I downloaded and installed ..Composer 2011 XE and saw PDF version of the tutorials. Then I installed
a second time due to problems with my licens number and now I can't see the PDF versons, only the HTML
ones. Where can I get the PDF documents?
Best regards
AS
Best regards
AS
Thanks for using the forum to submit your issue. I will get back to you soon on this one.
Krishna
Krishna
You can find pdf versions of the same from the below links:
Hope that helps.
Neither of these links are any good now.
This is the current link for documentation:
https://software.intel.com/en-us/intel-software-technical-documentation
In addition, product documentation can be found in the Documentation folder under installation folder such as C:\Program Files\Intel\Composer XE 2011 SP1
Devorah Hayman
Intel® Developer Support
