Software Archive
Read-only legacy content
17060 Discussions
Offload error
chavhan__hitesh
I am trying to offload a part of code and using 3 arrays of dimensions (14000*3600)
but this is giving some error related to system calls if I reduce the size of arrays to 1400*360 the code works fine
HOST--ERROR:myoiOSSetPageAccess: mprotect failed!
 Please increase the maximum of memory map areas
        i.e. echo 256000 > /proc/sys/vm/max_map_count
offload error: process on the device 0 unexpectedly exited with code 1
HOST--ERROR:myoiThreadMutexDestroy1: Fail to destroy a mutex (0x18762b8)! error: 16
HOST--ERROR:myoiOSDetachSharedMemory: shmdt failed: Invalid argument
HOST--ERROR:myoiOSDestroySharedMemory: shmctl failed: Invalid argument
Sumedh_N_Intel
Hi Hitesh,
Can you please share a reproducer for this issue. Also which version of the compiler and the MPSS are you using?
chavhan__hitesh
compiler version is 14.0.1
I am not able to find out the MPSS version
also I compiled the code natively it works fine .
Sumedh_N_Intel
Hi Hitesh,
Can you please share the code with us as well?
thanks,
Sumedh
chavhan__hitesh
#include "omp.h"
#include <cilk/cilk.h>
#include <cilk/cilk_api.h>
#include "offload.h"
#define SQUARE(i) i*i
#define mina(a,b) (((a)<(b)) ? (a) : (b))
 _Cilk_shared int  foo(int, int, int, int, int, int, float _Cilk_shared  ** a , float _Cilk_shared ** b, float _Cilk_shared ** c );
float  _Cilk_shared ** a1;
float _Cilk_shared ** b1;
float  _Cilk_shared ** c1;
int main(int argc, char* argv[])
    //printf("before the code ");
    int i,j,bx,bz,halfLength;
     int nx,nz,ITER;
     int thrd;
    halfLength=2;
    nx=14000+halfLength*2;
    nz=3600+halfLength*2;
    if(argc < 2)
        printf("Error !!! Give number of threads to be spawned . \n");
        exit(-1);
    sscanf(argv[1],"%d",&thrd);
    sscanf(argv[2],"%d",&bx);
    sscanf(argv[3],"%d",&bz);
    //printf("%s %d \n",__FILE__,__LINE__);
    //-----------------------------Aligned memory allocation-------------------------------------------------------
     a1=(float  _Cilk_shared **)_Offload_shared_aligned_malloc(sizeof(float *)*nx,64);
     b1=(float  _Cilk_shared **)_Offload_shared_aligned_malloc(sizeof(float*)*nx,64);
     c1=(float  _Cilk_shared **)_Offload_shared_aligned_malloc(sizeof(float*)*nx,64);
    for( i=0;i<nx;i++)
        a1=(float  _Cilk_shared *)_Offload_shared_aligned_malloc(sizeof (float)*nz,64);
        b1=(float  _Cilk_shared *)_Offload_shared_aligned_malloc(sizeof (float)*nz,64);
        c1=(float  _Cilk_shared *)_Offload_shared_aligned_malloc(sizeof (float)*nz,64);
    #pragma omp parallel for private(i,j)
    for(i=0;i<nx;i++)
        for(j=0;j<nz;j++)
            a1=2.0f;
            b1=2.0f;
            c1=2.0f;
    _Cilk_offload_to(1) foo(thrd, nx, nz, bx, bz, halfLength,  a1,  b1,  c1);
    for(i=0;i<nx;i++){
    _Offload_shared_aligned_free(a1);
    _Offload_shared_aligned_free(b1);
    _Offload_shared_aligned_free(c1);
return 0;
 _Cilk_shared  int foo(int thrd, int nx, int nz, int bx, int bz, int halfLength, float _Cilk_shared **  a, float  _Cilk_shared  **  b, float  _Cilk_shared
**   c){
 int ii,jj,i,j;
printf("total thread=%d",thrd);
        __assume_aligned(a,64);
        __assume_aligned(b,64);
        __assume_aligned(c,64);
    omp_set_num_threads(thrd);
    #pragma omp parallel for  private (ii,jj,i,j) schedule(dynamic,1)
    for(ii=2;ii<nx-halfLength*2;ii+=bx)
        for(jj=2;jj<nz-halfLength*2;jj+=bz)
            for(i=ii;i<mina(bx+ii,nx-halfLength);++i)
                                #pragma simd
                for(j=jj;j<mina(bz+jj,nz-halfLength);++j)
                    a =b+c;
return 0;
Amanda_S_Intel
Thanks for the test code. I can reproduce the error. When I compile natively (with -mmic) I still run into compilation errors and cannot make it work. What compiler options did you use for both offload and native compilations?
chavhan__hitesh
For running the code in offload model I am not using any compiler options .Is there any specific option that I should use?
I am using
icc -openmp <name_of_program >  thats it no compiler options
when code was not cilk shared I compiled it natively using -mmic -openmp -03 -ansi-alias but mine worked fine .
Amanda_S_Intel
Thanks for the update. This looks similar to a known issue, but I still need to investigate further to confirm this. I will provide more information soon.
chavhan__hitesh
CARD--ERROR:1 myoiPageFaultHandler: (nil) Out of Range!
CARD--ERROR:1 _myoiPageFaultHandler: (nil) switch to default signal handle
CARD--ERROR:1 Segment Fault!
CARD--ERROR:1 CARD--ERROR:1 myoiPageFaultHandler: (nil) Out of Range!
Segment Fault!
inside the function
total procs=236CARD--ERROR:1 CARD--ERROR:1 CARD--ERROR:1 CARD--ERROR:1 CARD--ERROR:1 myoiPageFaultHandler: (nil) Out of Range!
Segment Fault!
inside the function
Segment Fault!
HOST--ERROR:myoiScifGetRecvId: Call recv() Header Failed ! for source: 1, errno = 104
HOST--ERROR:myoiScifSend: Call send() Failed! errno = 104
HOST--ERROR:myoiSend: Fail to send message!
HOST--ERROR:_myoiWatchdogDaemon: could not send to target: 1
same code is now showing new error.no change in the code done .
Kevin_D_Intel
Please refer to the response here for more details and a resolution.
