":"com.cranberrygame.cordova.plugin.ad.admob.Admob"},"text":"","tail":"\r\n            ","_children":[]}]}]},{"_id":92,"tag":"source-file","attrib":{"src":"src/android/Admob.java","target-dir":"src/com/cranberrygame/cordova/plugin/ad/admob"},"text":"","tail":"\t\t\r\n        ","_children":[]},{"_id":93,"tag":"source-file","attrib":{"src":"src/android/AdmobOverlap.java","target-dir":"src/com/cranberrygame/cordova/plugin/ad/admob"},"text":"","tail":"\t\t\r\n        ","_children":[]},{"_id":94,"tag":"source-file","attrib":{"src":"src/android/AdmobSplit.java","target-dir":"src/com/cranberrygame/cordova/plugin/ad/admob"},"text":"","tail":"\r\n\t\t\r\n\t\t\r\n\t\t","_children":[]},{"_id":95,"tag":"dependency","attrib":{"id":"cordova-plugin-ad-admobsdk","url":"https://github.com/cranberrygame/cordova-plugin-ad-admobsdk"},"text":"","tail":"\r\n    ","_children":[]}]},{"_id":96,"tag":"platform","attrib":{"name":"ios"},"text":"\r\n\t\t","tail":"\r\n\t\r\n    \r\n    ","_children":[{"_id":97,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\r\n\t\t\t","tail":"\r\n\t\t\r\n\t\t","_children":[{"_id":98,"tag":"feature","attrib":{"name":"Admob"},"text":"\r\n\t\t\t\t","tail":"\r\n\t\t","_children":[{"_id":99,"tag":"param","attrib":{"name":"ios-package","value":"Admob"},"text":"","tail":"\r\n\t\t\t\t","_children":[]},{"_id":100,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\r\n\t\t\t","_children":[]}]}]},{"_id":101,"tag":"header-file","attrib":{"src":"src/ios/Admob.h"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":102,"tag":"source-file","attrib":{"src":"src/ios/Admob.m"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":103,"tag":"header-file","attrib":{"src":"src/ios/AdmobOverlap.h"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":104,"tag":"source-file","attrib":{"src":"src/ios/AdmobOverlap.m"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":105,"tag":"header-file","attrib":{"src":"src/ios/AdmobSplit.h"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":106,"tag":"source-file","attrib":{"src":"src/ios/AdmobSplit.m"},"text":"","tail":"\r\n\r\n\t\t\r\n\t\t","_children":[]},{"_id":107,"tag":"dependency","attrib":{"id":"cordova-plugin-ad-admobsdk","url":"https://github.com/cranberrygame/cordova-plugin-ad-admobsdk"},"text":"","tail":"\r\n\t","_children":[]}]},{"_id":108,"tag":"platform","attrib":{"name":"wp8"},"text":"\t\t\r\n        ","tail":"\r\n\t\r\n\t \r\n\t\t\r\n\r\n\t\t\r\n\t\t\r\n\t\r\n","_children":[{"_id":109,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\r\n            ","tail":"\r\n\r\n        ","_children":[{"_id":110,"tag":"feature","attrib":{"name":"Admob"},"text":"\r\n                ","tail":"\r\n        ","_children":[{"_id":111,"tag":"param","attrib":{"name":"wp-package","value":"Admob"},"text":"","tail":"\r\n            ","_children":[]}]}]},{"_id":112,"tag":"source-file","attrib":{"src":"src/wp8/Admob.cs"},"text":"","tail":"\r\n        ","_children":[]},{"_id":113,"tag":"source-file","attrib":{"src":"src/wp8/AdmobOverlap.cs"},"text":"","tail":"\r\n        ","_children":[]},{"_id":114,"tag":"source-file","attrib":{"src":"src/wp8/AdmobSplit.cs"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":115,"tag":"framework","attrib":{"src":"src/wp8/Silverlight.Md5.dll","custom":"true"},"text":"","tail":"\t\t\r\n\t\t\r\n\t\t\r\n\t\t","_children":[]},{"_id":116,"tag":"dependency","attrib":{"id":"cordova-plugin-ad-admobsdk","url":"https://github.com/cranberrygame/cordova-plugin-ad-admobsdk"},"text":"","tail":"\r\n    ","_children":[]}]}]}},"id":"cordova-plugin-ad-admob","version":"1.0.101","name":"Cordova Admob plugin","description":"Show admob banner and interstitial ad","license":"MIT","repo":"https://github.com/cranberrygame/cordova-plugin-ad-admob","issue":"https://github.com/cranberrygame/cordova-plugin-ad-admob/issues","keywords":["cordova","plugin","ad","admob","monetisation"]}},"_getAllCache":{}},"nohooks":["."]}"
Installing "cordova-plugin-ad-admob" for android
Running command: .../LastoftesurvivorsV4/platforms/android/cordova/version
Command finished with error code 0: .../LastoftesurvivorsV4/platforms/android/cordova/version
Dependent plugin "cordova-plugin-ad-admobsdk" already fetched, using that version.
Dependent plugin "cordova-plugin-ad-admobsdk" already installed on android.
Install start for "cordova-plugin-ad-admob" on android.
Beginning processing of action stack for android project...
Parsing android project files...
Action stack processing complete.
Writing out android project files...
Preparing android project
Processing configuration changes for plugins.
  'cordova-plugin-ad-admobsdk',
  'cordova-plugin-ad-admob' ]
Writing out cordova_plugins.js...
Install complete for cordova-plugin-ad-admob on android.
Calling plugman.fetch on plugin ".../cachedPlugins.3S97UO.tmp/cache.udqM3M.pl/cordova-plugin-payment-iap"
Copying plugin ".../cachedPlugins.3S97UO.tmp/cache.udqM3M.pl/cordova-plugin-payment-iap" => ".../LastoftesurvivorsV4/plugins/cordova-plugin-payment-iap"
Calling plugman.install on plugin ".../LastoftesurvivorsV4/plugins/cordova-plugin-payment-iap" for platform "android" with options "{"cli_variables":{},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.3S97UO.tmp/cache.udqM3M.pl/cordova-plugin-payment-iap":{"filepath":".../cachedPlugins.3S97UO.tmp/cache.udqM3M.pl/cordova-plugin-payment-iap/plugin.xml","dir":".../cachedPlugins.3S97UO.tmp/cache.udqM3M.pl/cordova-plugin-payment-iap","_et":{"_root":{"_id":35,"tag":"plugin","attrib":{"xmlns":"http://www.phonegap.com/ns/plugins/1.0","xmlns:android":"http://schemas.android.com/apk/res/android","id":"cordova-plugin-payment-iap","version":"2.0.39"},"text":"\r\n\r\n\t","tail":null,"_children":[{"_id":36,"tag":"name","attrib":{},"text":"Cordova IAP plugin","tail":"\r\n    ","_children":[]},{"_id":37,"tag":"description","attrib":{},"text":"Cordova IAP plugin","tail":"\r\n    ","_children":[]},{"_id":38,"tag":"author","attrib":{},"text":"Sang Ki Kwon (Cranberrygame)","tail":"\t\t\r\n    ","_children":[]},{"_id":39,"tag":"license","attrib":{},"text":"MIT","tail":"\r\n    ","_children":[]},{"_id":40,"tag":"keywords","attrib":{},"text":"cordova,plugin,payment,IAP","tail":"\r\n    ","_children":[]},{"_id":41,"tag":"repo","attrib":{},"text":"https://github.com/cranberrygame/cordova-plugin-payment-iap","tail":"\r\n    ","_children":[]},{"_id":42,"tag":"issue","attrib":{},"text":"https://github.com/cranberrygame/cordova-plugin-payment-iap/issues","tail":"\r\n\t","_children":[]},{"_id":43,"tag":"engines","attrib":{},"text":"\r\n\t    ","tail":"\r\n\t\r\n    ","_children":[{"_id":44,"tag":"engine","attrib":{"name":"cordova","version":">=3.0.0"},"text":"","tail":"\r\n\t","_children":[]}]},{"_id":45,"tag":"js-module","attrib":{"src":"www/iap.js"},"text":"\r\n        ","tail":"\r\n    \r\n    \r\n    ","_children":[{"_id":46,"tag":"clobbers","attrib":{"target":"window.iap"},"text":"","tail":"\r\n    ","_children":[]}]},{"_id":47,"tag":"platform","attrib":{"name":"android"},"text":"    \r\n\t\t","tail":"\r\n\t\r\n    \r\n    ","_children":[{"_id":48,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\r\n\t\t\t","tail":"\r\n\t    \r\n\t\t","_children":[{"_id":49,"tag":"feature","attrib":{"name":"IAP"},"text":"\r\n\t\t\t\t","tail":"\r\n\t    ","_children":[{"_id":50,"tag":"param","attrib":{"name":"android-package","value":"jp.wizcorp.phonegap.plugin.wizPurchase.IAP"},"text":"","tail":"\r\n\t\t\t","_children":[]}]}]},{"_id":51,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/manifest"},"text":"\r\n\t\t\t","tail":"\t\t\r\n\t\t\r\n\t    ","_children":[{"_id":52,"tag":"uses-permission","attrib":{"android:name":"com.android.vending.BILLING"},"text":"","tail":"\r\n        ","_children":[]}]},{"_id":53,"tag":"source-file","attrib":{"src":"src/android/IAP.java","target-dir":"src/jp/wizcorp/phonegap/plugin/wizPurchase"},"text":"","tail":"\r\n\t            \r\n\t    ","_children":[]},{"_id":54,"tag":"source-file","attrib":{"src":"src/android/Base64.java","target-dir":"src/com/smartmobilesoftware/util"},"text":"","tail":"\r\n\t    ","_children":[]},{"_id":55,"tag":"source-file","attrib":{"src":"src/android/Base64DecoderException.java","target-dir":"src/com/smartmobilesoftware/util"},"text":"","tail":"\r\n\t    ","_children":[]},{"_id":56,"tag":"source-file","attrib":{"src":"src/android/IabException.java","target-dir":"src/com/smartmobilesoftware/util"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":57,"tag":"source-file","attrib":{"src":"src/android/IabHelper.java","target-dir":"src/com/smartmobilesoftware/util"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":58,"tag":"source-file","attrib":{"src":"src/android/IabResult.java","target-dir":"src/com/smartmobilesoftware/util"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":59,"tag":"source-file","attrib":{"src":"src/android/Inventory.java","target-dir":"src/com/smartmobilesoftware/util"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":60,"tag":"source-file","attrib":{"src":"src/android/Purchase.java","target-dir":"src/com/smartmobilesoftware/util"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":61,"tag":"source-file","attrib":{"src":"src/android/Security.java","target-dir":"src/com/smartmobilesoftware/util"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":62,"tag":"source-file","attrib":{"src":"src/android/SkuDetails.java","target-dir":"src/com/smartmobilesoftware/util"},"text":"","tail":"              \r\n\t    ","_children":[]},{"_id":63,"tag":"source-file","attrib":{"src":"src/android/IInAppBillingService.aidl","target-dir":"src/com/android/vending/billing"},"text":"","tail":"\r\n    ","_children":[]}]},{"_id":64,"tag":"platform","attrib":{"name":"ios"},"text":"\r\n        ","tail":"\r\n\t\r\n\t\r\n\t","_children":[{"_id":65,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\r\n\t\t    ","tail":"\r\n               \r\n        ","_children":[{"_id":66,"tag":"feature","attrib":{"name":"IAP"},"text":"\r\n\t\t        ","tail":"\r\n        ","_children":[{"_id":67,"tag":"param","attrib":{"name":"ios-package","value":"IAP"},"text":"","tail":"\r\n\t\t        ","_children":[]},{"_id":68,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\r\n\t\t    ","_children":[]}]}]},{"_id":69,"tag":"header-file","attrib":{"src":"src/ios/IAP.h"},"text":"","tail":"\r\n        ","_children":[]},{"_id":70,"tag":"source-file","attrib":{"src":"src/ios/IAP.m"},"text":"","tail":"        \r\n\r\n        ","_children":[]},{"_id":71,"tag":"header-file","attrib":{"src":"src/ios/IAPDebugLog.h"},"text":"","tail":"\r\n        \r\n        ","_children":[]},{"_id":72,"tag":"framework","attrib":{"src":"StoreKit.framework"},"text":"","tail":"                \t\r\n    ","_children":[]}]},{"_id":73,"tag":"platform","attrib":{"name":"wp8"},"text":"\r\n        ","tail":"\t\r\n","_children":[{"_id":74,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\r\n            ","tail":"\r\n\r\n        ","_children":[{"_id":75,"tag":"feature","attrib":{"name":"IAP"},"text":"\r\n                ","tail":"\r\n        ","_children":[{"_id":76,"tag":"param","attrib":{"name":"wp-package","value":"IAP"},"text":"","tail":"\r\n            ","_children":[]}]}]},{"_id":77,"tag":"source-file","attrib":{"src":"src/wp8/IAP.cs"},"text":"","tail":"\r\n    ","_children":[]}]}]}},"id":"cordova-plugin-payment-iap","version":"2.0.39","name":"Cordova IAP plugin","description":"Cordova IAP plugin","license":"MIT","repo":"https://github.com/cranberrygame/cordova-plugin-payment-iap","issue":"https://github.com/cranberrygame/cordova-plugin-payment-iap/issues","keywords":["cordova","plugin","payment","IAP"]},".../LastoftesurvivorsV4/plugins/cordova-plugin-payment-iap":{"filepath":".../LastoftesurvivorsV4/plugins/cordova-plugin-payment-iap/plugin.xml","dir":".../LastoftesurvivorsV4/plugins/cordova-plugin-payment-iap","_et":{"_root":{"_id":78,"tag":"plugin","attrib":{"xmlns":"http://www.phonegap.com/ns/plugins/1.0","xmlns:android":"http://schemas.android.com/apk/res/android","id":"cordova-plugin-payment-iap","version":"2.0.39"},"text":"\r\n\r\n\t","tail":null,"_children":[{"_id":79,"tag":"name","attrib":{},"text":"Cordova IAP plugin","tail":"\r\n    ","_children":[]},{"_id":80,"tag":"description","attrib":{},"text":"Cordova IAP plugin","tail":"\r\n    ","_children":[]},{"_id":81,"tag":"author","attrib":{},"text":"Sang Ki Kwon (Cranberrygame)","tail":"\t\t\r\n    ","_children":[]},{"_id":82,"tag":"license","attrib":{},"text":"MIT","tail":"\r\n    ","_children":[]},{"_id":83,"tag":"keywords","attrib":{},"text":"cordova,plugin,payment,IAP","tail":"\r\n    ","_children":[]},{"_id":84,"tag":"repo","attrib":{},"text":"https://github.com/cranberrygame/cordova-plugin-payment-iap","tail":"\r\n    ","_children":[]},{"_id":85,"tag":"issue","attrib":{},"text":"https://github.com/cranberrygame/cordova-plugin-payment-iap/issues","tail":"\r\n\t","_children":[]},{"_id":86,"tag":"engines","attrib":{},"text":"\r\n\t    ","tail":"\r\n\t\r\n    ","_children":[{"_id":87,"tag":"engine","attrib":{"name":"cordova","version":">=3.0.0"},"text":"","tail":"\r\n\t","_children":[]}]},{"_id":88,"tag":"js-module","attrib":{"src":"www/iap.js"},"text":"\r\n        ","tail":"\r\n    \r\n    \r\n    ","_children":[{"_id":89,"tag":"clobbers","attrib":{"target":"window.iap"},"text":"","tail":"\r\n    ","_children":[]}]},{"_id":90,"tag":"platform","attrib":{"name":"android"},"text":"    \r\n\t\t","tail":"\r\n\t\r\n    \r\n    ","_children":[{"_id":91,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\r\n\t\t\t","tail":"\r\n\t    \r\n\t\t","_children":[{"_id":92,"tag":"feature","attrib":{"name":"IAP"},"text":"\r\n\t\t\t\t","tail":"\r\n\t    ","_children":[{"_id":93,"tag":"param","attrib":{"name":"android-package","value":"jp.wizcorp.phonegap.plugin.wizPurchase.IAP"},"text":"","tail":"\r\n\t\t\t","_children":[]}]}]},{"_id":94,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/manifest"},"text":"\r\n\t\t\t","tail":"\t\t\r\n\t\t\r\n\t    ","_children":[{"_id":95,"tag":"uses-permission","attrib":{"android:name":"com.android.vending.BILLING"},"text":"","tail":"\r\n        ","_children":[]}]},{"_id":96,"tag":"source-file","attrib":{"src":"src/android/IAP.java","target-dir":"src/jp/wizcorp/phonegap/plugin/wizPurchase"},"text":"","tail":"\r\n\t            \r\n\t    ","_children":[]},{"_id":97,"tag":"source-file","attrib":{"src":"src/android/Base64.java","target-dir":"src/com/smartmobilesoftware/util"},"text":"","tail":"\r\n\t    ","_children":[]},{"_id":98,"tag":"source-file","attrib":{"src":"src/android/Base64DecoderException.java","target-dir":"src/com/smartmobilesoftware/util"},"text":"","tail":"\r\n\t    ","_children":[]},{"_id":99,"tag":"source-file","attrib":{"src":"src/android/IabException.java","target-dir":"src/com/smartmobilesoftware/util"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":100,"tag":"source-file","attrib":{"src":"src/android/IabHelper.java","target-dir":"src/com/smartmobilesoftware/util"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":101,"tag":"source-file","attrib":{"src":"src/android/IabResult.java","target-dir":"src/com/smartmobilesoftware/util"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":102,"tag":"source-file","attrib":{"src":"src/android/Inventory.java","target-dir":"src/com/smartmobilesoftware/util"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":103,"tag":"source-file","attrib":{"src":"src/android/Purchase.java","target-dir":"src/com/smartmobilesoftware/util"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":104,"tag":"source-file","attrib":{"src":"src/android/Security.java","target-dir":"src/com/smartmobilesoftware/util"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":105,"tag":"source-file","attrib":{"src":"src/android/SkuDetails.java","target-dir":"src/com/smartmobilesoftware/util"},"text":"","tail":"              \r\n\t    ","_children":[]},{"_id":106,"tag":"source-file","attrib":{"src":"src/android/IInAppBillingService.aidl","target-dir":"src/com/android/vending/billing"},"text":"","tail":"\r\n    ","_children":[]}]},{"_id":107,"tag":"platform","attrib":{"name":"ios"},"text":"\r\n        ","tail":"\r\n\t\r\n\t\r\n\t","_children":[{"_id":108,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\r\n\t\t    ","tail":"\r\n               \r\n        ","_children":[{"_id":109,"tag":"feature","attrib":{"name":"IAP"},"text":"\r\n\t\t        ","tail":"\r\n        ","_children":[{"_id":110,"tag":"param","attrib":{"name":"ios-package","value":"IAP"},"text":"","tail":"\r\n\t\t        ","_children":[]},{"_id":111,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\r\n\t\t    ","_children":[]}]}]},{"_id":112,"tag":"header-file","attrib":{"src":"src/ios/IAP.h"},"text":"","tail":"\r\n        ","_children":[]},{"_id":113,"tag":"source-file","attrib":{"src":"src/ios/IAP.m"},"text":"","tail":"        \r\n\r\n        ","_children":[]},{"_id":114,"tag":"header-file","attrib":{"src":"src/ios/IAPDebugLog.h"},"text":"","tail":"\r\n        \r\n        ","_children":[]},{"_id":115,"tag":"framework","attrib":{"src":"StoreKit.framework"},"text":"","tail":"                \t\r\n    ","_children":[]}]},{"_id":116,"tag":"platform","attrib":{"name":"wp8"},"text":"\r\n        ","tail":"\t\r\n","_children":[{"_id":117,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\r\n            ","tail":"\r\n\r\n        ","_children":[{"_id":118,"tag":"feature","attrib":{"name":"IAP"},"text":"\r\n                ","tail":"\r\n        ","_children":[{"_id":119,"tag":"param","attrib":{"name":"wp-package","value":"IAP"},"text":"","tail":"\r\n            ","_children":[]}]}]},{"_id":120,"tag":"source-file","attrib":{"src":"src/wp8/IAP.cs"},"text":"","tail":"\r\n    ","_children":[]}]}]}},"id":"cordova-plugin-payment-iap","version":"2.0.39","name":"Cordova IAP plugin","description":"Cordova IAP plugin","license":"MIT","repo":"https://github.com/cranberrygame/cordova-plugin-payment-iap","issue":"https://github.com/cranberrygame/cordova-plugin-payment-iap/issues","keywords":["cordova","plugin","payment","IAP"]}},"_getAllCache":{}},"nohooks":["."]}"
Installing "cordova-plugin-payment-iap" for android
Install start for "cordova-plugin-payment-iap" on android.
