Software Archive
Read-only legacy content
17060 Discussions
Noob question r.e
GingerGeek
This is the code:
function apiCall(action, params) {
    var callURL = siteURL + apiURL + "action=" + action + "&" + params, xmlHttp = null;
    xmlHttp = new XMLHttpRequest();
    xmlHttp.open("GET", callURL, false);
    xmlHttp.send();
    return xmlHttp.responseText;
This is the error:
Uncaught NetworkError: A network error occurred. /C:/Users/MYUSERNAME/AppData/Local/Intel/XDK/xdk/components/client/emulator/ripple.js:60282
(anonymous function) /C:/Users/MYUSERNAME/AppData/Local/Intel/XDK/xdk/components/client/emulator/ripple.js:60282
apiCall gingerlib.js:17
doLogin gingerlib.js:26
onclick index.html:79
GingerGeek
bump
PaulF_IntelCorp
Sorry, but not much to go on with the info you've provided. Does this work in a standard browser? Did you try it using an Android 4.x device attached with USB and using the Debug tab? Nothing about your code is XDK-specific. Was your network connection working when you performed the test?
GingerGeek
When run on the device, using debug it does nto work causing a Network Error.
Network connections was up
It just seems like the XMLHttpRequest does not work with Intel XDK at all :(. This is the app header:
<meta http-equiv="Content-type" content="text/html; charset=utf-8">
<meta name="viewport" content="width=device-width, initial-scale=1, maximum-scale=1, user-scalable=0">
<meta name="apple-mobile-web-app-capable" content="yes">
<script src="intelxdk.js"></script>
<script src="xhr.js"></script>
<meta http-equiv="Pragma" content="no-cache">
<script type="text/javascript" charset="utf-8" src="intelxdk.js"></script>
<script type="text/javascript" src="js/gingerlib.js"></script>
<script type="text/javascript" language="javascript">
    // This event handler is fired once the intel libraries are ready
    function onDeviceReady() {
        //hide splash screen now that our app is ready to run
        intel.xdk.device.hideSplashScreen();
        setTimeout(function () {
            $.ui.launch();
        }, 50);
    //initial event handler to detect when intel is ready to roll
    document.addEventListener("intel.xdk.device.ready", onDeviceReady, false);
</script>
<script type="text/javascript" style="">
</script>
<script src="js/appframework.ui.min.js"></script>
<script>
    $.ui.autoLaunch = false;
    $.ui.useOSThemes = true; //Change this to false to force a device theme
    $.ui.blockPageScroll();
    $(document).ready(function () {
        //if ($.ui.useOSThemes && !$.os.ios && $("#afui").get(0).className !== "ios")
          //  $("#afui").removeClass("ios");
</script>
<link href="css/icons.css" rel="stylesheet" type="text/css">
<link href="css/af.ui.css" rel="stylesheet" type="text/css">
That function was in gingerlib.js
PaulF_IntelCorp
Put your code inside the onDeviceReady() function, otherwise it will run before the underlying XDK subsystem is ready.
GingerGeek
It is only intitiated on a user clicking a button, so it can't be before onDeviceReady().
PaulF_IntelCorp
Your inclusion of gingerlib.js must contain code that is getting executed and causing the error before the underlying device and xdk JS files are ready. Turn your gingerlib.js file into definition code, only and put the init code inside of it into onDeviceReady().
GingerGeek
I've changed some stuff around:
This is my header:
<head>
<script>
window['_native_XMLHttpRequest'] = window.XMLHttpRequest; // xhr.js store it too, but for good measure we do it on our own
</script>
    var isIntel=window.intel&&window.intel.xdk
            $.ui.launch();
        }, 50);
</script>
<script>
    if(isIntel)
        if ($.ui.useOSThemes && (!$.os.ios||$.os.ios7))
</script>
<script src="js/myScript.js" type="text/javascript"></script>
</head>
Then, this is a fucntion in my Javascript file myScript
    var callURL = siteURL + apiURL + "action=" + action + "&" + params;
    xmlHttp = null;
    xmlHttp = new window['_native_XMLHttpRequest'];
    xmlHttp.onreadystatechange = function() {
        if (xmlHttp.readyState == 4) {  //Request is complete
            if(xmlHttp.status == 200) {  //Response is ready
                alert("Request succeeded. Data:  "+xhr.responseText);
            } else {
                alert("NetError:"+xmlHttp.readyState+" "+xmlHttp.status);
                return null;
    xmlHttp.send(null);
I always get "NetError: 4 0"
The only thing in the init of the Javascript file is declaring two variables.
PaulF_IntelCorp
Are you able to build a test version that removes the suspect libraries and then add them back, one by one (or remove, one by one) to determine which might be causing the problem? The trouble is there are many unknowns in your code, so it needs to be isolated before we can really start to provide a fix.
