Software Archive
Read-only legacy content
17061 Discussions
No shows the properties of controls
Manu_M_
Hi again,
I have a new problem with Intel XDK...
While I'm working in some projects, there comes a time when I select a control, its propierties don't appear in the propierties window (in design mode). In this case, when I create a new control, I can change its propierties in its window, but when I deselect and select again.. I can't...
This problem has occurred on several projects...
I attach an image where you can see what I say
Amrita_C_Intel
Hello Manu,
Which Version of Intel XDK are you using?
-Amrita
Manu_M_
Hi Amrita,
I use 1878
Chris_P_Intel
 Interesting. Clicking the item isn't selecting it.
On the main toolbar when in Design mode there is a Refresh/Reload button. (The one with two arrows).  Click that and the Design mode will reload itself and your document.  That should work around the issue.
If you can get this issue to be repeatable, then let us know how to fully repeat and we can try to get to the bottom of it.