Iterating over installed plugins: [ 'cordova-plugin-splashscreen',
  'cordova-plugin-ad-admob',
  'cordova-plugin-payment-iap' ]
Install complete for cordova-plugin-payment-iap on android.
Calling plugman.fetch on plugin ".../cachedPlugins.3S97UO.tmp/cache.Wmwtl1.pl/cordova-plugin-ad-adcolony"
Copying plugin ".../cachedPlugins.3S97UO.tmp/cache.Wmwtl1.pl/cordova-plugin-ad-adcolony" => ".../LastoftesurvivorsV4/plugins/cordova-plugin-ad-adcolony"
Calling plugman.install on plugin ".../LastoftesurvivorsV4/plugins/cordova-plugin-ad-adcolony" for platform "android" with options "{"cli_variables":{},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.3S97UO.tmp/cache.Wmwtl1.pl/cordova-plugin-ad-adcolony":{"filepath":".../cachedPlugins.3S97UO.tmp/cache.Wmwtl1.pl/cordova-plugin-ad-adcolony/plugin.xml","dir":".../cachedPlugins.3S97UO.tmp/cache.Wmwtl1.pl/cordova-plugin-ad-adcolony","_et":{"_root":{"_id":35,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:android":"http://schemas.android.com/apk/res/android","id":"cordova-plugin-ad-adcolony","version":"1.0.40"},"text":"\r\n\t\r\n    ","tail":null,"_children":[{"_id":36,"tag":"name","attrib":{},"text":"Cordova AdColony plugin","tail":"\r\n    ","_children":[]},{"_id":37,"tag":"description","attrib":{},"text":"Show adcolony interstitial ad and rewarded video ad","tail":"\r\n    ","_children":[]},{"_id":38,"tag":"author","attrib":{},"text":"Sang Ki Kwon (Cranberrygame)","tail":"\t\r\n    ","_children":[]},{"_id":39,"tag":"license","attrib":{},"text":"MIT","tail":"\r\n    ","_children":[]},{"_id":40,"tag":"keywords","attrib":{},"text":"cordova,plugin,ad,video,adcolony,monetisation","tail":"\r\n    ","_children":[]},{"_id":41,"tag":"repo","attrib":{},"text":"https://github.com/cranberrygame/cordova-plugin-ad-adcolony","tail":"\r\n    ","_children":[]},{"_id":42,"tag":"issue","attrib":{},"text":"https://github.com/cranberrygame/cordova-plugin-ad-adcolony/issues","tail":"\t\r\n\t","_children":[]},{"_id":43,"tag":"engines","attrib":{},"text":"\r\n\t    ","tail":"\r\n \t\r\n    ","_children":[{"_id":44,"tag":"engine","attrib":{"name":"cordova","version":">=3.0.0"},"text":"","tail":"\r\n\t","_children":[]}]},{"_id":45,"tag":"js-module","attrib":{"src":"www/adcolony.js"},"text":"\r\n        ","tail":"    \r\n    \r\n\t\r\n\t","_children":[{"_id":46,"tag":"clobbers","attrib":{"target":"window.adcolony"},"text":"","tail":"\r\n    ","_children":[]}]},{"_id":47,"tag":"platform","attrib":{"name":"android"},"text":"\r\n\t\t","tail":"\r\n\r\n\t\r\n\t","_children":[{"_id":48,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\r\n\t\t\t","tail":"\r\n\r\n\t\t","_children":[{"_id":49,"tag":"feature","attrib":{"name":"AdColonyPlugin"},"text":"\r\n\t\t\t\t","tail":"\r\n\t\t","_children":[{"_id":50,"tag":"param","attrib":{"name":"android-package","value":"com.cranberrygame.cordova.plugin.ad.adcolony.AdColonyPlugin"},"text":"","tail":"\r\n\t\t\t","_children":[]}]}]},{"_id":51,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/*"},"text":"\r\n\t\t\t","tail":"\r\n\r\n\t\t","_children":[{"_id":52,"tag":"uses-permission","attrib":{"android:name":"android.permission.INTERNET"},"text":"","tail":"\r\n\t\t\t","_children":[]},{"_id":53,"tag":"uses-permission","attrib":{"android:name":"android.permission.ACCESS_NETWORK_STATE"},"text":"","tail":"\r\n\t\t","_children":[]}]},{"_id":54,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/manifest/application"},"text":"\r\n\t\t\t","tail":"\r\n\r\n\t\t","_children":[{"_id":55,"tag":"activity","attrib":{"android:configChanges":"keyboardHidden|orientation|screenSize","android:name":"com.jirbo.adcolony.AdColonyOverlay","android:theme":"@android:style/Theme.Translucent.NoTitleBar.Fullscreen"},"text":"","tail":"\r\n\t\t\t","_children":[]},{"_id":56,"tag":"activity","attrib":{"android:configChanges":"keyboardHidden|orientation|screenSize","android:name":"com.jirbo.adcolony.AdColonyFullscreen","android:theme":"@android:style/Theme.Black.NoTitleBar.Fullscreen"},"text":"","tail":"\r\n\t\t\t","_children":[]},{"_id":57,"tag":"activity","attrib":{"android:configChanges":"keyboardHidden|orientation|screenSize","android:name":"com.jirbo.adcolony.AdColonyBrowser","android:theme":"@android:style/Theme.Black.NoTitleBar.Fullscreen"},"text":"","tail":"\r\n\t\t","_children":[]}]},{"_id":58,"tag":"source-file","attrib":{"src":"src/android/AdColonyPlugin.java","target-dir":"src/com/cranberrygame/cordova/plugin/ad/adcolony"},"text":"","tail":"\r\n\t\t\r\n\t\t","_children":[]},{"_id":59,"tag":"source-file","attrib":{"src":"src/android/adcolony.jar","target-dir":"libs"},"text":"","tail":"\r\n\t","_children":[]}]},{"_id":60,"tag":"platform","attrib":{"name":"ios"},"text":"\r\n\t\t","tail":"\r\n","_children":[{"_id":61,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\r\n\t\t\t","tail":"\r\n\r\n\t\t","_children":[{"_id":62,"tag":"feature","attrib":{"name":"AdColonyPlugin"},"text":"\r\n\t\t\t\t","tail":"\r\n\t\t","_children":[{"_id":63,"tag":"param","attrib":{"name":"ios-package","value":"AdColonyPlugin"},"text":"","tail":"\r\n\t\t\t","_children":[]}]}]},{"_id":64,"tag":"header-file","attrib":{"src":"src/ios/AdColonyPlugin.h"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":65,"tag":"source-file","attrib":{"src":"src/ios/AdColonyPlugin.m"},"text":"","tail":"\r\n\r\n\t\t","_children":[]},{"_id":66,"tag":"framework","attrib":{"src":"src/ios/AdColony.framework","custom":"true"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":67,"tag":"framework","attrib":{"src":"AudioToolbox.framework","weak":"true"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":68,"tag":"framework","attrib":{"src":"AdSupport.framework","weak":"true"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":69,"tag":"framework","attrib":{"src":"AVFoundation.framework"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":70,"tag":"framework","attrib":{"src":"CFNetwork.framework"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":71,"tag":"framework","attrib":{"src":"CoreGraphics.framework"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":72,"tag":"framework","attrib":{"src":"CoreMedia.framework"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":73,"tag":"framework","attrib":{"src":"CoreTelephony.framework"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":74,"tag":"framework","attrib":{"src":"EventKit.framework"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":75,"tag":"framework","attrib":{"src":"EventKitUI.framework"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":76,"tag":"framework","attrib":{"src":"Foundation.framework"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":77,"tag":"framework","attrib":{"src":"libz.1.2.5.dylib"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":78,"tag":"framework","attrib":{"src":"MediaPlayer.framework"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":79,"tag":"framework","attrib":{"src":"MessageUI.framework"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":80,"tag":"framework","attrib":{"src":"QuartzCore.framework"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":81,"tag":"framework","attrib":{"src":"Social.framework","weak":"true"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":82,"tag":"framework","attrib":{"src":"StoreKit.framework"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":83,"tag":"framework","attrib":{"src":"SystemConfiguration.framework"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":84,"tag":"framework","attrib":{"src":"UIKit.framework"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":85,"tag":"framework","attrib":{"src":"WebKit.framework"},"text":"","tail":"\r\n\t","_children":[]}]}]}},"id":"cordova-plugin-ad-adcolony","version":"1.0.40","name":"Cordova AdColony plugin","description":"Show adcolony interstitial ad and rewarded video ad","license":"MIT","repo":"https://github.com/cranberrygame/cordova-plugin-ad-adcolony","issue":"https://github.com/cranberrygame/cordova-plugin-ad-adcolony/issues","keywords":["cordova","plugin","ad","video","adcolony","monetisation"]},".../LastoftesurvivorsV4/plugins/cordova-plugin-ad-adcolony":{"filepath":".../LastoftesurvivorsV4/plugins/cordova-plugin-ad-adcolony/plugin.xml","dir":".../LastoftesurvivorsV4/plugins/cordova-plugin-ad-adcolony","_et":{"_root":{"_id":86,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:android":"http://schemas.android.com/apk/res/android","id":"cordova-plugin-ad-adcolony","version":"1.0.40"},"text":"\r\n\t\r\n    ","tail":null,"_children":[{"_id":87,"tag":"name","attrib":{},"text":"Cordova AdColony plugin","tail":"\r\n    ","_children":[]},{"_id":88,"tag":"description","attrib":{},"text":"Show adcolony interstitial ad and rewarded video ad","tail":"\r\n    ","_children":[]},{"_id":89,"tag":"author","attrib":{},"text":"Sang Ki Kwon (Cranberrygame)","tail":"\t\r\n    ","_children":[]},{"_id":90,"tag":"license","attrib":{},"text":"MIT","tail":"\r\n    ","_children":[]},{"_id":91,"tag":"keywords","attrib":{},"text":"cordova,plugin,ad,video,adcolony,monetisation","tail":"\r\n    ","_children":[]},{"_id":92,"tag":"repo","attrib":{},"text":"https://github.com/cranberrygame/cordova-plugin-ad-adcolony","tail":"\r\n    ","_children":[]},{"_id":93,"tag":"issue","attrib":{},"text":"https://github.com/cranberrygame/cordova-plugin-ad-adcolony/issues","tail":"\t\r\n\t","_children":[]},{"_id":94,"tag":"engines","attrib":{},"text":"\r\n\t    ","tail":"\r\n \t\r\n    ","_children":[{"_id":95,"tag":"engine","attrib":{"name":"cordova","version":">=3.0.0"},"text":"","tail":"\r\n\t","_children":[]}]},{"_id":96,"tag":"js-module","attrib":{"src":"www/adcolony.js"},"text":"\r\n        ","tail":"    \r\n    \r\n\t\r\n\t","_children":[{"_id":97,"tag":"clobbers","attrib":{"target":"window.adcolony"},"text":"","tail":"\r\n    ","_children":[]}]},{"_id":98,"tag":"platform","attrib":{"name":"android"},"text":"\r\n\t\t","tail":"\r\n\r\n\t\r\n\t","_children":[{"_id":99,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\r\n\t\t\t","tail":"\r\n\r\n\t\t","_children":[{"_id":100,"tag":"feature","attrib":{"name":"AdColonyPlugin"},"text":"\r\n\t\t\t\t","tail":"\r\n\t\t","_children":[{"_id":101,"tag":"param","attrib":{"name":"android-package","value":"com.cranberrygame.cordova.plugin.ad.adcolony.AdColonyPlugin"},"text":"","tail":"\r\n\t\t\t","_children":[]}]}]},{"_id":102,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/*"},"text":"\r\n\t\t\t","tail":"\r\n\r\n\t\t","_children":[{"_id":103,"tag":"uses-permission","attrib":{"android:name":"android.permission.INTERNET"},"text":"","tail":"\r\n\t\t\t","_children":[]},{"_id":104,"tag":"uses-permission","attrib":{"android:name":"android.permission.ACCESS_NETWORK_STATE"},"text":"","tail":"\r\n\t\t","_children":[]}]},{"_id":105,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/manifest/application"},"text":"\r\n\t\t\t","tail":"\r\n\r\n\t\t","_children":[{"_id":106,"tag":"activity","attrib":{"android:configChanges":"keyboardHidden|orientation|screenSize","android:name":"com.jirbo.adcolony.AdColonyOverlay","android:theme":"@android:style/Theme.Translucent.NoTitleBar.Fullscreen"},"text":"","tail":"\r\n\t\t\t","_children":[]},{"_id":107,"tag":"activity","attrib":{"android:configChanges":"keyboardHidden|orientation|screenSize","android:name":"com.jirbo.adcolony.AdColonyFullscreen","android:theme":"@android:style/Theme.Black.NoTitleBar.Fullscreen"},"text":"","tail":"\r\n\t\t\t","_children":[]},{"_id":108,"tag":"activity","attrib":{"android:configChanges":"keyboardHidden|orientation|screenSize","android:name":"com.jirbo.adcolony.AdColonyBrowser","android:theme":"@android:style/Theme.Black.NoTitleBar.Fullscreen"},"text":"","tail":"\r\n\t\t","_children":[]}]},{"_id":109,"tag":"source-file","attrib":{"src":"src/android/AdColonyPlugin.java","target-dir":"src/com/cranberrygame/cordova/plugin/ad/adcolony"},"text":"","tail":"\r\n\t\t\r\n\t\t","_children":[]},{"_id":110,"tag":"source-file","attrib":{"src":"src/android/adcolony.jar","target-dir":"libs"},"text":"","tail":"\r\n\t","_children":[]}]},{"_id":111,"tag":"platform","attrib":{"name":"ios"},"text":"\r\n\t\t","tail":"\r\n","_children":[{"_id":112,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\r\n\t\t\t","tail":"\r\n\r\n\t\t","_children":[{"_id":113,"tag":"feature","attrib":{"name":"AdColonyPlugin"},"text":"\r\n\t\t\t\t","tail":"\r\n\t\t","_children":[{"_id":114,"tag":"param","attrib":{"name":"ios-package","value":"AdColonyPlugin"},"text":"","tail":"\r\n\t\t\t","_children":[]}]}]},{"_id":115,"tag":"header-file","attrib":{"src":"src/ios/AdColonyPlugin.h"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":116,"tag":"source-file","attrib":{"src":"src/ios/AdColonyPlugin.m"},"text":"","tail":"\r\n\r\n\t\t","_children":[]},{"_id":117,"tag":"framework","attrib":{"src":"src/ios/AdColony.framework","custom":"true"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":118,"tag":"framework","attrib":{"src":"AudioToolbox.framework","weak":"true"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":119,"tag":"framework","attrib":{"src":"AdSupport.framework","weak":"true"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":120,"tag":"framework","attrib":{"src":"AVFoundation.framework"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":121,"tag":"framework","attrib":{"src":"CFNetwork.framework"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":122,"tag":"framework","attrib":{"src":"CoreGraphics.framework"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":123,"tag":"framework","attrib":{"src":"CoreMedia.framework"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":124,"tag":"framework","attrib":{"src":"CoreTelephony.framework"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":125,"tag":"framework","attrib":{"src":"EventKit.framework"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":126,"tag":"framework","attrib":{"src":"EventKitUI.framework"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":127,"tag":"framework","attrib":{"src":"Foundation.framework"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":128,"tag":"framework","attrib":{"src":"libz.1.2.5.dylib"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":129,"tag":"framework","attrib":{"src":"MediaPlayer.framework"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":130,"tag":"framework","attrib":{"src":"MessageUI.framework"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":131,"tag":"framework","attrib":{"src":"QuartzCore.framework"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":132,"tag":"framework","attrib":{"src":"Social.framework","weak":"true"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":133,"tag":"framework","attrib":{"src":"StoreKit.framework"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":134,"tag":"framework","attrib":{"src":"SystemConfiguration.framework"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":135,"tag":"framework","attrib":{"src":"UIKit.framework"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":136,"tag":"framework","attrib":{"src":"WebKit.framework"},"text":"","tail":"\r\n\t","_children":[]}]}]}},"id":"cordova-plugin-ad-adcolony","version":"1.0.40","name":"Cordova AdColony plugin","description":"Show adcolony interstitial ad and rewarded video ad","license":"MIT","repo":"https://github.com/cranberrygame/cordova-plugin-ad-adcolony","issue":"https://github.com/cranberrygame/cordova-plugin-ad-adcolony/issues","keywords":["cordova","plugin","ad","video","adcolony","monetisation"]}},"_getAllCache":{}},"nohooks":["."]}"
Installing "cordova-plugin-ad-adcolony" for android
Install start for "cordova-plugin-ad-adcolony" on android.
