- Tags:
- Android* OS
Hi Vipin,
I'm not aware of any existing method to do so. You can reduce the clock speed if you have root access but this is all what I know is working.
If you want to do experiments we have a program called Mobile Development Kit (MDK). At the moment only two Dell devices are supported. For MDK supported devices you can unlock your boot loader and you get full sources to recompile the OS.
Even if you have your own Kernel with the required patches for dvfs I'm not sure if the firmware will support overclocking or undervolting. So it might be a lot of effort without any result.
Alex
Hi Vipin,
if you are working directly with an OEM and receiving unlocked devices and sources from them you should ask your questions to Intel through this OEM. The Intel Support team for this OEM knows the configuration of the device and firmware.
Unfortunately this forum might not really help you.
Alex
