Software Archive
Read-only legacy content
17061 Discussions
Not registering ios device, Showing error "ReferenceError: Can't find variable: PushNotification" while debugging
mohneesh_b_
Developing cross platform app for android and ios.
Cordova cli version : 5.1.1
Push Plugin Version : 1.4.3
IOS Device: Iphone OS v 9.3
I am using plugin push from featured plugin for push notification.
Not getting token, when app launch, Showing error "ReferenceError: Can't find variable: PushNotification" while debugging on ios device. It is working on android very well.
Please guide me where am I doing wrong. If any process for ios implementation is available for this plugin Please share with example.
Pamela_H_Intel
Moneesh,
There have been a lot of updates to PhoneGap Push Notifications plugin since 1.4.3 related to iOS. We cannot feature the latest version because it includes a gradle script. However, I think you need a more recent version. Try the following:
  • Remove push 1.4.3 from your project using the Plugin Manager
  • Download the zip of the push plugin 1.6.4: https://github.com/phonegap/phonegap-plugin-push/archive/1.6.4.zip
  • in the plugin.xml file, comment out this line: <framework src="push.gradle" custom="true" type="gradleReference" />
  • then import the plugin as a local plugin
This should work better with iOS9.
After doing this and testing iOS, test Android again.
NOTE: If Android no longer works it is likely because the gradle script points to a specific Android version v4:23.4.0. We think that is a minimum which will be okay, and you're good. But if not, you can post back here so we can remember what happened and what the probable cause is.
mohneesh_b_
Dear Pamela,
Thanks for your time on this issue.
I followed your given instructions but getting same error now.
Please let me know if I am doing anything wrong.
