I need help on the proper step to include ngCordova into my project. I'm using XDK with Ionic blank project as seed.
I tested Ionic and AngulaJS working without problem.
But when I try to include ngCordova, my AngularJS stop working. Please see the screenshot for easier understanding.
Please point me some light, what I did wrong? Please advice.
Please help! What I did wrong here?
- Tags:
- HTML5
- Intel® XDK
Hello SithLord,
I tested move the app.js line to before body tag closing. Same error as seen below. I'm new to explore Angular and Ionic, so I didn't understand much what is this error mean. Do you have any idea? I can provide more info if you need. Thanks.
you need to include ngRoute, angular.module('IonicApp', ['ionic', 'ngCordova', 'ngRoute'] and on your index.html
<script type="application/javascript" src="https://code.angularjs.org/1.3.15/angular-route.min.js"></script>
Hi, I tried do what you advice but it's the same result.
Make sure you are using the current version of the core AngularJS library as well
<script type="application/javascript" src="https://code.angularjs.org/1.3.15/angular.min.js"></script> <script type="application/javascript" src="https://code.angularjs.org/1.3.15/angular-route.min.js"></script>
I added ng-cordova.min.js to my existing app and it broke my app with the same error. Including ngRoute resolved the problem for me so i dont know what else to try.
btw, my test was using ngCordova in a AFUI project not Ionic so its possible your issue is specific to ionic being in the mix and not just angular related.
Hope someone else have idea on what is happening here. I tried your second advice, failed with same error.
Are you able to share the code/project for people to look at?
At a minimum, no pun intended, I would recommend loading the non-minimized version of ng-cordova.js so you can actually see and report what the error is.
Also, shouldn't the library code load ahead of your app code?
Hello everyone,
I fixed the problem by adding:
var app = angular.module('myApp', ['ionic', 'ui.router', 'ngCordova']);
ui.router instead of ngRoute. Fixed. Not sure which part cause the conflict yet.
