Software Archive
Read-only legacy content
17060 Discussions
No network support enabled/configured when you build from yocto meta-intel-iot-devkit
Gary_C_
When a user tries to build yocto image based on the following docs the Network support is not configured or plumbed to "eth0"
http://software.intel.com/sites/default/files/managed/f1/49/building_yocto_and__ipks.pdf
Built with "bitbake iot-devkit-prof-dev-image"
root@clanton:~# cat /proc/version
Linux version 3.8.7-yocto-standard (gmcollin@haro) (gcc version 4.8.1 (GCC) ) #1 Mon Apr 14 12:29:48 PDT 2014
root@clanton:~# ifconfig -a
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:12 errors:0 dropped:0 overruns:0 frame:0
          TX packets:12 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:892 (892.0 B)  TX bytes:892 (892.0 B)
Tom_Ingleby_Intel
What firmware do you have on your Galileo?
Also did you build from sstate download or from git sources. If git, which branch did you build from.
Gary_C_
I updated it last week. Running Arduino 1.5.3.
Built from git sources fails with networking.  The 4.5gb sstate version works fine.
This is the steps I use to create a repo.
git clone git://git.yoctoproject.org/meta-intel-iot-devkit
 cd meta-intel-iot-devkit/
source iot-devkit-init-build-env
