Software Archive
Read-only legacy content
17060 Discussions
Bug in debug mode
Ashley_Weinstein
Say I have the following code:
integer :: i, j, m, n, loc1
loc1=65
m=1
n=1
j=1
DO i=1,500
    DO WHILE(j.lt.loc1)
       j=j+1
       m=m+1
       IF(n.eq.1000)
           m=0
       END IF
       n=n+1
    END DO
    j=0
END DO
The bug I'm encountering is this:
If I put a breakpoint on the line "DO WHILE (j.lt.loc1)" before 'Start Debugging' and I choose a breakpoint condition of m=1 is true, with each execution of the inner loop the debugger does not increment the variable m however the variable n increments by 1 as it should.
Has anyone else encountered this problem??
If I put m=5 before 'Start Debugging' then it will execute the inner loop properly until m=5 and n=5, then thereafter m will remain 5!
This doesn't make any sense to me...
Ashley_Weinstein
Another thing I've noticed that can happen when debugging DO loops is if I choose the DO variable counter as the breakpoint condition (e.g. i=30), then when the breakpoint is reached, the counter variable gets reset to 1!
Since no one has replied to this thread I guess I am the only person who has this problem???
