Software Archive
Read-only legacy content
17060 Discussions
Vectorization of complex number operations using Cilk Plus (C++)
sheliak
Hi, during optimization of my code I found that even simple C++ std::complex operations
are not vectorized. See following code
#ifdef USE_CPP
   #include
   typedef std::complex cmplx16;
#else
   #include
   typedef complex double cmplx16;
#endif // USE_CPP
#define simd_for _Pragma ("simd") for
void sum(int Nx, int Ny, int Nz, cmplx16 A[Nx][Ny][Nz], cmplx16 B[Nx][Ny][Nz], cmplx16 C[Nx][Ny][Nz])
__assume_aligned(A,32);
__assume_aligned(B,32);
__assume_aligned(C,32);
for(int x=0; x
  C = A + B;
Compiling with icc (or icpc) to use C (complex doubles) outputs
$>  icc -c vector.cpp -vec-report=2  -O3 -mavx
outputs vector.cpp(18): (col. 54) remark: SIMD LOOP WAS VECTORIZED.
However, using C++ (std::complex), outputs
$> icc -c vector.cpp -vec-report=2 -complex-limited-range -O3 -mavx -DUSE_CPP
vector.cpp(20): (col. 29) remark: loop was not vectorized: unsupported data type.
vector.cpp(18): (col. 54) warning #13379: loop was not vectorized with "simd"
Thus obviously vectorization is not supported for C++ complex numbers but for C.
 With -guide-vec=2 I can trace the problem to
/usr/include/c++/4.4.6/complex(321): (col. 24) remark: loop was not vectorized: unsupported data type.
However, is there anyway to enable proper vectorization using some kind of pragmas or
a different libstdc++ implementation or MKL or ... ? If not, is this going to be fixed in the
near future or is the general advice to use C complex numbers in C++ code in case
of doing explicit real/imaginary part calculations is not an option ?
thanks a lot !
Paul
Knud_K_Intel
In order to get the simd loop to vectorize please try to define the simd_for macro as:
#define simd_for _Pragma ("simd vectorlength(2)") for
That should ensure the for loop operanting on complex arrays will vectorize and ensure AVX instructions are used.
The intent is to improve the simd vectorization in a product update of the Intel Composer XE 2013.
