Software Archive
Read-only legacy content
Network access issue on Android
Aya_S_
Same issue here, can't access network through android phone
XDK 2893
Available cordova CLI versions are 5.1.1 and 4.1.2
does any one have any idea about what is the problem with this version??
Swati_S_Intel1
@Aya, please provide more details. When you say can't access network, is AJAX not working? or any other error?
Please post the screen shots of the errors you are getting. Also, provide the Android OS version and what build are you using Android/Crosswalk.
Aya_S_
@SWATI
Weirdly, I was trying to switch between CLI versions to recreate the issue for you and it worked for both cases, and am not pretty sure that it was a false alarm as i tested it several times before posting the issue, any suggestions??
Thanks for your instant support
Swati_S_Intel1
Glad it worked for you. Not sure what you might have done earlier. May be you did not upgrade or downgrade the project and associated plugins properly. Let me know if you come across this issue again.
Aya_S_
@SWATI I had an unstable network, i guess that was the problem
