Software Archive
Read-only legacy content
17060 Discussions
My File Won't Open
Intel_C_Intel
I'm developing a program written in Fortran 90.
At one point i call a text file to read setup data for the program.
After editing it (i had to change a parameter) it won't open, and instead flags the error message specified in OPEN.
Any ideas?
Ronan
What is the error message?
Steve
Intel_C_Intel
THe error message was just a text box with the filename which was called by 'err=' in the open statement. I discovered that it was also called by another part of the program, but the ofiginal filename was kept. stupid huh.
but onwards:
the problem now is that after the program loads the file, it crashes with the error message:
MOVIE caused an exception 05H in module MOVIE.EXE at 015f:0040592f.
Registers:
EAX=ffffffff CS=015f EIP=0040592f EFLGS=00010296
EBX=00000000 SS=0167 ESP=0081f780 EBP=0081f810
ECX=00000020 DS=0167 ESI=0048b93c FS=5197
EDX=0000003f ES=0167 EDI=005cb1e0 GS=5476
Bytes at CS:EIP:
62 45 8c 69 15 74 e7 49 00 10 01 00 00 8b 92 ac
Stack dump:
005cb1e0 0048b93c 00000000 0048b93c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
unfotrunately, i can't find the call that's causing the crash because, if i select debug, i get another error message, this time for DFdev:
DFDEV caused an invalid page fault in
module DEVD
Intel_C_Intel
sorry, the end of my message was cut off. here's hoping:
but onwards:
Registers: EAX=ffffffff CS=015f EIP=0040592f EFLGS=00010296
ECX=00000020 DS=0167 ESI=0048b93c FS=5197 EDX=0000003f ES=0167
EDI=005cb1e0 GS=5476 Bytes at CS:EIP: 62 45 8c 69 15 74 e7 49 00 10 01 00 00 8b 92 ac Stack dump: 005cb1e0 0048b93c 00000000
Intel_C_Intel
right, third time lucky.
the first error message is in the other replies, so i won't bother repeating it.
when i select debug, i get another error message for, Dfdev this time. the contents of the message are:
module DEVDBG.PKG at 015f:50c21af0.
Registers:
EAX=00692450 CS=015f EIP=50c21af0 EFLGS=00010246
EBX=50c21abd SS=0167 ESP=0067db78 EBP=0067dc04
ECX=00692400 DS=0167 ESI=0082eb80 FS=1c67
EDX=0000010a ES=0167 EDI=00000000 GS=5ca7
Bytes at CS:EIP:
ff 92 50 01 00 00 8b 44 24 0c 83 f8 ff 89 86 a4
Stack dump:
00000000 00692450 0082eb80 00000000 5f401ed5
00000000 00000000 0082eb80 0082eb80 00550160
000c0000 169f21e6 38670000 38868bd8 38670000
00000000
What version of Visual Fortran are you using? You entered 90, which isn't right.
Try taking the ERR= off to see what the real error message is.
The DFDEV error can probably be fixed by deleting the .OPT file from your project folder.
Steve
Intel_C_Intel
Thanks heaps. removing the .opt file lets the debugger run, so hopefully i can get to the root of the problem.
The problem with the 'err=' is ok now, but cheers anyway.
ronan
