Software Archive
Read-only legacy content
17060 Discussions
Opcode unsupported
Ioannis_P_
I have installed Intel Compiler 15.0.1.148 and MPSS 3.4.7 on Windows.
I try to compile my application natively for Xeon Phi (using /Qmic) but I get lots of errors like this:
C:/Program Files/Intel/MPSS//k1om-mpss-linux/usr/include/c++/iostream(75): (col. 25) error #13393: Opcode unsupported on target architecture: movdqa
Note: I get similar "Opcode unsupported" error when compiling on Linux for native Xeon Phi build (-mmic) using Intel Compiler 15 6th update and MPSS 3.7.
Any ideas how to solve this?
Loc_N_Intel
It means the operation MOVDQA in the machine  language is not supported. Is it possible that you post your code and how do you compile it? Thanks.
Ioannis_P_
Hi and thanks,
the code is pretty big to show for this case but I can show something small that gives the same problem:
#include <float.h>
template <class T>
class limits
    public:
        static inline T Min() { return 0; }
        static inline T Max() { return 0; }
        static inline T Epsilon() { return 0; }
template <>
class limits<float>
    public:
        static inline float Min() { return FLT_MIN; }
        static inline float Max() { return FLT_MAX; }
        static inline float Epsilon() { return FLT_EPSILON; }
static const float PrecisionMax=limits<float>::Max();
I get the same Opcode unsupported error at the line that defines PrecisionMax.
The program is compiled with /Qmic & intel compiler.
Best wishes
Kevin_D_Intel
I cannot reproduce this. I am not exactly aligned with your MPSS but given you reproduced this across Windows/Linux with different MPSS and compilers makes me think I should be able to reproduce this with combinations I have. On Windows under MPSS 3.5.37182.0, with PSXE 2015 Update 1, I cannot reproduce the error.
C:\u629126> icl /Qmic -c  u629126.cpp
Intel(R) C++ Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0.1.148 Build 20141023
Copyright (C) 1985-2014 Intel Corporation.  All rights reserved.
Can you show us the actual compile line or at least the compiler options used. Is anything more than /Qmic (-mmic) used?
Ioannis_P_
To be absolutely honest with you, I reduced the code to only a small part but didn't check whether there was still error emitted. I am actually glad that you couldn't reproduce it meaning that I must be doing something wrong on my side.
Let me test to see if I can find a small code sample that does not compile.