  'cordova-plugin-payment-iap',
  'cordova-plugin-ad-adcolony' ]
Install complete for cordova-plugin-ad-adcolony on android.
Calling plugman.fetch on plugin ".../cachedPlugins.3S97UO.tmp/cache.bHjwJ0.pl/cordova-plugin-ad-chartboost"
Copying plugin ".../cachedPlugins.3S97UO.tmp/cache.bHjwJ0.pl/cordova-plugin-ad-chartboost" => ".../LastoftesurvivorsV4/plugins/cordova-plugin-ad-chartboost"
Calling plugman.install on plugin ".../LastoftesurvivorsV4/plugins/cordova-plugin-ad-chartboost" for platform "android" with options "{"cli_variables":{},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.3S97UO.tmp/cache.bHjwJ0.pl/cordova-plugin-ad-chartboost":{"filepath":".../cachedPlugins.3S97UO.tmp/cache.bHjwJ0.pl/cordova-plugin-ad-chartboost/plugin.xml","dir":".../cachedPlugins.3S97UO.tmp/cache.bHjwJ0.pl/cordova-plugin-ad-chartboost","_et":{"_root":{"_id":35,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:android":"http://schemas.android.com/apk/res/android","id":"cordova-plugin-ad-chartboost","version":"1.0.75"},"text":"\r\n\t\r\n    ","tail":null,"_children":[{"_id":36,"tag":"name","attrib":{},"text":"Cordova Chartboost plugin","tail":"\r\n    ","_children":[]},{"_id":37,"tag":"description","attrib":{},"text":"Show chartboost interstitial (static interstitial, video interstial), more apps, rewarded video ad","tail":"\r\n    ","_children":[]},{"_id":38,"tag":"author","attrib":{},"text":"Sang Ki Kwon (Cranberrygame)","tail":"\t\r\n    ","_children":[]},{"_id":39,"tag":"license","attrib":{},"text":"MIT","tail":"\r\n    ","_children":[]},{"_id":40,"tag":"keywords","attrib":{},"text":"cordova,plugin,ad,chartboost,monetisation,interstitial,video","tail":"\r\n    ","_children":[]},{"_id":41,"tag":"repo","attrib":{},"text":"https://github.com/cranberrygame/cordova-plugin-ad-chartboost","tail":"\r\n    ","_children":[]},{"_id":42,"tag":"issue","attrib":{},"text":"https://github.com/cranberrygame/cordova-plugin-ad-chartboost/issues","tail":"\t\r\n\t","_children":[]},{"_id":43,"tag":"engines","attrib":{},"text":"\r\n\t    ","tail":"\r\n \t\r\n    ","_children":[{"_id":44,"tag":"engine","attrib":{"name":"cordova","version":">=3.0.0"},"text":"","tail":"\r\n\t","_children":[]}]},{"_id":45,"tag":"js-module","attrib":{"src":"www/chartboost.js"},"text":"\r\n        ","tail":"    \r\n    \r\n    \t\r\n    ","_children":[{"_id":46,"tag":"clobbers","attrib":{"target":"window.chartboost"},"text":"","tail":"\r\n    ","_children":[]}]},{"_id":47,"tag":"platform","attrib":{"name":"android"},"text":"\r\n        ","tail":"\r\n\r\n\t\r\n\t","_children":[{"_id":48,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\r\n            ","tail":"\r\n        \r\n        ","_children":[{"_id":49,"tag":"feature","attrib":{"name":"ChartboostPlugin"},"text":"\r\n                ","tail":"\r\n        ","_children":[{"_id":50,"tag":"param","attrib":{"name":"android-package","value":"com.cranberrygame.cordova.plugin.ad.chartboost.ChartboostPlugin"},"text":"","tail":"\r\n            ","_children":[]}]}]},{"_id":51,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/manifest"},"text":"\r\n                ","tail":"\r\n        \r\n        ","_children":[{"_id":52,"tag":"uses-permission","attrib":{"android:name":"android.permission.ACCESS_NETWORK_STATE"},"text":"","tail":"\r\n                ","_children":[]},{"_id":53,"tag":"uses-permission","attrib":{"android:name":"android.permission.INTERNET"},"text":"","tail":"\r\n                ","_children":[]},{"_id":54,"tag":"uses-permission","attrib":{"android:name":"android.permission.WRITE_EXTERNAL_STORAGE"},"text":"","tail":"\r\n        ","_children":[]}]},{"_id":55,"tag":"source-file","attrib":{"src":"src/android/ChartboostPlugin.java","target-dir":"src/com/cranberrygame/cordova/plugin/ad/chartboost"},"text":"","tail":"\r\n\t\t\r\n        ","_children":[]},{"_id":56,"tag":"source-file","attrib":{"src":"src/android/chartboost.jar","target-dir":"libs"},"text":"","tail":"\r\n    ","_children":[]}]},{"_id":57,"tag":"platform","attrib":{"name":"ios"},"text":"\r\n\t\t","tail":"\r\n","_children":[{"_id":58,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\r\n\t\t\t","tail":"\r\n\t\t\r\n\t\t","_children":[{"_id":59,"tag":"feature","attrib":{"name":"ChartboostPlugin"},"text":"\r\n\t\t\t\t","tail":"\r\n\t\t","_children":[{"_id":60,"tag":"param","attrib":{"name":"ios-package","value":"ChartboostPlugin"},"text":"","tail":"\r\n\t\t\t\t","_children":[]},{"_id":61,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\r\n\t\t\t","_children":[]}]}]},{"_id":62,"tag":"header-file","attrib":{"src":"src/ios/ChartboostPlugin.h"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":63,"tag":"source-file","attrib":{"src":"src/ios/ChartboostPlugin.m"},"text":"","tail":"\r\n\t\t\r\n\t\t","_children":[]},{"_id":64,"tag":"framework","attrib":{"src":"src/ios/Chartboost.framework","custom":"true"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":65,"tag":"framework","attrib":{"src":"StoreKit.framework","weak":"true"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":66,"tag":"framework","attrib":{"src":"Foundation.framework"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":67,"tag":"framework","attrib":{"src":"CoreGraphics.framework"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":68,"tag":"framework","attrib":{"src":"UIKit.framework"},"text":"","tail":"\r\n\t","_children":[]}]}]}},"id":"cordova-plugin-ad-chartboost","version":"1.0.75","name":"Cordova Chartboost plugin","description":"Show chartboost interstitial (static interstitial, video interstial), more apps, rewarded video ad","license":"MIT","repo":"https://github.com/cranberrygame/cordova-plugin-ad-chartboost","issue":"https://github.com/cranberrygame/cordova-plugin-ad-chartboost/issues","keywords":["cordova","plugin","ad","chartboost","monetisation","interstitial","video"]},".../LastoftesurvivorsV4/plugins/cordova-plugin-ad-chartboost":{"filepath":".../LastoftesurvivorsV4/plugins/cordova-plugin-ad-chartboost/plugin.xml","dir":".../LastoftesurvivorsV4/plugins/cordova-plugin-ad-chartboost","_et":{"_root":{"_id":69,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:android":"http://schemas.android.com/apk/res/android","id":"cordova-plugin-ad-chartboost","version":"1.0.75"},"text":"\r\n\t\r\n    ","tail":null,"_children":[{"_id":70,"tag":"name","attrib":{},"text":"Cordova Chartboost plugin","tail":"\r\n    ","_children":[]},{"_id":71,"tag":"description","attrib":{},"text":"Show chartboost interstitial (static interstitial, video interstial), more apps, rewarded video ad","tail":"\r\n    ","_children":[]},{"_id":72,"tag":"author","attrib":{},"text":"Sang Ki Kwon (Cranberrygame)","tail":"\t\r\n    ","_children":[]},{"_id":73,"tag":"license","attrib":{},"text":"MIT","tail":"\r\n    ","_children":[]},{"_id":74,"tag":"keywords","attrib":{},"text":"cordova,plugin,ad,chartboost,monetisation,interstitial,video","tail":"\r\n    ","_children":[]},{"_id":75,"tag":"repo","attrib":{},"text":"https://github.com/cranberrygame/cordova-plugin-ad-chartboost","tail":"\r\n    ","_children":[]},{"_id":76,"tag":"issue","attrib":{},"text":"https://github.com/cranberrygame/cordova-plugin-ad-chartboost/issues","tail":"\t\r\n\t","_children":[]},{"_id":77,"tag":"engines","attrib":{},"text":"\r\n\t    ","tail":"\r\n \t\r\n    ","_children":[{"_id":78,"tag":"engine","attrib":{"name":"cordova","version":">=3.0.0"},"text":"","tail":"\r\n\t","_children":[]}]},{"_id":79,"tag":"js-module","attrib":{"src":"www/chartboost.js"},"text":"\r\n        ","tail":"    \r\n    \r\n    \t\r\n    ","_children":[{"_id":80,"tag":"clobbers","attrib":{"target":"window.chartboost"},"text":"","tail":"\r\n    ","_children":[]}]},{"_id":81,"tag":"platform","attrib":{"name":"android"},"text":"\r\n        ","tail":"\r\n\r\n\t\r\n\t","_children":[{"_id":82,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\r\n            ","tail":"\r\n        \r\n        ","_children":[{"_id":83,"tag":"feature","attrib":{"name":"ChartboostPlugin"},"text":"\r\n                ","tail":"\r\n        ","_children":[{"_id":84,"tag":"param","attrib":{"name":"android-package","value":"com.cranberrygame.cordova.plugin.ad.chartboost.ChartboostPlugin"},"text":"","tail":"\r\n            ","_children":[]}]}]},{"_id":85,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/manifest"},"text":"\r\n                ","tail":"\r\n        \r\n        ","_children":[{"_id":86,"tag":"uses-permission","attrib":{"android:name":"android.permission.ACCESS_NETWORK_STATE"},"text":"","tail":"\r\n                ","_children":[]},{"_id":87,"tag":"uses-permission","attrib":{"android:name":"android.permission.INTERNET"},"text":"","tail":"\r\n                ","_children":[]},{"_id":88,"tag":"uses-permission","attrib":{"android:name":"android.permission.WRITE_EXTERNAL_STORAGE"},"text":"","tail":"\r\n        ","_children":[]}]},{"_id":89,"tag":"source-file","attrib":{"src":"src/android/ChartboostPlugin.java","target-dir":"src/com/cranberrygame/cordova/plugin/ad/chartboost"},"text":"","tail":"\r\n\t\t\r\n        ","_children":[]},{"_id":90,"tag":"source-file","attrib":{"src":"src/android/chartboost.jar","target-dir":"libs"},"text":"","tail":"\r\n    ","_children":[]}]},{"_id":91,"tag":"platform","attrib":{"name":"ios"},"text":"\r\n\t\t","tail":"\r\n","_children":[{"_id":92,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\r\n\t\t\t","tail":"\r\n\t\t\r\n\t\t","_children":[{"_id":93,"tag":"feature","attrib":{"name":"ChartboostPlugin"},"text":"\r\n\t\t\t\t","tail":"\r\n\t\t","_children":[{"_id":94,"tag":"param","attrib":{"name":"ios-package","value":"ChartboostPlugin"},"text":"","tail":"\r\n\t\t\t\t","_children":[]},{"_id":95,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\r\n\t\t\t","_children":[]}]}]},{"_id":96,"tag":"header-file","attrib":{"src":"src/ios/ChartboostPlugin.h"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":97,"tag":"source-file","attrib":{"src":"src/ios/ChartboostPlugin.m"},"text":"","tail":"\r\n\t\t\r\n\t\t","_children":[]},{"_id":98,"tag":"framework","attrib":{"src":"src/ios/Chartboost.framework","custom":"true"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":99,"tag":"framework","attrib":{"src":"StoreKit.framework","weak":"true"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":100,"tag":"framework","attrib":{"src":"Foundation.framework"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":101,"tag":"framework","attrib":{"src":"CoreGraphics.framework"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":102,"tag":"framework","attrib":{"src":"UIKit.framework"},"text":"","tail":"\r\n\t","_children":[]}]}]}},"id":"cordova-plugin-ad-chartboost","version":"1.0.75","name":"Cordova Chartboost plugin","description":"Show chartboost interstitial (static interstitial, video interstial), more apps, rewarded video ad","license":"MIT","repo":"https://github.com/cranberrygame/cordova-plugin-ad-chartboost","issue":"https://github.com/cranberrygame/cordova-plugin-ad-chartboost/issues","keywords":["cordova","plugin","ad","chartboost","monetisation","interstitial","video"]}},"_getAllCache":{}},"nohooks":["."]}"
Installing "cordova-plugin-ad-chartboost" for android
Install start for "cordova-plugin-ad-chartboost" on android.
  'cordova-plugin-device',
  'cordova-plugin-device-motion',
  'cordova-plugin-ad-adcolony',
  'cordova-plugin-ad-chartboost' ]
Install complete for cordova-plugin-ad-chartboost on android.
