Software Archive
Read-only legacy content
17060 Discussions
Need help to include ngCordova
Mark_Z_1
I need help on the proper step to include ngCordova into my project. I'm using XDK with Ionic blank project as seed.
I tested Ionic and AngulaJS working without problem.
But when I try to include ngCordova, my AngularJS stop working. Please see the screenshot for easier understanding.
Please point me some light, what I did wrong? Please advice.
Please help! What I did wrong here?
SithLord
Thanks for bringing the existence of ngCordova to my attention. In your last screenshot hit the icon in the top left corner that looks like a bug. Check the console of javascript errors as it may give you some indication as to what is breaking the scripts. (function () { //You may be calling angular code too quickly, try moving the app.js include to just before the close of the body tag. Plus i dont see you including the full angular.min.js lib. Does ngCordova bundle it? })(); " "
Mark_Z_1
Hello SithLord,
I tested move the app.js line to before body tag closing. Same error as seen below. I'm new to explore Angular and Ionic, so I didn't understand much what is this error mean. Do you have any idea? I can provide more info if you need. Thanks.
SithLord
you need to include ngRoute, angular.module('IonicApp', ['ionic', 'ngCordova', 'ngRoute'] and on your index.html
<script type="application/javascript" src="https://code.angularjs.org/1.3.15/angular-route.min.js"></script>
Mark_Z_1
Hi, I tried do what you advice but it's the same result.
SithLord
Make sure you are using the current version of the core AngularJS library as well
<script type="application/javascript" src="https://code.angularjs.org/1.3.15/angular.min.js"></script>
I added ng-cordova.min.js to my existing app and it broke my app with the same error. Including ngRoute resolved the problem for me so i dont know what else to  try.
btw, my test was using ngCordova in a AFUI project not Ionic so its possible your issue is specific to ionic being in the mix and not just angular related.
Mark_Z_1
Hope someone else have idea on what is happening here. I tried your second advice, failed with same error.
Adam_G_
Are you able to share the code/project for people to look at?
Barry_Johnson
At a minimum, no pun intended, I would recommend loading the non-minimized version of ng-cordova.js so you can actually see and report what the error is.
Also, shouldn't the library code load ahead of your app code?
Mark_Z_1
Hello everyone,
I fixed the problem by adding:
var app = angular.module('myApp', ['ionic', 'ui.router', 'ngCordova']);
ui.router instead of ngRoute. Fixed. Not sure which part cause the conflict yet.
