Software Archive
Read-only legacy content
17060 Discussions
Network Connected and Disconnected Events in a Forms Application
James_M_Intel1
We've had a few people ask for sample code demonstrating the use of the Intel Mobile Platfrom SDK (See: http://www.intel.com/software/products/mobileplatform) within a Windows Forms application. Note that the SDK comes with extensive sample code but it is limited to console application. For those who would like a forms app that runs on .Net v1.1 see the attached zip file. The source code shows a simple forms application that receive the connected and disconnected events and updates the GUI each time this happens.
Lester Memmott
James_M_Intel1
It looks like the forum is having trouble with attachments so here it is as text:
// _____________________________________________________________________________
// Copyright (C) Intel Corporation (2006)
// DISCLAIMER OF WARRANTY
// NEITHER INTEL NOR ITS SUPPLIERS MAKE ANY REPRESENTATION OR WARRANTY OR
// CONDITION OF ANY KIND WHETHER EXPRESS OR IMPLIED (EITHER IN FACT OR BY
// OPERATION OF LAW) WITH RESPECT TO THE SOURCE CODE. INTEL AND ITS SUPPLIERS
// EXPRESSLY DISCLAIM ALL WARRANTIES OR CONDITIONS OF MERCHANTABILITY OR
// FITNESS FOR A PARTICULAR PURPOSE. INTEL AND ITS SUPPLIERS DO NOT WARRANT
// THAT THE SOURCE CODE IS ERROR-FREE OR THAT OPERATION OF THE SOURCE CODE WILL
// BE SECURE OR UNINTERRUPTED AND HEREBY DISCLAIM ANY AND ALL LIABILITY ON
// ACCOUNT THEREOF. THERE IS ALSO NO IMPLIED WARRANTY OF NON-INFRINGEMENT.
// SOURCE CODE IS LICENSED TO LICENSEE ON AN "AS IS" BASIS AND NEITHER INTEL
// NOR ITS SUPPLIERS WILL PROVIDE ANY SUPPORT, ASSISTANCE, INSTALLATION,
// TRAINING OR OTHER SERVICES. INTEL AND ITS SUPPLIERS WILL NOT PROVIDE ANY
// UPDATES, ENHANCEMENTS OR EXTENSIONS.
using
System;
using
System.Drawing;
using
System.Collections;
using
System.ComponentModel;
using
System.Windows.Forms;
using
System.Data;
using
Intel.Mobile.Base;
using
Intel.Mobile.Context;
namespace
EventFormSample
/// Summary description for Form1.
public class Form1 : System.Windows.Forms.Form
private System.Windows.Forms.Label label1;
private System.Windows.Forms.Label Label_Status;
public System.Windows.Forms.TextBox textBox_info;
private ContextClass myClass;
private System.Windows.Forms.Label label2;
public static EventObserver m_clObserver;
/// Required designer variable
private System.ComponentModel.Container components = null;
public Form1()
// Required for Windows Form Designer support
InitializeComponent();
// TODO: Add any constructor code after InitializeComponent call
/// Clean up any resources being used.
protected override void Dispose( bool disposing )
if( disposing )
if (components != null)
components.Dispose();
base.Dispose( disposing );
#region
Windows Form Designer generated code
/// Required method for Designer support - do not modify
/// the contents of this method with the code editor.
private void InitializeComponent()
this.label1 = new System.Windows.Forms.Label();
this.Label_Status = new System.Windows.Forms.Label();
this.textBox_info = new System.Windows.Forms.TextBox();
this.label2 = new System.Windows.Forms.Label();
this.SuspendLayout();
// label1
this.label1.Location = new System.Drawing.Point(16, 16);
this.label1.Name = "label1";
this.label1.Size = new System.Drawing.Size(40, 23);
this.label1.TabIndex = 0;
this.label1.Text = "Status:";
// Label_Status
this.Label_Status.Location = new System.Drawing.Point(64, 16);
this.Label_Status.Name = "Label_Status";
this.Label_Status.TabIndex = 1;
// textBox_info
this.textBox_info.Location = new System.Drawing.Point(16, 72);
this.textBox_info.Multiline = true;
this.textBox_info.Name = "textBox_info";
this.textBox_info.ScrollBars = System.Windows.Forms.ScrollBars.Horizontal;
this.textBox_info.Size = new System.Drawing.Size(256, 152);
this.textBox_info.TabIndex = 2;
this.textBox_info.Text = "";
// label2
this.label2.Location = new System.Drawing.Point(16, 48);
this.label2.Name = "label2";
this.label2.Size =
new System.Drawing.Size(100, 16);
this.label2.TabIndex = 3;
this.label2.Text = "Event Log :";
// Form1
this.AutoScaleBaseSize = new System.Drawing.Size(5, 13);
this.ClientSize = new System.Drawing.Size(292, 238);
this.Controls.Add(this.label2);
this.Controls.Add(this.textBox_info);
this.Controls.Add(this.Label_Status);
this.Controls.Add(this.label1);
this.Name = "Form1";
this.Text = "EventTestForm";
this.Closing += new System.ComponentModel.CancelEventHandler(this.Form1_Closing);
this.Load += new System.EventHandler(this.Form1_Load);
this.ResumeLayout(false);
#endregion
/// The main entry point for the application.
[MTAThread]
static void Main()
Application.Run(
new Form1());
private void Form1_Load(object sender, System.EventArgs e)
try
myClass =
new ContextClass();
ConnectivityInstance myInstance = (ConnectivityInstance) myClass.GetInstance("Co nnectivity");
m_clObserver =
new EventObserver();
myInstance.Connected.AddObserver( m_clObserver );
myInstance.Disconnected.AddObserver( m_clObserver );
Label_Status.Text = myInstance.IsConnected.GetValue()?"Connected":"Disconnected";
m_clObserver.MyEvent +=
new EventObserver.MyEventHandler(EventHandler);
catch (IntelMobileException ex)
MessageBox.Show(Form.ActiveForm, "Message: " + ex.Message, "Exception" );
private void Form1_Closing(object sender, System.ComponentModel.CancelEventArgs e)
ConnectivityInstance myInstance = (ConnectivityInstance) myClass.GetInstance("Connectivity");
myInstance.Connected.RemoveObserver( m_clObserver );
m_clObserver.Close();
private void EventHandler(bool bStatus, String sInfo)
textBox_info.AppendText( sInfo );
textBox_info.AppendText( " " );
Label_Status.Text = bStatus?"Connected":"Disconnected";
public class EventObserver : Observer
public delegate void MyEventHandler(bool bStatus, String sInfo);
public event MyEventHandler MyEvent;
public override void Notify(Event ev)
try
if ( ev.GetType() == EventBase.EventType.eConnected )
MyEvent(
true, ev.GetTSstring() + " Connected event occurred for " + ev.GetOriginator().GetType() );
if ( ev.GetType() == EventBase.EventType.eDisconnected )
MyEvent (
false, ev.GetTSstring() + " Disconnected event occurred for " + ev.GetOriginator().GetType() );