Calling plugman.fetch on plugin ".../cachedPlugins.3S97UO.tmp/cache.zSLo4k.pl/cordova-plugin-google-analytics"
Copying plugin ".../cachedPlugins.3S97UO.tmp/cache.zSLo4k.pl/cordova-plugin-google-analytics" => ".../LastoftesurvivorsV4/plugins/cordova-plugin-google-analytics"
Calling plugman.install on plugin ".../LastoftesurvivorsV4/plugins/cordova-plugin-google-analytics" for platform "android" with options "{"cli_variables":{},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.3S97UO.tmp/cache.zSLo4k.pl/cordova-plugin-google-analytics":{"filepath":".../cachedPlugins.3S97UO.tmp/cache.zSLo4k.pl/cordova-plugin-google-analytics/plugin.xml","dir":".../cachedPlugins.3S97UO.tmp/cache.zSLo4k.pl/cordova-plugin-google-analytics","_et":{"_root":{"_id":35,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:android":"http://schemas.android.com/apk/res/android","id":"cordova-plugin-google-analytics","version":"0.8.0"},"text":"\n  ","tail":null,"_children":[{"_id":36,"tag":"engines","attrib":{},"text":"\n    ","tail":"\n  ","_children":[{"_id":37,"tag":"engine","attrib":{"name":"cordova","version":">=3.0.0"},"text":"","tail":"\n  ","_children":[]}]},{"_id":38,"tag":"name","attrib":{},"text":"Google Universal Analytics Plugin","tail":"\n  ","_children":[]},{"_id":39,"tag":"description","attrib":{},"text":"Simple tracking (screens/events) for Google Analytics SDK 3.0 (iOS) and SDK 4.0 (Android)","tail":"\n  ","_children":[]},{"_id":40,"tag":"author","attrib":{},"text":"Daniel C. Wilson","tail":"\n  ","_children":[]},{"_id":41,"tag":"license","attrib":{},"text":"MIT License","tail":"\n  ","_children":[]},{"_id":42,"tag":"js-module","attrib":{"src":"www/analytics.js","name":"UniversalAnalytics"},"text":"\n    ","tail":"\n\n  ","_children":[{"_id":43,"tag":"clobbers","attrib":{"target":"analytics"},"text":"","tail":"\n  ","_children":[]}]},{"_id":44,"tag":"platform","attrib":{"name":"ios"},"text":"\n    ","tail":"\n\n  ","_children":[{"_id":45,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n      ","tail":"\n\n    ","_children":[{"_id":46,"tag":"feature","attrib":{"name":"UniversalAnalytics"},"text":"\n        ","tail":"\n    ","_children":[{"_id":47,"tag":"param","attrib":{"name":"ios-package","value":"UniversalAnalyticsPlugin"},"text":"","tail":"\n      ","_children":[]}]}]},{"_id":48,"tag":"header-file","attrib":{"src":"ios/UniversalAnalyticsPlugin.h"},"text":"","tail":"\n    ","_children":[]},{"_id":49,"tag":"source-file","attrib":{"src":"ios/UniversalAnalyticsPlugin.m"},"text":"","tail":"\n\n    ","_children":[]},{"_id":50,"tag":"source-file","attrib":{"src":"ios/libGoogleAnalyticsServices.a","framework":"true"},"text":"","tail":"\n    ","_children":[]},{"_id":51,"tag":"header-file","attrib":{"src":"ios/GAIDictionaryBuilder.h"},"text":"","tail":"\n    ","_children":[]},{"_id":52,"tag":"header-file","attrib":{"src":"ios/GAIFields.h"},"text":"","tail":"\n    ","_children":[]},{"_id":53,"tag":"header-file","attrib":{"src":"ios/GAILogger.h"},"text":"","tail":"\n    ","_children":[]},{"_id":54,"tag":"header-file","attrib":{"src":"ios/GAITrackedViewController.h"},"text":"","tail":"\n    ","_children":[]},{"_id":55,"tag":"header-file","attrib":{"src":"ios/GAI.h"},"text":"","tail":"\n    ","_children":[]},{"_id":56,"tag":"header-file","attrib":{"src":"ios/GAITracker.h"},"text":"","tail":"\n    ","_children":[]},{"_id":57,"tag":"header-file","attrib":{"src":"ios/GAIEcommerceFields.h"},"text":"","tail":"\n    ","_children":[]},{"_id":58,"tag":"header-file","attrib":{"src":"ios/GAIEcommerceProduct.h"},"text":"","tail":"\n    ","_children":[]},{"_id":59,"tag":"header-file","attrib":{"src":"ios/GAIEcommerceProductAction.h"},"text":"","tail":"\n    ","_children":[]},{"_id":60,"tag":"header-file","attrib":{"src":"ios/GAIEcommercePromotion.h"},"text":"","tail":"\n\n\n    ","_children":[]},{"_id":61,"tag":"framework","attrib":{"src":"SystemConfiguration.framework"},"text":"","tail":"\n    ","_children":[]},{"_id":62,"tag":"framework","attrib":{"src":"CoreData.framework"},"text":"","tail":"\n    ","_children":[]},{"_id":63,"tag":"framework","attrib":{"src":"libz.dylib"},"text":"","tail":"\n    ","_children":[]},{"_id":64,"tag":"framework","attrib":{"src":"libsqlite3.0.dylib"},"text":"","tail":"\n  ","_children":[]}]},{"_id":65,"tag":"platform","attrib":{"name":"android"},"text":"\n    ","tail":"\n","_children":[{"_id":66,"tag":"framework","attrib":{"src":"com.google.android.gms:play-services-analytics:+"},"text":"","tail":"\n\n    ","_children":[]},{"_id":67,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n      ","tail":"\n    ","_children":[{"_id":68,"tag":"feature","attrib":{"name":"UniversalAnalytics"},"text":"\n        ","tail":"\n    ","_children":[{"_id":69,"tag":"param","attrib":{"name":"android-package","value":"com.danielcwilson.plugins.analytics.UniversalAnalyticsPlugin"},"text":"","tail":"\n      ","_children":[]}]}]},{"_id":70,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/*"},"text":"\n      ","tail":"\n    ","_children":[{"_id":71,"tag":"uses-permission","attrib":{"android:name":"android.permission.INTERNET"},"text":"","tail":"\n      ","_children":[]},{"_id":72,"tag":"uses-permission","attrib":{"android:name":"android.permission.ACCESS_NETWORK_STATE"},"text":"","tail":"\n    ","_children":[]}]},{"_id":73,"tag":"source-file","attrib":{"src":"android/UniversalAnalyticsPlugin.java","target-dir":"src/com/danielcwilson/plugins/analytics"},"text":"","tail":"\n  ","_children":[]}]}]}},"id":"cordova-plugin-google-analytics","version":"0.8.0","name":"Google Universal Analytics Plugin","description":"Simple tracking (screens/events) for Google Analytics SDK 3.0 (iOS) and SDK 4.0 (Android)","license":"MIT License"},".../LastoftesurvivorsV4/plugins/cordova-plugin-google-analytics":{"filepath":".../LastoftesurvivorsV4/plugins/cordova-plugin-google-analytics/plugin.xml","dir":".../LastoftesurvivorsV4/plugins/cordova-plugin-google-analytics","_et":{"_root":{"_id":74,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:android":"http://schemas.android.com/apk/res/android","id":"cordova-plugin-google-analytics","version":"0.8.0"},"text":"\n  ","tail":null,"_children":[{"_id":75,"tag":"engines","attrib":{},"text":"\n    ","tail":"\n  ","_children":[{"_id":76,"tag":"engine","attrib":{"name":"cordova","version":">=3.0.0"},"text":"","tail":"\n  ","_children":[]}]},{"_id":77,"tag":"name","attrib":{},"text":"Google Universal Analytics Plugin","tail":"\n  ","_children":[]},{"_id":78,"tag":"description","attrib":{},"text":"Simple tracking (screens/events) for Google Analytics SDK 3.0 (iOS) and SDK 4.0 (Android)","tail":"\n  ","_children":[]},{"_id":79,"tag":"author","attrib":{},"text":"Daniel C. Wilson","tail":"\n  ","_children":[]},{"_id":80,"tag":"license","attrib":{},"text":"MIT License","tail":"\n  ","_children":[]},{"_id":81,"tag":"js-module","attrib":{"src":"www/analytics.js","name":"UniversalAnalytics"},"text":"\n    ","tail":"\n\n  ","_children":[{"_id":82,"tag":"clobbers","attrib":{"target":"analytics"},"text":"","tail":"\n  ","_children":[]}]},{"_id":83,"tag":"platform","attrib":{"name":"ios"},"text":"\n    ","tail":"\n\n  ","_children":[{"_id":84,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n      ","tail":"\n\n    ","_children":[{"_id":85,"tag":"feature","attrib":{"name":"UniversalAnalytics"},"text":"\n        ","tail":"\n    ","_children":[{"_id":86,"tag":"param","attrib":{"name":"ios-package","value":"UniversalAnalyticsPlugin"},"text":"","tail":"\n      ","_children":[]}]}]},{"_id":87,"tag":"header-file","attrib":{"src":"ios/UniversalAnalyticsPlugin.h"},"text":"","tail":"\n    ","_children":[]},{"_id":88,"tag":"source-file","attrib":{"src":"ios/UniversalAnalyticsPlugin.m"},"text":"","tail":"\n\n    ","_children":[]},{"_id":89,"tag":"source-file","attrib":{"src":"ios/libGoogleAnalyticsServices.a","framework":"true"},"text":"","tail":"\n    ","_children":[]},{"_id":90,"tag":"header-file","attrib":{"src":"ios/GAIDictionaryBuilder.h"},"text":"","tail":"\n    ","_children":[]},{"_id":91,"tag":"header-file","attrib":{"src":"ios/GAIFields.h"},"text":"","tail":"\n    ","_children":[]},{"_id":92,"tag":"header-file","attrib":{"src":"ios/GAILogger.h"},"text":"","tail":"\n    ","_children":[]},{"_id":93,"tag":"header-file","attrib":{"src":"ios/GAITrackedViewController.h"},"text":"","tail":"\n    ","_children":[]},{"_id":94,"tag":"header-file","attrib":{"src":"ios/GAI.h"},"text":"","tail":"\n    ","_children":[]},{"_id":95,"tag":"header-file","attrib":{"src":"ios/GAITracker.h"},"text":"","tail":"\n    ","_children":[]},{"_id":96,"tag":"header-file","attrib":{"src":"ios/GAIEcommerceFields.h"},"text":"","tail":"\n    ","_children":[]},{"_id":97,"tag":"header-file","attrib":{"src":"ios/GAIEcommerceProduct.h"},"text":"","tail":"\n    ","_children":[]},{"_id":98,"tag":"header-file","attrib":{"src":"ios/GAIEcommerceProductAction.h"},"text":"","tail":"\n    ","_children":[]},{"_id":99,"tag":"header-file","attrib":{"src":"ios/GAIEcommercePromotion.h"},"text":"","tail":"\n\n\n    ","_children":[]},{"_id":100,"tag":"framework","attrib":{"src":"SystemConfiguration.framework"},"text":"","tail":"\n    ","_children":[]},{"_id":101,"tag":"framework","attrib":{"src":"CoreData.framework"},"text":"","tail":"\n    ","_children":[]},{"_id":102,"tag":"framework","attrib":{"src":"libz.dylib"},"text":"","tail":"\n    ","_children":[]},{"_id":103,"tag":"framework","attrib":{"src":"libsqlite3.0.dylib"},"text":"","tail":"\n  ","_children":[]}]},{"_id":104,"tag":"platform","attrib":{"name":"android"},"text":"\n    ","tail":"\n","_children":[{"_id":105,"tag":"framework","attrib":{"src":"com.google.android.gms:play-services-analytics:+"},"text":"","tail":"\n\n    ","_children":[]},{"_id":106,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n      ","tail":"\n    ","_children":[{"_id":107,"tag":"feature","attrib":{"name":"UniversalAnalytics"},"text":"\n        ","tail":"\n    ","_children":[{"_id":108,"tag":"param","attrib":{"name":"android-package","value":"com.danielcwilson.plugins.analytics.UniversalAnalyticsPlugin"},"text":"","tail":"\n      ","_children":[]}]}]},{"_id":109,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/*"},"text":"\n      ","tail":"\n    ","_children":[{"_id":110,"tag":"uses-permission","attrib":{"android:name":"android.permission.INTERNET"},"text":"","tail":"\n      ","_children":[]},{"_id":111,"tag":"uses-permission","attrib":{"android:name":"android.permission.ACCESS_NETWORK_STATE"},"text":"","tail":"\n    ","_children":[]}]},{"_id":112,"tag":"source-file","attrib":{"src":"android/UniversalAnalyticsPlugin.java","target-dir":"src/com/danielcwilson/plugins/analytics"},"text":"","tail":"\n  ","_children":[]}]}]}},"id":"cordova-plugin-google-analytics","version":"0.8.0","name":"Google Universal Analytics Plugin","description":"Simple tracking (screens/events) for Google Analytics SDK 3.0 (iOS) and SDK 4.0 (Android)","license":"MIT License"}},"_getAllCache":{}},"nohooks":["."]}"
Installing "cordova-plugin-google-analytics" for android
Install start for "cordova-plugin-google-analytics" on android.
Installing Android library: com.google.android.gms:play-services-analytics:+
  'com.google.playservices',
  'cordova-plugin-ad-chartboost',
  'cordova-plugin-google-analytics' ]
Install complete for cordova-plugin-google-analytics on android.
Updating build files since android plugin contained <framework>
Calling plugman.fetch on plugin ".../cachedPlugins.3S97UO.tmp/cache.AwEOVn.pl/android.support.v4"
Copying plugin ".../cachedPlugins.3S97UO.tmp/cache.AwEOVn.pl/android.support.v4" => ".../LastoftesurvivorsV4/plugins/android.support.v4"
Calling plugman.install on plugin ".../LastoftesurvivorsV4/plugins/android.support.v4" for platform "android" with options "{"cli_variables":{},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.3S97UO.tmp/cache.AwEOVn.pl/android.support.v4":{"filepath":".../cachedPlugins.3S97UO.tmp/cache.AwEOVn.pl/android.support.v4/plugin.xml","dir":".../cachedPlugins.3S97UO.tmp/cache.AwEOVn.pl/android.support.v4","_et":{"_root":{"_id":35,"tag":"plugin","attrib":{"xmlns":"http://cordova.apache.org/ns/plugins/1.0","id":"android.support.v4","version":"1.0.0"},"text":"\n  ","tail":null,"_children":[{"_id":36,"tag":"engines","attrib":{},"text":"\n    ","tail":"\n\n  ","_children":[{"_id":37,"tag":"engine","attrib":{"name":"cordova","version":">=3.0.0"},"text":"","tail":"\n  ","_children":[]}]},{"_id":38,"tag":"name","attrib":{},"text":"Android Support v4","tail":"\n\n  ","_children":[]},{"_id":39,"tag":"platform","attrib":{"name":"android"},"text":"\n    ","tail":"\n","_children":[{"_id":40,"tag":"source-file","attrib":{"src":"android-support-v4.jar","target-dir":"libs"},"text":"","tail":"\n  ","_children":[]}]}]}},"id":"android.support.v4","version":"1.0.0","name":"Android Support v4"},".../LastoftesurvivorsV4/plugins/android.support.v4":{"filepath":".../LastoftesurvivorsV4/plugins/android.support.v4/plugin.xml","dir":".../LastoftesurvivorsV4/plugins/android.support.v4","_et":{"_root":{"_id":41,"tag":"plugin","attrib":{"xmlns":"http://cordova.apache.org/ns/plugins/1.0","id":"android.support.v4","version":"1.0.0"},"text":"\n  ","tail":null,"_children":[{"_id":42,"tag":"engines","attrib":{},"text":"\n    ","tail":"\n\n  ","_children":[{"_id":43,"tag":"engine","attrib":{"name":"cordova","version":">=3.0.0"},"text":"","tail":"\n  ","_children":[]}]},{"_id":44,"tag":"name","attrib":{},"text":"Android Support v4","tail":"\n\n  ","_children":[]},{"_id":45,"tag":"platform","attrib":{"name":"android"},"text":"\n    ","tail":"\n","_children":[{"_id":46,"tag":"source-file","attrib":{"src":"android-support-v4.jar","target-dir":"libs"},"text":"","tail":"\n  ","_children":[]}]}]}},"id":"android.support.v4","version":"1.0.0","name":"Android Support v4"}},"_getAllCache":{}},"nohooks":["."]}"
Installing "android.support.v4" for android
Install start for "android.support.v4" on android.
  'cordova-plugin-google-analytics',
  'android.support.v4' ]
Install complete for android.support.v4 on android.
