Software Archive
Read-only legacy content
17061 ディスカッション
Offload compilation using -tbb fails with "ld: cannot find -ltbb"
jiri
新規コントリビューター I
2,874件の閲覧回数
We have just upgraded to Composer XE 2013 SP1 and I can no longer do offload compilation of even a simple program.
I have included the variables script (compilevars.sh intel64) and the values of those variables look OK. However, if I take the following file:
[cpp]
#include <iostream>
int main()
        int i;
        #pragma offload target(mic:0)
                i=1;
        std::cout<<i<<std::endl;
[/cpp]
and try to compile it using "icc -tbb empty.cpp" then I get "ld: cannot find -ltbb". If I remove the pragma offload and run the same command, it is OK. Without the pragma, even "icc -mmic -tbb -lpthread empty.cpp" works just fine. Everything works when I go back to the previous version of the compiler.
What am I doing wrong? Has anyone seen the same issue?
0 件の賞賛
21 返答(返信)
Kevin_D_Intel
従業員
294件の閲覧回数
The MKL/TBB run-time issue (DPD200383051) noted in reply #9 is fixed in the Composer XE 2013 SP1 Update 2 (Version 14.0.2.144) release.
The erroneous warning #3441 discussed in replies #10 & #11 has not been addressed yet but the internal tracking id has been changed to the new id below.
(Internal tracking id: DPD200253687 - warning #3441)
返信
