Hi Everybody,
I have found a UPnP Libraty UPnPLib (http://www.sbbi.net/site/upnp/) to discover and interact with UPnP Device. Now I am trying to Create a Object in Intel UPnP AV Server by using this library. But when I try to invoke CreateObject action by giving ContainerID and Elements in input I am getting back the following SOAP error.
xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"
s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
s:Client
UPnPError
402
Argument [DIDL-Lite] : Object reference not set to an instance of an object.
I am using this DIDL-Lite file
xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"
xmlns:dc="http://purl.org/dc/elements/1.1/"
xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/">
Nothing Else Matters
object.item.audioItem.musicTrack
Metallica
UNKNOWN
importURI="http://192.168.0.199:60968/MediaServerContent_0/2/0000000000000007/">
http://192.168.0.199:60968/MediaServerContent_0/2/0000000000000007/Metallica%20-%20The_Unforgiven.mp3
importURI="http://192.168.67.1:59616/MediaServerContent_0/2/0000000000000007/">
http://192.168.67.1:59616/MediaServerContent_0/2/0000000000000007/Metallica%20-%20The_Unforgiven.mp3
Nice song of Metallica English
Metal
and the input parameter for ContainerID is 0000000000000005. If I use Intel Device Spy with this same ContainerID and DIDL-Lite description then the object creation is working properly. But from my Java Program this is not working.
I am also sending the Java Code . I appreciate if anybody can help me anyway.
package com.philips.research.my.test;
import java.io.BufferedInputStream;
import java.io.DataInputStream;
import java.io.File;
import java.io.FileInputStream;
import java.io.FileNotFoundException;
import java.io.IOException;
import java.io.ObjectInputStream;
import net.sbbi.upnp.Discovery;
import net.sbbi.upnp.devices.UPNPRootDevice;
import net.sbbi.upnp.messages.ActionMessage;
import net.sbbi.upnp.messages.ActionResponse;
import net.sbbi.upnp.messages.UPNPMessageFactory;
import net.sbbi.upnp.messages.UPNPResponseException;
import net.sbbi.upnp.services.UPNPService;
public class TestUPnPServer
public static void main(String[] args) {
new TestUPnPServer();
public TestUPnPServer()
try
String st = "urn:schemas-upnp-org:device:MediaServer:1";
UPNPRootDevice[] rootDevice = Discovery.discover(st);
if ( rootDevice != null )
for ( int i = 0; i < rootDevice.length; i++ ) {
System.out.println( "Found device "
+ rootDevice.getModelName());
File file = new
File("C:\Dump_Factory\RAClient\MetaData\DIDL.txt");
FileInputStream fis = null;
BufferedInputStream bis = null;
DataInputStream dis = null;
StringBuffer body = new StringBuffer(256);
try
fis = new FileInputStream(file);
bis = new BufferedInputStream(f is);
dis = new DataInputStream(bis);
while (dis.available() != 0) {
body.append(dis.readLine());
body.trimToSize();
// dispose all the resources after using them.
fis.close();
bis.close();
dis.close();
} catch (FileNotFoundException e) {
e.printStackTrace();
} catch (IOException e) {
System.out.println(body);
/* FileInputStream f_in = new FileInputStream
("C:\Dump_Factory\RAClient\MetaData\MetaData.xml");
ObjectInputStream obj_in = new ObjectInputStream(f_in);
Object obj = obj_in.readObject ();
System.out.println(obj.toString());*/
String srvURN = "urn:schemas-upnp-org:service:ContentDirectory:1";
UPNPService contentDirectory = rootDevice[0].getService(srvURN);
//System.out.println(contentDirectory.getAvailableActionsName());
if (contentDirectory != null )
// System.out.println( "Service ID " +
// contentDirectory.getServiceId() );
UPNPMessageFactory factory =
UPNPMessageFactory.getNewInstance(contentDirectory);
ActionMessage action =
factory.getMessage("CreateObject");
/* ActionMessage action1 =
factory.getMessage( "DestroyObject" );
action1.setInputParameter
("ObjectID", "0000000000000006");
ActionResponse resp1 = action1.service();
//System.out.println(resp1.toString());
if ( action != null ) {
// setting the input params
action.setInputParameter
("ContainerID", "0000000000000005");
("Elements", body);
try
ActionResponse resp = action.service();
System.out.println(resp.getOutActionArgumentValue("ObjectID"));
System.out.println(resp.getOutActionArgumentValue("Result"));
} catch ( UPNPResponseException respEx )
respEx.printStackTrace();
} catch ( IOException ioEx ) {ioEx.printStackTrace();
} catch (Except ion e) {
Best regards
Yeasin Habib
try
File file = new
try
body.trimToSize();
fis.close();
bis.close();
dis.close();
("Elements", body);
try
Best regards
Yeasin Habib
![](/skins/images/D3C0B914909A6564BBB97F4AD1ED1973/responsive_peak/images/icon_anonymous_message.png)
