Software Archive
Read-only legacy content
17060 Discussions
Notebook s-video output and RCA TV
aeolis
Hi folks,
Well, I have bought a HP DV2255BR notebook with a s-video TV output, but all my TV's are RCA. The video board is a Intel GMA 950 and it does not offer through the driver interface to force TV detection as many video boards allow nowadays. So, is there a way to make it work? Maybe a registry hack to create a "TV" and force the board to send signal? I have bought the right cables to a s-video input and a RCA output, but I still don't have a picture on my TV. Can somebody help?
See you later,
Aeolis
aeolis
Hi folks,
Anybody help?! Please, isn't there any registry switches or hidden options in the control panel to solve this problem and force the video card sending signal even if the TV is not detected? Guys I need you help.
See you later,
Aeolis
sergey_holod
Hi, Aeolis!
The same problem with HP 6710b, but I just have long s-video cable, about 7 meters. I had to check "Force TV Detection" in ATi's setting in the previous notebook and It'd just worked. Now I don't know hot to do the same with Intel's X3100.
skipper2040
I have the same problem with my laptop toshiba 100A and a tft tv monitor 7" mustek
My pc dont see my tv monitor , when i connect a bigtv is it playing normal.
By other graphic cards ATI and Nvidea is there a software solution with a forcing tv out.
Please help.
I try with a condenser from 470 pF over pin 3 and 4 from the s-video conector without succes.
tom_ye
I'm having the same problem with my Lenovo Y410. it has Mobile Intel 965 video board.
If anyone know how to solve the problem please help.
gsholtz
My HP has a spot for S- Video, What do I need to fill it.
assilabox
Hi all,
I having the same problem with HP 2742se and 6510b. How to FORCE TV Detection ?
I need you help.
thelonelywolf
Hi All.
I have the same problem, my notebook Acer Aspire 5315 with Intel GMA 965 graphics card can not obnoruzhit TV using adapter S-Video -> RCA. (Another TV can).
I found one solution as the TV Wizsrd leery bust of options, but it is activated in BW mode. If it's possible to do what it was normal