Calling plugman.fetch on plugin ".../cachedPlugins.3S97UO.tmp/cache.7XUEvm.pl/cordova-plugin-game"
Copying plugin ".../cachedPlugins.3S97UO.tmp/cache.7XUEvm.pl/cordova-plugin-game" => ".../LastoftesurvivorsV4/plugins/cordova-plugin-game"
Calling plugman.install on plugin ".../LastoftesurvivorsV4/plugins/cordova-plugin-game" for platform "android" with options "{"cli_variables":{"APP_ID":"736042962392"},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.3S97UO.tmp/cache.7XUEvm.pl/cordova-plugin-game":{"filepath":".../cachedPlugins.3S97UO.tmp/cache.7XUEvm.pl/cordova-plugin-game/plugin.xml","dir":".../cachedPlugins.3S97UO.tmp/cache.7XUEvm.pl/cordova-plugin-game","_et":{"_root":{"_id":35,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:android":"http://schemas.android.com/apk/res/android","id":"cordova-plugin-game","version":"1.0.105"},"text":"\r\n\t\r\n    ","tail":null,"_children":[{"_id":36,"tag":"name","attrib":{},"text":"Cordova Game plugin","tail":"\r\n    ","_children":[]},{"_id":37,"tag":"description","attrib":{},"text":"show leaderboard and achievements (google play game and game center, SDK)","tail":"\r\n    ","_children":[]},{"_id":38,"tag":"author","attrib":{},"text":"Sang Ki Kwon (Cranberrygame)","tail":"\t\r\n    ","_children":[]},{"_id":39,"tag":"license","attrib":{},"text":"MIT","tail":"\r\n    ","_children":[]},{"_id":40,"tag":"keywords","attrib":{},"text":"cordova,plugin,game,google play game,game center","tail":"\r\n    ","_children":[]},{"_id":41,"tag":"repo","attrib":{},"text":"https://github.com/cranberrygame/cordova-plugin-game","tail":"\r\n    ","_children":[]},{"_id":42,"tag":"issue","attrib":{},"text":"https://github.com/cranberrygame/cordova-plugin-game/issues","tail":"\t\r\n\t","_children":[]},{"_id":43,"tag":"engines","attrib":{},"text":"\r\n\t    ","tail":"\r\n \t\t\r\n    ","_children":[{"_id":44,"tag":"engine","attrib":{"name":"cordova","version":">=3.0.0"},"text":"","tail":"\r\n\t","_children":[]}]},{"_id":45,"tag":"js-module","attrib":{"src":"www/game.js"},"text":"\r\n        ","tail":"\r\n\t\r\n    \r\n    ","_children":[{"_id":46,"tag":"clobbers","attrib":{"target":"window.game"},"text":"","tail":"\r\n    ","_children":[]}]},{"_id":47,"tag":"platform","attrib":{"name":"android"},"text":"\r\n\t\t","tail":"\r\n\t\r\n    \r\n    ","_children":[{"_id":48,"tag":"preference","attrib":{"name":"APP_ID"},"text":"","tail":"\t\r\n\t\t\r\n\t\t","_children":[]},{"_id":49,"tag":"dependency","attrib":{"id":"com.google.playservices@21.0.0"},"text":"","tail":"\t\t\r\n\t\t","_children":[]},{"_id":50,"tag":"dependency","attrib":{"id":"android.support.v4@1.0.0"},"text":"","tail":"\r\n\r\n\t    ","_children":[]},{"_id":51,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\r\n\t\t\t","tail":"\r\n\t\t\r\n\t\t","_children":[{"_id":52,"tag":"feature","attrib":{"name":"Game"},"text":"\r\n\t\t\t\t","tail":"\r\n        ","_children":[{"_id":53,"tag":"param","attrib":{"name":"android-package","value":"com.cranberrygame.cordova.plugin.game.Game"},"text":"","tail":"\r\n\t\t\t","_children":[]}]}]},{"_id":54,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/manifest/application"},"text":"\r\n\t\t\t","tail":"\r\n\r\n        ","_children":[{"_id":55,"tag":"meta-data","attrib":{"android:name":"com.google.android.gms.games.APP_ID","android:value":"@string/app_id"},"text":"","tail":"\r\n\t\t","_children":[]}]},{"_id":56,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/manifest"},"text":"\r\n            ","tail":"\t\t\r\n\t\r\n\t\t","_children":[{"_id":57,"tag":"uses-permission","attrib":{"android:name":"android.permission.INTERNET"},"text":"","tail":"\r\n            ","_children":[]},{"_id":58,"tag":"uses-permission","attrib":{"android:name":"android.permission.ACCESS_NETWORK_STATE"},"text":"","tail":"\r\n        ","_children":[]}]},{"_id":59,"tag":"source-file","attrib":{"src":"src/android/ids.xml","target-dir":"res/values"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":60,"tag":"config-file","attrib":{"target":"res/values/ids.xml","parent":"/*"},"text":"\r\n\t\t\t","tail":"\r\n\t\t\r\n\t\t\r\n\t\t\r\n\t\t\r\n\t\t\r\n\t\t","_children":[{"_id":61,"tag":"string","attrib":{"name":"app_id"},"text":"$APP_ID","tail":"\r\n\t\t","_children":[]}]},{"_id":62,"tag":"source-file","attrib":{"src":"src/android/GameHelper.java","target-dir":"src/com/google/example/games/basegameutils"},"text":"","tail":"\t\t\r\n\t\t","_children":[]},{"_id":63,"tag":"source-file","attrib":{"src":"src/android/GameHelperUtils.java","target-dir":"src/com/google/example/games/basegameutils"},"text":"","tail":"\t\t\r\n\t\t","_children":[]},{"_id":64,"tag":"source-file","attrib":{"src":"src/android/Game.java","target-dir":"src/com/cranberrygame/cordova/plugin/game"},"text":"","tail":"\r\n\t\t\r\n\t\t\r\n\t\t\t\t\r\n    ","_children":[]}]},{"_id":65,"tag":"platform","attrib":{"name":"ios"},"text":"\r\n        ","tail":"\t\r\n","_children":[{"_id":66,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\r\n\t\t    ","tail":"\r\n               \r\n        ","_children":[{"_id":67,"tag":"feature","attrib":{"name":"Game"},"text":"\r\n\t\t        ","tail":"\r\n        ","_children":[{"_id":68,"tag":"param","attrib":{"name":"ios-package","value":"Game"},"text":"","tail":"\r\n\t\t        ","_children":[]},{"_id":69,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\r\n\t\t    ","_children":[]}]}]},{"_id":70,"tag":"header-file","attrib":{"src":"src/ios/Game.h","compiler-flags":"-fno-objc-arc"},"text":"","tail":"\r\n        ","_children":[]},{"_id":71,"tag":"source-file","attrib":{"src":"src/ios/Game.m","compiler-flags":"-fno-objc-arc"},"text":"","tail":"\r\n        \r\n        ","_children":[]},{"_id":72,"tag":"framework","attrib":{"src":"GameKit.framework"},"text":"","tail":"                \t\r\n    ","_children":[]}]}]}},"id":"cordova-plugin-game","version":"1.0.105","name":"Cordova Game plugin","description":"show leaderboard and achievements (google play game and game center, SDK)","license":"MIT","repo":"https://github.com/cranberrygame/cordova-plugin-game","issue":"https://github.com/cranberrygame/cordova-plugin-game/issues","keywords":["cordova","plugin","game","google play game","game center"]},".../LastoftesurvivorsV4/plugins/cordova-plugin-game":{"filepath":".../LastoftesurvivorsV4/plugins/cordova-plugin-game/plugin.xml","dir":".../LastoftesurvivorsV4/plugins/cordova-plugin-game","_et":{"_root":{"_id":73,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:android":"http://schemas.android.com/apk/res/android","id":"cordova-plugin-game","version":"1.0.105"},"text":"\r\n\t\r\n    ","tail":null,"_children":[{"_id":74,"tag":"name","attrib":{},"text":"Cordova Game plugin","tail":"\r\n    ","_children":[]},{"_id":75,"tag":"description","attrib":{},"text":"show leaderboard and achievements (google play game and game center, SDK)","tail":"\r\n    ","_children":[]},{"_id":76,"tag":"author","attrib":{},"text":"Sang Ki Kwon (Cranberrygame)","tail":"\t\r\n    ","_children":[]},{"_id":77,"tag":"license","attrib":{},"text":"MIT","tail":"\r\n    ","_children":[]},{"_id":78,"tag":"keywords","attrib":{},"text":"cordova,plugin,game,google play game,game center","tail":"\r\n    ","_children":[]},{"_id":79,"tag":"repo","attrib":{},"text":"https://github.com/cranberrygame/cordova-plugin-game","tail":"\r\n    ","_children":[]},{"_id":80,"tag":"issue","attrib":{},"text":"https://github.com/cranberrygame/cordova-plugin-game/issues","tail":"\t\r\n\t","_children":[]},{"_id":81,"tag":"engines","attrib":{},"text":"\r\n\t    ","tail":"\r\n \t\t\r\n    ","_children":[{"_id":82,"tag":"engine","attrib":{"name":"cordova","version":">=3.0.0"},"text":"","tail":"\r\n\t","_children":[]}]},{"_id":83,"tag":"js-module","attrib":{"src":"www/game.js"},"text":"\r\n        ","tail":"\r\n\t\r\n    \r\n    ","_children":[{"_id":84,"tag":"clobbers","attrib":{"target":"window.game"},"text":"","tail":"\r\n    ","_children":[]}]},{"_id":85,"tag":"platform","attrib":{"name":"android"},"text":"\r\n\t\t","tail":"\r\n\t\r\n    \r\n    ","_children":[{"_id":86,"tag":"preference","attrib":{"name":"APP_ID"},"text":"","tail":"\t\r\n\t\t\r\n\t\t","_children":[]},{"_id":87,"tag":"dependency","attrib":{"id":"com.google.playservices@21.0.0"},"text":"","tail":"\t\t\r\n\t\t","_children":[]},{"_id":88,"tag":"dependency","attrib":{"id":"android.support.v4@1.0.0"},"text":"","tail":"\r\n\r\n\t    ","_children":[]},{"_id":89,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\r\n\t\t\t","tail":"\r\n\t\t\r\n\t\t","_children":[{"_id":90,"tag":"feature","attrib":{"name":"Game"},"text":"\r\n\t\t\t\t","tail":"\r\n        ","_children":[{"_id":91,"tag":"param","attrib":{"name":"android-package","value":"com.cranberrygame.cordova.plugin.game.Game"},"text":"","tail":"\r\n\t\t\t","_children":[]}]}]},{"_id":92,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/manifest/application"},"text":"\r\n\t\t\t","tail":"\r\n\r\n        ","_children":[{"_id":93,"tag":"meta-data","attrib":{"android:name":"com.google.android.gms.games.APP_ID","android:value":"@string/app_id"},"text":"","tail":"\r\n\t\t","_children":[]}]},{"_id":94,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/manifest"},"text":"\r\n            ","tail":"\t\t\r\n\t\r\n\t\t","_children":[{"_id":95,"tag":"uses-permission","attrib":{"android:name":"android.permission.INTERNET"},"text":"","tail":"\r\n            ","_children":[]},{"_id":96,"tag":"uses-permission","attrib":{"android:name":"android.permission.ACCESS_NETWORK_STATE"},"text":"","tail":"\r\n        ","_children":[]}]},{"_id":97,"tag":"source-file","attrib":{"src":"src/android/ids.xml","target-dir":"res/values"},"text":"","tail":"\r\n\t\t","_children":[]},{"_id":98,"tag":"config-file","attrib":{"target":"res/values/ids.xml","parent":"/*"},"text":"\r\n\t\t\t","tail":"\r\n\t\t\r\n\t\t\r\n\t\t\r\n\t\t\r\n\t\t\r\n\t\t","_children":[{"_id":99,"tag":"string","attrib":{"name":"app_id"},"text":"$APP_ID","tail":"\r\n\t\t","_children":[]}]},{"_id":100,"tag":"source-file","attrib":{"src":"src/android/GameHelper.java","target-dir":"src/com/google/example/games/basegameutils"},"text":"","tail":"\t\t\r\n\t\t","_children":[]},{"_id":101,"tag":"source-file","attrib":{"src":"src/android/GameHelperUtils.java","target-dir":"src/com/google/example/games/basegameutils"},"text":"","tail":"\t\t\r\n\t\t","_children":[]},{"_id":102,"tag":"source-file","attrib":{"src":"src/android/Game.java","target-dir":"src/com/cranberrygame/cordova/plugin/game"},"text":"","tail":"\r\n\t\t\r\n\t\t\r\n\t\t\t\t\r\n    ","_children":[]}]},{"_id":103,"tag":"platform","attrib":{"name":"ios"},"text":"\r\n        ","tail":"\t\r\n","_children":[{"_id":104,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\r\n\t\t    ","tail":"\r\n               \r\n        ","_children":[{"_id":105,"tag":"feature","attrib":{"name":"Game"},"text":"\r\n\t\t        ","tail":"\r\n        ","_children":[{"_id":106,"tag":"param","attrib":{"name":"ios-package","value":"Game"},"text":"","tail":"\r\n\t\t        ","_children":[]},{"_id":107,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\r\n\t\t    ","_children":[]}]}]},{"_id":108,"tag":"header-file","attrib":{"src":"src/ios/Game.h","compiler-flags":"-fno-objc-arc"},"text":"","tail":"\r\n        ","_children":[]},{"_id":109,"tag":"source-file","attrib":{"src":"src/ios/Game.m","compiler-flags":"-fno-objc-arc"},"text":"","tail":"\r\n        \r\n        ","_children":[]},{"_id":110,"tag":"framework","attrib":{"src":"GameKit.framework"},"text":"","tail":"                \t\r\n    ","_children":[]}]}]}},"id":"cordova-plugin-game","version":"1.0.105","name":"Cordova Game plugin","description":"show leaderboard and achievements (google play game and game center, SDK)","license":"MIT","repo":"https://github.com/cranberrygame/cordova-plugin-game","issue":"https://github.com/cranberrygame/cordova-plugin-game/issues","keywords":["cordova","plugin","game","google play game","game center"]}},"_getAllCache":{}},"nohooks":["."]}"
Installing "cordova-plugin-game" for android
Running command: .../LastoftesurvivorsV4/platforms/android/cordova/version
Command finished with error code 0: .../LastoftesurvivorsV4/platforms/android/cordova/version
Dependencies detected, iterating through them...
Dependent plugin "com.google.playservices@21.0.0" not fetched, retrieving then installing.
WARNING: com.google.playservices has been renamed to cordova-plugin-googleplayservices. You may not be getting the latest version! We suggest you `cordova plugin rm com.google.playservices` and `cordova plugin add cordova-plugin-googleplayservices`.
Fetching plugin "com.google.playservices@21.0.0" via cordova plugins registry
Copying plugin "/home/builduser/.plugman/cache/com.google.playservices/21.0.0/package" => ".../LastoftesurvivorsV4/plugins/com.google.playservices"
Dependent plugin "com.google.playservices" already installed on android.
Dependent plugin "android.support.v4@1.0.0" not fetched, retrieving then installing.
WARNING: android.support.v4 has been renamed to cordova-plugin-android-support-v4. You may not be getting the latest version! We suggest you `cordova plugin rm android.support.v4` and `cordova plugin add cordova-plugin-android-support-v4`.
Fetching plugin "android.support.v4@1.0.0" via cordova plugins registry
Copying plugin "/home/builduser/.plugman/cache/android.support.v4/1.0.0/package" => ".../LastoftesurvivorsV4/plugins/android.support.v4"
Dependent plugin "android.support.v4" already installed on android.
Install start for "cordova-plugin-game" on android.
Beginning processing of action stack for android project...
Parsing android project files...
Action stack processing complete.
Writing out android project files...
Preparing android project
Processing configuration changes for plugins.
  'cordova-plugin-ad-admobsdk',
  'android.support.v4',
  'cordova-plugin-game' ]
Writing out cordova_plugins.js...
Install complete for cordova-plugin-game on android.
