Software Archive
Read-only legacy content
17060 Discussions
Need help To Run parallel Advisor
Abhishek_Raut
Hi ,
I am trying to use parallel advisor , I have downloaded and installed trial version , when I tried to run Advisor workflow I am getting following error , It happens with the also with samples provided ,
I am using Windows 7 64Bit ,Core I7 processor with 12 GB Ram, can anyone help me with running the tool >? any help / guidance ?
Error: SYSCALL_INSPECTOR: The NTDLL!NtProtectVirtualMemory function jumps out of NTDLL, at 0x3fff0078. It may be hooked by a PIN-incompatible software installed on the system Incompatible operating system or incompatible software installed on the system Failed to initialize pin common boot record Pin is exiting due to fatal error
Data collection processing end
Collection time: 00s
Error: SYSCALL_INSPECTOR: The NTDLL!NtProtectVirtualMemory function jumps out of NTDLL, at 0x3fff0078. It may be hooked by a PIN-incompatible software installed on the system Incompatible operating system or incompatible software installed on the system Failed to initialize pin common boot record Pin is exiting due to fatal error Data collection processing endCollection time: 00sData collection processing end
