Software Archive
Read-only legacy content
17060 Discussions
My app wont show images!
Ram_Pawar
I created one small app for test, which contains some pictures (jpg, png).
I can see pictures in "Emulate" option, but can't see in my device when I test my app with "App Preview". I tried to build app too and installed .apk to device, but it still same.
Any solution? :)
Thanks!
bhavna_s_
i also had the same problem but the problem is resolved u might have not copies the whole path of the image firstly when you click on element and drag the image on the screen then go to that image and then open its properties and copy the whole path and paste there and after that include the image name now apply and your problem will be solved if any problem then you can surely ask.....:-)
PaulF_IntelCorp
Can you provide some sample code?
bhavna_s_
You might not have the images in your device in which you are running the app review. Make sure that all the images you use in your app are present in your device in the specified folder. Try to run your app after this.
Ram_Pawar
Hello Paul Fischer (Intel) & bhavna s
I've solved the problem by copying "images" folder to "www" folder! :)
BEFORE:
AFTER:
Thank you very much! :)
bhavna_s_
It was pleasure helping... :-)
all the best with ur app...:-) any problem u r free to contact.......:-)
Vihanga_A_
I created an app using App Starter, include images (SVG). I can't see any picture in Develop Tab and Emulate Tab. I used PNG and JPEG file formats too. But it didn't work. Any solutions?
Ram_Pawar
Vihanga Ashinsana try to move "images" folder to "www" folder. (you can see in my last comment)
Vihanga_A_
Got it! Thanks Ram Pawar
Vihanga_A_
Can I change the font? How do I do it?
Ram_Pawar
#1 - Select the text.
#2 - Go to "Text Styles"
#3 - Write "font-family:Georgia;" (replace font name...) And Apply!
Good luck!
Vihanga_A_
It is OK! Thanks!
Vihanga_A_
I have added a tweet widget to a page. I can see it in Develop tab but I can't see it in Emulate tab. How can I fix it?
Vidura_Dhananjaya
New Contributor II
How can I go for a database verification for my log in system.?
