Software Archive
Read-only legacy content
17060 Discussions
Offload error: process on the device 0 was terminated by signal 11 (SIGSEGV)
Dave_O_
I have the error message: offload error: process on the device 0 was terminated by signal 11 (SIGSEGV)
Compiler flags:
     icc $(SOURCES) -lOpenCL -fopenmp -O3
Offload code:
void Convolution_Serial_Offload_ExplicitMemCopy(float * pInput, float * pFilter, float * pOutput,
          const int nInWidth, const int nWidth, const int nHeight,
          const int nFilterWidth)
#pragma offload target(mic) in(pInput:length(nInWidth*nInWidth)) in(pFilter:length(nFilterWidth*nFilterWidth)) inout(pOutput:length(nWidth*nHeight))
//explict copying of data from host to MIC at start
    for (int yOut = 0; yOut < nHeight; yOut++)
        const int yInTopLeft = yOut;
        for (int xOut = 0; xOut < nWidth; xOut++)
            const int xInTopLeft = xOut;
            float sum = 0;
            for (int r = 0; r < nFilterWidth; r++)
                const int idxFtmp = r * nFilterWidth;
                const int yIn = yInTopLeft + r;
                const int idxIntmp = yIn * nInWidth + xInTopLeft;
#pragma ivdep                                                            //discards any data dependencies assumed by compiler
#pragma vector aligned                                                    //all data accessed in the loop is properly aligned
                for (int c = 0; c < nFilterWidth; c++)
                    const int idxF  = idxFtmp  + c;
                    const int idxIn = idxIntmp + c;
                    sum += pFilter[idxF]*pInput[idxIn];
            const int idxOut = yOut * nWidth + xOut;
            pOutput[idxOut] = sum;
    //end MIC offload: explict copying of data from MIC to host at finish
What could be the problem when I call this function from host?
Dave
Frances_R_Intel
This looks like it is the same alignment issue as in http://software.intel.com/en-us/comment/1785377. If there is something else going on here that needs to be looked at, please let us know.