Calling plugman.fetch on plugin ".../cachedPlugins.3S97UO.tmp/cache.vZzqLB.pl/cordova-plugin-inappbrowser"
Copying plugin ".../cachedPlugins.3S97UO.tmp/cache.vZzqLB.pl/cordova-plugin-inappbrowser" => ".../LastoftesurvivorsV4/plugins/cordova-plugin-inappbrowser"
Calling plugman.install on plugin ".../LastoftesurvivorsV4/plugins/cordova-plugin-inappbrowser" for platform "android" with options "{"cli_variables":{},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.3S97UO.tmp/cache.vZzqLB.pl/cordova-plugin-inappbrowser":{"filepath":".../cachedPlugins.3S97UO.tmp/cache.vZzqLB.pl/cordova-plugin-inappbrowser/plugin.xml","dir":".../cachedPlugins.3S97UO.tmp/cache.vZzqLB.pl/cordova-plugin-inappbrowser","_et":{"_root":{"_id":35,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","id":"cordova-plugin-inappbrowser","version":"1.0.1"},"text":"\n\n    ","tail":null,"_children":[{"_id":36,"tag":"name","attrib":{},"text":"InAppBrowser","tail":"\n    ","_children":[]},{"_id":37,"tag":"description","attrib":{},"text":"Cordova InAppBrowser Plugin","tail":"\n    ","_children":[]},{"_id":38,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":39,"tag":"keywords","attrib":{},"text":"cordova,in,app,browser,inappbrowser","tail":"\n    ","_children":[]},{"_id":40,"tag":"repo","attrib":{},"text":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-inappbrowser.git","tail":"\n    ","_children":[]},{"_id":41,"tag":"issue","attrib":{},"text":"https://issues.apache.org/jira/browse/CB/component/12320641","tail":"\n\n    ","_children":[]},{"_id":42,"tag":"engines","attrib":{},"text":"\n      ","tail":"\n\n    \n    ","_children":[{"_id":43,"tag":"engine","attrib":{"name":"cordova","version":">=3.1.0"},"text":"","tail":"\n    ","_children":[]}]},{"_id":44,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":45,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"\n        ","_children":[{"_id":46,"tag":"clobbers","attrib":{"target":"cordova.InAppBrowser.open"},"text":"","tail":"\n            ","_children":[]},{"_id":47,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":48,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":49,"tag":"feature","attrib":{"name":"InAppBrowser"},"text":" \n                ","tail":"\n        ","_children":[{"_id":50,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.inappbrowser.InAppBrowser"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":51,"tag":"source-file","attrib":{"src":"src/android/InAppBrowser.java","target-dir":"src/org/apache/cordova/inappbrowser"},"text":"","tail":"\n        ","_children":[]},{"_id":52,"tag":"source-file","attrib":{"src":"src/android/InAppBrowserDialog.java","target-dir":"src/org/apache/cordova/inappbrowser"},"text":"","tail":"\n        ","_children":[]},{"_id":53,"tag":"source-file","attrib":{"src":"src/android/InAppChromeClient.java","target-dir":"src/org/apache/cordova/inappbrowser"},"text":"","tail":"\n\n        \n        ","_children":[]},{"_id":54,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-hdpi/ic_action_next_item.png","target":"res/drawable-hdpi/ic_action_next_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":55,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-mdpi/ic_action_next_item.png","target":"res/drawable-mdpi/ic_action_next_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":56,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xhdpi/ic_action_next_item.png","target":"res/drawable-xhdpi/ic_action_next_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":57,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xxhdpi/ic_action_next_item.png","target":"res/drawable-xxhdpi/ic_action_next_item.png"},"text":"","tail":"\n\n        ","_children":[]},{"_id":58,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-hdpi/ic_action_previous_item.png","target":"res/drawable-hdpi/ic_action_previous_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":59,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-mdpi/ic_action_previous_item.png","target":"res/drawable-mdpi/ic_action_previous_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":60,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xhdpi/ic_action_previous_item.png","target":"res/drawable-xhdpi/ic_action_previous_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":61,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xxhdpi/ic_action_previous_item.png","target":"res/drawable-xxhdpi/ic_action_previous_item.png"},"text":"","tail":"\n\n        ","_children":[]},{"_id":62,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-hdpi/ic_action_remove.png","target":"res/drawable-hdpi/ic_action_remove.png"},"text":"","tail":"\n        ","_children":[]},{"_id":63,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-mdpi/ic_action_remove.png","target":"res/drawable-mdpi/ic_action_remove.png"},"text":"","tail":"\n        ","_children":[]},{"_id":64,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xhdpi/ic_action_remove.png","target":"res/drawable-xhdpi/ic_action_remove.png"},"text":"","tail":"\n        ","_children":[]},{"_id":65,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xxhdpi/ic_action_remove.png","target":"res/drawable-xxhdpi/ic_action_remove.png"},"text":"","tail":"\n\n    ","_children":[]}]},{"_id":66,"tag":"platform","attrib":{"name":"amazon-fireos"},"text":"\n        ","tail":"\n    \n    \n    ","_children":[{"_id":67,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"\n        ","_children":[{"_id":68,"tag":"clobbers","attrib":{"target":"cordova.InAppBrowser.open"},"text":"","tail":"\n            ","_children":[]},{"_id":69,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":70,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":71,"tag":"feature","attrib":{"name":"InAppBrowser"},"text":" \n                ","tail":"\n        ","_children":[{"_id":72,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.inappbrowser.InAppBrowser"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":73,"tag":"source-file","attrib":{"src":"src/amazon/InAppBrowser.java","target-dir":"src/org/apache/cordova/inappbrowser"},"text":"","tail":"\n        ","_children":[]},{"_id":74,"tag":"source-file","attrib":{"src":"src/android/InAppBrowserDialog.java","target-dir":"src/org/apache/cordova/inappbrowser"},"text":"","tail":"\n        ","_children":[]},{"_id":75,"tag":"source-file","attrib":{"src":"src/amazon/InAppChromeClient.java","target-dir":"src/org/apache/cordova/inappbrowser"},"text":"","tail":"\n        \n        \n        ","_children":[]},{"_id":76,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-hdpi/ic_action_next_item.png","target":"res/drawable-hdpi/ic_action_next_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":77,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-mdpi/ic_action_next_item.png","target":"res/drawable-mdpi/ic_action_next_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":78,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xhdpi/ic_action_next_item.png","target":"res/drawable-xhdpi/ic_action_next_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":79,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xxhdpi/ic_action_next_item.png","target":"res/drawable-xxhdpi/ic_action_next_item.png"},"text":"","tail":"\n        \n        ","_children":[]},{"_id":80,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-hdpi/ic_action_previous_item.png","target":"res/drawable-hdpi/ic_action_previous_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":81,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-mdpi/ic_action_previous_item.png","target":"res/drawable-mdpi/ic_action_previous_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":82,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xhdpi/ic_action_previous_item.png","target":"res/drawable-xhdpi/ic_action_previous_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":83,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xxhdpi/ic_action_previous_item.png","target":"res/drawable-xxhdpi/ic_action_previous_item.png"},"text":"","tail":"\n        \n        ","_children":[]},{"_id":84,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-hdpi/ic_action_remove.png","target":"res/drawable-hdpi/ic_action_remove.png"},"text":"","tail":"\n        ","_children":[]},{"_id":85,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-mdpi/ic_action_remove.png","target":"res/drawable-mdpi/ic_action_remove.png"},"text":"","tail":"\n        ","_children":[]},{"_id":86,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xhdpi/ic_action_remove.png","target":"res/drawable-xhdpi/ic_action_remove.png"},"text":"","tail":"\n        ","_children":[]},{"_id":87,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xxhdpi/ic_action_remove.png","target":"res/drawable-xxhdpi/ic_action_remove.png"},"text":"","tail":"\n    ","_children":[]}]},{"_id":88,"tag":"platform","attrib":{"name":"ubuntu"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":89,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"\n        ","_children":[{"_id":90,"tag":"clobbers","attrib":{"target":"cordova.InAppBrowser.open"},"text":"","tail":"\n            ","_children":[]},{"_id":91,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":92,"tag":"header-file","attrib":{"src":"src/ubuntu/inappbrowser.h"},"text":"","tail":"\n        ","_children":[]},{"_id":93,"tag":"source-file","attrib":{"src":"src/ubuntu/inappbrowser.cpp"},"text":"","tail":"\n        ","_children":[]},{"_id":94,"tag":"resource-file","attrib":{"src":"src/ubuntu/InAppBrowser.qml"},"text":"","tail":"\n        ","_children":[]},{"_id":95,"tag":"resource-file","attrib":{"src":"src/ubuntu/InAppBrowser_escapeScript.js"},"text":"","tail":"\n        ","_children":[]},{"_id":96,"tag":"resource-file","attrib":{"src":"src/ubuntu/close.png"},"text":"","tail":"\n    ","_children":[]}]},{"_id":97,"tag":"platform","attrib":{"name":"ios"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":98,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"  \n        ","_children":[{"_id":99,"tag":"clobbers","attrib":{"target":"cordova.InAppBrowser.open"},"text":"","tail":"\n            ","_children":[]},{"_id":100,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":101,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":102,"tag":"feature","attrib":{"name":"InAppBrowser"},"text":"\n                ","tail":"\n        ","_children":[{"_id":103,"tag":"param","attrib":{"name":"ios-package","value":"CDVInAppBrowser"},"text":"","tail":" \n            ","_children":[]}]}]},{"_id":104,"tag":"header-file","attrib":{"src":"src/ios/CDVInAppBrowser.h"},"text":"","tail":"\n\t    ","_children":[]},{"_id":105,"tag":"source-file","attrib":{"src":"src/ios/CDVInAppBrowser.m"},"text":"","tail":"\n\t    \n\t    ","_children":[]},{"_id":106,"tag":"framework","attrib":{"src":"CoreGraphics.framework"},"text":"","tail":"\n    ","_children":[]}]},{"_id":107,"tag":"platform","attrib":{"name":"wp7"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":108,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":109,"tag":"Capability","attrib":{"Name":"ID_CAP_NETWORKING"},"text":"","tail":"\n        ","_children":[]}]},{"_id":110,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"\n        ","_children":[{"_id":111,"tag":"clobbers","attrib":{"target":"cordova.InAppBrowser.open"},"text":"","tail":"\n            ","_children":[]},{"_id":112,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":113,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":114,"tag":"feature","attrib":{"name":"InAppBrowser"},"text":"\n                ","tail":"\n        ","_children":[{"_id":115,"tag":"param","attrib":{"name":"wp-package","value":"InAppBrowser"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":116,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":117,"tag":"Capability","attrib":{"Name":"ID_CAP_NETWORKING"},"text":"","tail":"\n        ","_children":[]}]},{"_id":118,"tag":"source-file","attrib":{"src":"src/wp/InAppBrowser.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":119,"tag":"platform","attrib":{"name":"wp8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":120,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n                \n        ","_children":[{"_id":121,"tag":"Capability","attrib":{"Name":"ID_CAP_NETWORKING"},"text":"","tail":"\n        ","_children":[]}]},{"_id":122,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"\n        ","_children":[{"_id":123,"tag":"clobbers","attrib":{"target":"cordova.InAppBrowser.open"},"text":"","tail":"\n            ","_children":[]},{"_id":124,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":125,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":126,"tag":"feature","attrib":{"name":"InAppBrowser"},"text":"\n                ","tail":"\n        ","_children":[{"_id":127,"tag":"param","attrib":{"name":"wp-package","value":"InAppBrowser"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":128,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":129,"tag":"Capability","attrib":{"Name":"ID_CAP_NETWORKING"},"text":"","tail":"\n        ","_children":[]}]},{"_id":130,"tag":"source-file","attrib":{"src":"src/wp/InAppBrowser.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":131,"tag":"platform","attrib":{"name":"windows8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":132,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"\n        ","_children":[{"_id":133,"tag":"clobbers","attrib":{"target":"cordova.InAppBrowser.open"},"text":"","tail":"\n            ","_children":[]},{"_id":134,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":135,"tag":"js-module","attrib":{"src":"www/windows8/InAppBrowserProxy.js","name":"InAppBrowserProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":136,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":137,"tag":"platform","attrib":{"name":"windows"},"text":"\n        ","tail":"\n  \n    \n    ","_children":[{"_id":138,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"\n        ","_children":[{"_id":139,"tag":"clobbers","attrib":{"target":"cordova.InAppBrowser.open"},"text":"","tail":"\n            ","_children":[]},{"_id":140,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":141,"tag":"js-module","attrib":{"src":"src/windows/InAppBrowserProxy.js","name":"InAppBrowserProxy"},"text":"\n            ","tail":"\n        ","_children":[{"_id":142,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]},{"_id":143,"tag":"asset","attrib":{"src":"www/inappbrowser.css","target":"css/inappbrowser.css"},"text":"","tail":"\n    ","_children":[]}]},{"_id":144,"tag":"platform","attrib":{"name":"firefoxos"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":145,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n        ","_children":[{"_id":146,"tag":"permission","attrib":{"name":"browser","description":"Enables the app to implement a browser in an iframe.","privileged":"true"},"text":"","tail":"\n        ","_children":[]}]},{"_id":147,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"\n        ","_children":[{"_id":148,"tag":"clobbers","attrib":{"target":"cordova.InAppBrowser.open"},"text":"","tail":"\n            ","_children":[]},{"_id":149,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":150,"tag":"js-module","attrib":{"src":"src/firefoxos/InAppBrowserProxy.js","name":"InAppBrowserProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":151,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":152,"tag":"platform","attrib":{"name":"browser"},"text":"\n        ","tail":"\n","_children":[{"_id":153,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"\n        ","_children":[{"_id":154,"tag":"clobbers","attrib":{"target":"cordova.InAppBrowser.open"},"text":"","tail":"\n            ","_children":[]},{"_id":155,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":156,"tag":"js-module","attrib":{"src":"src/browser/InAppBrowserProxy.js","name":"InAppBrowserProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":157,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"cordova-plugin-inappbrowser","version":"1.0.1","name":"InAppBrowser","description":"Cordova InAppBrowser Plugin","license":"Apache 2.0","repo":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-inappbrowser.git","issue":"https://issues.apache.org/jira/browse/CB/component/12320641","keywords":["cordova","in","app","browser","inappbrowser"]},".../LastoftesurvivorsV4/plugins/cordova-plugin-inappbrowser":{"filepath":".../LastoftesurvivorsV4/plugins/cordova-plugin-inappbrowser/plugin.xml","dir":".../LastoftesurvivorsV4/plugins/cordova-plugin-inappbrowser","_et":{"_root":{"_id":158,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","id":"cordova-plugin-inappbrowser","version":"1.0.1"},"text":"\n\n    ","tail":null,"_children":[{"_id":159,"tag":"name","attrib":{},"text":"InAppBrowser","tail":"\n    ","_children":[]},{"_id":160,"tag":"description","attrib":{},"text":"Cordova InAppBrowser Plugin","tail":"\n    ","_children":[]},{"_id":161,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":162,"tag":"keywords","attrib":{},"text":"cordova,in,app,browser,inappbrowser","tail":"\n    ","_children":[]},{"_id":163,"tag":"repo","attrib":{},"text":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-inappbrowser.git","tail":"\n    ","_children":[]},{"_id":164,"tag":"issue","attrib":{},"text":"https://issues.apache.org/jira/browse/CB/component/12320641","tail":"\n\n    ","_children":[]},{"_id":165,"tag":"engines","attrib":{},"text":"\n      ","tail":"\n\n    \n    ","_children":[{"_id":166,"tag":"engine","attrib":{"name":"cordova","version":">=3.1.0"},"text":"","tail":"\n    ","_children":[]}]},{"_id":167,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":168,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"\n        ","_children":[{"_id":169,"tag":"clobbers","attrib":{"target":"cordova.InAppBrowser.open"},"text":"","tail":"\n            ","_children":[]},{"_id":170,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":171,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":172,"tag":"feature","attrib":{"name":"InAppBrowser"},"text":" \n                ","tail":"\n        ","_children":[{"_id":173,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.inappbrowser.InAppBrowser"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":174,"tag":"source-file","attrib":{"src":"src/android/InAppBrowser.java","target-dir":"src/org/apache/cordova/inappbrowser"},"text":"","tail":"\n        ","_children":[]},{"_id":175,"tag":"source-file","attrib":{"src":"src/android/InAppBrowserDialog.java","target-dir":"src/org/apache/cordova/inappbrowser"},"text":"","tail":"\n        ","_children":[]},{"_id":176,"tag":"source-file","attrib":{"src":"src/android/InAppChromeClient.java","target-dir":"src/org/apache/cordova/inappbrowser"},"text":"","tail":"\n\n        \n        ","_children":[]},{"_id":177,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-hdpi/ic_action_next_item.png","target":"res/drawable-hdpi/ic_action_next_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":178,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-mdpi/ic_action_next_item.png","target":"res/drawable-mdpi/ic_action_next_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":179,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xhdpi/ic_action_next_item.png","target":"res/drawable-xhdpi/ic_action_next_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":180,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xxhdpi/ic_action_next_item.png","target":"res/drawable-xxhdpi/ic_action_next_item.png"},"text":"","tail":"\n\n        ","_children":[]},{"_id":181,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-hdpi/ic_action_previous_item.png","target":"res/drawable-hdpi/ic_action_previous_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":182,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-mdpi/ic_action_previous_item.png","target":"res/drawable-mdpi/ic_action_previous_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":183,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xhdpi/ic_action_previous_item.png","target":"res/drawable-xhdpi/ic_action_previous_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":184,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xxhdpi/ic_action_previous_item.png","target":"res/drawable-xxhdpi/ic_action_previous_item.png"},"text":"","tail":"\n\n        ","_children":[]},{"_id":185,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-hdpi/ic_action_remove.png","target":"res/drawable-hdpi/ic_action_remove.png"},"text":"","tail":"\n        ","_children":[]},{"_id":186,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-mdpi/ic_action_remove.png","target":"res/drawable-mdpi/ic_action_remove.png"},"text":"","tail":"\n        ","_children":[]},{"_id":187,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xhdpi/ic_action_remove.png","target":"res/drawable-xhdpi/ic_action_remove.png"},"text":"","tail":"\n        ","_children":[]},{"_id":188,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xxhdpi/ic_action_remove.png","target":"res/drawable-xxhdpi/ic_action_remove.png"},"text":"","tail":"\n\n    ","_children":[]}]},{"_id":189,"tag":"platform","attrib":{"name":"amazon-fireos"},"text":"\n        ","tail":"\n    \n    \n    ","_children":[{"_id":190,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"\n        ","_children":[{"_id":191,"tag":"clobbers","attrib":{"target":"cordova.InAppBrowser.open"},"text":"","tail":"\n            ","_children":[]},{"_id":192,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":193,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":194,"tag":"feature","attrib":{"name":"InAppBrowser"},"text":" \n                ","tail":"\n        ","_children":[{"_id":195,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.inappbrowser.InAppBrowser"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":196,"tag":"source-file","attrib":{"src":"src/amazon/InAppBrowser.java","target-dir":"src/org/apache/cordova/inappbrowser"},"text":"","tail":"\n        ","_children":[]},{"_id":197,"tag":"source-file","attrib":{"src":"src/android/InAppBrowserDialog.java","target-dir":"src/org/apache/cordova/inappbrowser"},"text":"","tail":"\n        ","_children":[]},{"_id":198,"tag":"source-file","attrib":{"src":"src/amazon/InAppChromeClient.java","target-dir":"src/org/apache/cordova/inappbrowser"},"text":"","tail":"\n        \n        \n        ","_children":[]},{"_id":199,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-hdpi/ic_action_next_item.png","target":"res/drawable-hdpi/ic_action_next_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":200,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-mdpi/ic_action_next_item.png","target":"res/drawable-mdpi/ic_action_next_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":201,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xhdpi/ic_action_next_item.png","target":"res/drawable-xhdpi/ic_action_next_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":202,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xxhdpi/ic_action_next_item.png","target":"res/drawable-xxhdpi/ic_action_next_item.png"},"text":"","tail":"\n        \n        ","_children":[]},{"_id":203,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-hdpi/ic_action_previous_item.png","target":"res/drawable-hdpi/ic_action_previous_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":204,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-mdpi/ic_action_previous_item.png","target":"res/drawable-mdpi/ic_action_previous_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":205,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xhdpi/ic_action_previous_item.png","target":"res/drawable-xhdpi/ic_action_previous_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":206,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xxhdpi/ic_action_previous_item.png","target":"res/drawable-xxhdpi/ic_action_previous_item.png"},"text":"","tail":"\n        \n        ","_children":[]},{"_id":207,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-hdpi/ic_action_remove.png","target":"res/drawable-hdpi/ic_action_remove.png"},"text":"","tail":"\n        ","_children":[]},{"_id":208,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-mdpi/ic_action_remove.png","target":"res/drawable-mdpi/ic_action_remove.png"},"text":"","tail":"\n        ","_children":[]},{"_id":209,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xhdpi/ic_action_remove.png","target":"res/drawable-xhdpi/ic_action_remove.png"},"text":"","tail":"\n        ","_children":[]},{"_id":210,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xxhdpi/ic_action_remove.png","target":"res/drawable-xxhdpi/ic_action_remove.png"},"text":"","tail":"\n    ","_children":[]}]},{"_id":211,"tag":"platform","attrib":{"name":"ubuntu"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":212,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"\n        ","_children":[{"_id":213,"tag":"clobbers","attrib":{"target":"cordova.InAppBrowser.open"},"text":"","tail":"\n            ","_children":[]},{"_id":214,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":215,"tag":"header-file","attrib":{"src":"src/ubuntu/inappbrowser.h"},"text":"","tail":"\n        ","_children":[]},{"_id":216,"tag":"source-file","attrib":{"src":"src/ubuntu/inappbrowser.cpp"},"text":"","tail":"\n        ","_children":[]},{"_id":217,"tag":"resource-file","attrib":{"src":"src/ubuntu/InAppBrowser.qml"},"text":"","tail":"\n        ","_children":[]},{"_id":218,"tag":"resource-file","attrib":{"src":"src/ubuntu/InAppBrowser_escapeScript.js"},"text":"","tail":"\n        ","_children":[]},{"_id":219,"tag":"resource-file","attrib":{"src":"src/ubuntu/close.png"},"text":"","tail":"\n    ","_children":[]}]},{"_id":220,"tag":"platform","attrib":{"name":"ios"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":221,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"  \n        ","_children":[{"_id":222,"tag":"clobbers","attrib":{"target":"cordova.InAppBrowser.open"},"text":"","tail":"\n            ","_children":[]},{"_id":223,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":224,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":225,"tag":"feature","attrib":{"name":"InAppBrowser"},"text":"\n                ","tail":"\n        ","_children":[{"_id":226,"tag":"param","attrib":{"name":"ios-package","value":"CDVInAppBrowser"},"text":"","tail":" \n            ","_children":[]}]}]},{"_id":227,"tag":"header-file","attrib":{"src":"src/ios/CDVInAppBrowser.h"},"text":"","tail":"\n\t    ","_children":[]},{"_id":228,"tag":"source-file","attrib":{"src":"src/ios/CDVInAppBrowser.m"},"text":"","tail":"\n\t    \n\t    ","_children":[]},{"_id":229,"tag":"framework","attrib":{"src":"CoreGraphics.framework"},"text":"","tail":"\n    ","_children":[]}]},{"_id":230,"tag":"platform","attrib":{"name":"wp7"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":231,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":232,"tag":"Capability","attrib":{"Name":"ID_CAP_NETWORKING"},"text":"","tail":"\n        ","_children":[]}]},{"_id":233,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"\n        ","_children":[{"_id":234,"tag":"clobbers","attrib":{"target":"cordova.InAppBrowser.open"},"text":"","tail":"\n            ","_children":[]},{"_id":235,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":236,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":237,"tag":"feature","attrib":{"name":"InAppBrowser"},"text":"\n                ","tail":"\n        ","_children":[{"_id":238,"tag":"param","attrib":{"name":"wp-package","value":"InAppBrowser"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":239,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":240,"tag":"Capability","attrib":{"Name":"ID_CAP_NETWORKING"},"text":"","tail":"\n        ","_children":[]}]},{"_id":241,"tag":"source-file","attrib":{"src":"src/wp/InAppBrowser.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":242,"tag":"platform","attrib":{"name":"wp8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":243,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n                \n        ","_children":[{"_id":244,"tag":"Capability","attrib":{"Name":"ID_CAP_NETWORKING"},"text":"","tail":"\n        ","_children":[]}]},{"_id":245,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"\n        ","_children":[{"_id":246,"tag":"clobbers","attrib":{"target":"cordova.InAppBrowser.open"},"text":"","tail":"\n            ","_children":[]},{"_id":247,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":248,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":249,"tag":"feature","attrib":{"name":"InAppBrowser"},"text":"\n                ","tail":"\n        ","_children":[{"_id":250,"tag":"param","attrib":{"name":"wp-package","value":"InAppBrowser"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":251,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":252,"tag":"Capability","attrib":{"Name":"ID_CAP_NETWORKING"},"text":"","tail":"\n        ","_children":[]}]},{"_id":253,"tag":"source-file","attrib":{"src":"src/wp/InAppBrowser.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":254,"tag":"platform","attrib":{"name":"windows8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":255,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"\n        ","_children":[{"_id":256,"tag":"clobbers","attrib":{"target":"cordova.InAppBrowser.open"},"text":"","tail":"\n            ","_children":[]},{"_id":257,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":258,"tag":"js-module","attrib":{"src":"www/windows8/InAppBrowserProxy.js","name":"InAppBrowserProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":259,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":260,"tag":"platform","attrib":{"name":"windows"},"text":"\n        ","tail":"\n  \n    \n    ","_children":[{"_id":261,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"\n        ","_children":[{"_id":262,"tag":"clobbers","attrib":{"target":"cordova.InAppBrowser.open"},"text":"","tail":"\n            ","_children":[]},{"_id":263,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":264,"tag":"js-module","attrib":{"src":"src/windows/InAppBrowserProxy.js","name":"InAppBrowserProxy"},"text":"\n            ","tail":"\n        ","_children":[{"_id":265,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]},{"_id":266,"tag":"asset","attrib":{"src":"www/inappbrowser.css","target":"css/inappbrowser.css"},"text":"","tail":"\n    ","_children":[]}]},{"_id":267,"tag":"platform","attrib":{"name":"firefoxos"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":268,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n        ","_children":[{"_id":269,"tag":"permission","attrib":{"name":"browser","description":"Enables the app to implement a browser in an iframe.","privileged":"true"},"text":"","tail":"\n        ","_children":[]}]},{"_id":270,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"\n        ","_children":[{"_id":271,"tag":"clobbers","attrib":{"target":"cordova.InAppBrowser.open"},"text":"","tail":"\n            ","_children":[]},{"_id":272,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":273,"tag":"js-module","attrib":{"src":"src/firefoxos/InAppBrowserProxy.js","name":"InAppBrowserProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":274,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":275,"tag":"platform","attrib":{"name":"browser"},"text":"\n        ","tail":"\n","_children":[{"_id":276,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"\n        ","_children":[{"_id":277,"tag":"clobbers","attrib":{"target":"cordova.InAppBrowser.open"},"text":"","tail":"\n            ","_children":[]},{"_id":278,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":279,"tag":"js-module","attrib":{"src":"src/browser/InAppBrowserProxy.js","name":"InAppBrowserProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":280,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"cordova-plugin-inappbrowser","version":"1.0.1","name":"InAppBrowser","description":"Cordova InAppBrowser Plugin","license":"Apache 2.0","repo":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-inappbrowser.git","issue":"https://issues.apache.org/jira/browse/CB/component/12320641","keywords":["cordova","in","app","browser","inappbrowser"]}},"_getAllCache":{}},"nohooks":["."]}"
Installing "cordova-plugin-inappbrowser" for android
Install start for "cordova-plugin-inappbrowser" on android.
Copying resource file src/android/res/drawable-hdpi/ic_action_next_item.png to res/drawable-hdpi/ic_action_next_item.png
Copying resource file src/android/res/drawable-mdpi/ic_action_next_item.png to res/drawable-mdpi/ic_action_next_item.png
Copying resource file src/android/res/drawable-xhdpi/ic_action_next_item.png to res/drawable-xhdpi/ic_action_next_item.png
Copying resource file src/android/res/drawable-xxhdpi/ic_action_next_item.png to res/drawable-xxhdpi/ic_action_next_item.png
Copying resource file src/android/res/drawable-hdpi/ic_action_previous_item.png to res/drawable-hdpi/ic_action_previous_item.png
Copying resource file src/android/res/drawable-mdpi/ic_action_previous_item.png to res/drawable-mdpi/ic_action_previous_item.png
Copying resource file src/android/res/drawable-xhdpi/ic_action_previous_item.png to res/drawable-xhdpi/ic_action_previous_item.png
Copying resource file src/android/res/drawable-xxhdpi/ic_action_previous_item.png to res/drawable-xxhdpi/ic_action_previous_item.png
Copying resource file src/android/res/drawable-hdpi/ic_action_remove.png to res/drawable-hdpi/ic_action_remove.png
Copying resource file src/android/res/drawable-mdpi/ic_action_remove.png to res/drawable-mdpi/ic_action_remove.png
Copying resource file src/android/res/drawable-xhdpi/ic_action_remove.png to res/drawable-xhdpi/ic_action_remove.png
Copying resource file src/android/res/drawable-xxhdpi/ic_action_remove.png to res/drawable-xxhdpi/ic_action_remove.png
Iterating over installed plugins: [ 'cordova-plugin-splashscreen',
  'cordova-plugin-device',
  'cordova-plugin-device-motion',
  'cordova-plugin-ad-admob',
  'cordova-plugin-payment-iap',
  'cordova-plugin-ad-adcolony',
  'cordova-plugin-game',
  'cordova-plugin-inappbrowser' ]
Install complete for cordova-plugin-inappbrowser on android.
Calling plugman.fetch on plugin ".../cachedPlugins.3S97UO.tmp/cache.r7J9ne.pl/cordova-plugin-legacy-whitelist"
Copying plugin ".../cachedPlugins.3S97UO.tmp/cache.r7J9ne.pl/cordova-plugin-legacy-whitelist" => ".../LastoftesurvivorsV4/plugins/cordova-plugin-legacy-whitelist"
Calling plugman.install on plugin ".../LastoftesurvivorsV4/plugins/cordova-plugin-legacy-whitelist" for platform "android" with options "{"cli_variables":{},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.3S97UO.tmp/cache.r7J9ne.pl/cordova-plugin-legacy-whitelist":{"filepath":".../cachedPlugins.3S97UO.tmp/cache.r7J9ne.pl/cordova-plugin-legacy-whitelist/plugin.xml","dir":".../cachedPlugins.3S97UO.tmp/cache.r7J9ne.pl/cordova-plugin-legacy-whitelist","_et":{"_root":{"_id":35,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","id":"cordova-plugin-legacy-whitelist","version":"1.1.0"},"text":"\n    ","tail":null,"_children":[{"_id":36,"tag":"name","attrib":{},"text":"Legacy Whitelist","tail":"\n    ","_children":[]},{"_id":37,"tag":"description","attrib":{},"text":"Cordova Legacy Whitelist Plugin","tail":"\n    ","_children":[]},{"_id":38,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":39,"tag":"keywords","attrib":{},"text":"cordova,whitelist","tail":"\n\n    ","_children":[]},{"_id":40,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n","_children":[{"_id":41,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":42,"tag":"feature","attrib":{"name":"Whitelist"},"text":"\n                ","tail":"\n        ","_children":[{"_id":43,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.whitelist.LegacyWhitelistPlugin"},"text":"","tail":"\n                ","_children":[]},{"_id":44,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":45,"tag":"source-file","attrib":{"src":"src/android/LegacyWhitelistPlugin.java","target-dir":"src/org/apache/cordova/whitelist"},"text":"","tail":"\n    ","_children":[]}]}]}},"id":"cordova-plugin-legacy-whitelist","version":"1.1.0","name":"Legacy Whitelist","description":"Cordova Legacy Whitelist Plugin","license":"Apache 2.0","keywords":["cordova","whitelist"]},".../LastoftesurvivorsV4/plugins/cordova-plugin-legacy-whitelist":{"filepath":".../LastoftesurvivorsV4/plugins/cordova-plugin-legacy-whitelist/plugin.xml","dir":".../LastoftesurvivorsV4/plugins/cordova-plugin-legacy-whitelist","_et":{"_root":{"_id":46,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","id":"cordova-plugin-legacy-whitelist","version":"1.1.0"},"text":"\n    ","tail":null,"_children":[{"_id":47,"tag":"name","attrib":{},"text":"Legacy Whitelist","tail":"\n    ","_children":[]},{"_id":48,"tag":"description","attrib":{},"text":"Cordova Legacy Whitelist Plugin","tail":"\n    ","_children":[]},{"_id":49,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":50,"tag":"keywords","attrib":{},"text":"cordova,whitelist","tail":"\n\n    ","_children":[]},{"_id":51,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n","_children":[{"_id":52,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":53,"tag":"feature","attrib":{"name":"Whitelist"},"text":"\n                ","tail":"\n        ","_children":[{"_id":54,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.whitelist.LegacyWhitelistPlugin"},"text":"","tail":"\n                ","_children":[]},{"_id":55,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":56,"tag":"source-file","attrib":{"src":"src/android/LegacyWhitelistPlugin.java","target-dir":"src/org/apache/cordova/whitelist"},"text":"","tail":"\n    ","_children":[]}]}]}},"id":"cordova-plugin-legacy-whitelist","version":"1.1.0","name":"Legacy Whitelist","description":"Cordova Legacy Whitelist Plugin","license":"Apache 2.0","keywords":["cordova","whitelist"]}},"_getAllCache":{}},"nohooks":["."]}"
Installing "cordova-plugin-legacy-whitelist" for android
Install start for "cordova-plugin-legacy-whitelist" on android.
  'cordova-plugin-inappbrowser',
  'cordova-plugin-legacy-whitelist' ]
Install complete for cordova-plugin-legacy-whitelist on android.
