Software Archive
Read-only legacy content
17060 Discussions
Obtaining older versions of icc/mkl (intel c++ composer xe for linux)
John_Naliboff
Hello all,
I recently purchased the intel c++ composer xe for linux. I complied my codes successfully with mkl and icc, but unfortunately one of the codes is having PARDISO solver errors). Based on discussions with other folks using the same codes, it seems this is likely related to the most recent icc/mkl versions.
As such, I'm wondering if it possible to download older versions of icc/mkl and if this is indeed possible, who at intel I should contact about this.
Cheers,
John
Krishna_R_Intel
You can logon to the Intel Registration Center: https://registrationcenter.intel.com and view your product subscription history. Select the desired product and you should be able to choose the desired version.
If say you don't find the version that you want, please post back to this thread. I will run it by the team that handles downloads and learn how to proceed.
Krishna
John_Naliboff
Thanks Krishna, I'm now downloading an older version. Thank you for the prompt assitance!
Cheers,
John
