Software Archive
Read-only legacy content
PMC CONTROLLER
MVeer2
Dear all,
This is Muhilan Veerarasu from India. This code is my own design. I referred following for 8-series PCH ACPI.
Manual:- Intel 8-series-chipset-pch-datasheet.pdf
Chapter:- 5 - Functional description
Sections:- 1. 5.14 - Power management
                 2. 5.14.7.2 - Initiating sleep state.
                 3. 12.1.13 - ACPI BASE ADDRESS REGISTER
                 4. 18.8.3 - Power Management I/O Registers
And i designed following code for 8-series PCH Motherboards.
_BtLdrTurnOffPC:
push ax
push bx
push cx
push dx
push si
push di
push ds
push es
cli
mov eax,0x8000F840; Bus 0, Device 31, Function 0, Offset 0x40
mov dx,0x0CF8
out dx,eax
mov dx,0x0CFC
in ax,dx
and ax,0xFFFE
mov dx,ax
add dx,0x0004
mov eax,0x00003C00
out dx,eax
pop es
pop ds
pop di
pop si
pop dx
pop cx
pop bx
pop ax
ret
In the above code, I directly fetch APM Base address register and turn off PC. However, From Intel 100-series PCH onwards, PMC has be moved to new PCI Bus location.
I modified this code to following with some changes for intel 100-series PCH motherboard onwards.. This code has be designed with Bus# 0, Device# 31, Function# 2 and offset 0x40(ACPI Base address register).
_BtLdrTurnOffPC:
push ax
push bx
push cx
push dx
push si
push di
push ds
push es
cli
mov eax,0x8000FA40 ; Bus 0, Device 31, Function 2, Offset 0x40
mov dx,0x0CF8
out dx,eax
mov dx,0x0CFC
in ax,dx
and ax,0xFFFE
mov dx,ax
add dx,0x0004
mov eax,0x00003C00
out dx,eax
pop es
pop ds
pop di
pop si
pop dx
pop cx
pop bx
pop ax
ret
Will this code work? Will bios write ACPI Base address register and will enable it?
Thanks in advance. Kindly intimate me as early as possible since this is urgent.
MVeer2
Dear all,
I have attached my resume with this post. Kindly create me an opportunity in intel corporation bangalore as early as possible. I am going to supply more intel based products in regular basis.
Thanking you
Muhilan Veerarasu
Mobile:- +91-96296 33042
E-Mail Id:- rvmuhilan1979@gmail.com