Calling plugman.fetch on plugin ".../cachedPlugins.3S97UO.tmp/cache.hqb3d5.pl/cordova-plugin-crosswalk-webview"
Copying plugin ".../cachedPlugins.3S97UO.tmp/cache.hqb3d5.pl/cordova-plugin-crosswalk-webview" => ".../LastoftesurvivorsV4/plugins/cordova-plugin-crosswalk-webview"
Calling plugman.install on plugin ".../LastoftesurvivorsV4/plugins/cordova-plugin-crosswalk-webview" for platform "android" with options "{"cli_variables":{},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.3S97UO.tmp/cache.hqb3d5.pl/cordova-plugin-crosswalk-webview":{"filepath":".../cachedPlugins.3S97UO.tmp/cache.hqb3d5.pl/cordova-plugin-crosswalk-webview/plugin.xml","dir":".../cachedPlugins.3S97UO.tmp/cache.hqb3d5.pl/cordova-plugin-crosswalk-webview","_et":{"_root":{"_id":35,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","id":"cordova-plugin-crosswalk-webview","version":"1.3.1"},"text":"\n\n    ","tail":null,"_children":[{"_id":36,"tag":"name","attrib":{},"text":"Crosswalk WebView Engine","tail":"\n    ","_children":[]},{"_id":37,"tag":"description","attrib":{},"text":"Changes the default WebView to CrossWalk","tail":"\n    ","_children":[]},{"_id":38,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":39,"tag":"keywords","attrib":{},"text":"cordova,chromium,crosswalk,webview","tail":"\n    ","_children":[]},{"_id":40,"tag":"repo","attrib":{},"text":"https://github.com/crosswalk-project/cordova-plugin-crosswalk-webview","tail":"\n    ","_children":[]},{"_id":41,"tag":"issue","attrib":{},"text":"https://crosswalk-project.org/jira","tail":"\n\n    ","_children":[]},{"_id":42,"tag":"engines","attrib":{},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":43,"tag":"engine","attrib":{"name":"cordova-android","version":">=4"},"text":"","tail":"\n        ","_children":[]},{"_id":44,"tag":"engine","attrib":{"name":"cordova-plugman","version":">=4.2.0"},"text":"","tail":"\n    ","_children":[]}]},{"_id":45,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n","_children":[{"_id":46,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":47,"tag":"preference","attrib":{"name":"webView","value":"org.crosswalk.engine.XWalkWebViewEngine"},"text":"","tail":"\n            ","_children":[]},{"_id":48,"tag":"preference","attrib":{"name":"xwalkVersion","default":"14+"},"text":"","tail":"\n            ","_children":[]},{"_id":49,"tag":"preference","attrib":{"name":"xwalkCommandLine","default":"--disable-pull-to-refresh-effect"},"text":"","tail":"\n            ","_children":[]},{"_id":50,"tag":"preference","attrib":{"name":"xwalkMode","default":"embedded"},"text":"","tail":"\n        ","_children":[]}]},{"_id":51,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":52,"tag":"uses-permission","attrib":{"android:name":"android.permission.ACCESS_NETWORK_STATE"},"text":"","tail":"\n            ","_children":[]},{"_id":53,"tag":"uses-permission","attrib":{"android:name":"android.permission.ACCESS_WIFI_STATE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":54,"tag":"source-file","attrib":{"src":"platforms/android/src/org/crosswalk/engine/XWalkWebViewEngine.java","target-dir":"src/org/crosswalk/engine"},"text":"","tail":"\n        ","_children":[]},{"_id":55,"tag":"source-file","attrib":{"src":"platforms/android/src/org/crosswalk/engine/XWalkExposedJsApi.java","target-dir":"src/org/crosswalk/engine"},"text":"","tail":"\n        ","_children":[]},{"_id":56,"tag":"source-file","attrib":{"src":"platforms/android/src/org/crosswalk/engine/XWalkCordovaResourceClient.java","target-dir":"src/org/crosswalk/engine"},"text":"","tail":"\n        ","_children":[]},{"_id":57,"tag":"source-file","attrib":{"src":"platforms/android/src/org/crosswalk/engine/XWalkCordovaUiClient.java","target-dir":"src/org/crosswalk/engine"},"text":"","tail":"\n        ","_children":[]},{"_id":58,"tag":"source-file","attrib":{"src":"platforms/android/src/org/crosswalk/engine/XWalkCordovaView.java","target-dir":"src/org/crosswalk/engine"},"text":"","tail":"\n        ","_children":[]},{"_id":59,"tag":"source-file","attrib":{"src":"platforms/android/src/org/crosswalk/engine/XWalkCordovaCookieManager.java","target-dir":"src/org/crosswalk/engine"},"text":"","tail":"\n\n        ","_children":[]},{"_id":60,"tag":"framework","attrib":{"src":"platforms/android/xwalk.gradle","custom":"true","type":"gradleReference"},"text":"","tail":"\n\n        ","_children":[]},{"_id":61,"tag":"hook","attrib":{"type":"after_plugin_install","src":"hooks/after_plugin_install/000-shared_mode_special.js"},"text":"","tail":"\n        ","_children":[]},{"_id":62,"tag":"hook","attrib":{"type":"before_plugin_uninstall","src":"hooks/before_plugin_uninstall/000-shared_mode_special.js"},"text":"","tail":"\n    ","_children":[]}]}]}},"id":"cordova-plugin-crosswalk-webview","version":"1.3.1","name":"Crosswalk WebView Engine","description":"Changes the default WebView to CrossWalk","license":"Apache 2.0","repo":"https://github.com/crosswalk-project/cordova-plugin-crosswalk-webview","issue":"https://crosswalk-project.org/jira","keywords":["cordova","chromium","crosswalk","webview"]},".../LastoftesurvivorsV4/plugins/cordova-plugin-crosswalk-webview":{"filepath":".../LastoftesurvivorsV4/plugins/cordova-plugin-crosswalk-webview/plugin.xml","dir":".../LastoftesurvivorsV4/plugins/cordova-plugin-crosswalk-webview","_et":{"_root":{"_id":63,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","id":"cordova-plugin-crosswalk-webview","version":"1.3.1"},"text":"\n\n    ","tail":null,"_children":[{"_id":64,"tag":"name","attrib":{},"text":"Crosswalk WebView Engine","tail":"\n    ","_children":[]},{"_id":65,"tag":"description","attrib":{},"text":"Changes the default WebView to CrossWalk","tail":"\n    ","_children":[]},{"_id":66,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":67,"tag":"keywords","attrib":{},"text":"cordova,chromium,crosswalk,webview","tail":"\n    ","_children":[]},{"_id":68,"tag":"repo","attrib":{},"text":"https://github.com/crosswalk-project/cordova-plugin-crosswalk-webview","tail":"\n    ","_children":[]},{"_id":69,"tag":"issue","attrib":{},"text":"https://crosswalk-project.org/jira","tail":"\n\n    ","_children":[]},{"_id":70,"tag":"engines","attrib":{},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":71,"tag":"engine","attrib":{"name":"cordova-android","version":">=4"},"text":"","tail":"\n        ","_children":[]},{"_id":72,"tag":"engine","attrib":{"name":"cordova-plugman","version":">=4.2.0"},"text":"","tail":"\n    ","_children":[]}]},{"_id":73,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n","_children":[{"_id":74,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":75,"tag":"preference","attrib":{"name":"webView","value":"org.crosswalk.engine.XWalkWebViewEngine"},"text":"","tail":"\n            ","_children":[]},{"_id":76,"tag":"preference","attrib":{"name":"xwalkVersion","default":"14+"},"text":"","tail":"\n            ","_children":[]},{"_id":77,"tag":"preference","attrib":{"name":"xwalkCommandLine","default":"--disable-pull-to-refresh-effect"},"text":"","tail":"\n            ","_children":[]},{"_id":78,"tag":"preference","attrib":{"name":"xwalkMode","default":"embedded"},"text":"","tail":"\n        ","_children":[]}]},{"_id":79,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":80,"tag":"uses-permission","attrib":{"android:name":"android.permission.ACCESS_NETWORK_STATE"},"text":"","tail":"\n            ","_children":[]},{"_id":81,"tag":"uses-permission","attrib":{"android:name":"android.permission.ACCESS_WIFI_STATE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":82,"tag":"source-file","attrib":{"src":"platforms/android/src/org/crosswalk/engine/XWalkWebViewEngine.java","target-dir":"src/org/crosswalk/engine"},"text":"","tail":"\n        ","_children":[]},{"_id":83,"tag":"source-file","attrib":{"src":"platforms/android/src/org/crosswalk/engine/XWalkExposedJsApi.java","target-dir":"src/org/crosswalk/engine"},"text":"","tail":"\n        ","_children":[]},{"_id":84,"tag":"source-file","attrib":{"src":"platforms/android/src/org/crosswalk/engine/XWalkCordovaResourceClient.java","target-dir":"src/org/crosswalk/engine"},"text":"","tail":"\n        ","_children":[]},{"_id":85,"tag":"source-file","attrib":{"src":"platforms/android/src/org/crosswalk/engine/XWalkCordovaUiClient.java","target-dir":"src/org/crosswalk/engine"},"text":"","tail":"\n        ","_children":[]},{"_id":86,"tag":"source-file","attrib":{"src":"platforms/android/src/org/crosswalk/engine/XWalkCordovaView.java","target-dir":"src/org/crosswalk/engine"},"text":"","tail":"\n        ","_children":[]},{"_id":87,"tag":"source-file","attrib":{"src":"platforms/android/src/org/crosswalk/engine/XWalkCordovaCookieManager.java","target-dir":"src/org/crosswalk/engine"},"text":"","tail":"\n\n        ","_children":[]},{"_id":88,"tag":"framework","attrib":{"src":"platforms/android/xwalk.gradle","custom":"true","type":"gradleReference"},"text":"","tail":"\n\n        ","_children":[]},{"_id":89,"tag":"hook","attrib":{"type":"after_plugin_install","src":"hooks/after_plugin_install/000-shared_mode_special.js"},"text":"","tail":"\n        ","_children":[]},{"_id":90,"tag":"hook","attrib":{"type":"before_plugin_uninstall","src":"hooks/before_plugin_uninstall/000-shared_mode_special.js"},"text":"","tail":"\n    ","_children":[]}]}]}},"id":"cordova-plugin-crosswalk-webview","version":"1.3.1","name":"Crosswalk WebView Engine","description":"Changes the default WebView to CrossWalk","license":"Apache 2.0","repo":"https://github.com/crosswalk-project/cordova-plugin-crosswalk-webview","issue":"https://crosswalk-project.org/jira","keywords":["cordova","chromium","crosswalk","webview"]}},"_getAllCache":{}},"nohooks":["."]}"
Installing "cordova-plugin-crosswalk-webview" for android
Install start for "cordova-plugin-crosswalk-webview" on android.
Installing Android library: platforms/android/xwalk.gradle
  'com.google.playservices',
  'cordova-plugin-ad-chartboost',
  'cordova-plugin-google-analytics',
  'cordova-plugin-legacy-whitelist',
  'cordova-plugin-crosswalk-webview' ]
Install complete for cordova-plugin-crosswalk-webview on android.
Updating build files since android plugin contained <framework>
Generating config.xml from defaults for platform "android"
Calling plugman.prepare for platform "android"
Wrote out Android application name to "Last of the Survivors"
deleted: .../LastoftesurvivorsV4/platforms/android/res/drawable-hdpi/icon.png
deleted: .../LastoftesurvivorsV4/platforms/android/res/drawable-ldpi/icon.png
deleted: .../LastoftesurvivorsV4/platforms/android/res/drawable-mdpi/icon.png
deleted: .../LastoftesurvivorsV4/platforms/android/res/drawable-xhdpi/icon.png
copying image from .../LastoftesurvivorsV4/www/app-icon_36.png to .../LastoftesurvivorsV4/platforms/android/res/drawable-ldpi/icon.png
copying image from .../LastoftesurvivorsV4/www/app-icon_48.png to .../LastoftesurvivorsV4/platforms/android/res/drawable-mdpi/icon.png
copying image from .../LastoftesurvivorsV4/www/app-icon_72.png to .../LastoftesurvivorsV4/platforms/android/res/drawable-hdpi/icon.png
copying image from .../LastoftesurvivorsV4/www/app-icon_96.png to .../LastoftesurvivorsV4/platforms/android/res/drawable-xhdpi/icon.png
Wrote out Android package name to "com.gamessolidrock.lastofthesurvivors"
************* Processing the main config.xml file (after_prepare)  *****************
App Directory = [.../LastoftesurvivorsV4]
Will process and update the following config files:
    Config.xml = [.../LastoftesurvivorsV4/config.xml]
Namespaces:
    prefix/uri ''/'http://www.w3.org/ns/widgets'
    prefix/uri 'intelxdk'/'http://xdk.intel.com/ns/v1'
Android Manifest Namespaces:
    prefix/uri 'android'/'http://schemas.android.com/apk/res/android'
Name of the app is [Last of the Survivors]
Updating full app name to [Last of the Survivors]
Processing preference android-minSdkVersion [14]
Processing preference android-targetSdkVersion [19]
Processing preference android-installLocation [auto]
Processing preference Orientation [landscape]
    Added [{http://schemas.android.com/apk/res/android}screenOrientation] with [landscape]
Processing preference permissions
Updating the versionCode
Updating the versionName
Added [{http://schemas.android.com/apk/res/android}debuggable] with [false]
Processing config file values
Saving config.xml to [.../LastoftesurvivorsV4/config.xml]
************* Completed processing the main config.xml file (after_prepare)  *****************
Running command: .../LastoftesurvivorsV4/platforms/android/cordova/build --release
ANDROID_HOME=/Developer/android-sdk-linux
JAVA_HOME=/usr/lib/jvm/java-7-oracle
Running: .../LastoftesurvivorsV4/platforms/android/gradlew cdvBuildRelease -b .../LastoftesurvivorsV4/platforms/android/build.gradle -Dorg.gradle.daemon=true
embedded
WARNING [Project: :] Current NDK support is deprecated.  Alternative will be provided in the future.
org.xwalk:xwalk_core_library_beta:15+
FAILURE: Build failed with an exception.
* What went wrong:
A problem occurred configuring root project 'android'.
> Could not resolve all dependencies for configuration ':_armv7DebugCompile'.
   > Could not find any version that matches com.google.android.gms:play-services-analytics:+.
     Searched in the following locations:
         https://repo1.maven.org/maven2/com/google/android/gms/play-services-analytics/maven-metadata.xml
         https://download.01.org/crosswalk/releases/crosswalk/android/maven2/com/google/android/gms/play-services-analytics/maven-metadata.xml
     Required by:
         :android:unspecified
* Try:
Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
BUILD FAILED
Total time: 7.242 secs
.../LastoftesurvivorsV4/platforms/android/cordova/node_modules/q/q.js:126
                    throw e;
Error code 1 for command: .../LastoftesurvivorsV4/platforms/android/gradlew with args: cdvBuildRelease,-b,.../LastoftesurvivorsV4/platforms/android/build.gradle,-Dorg.gradle.daemon=true
Command finished with error code 8: .../LastoftesurvivorsV4/platforms/android/cordova/build --release
ERROR building one of the platforms: Error: .../LastoftesurvivorsV4/platforms/android/cordova/build: Command failed with exit code 8
You may not have the required environment or OS to build this project
    at ChildProcess.whenDone (/Developer/cordova/5.1.1/node_modules/cordova/node_modules/cordova-lib/src/cordova/superspawn.js:134:23)
    at ChildProcess.EventEmitter.emit (events.js:98:17)
    at maybeClose (child_process.js:743:16)
    at Process.ChildProcess._handle.onexit (child_process.js:810:5)
PaulF_IntelCorp
Samuel, your error is described here: https://software.intel.com/en-us/forums/intel-xdk/topic/595059
Try including the "game services" plugin from the featured list and rebuild with that. If that doesn't work, change your build settings to CLI 4.1.2 and set Crosswalk to 14.
KM_D_
I am using XDK v2893, and have the exact same issue as the first post in this thread (for iOS).
All sound effects work fine. However the music (looping) has stopped working on the XDK Emulator and on the iOS device. When I run the same game from construct 2, everything works normally. There has been no changes on the Music function and the music files (m4a and .ogg) are present in the www/media folder.
Also tried above suggestion of CLI 4.x and Crosswalk - no change. Hope someone else has music working!!
Plugins include: cordova-plugin-device, and cordova-plugin-splashscreen
== debugger note ======
Failed to load resource: The server responded with a status of 401 (unauthorized). ..../ios/www/media/bg_music.ogg Why would it be trying to load the .oog file for iOS.  All of the sounds load the m4a files.
PaulF_IntelCorp
Several Construct2 users reported issues with music files and it turned out to be something related to a Construct2 beta release. I don't recall what the specific solution was, but it was related to a Construct2 release. You might have to try exporting your app from Construct2 again.
KM_D_
The latest Construct2 beta did have issues, so I have been using the last stable release r221.
Have tried starting from scratch and re-exporting several times. Same result :(
PaulF_IntelCorp
The iOS build system was recently updated to use Xcode 7, and that has been reported to resolve some issues similar to what you are describing. Please try a new build to see if you are still experiencing this problem.
KM_D_
Thanks for the great news!
Rebuilt several iOS projects, both sounds and all music are working now!
