Software Archive
Read-only legacy content
17061 Discussions
PXC_STATUS_NO_ERROR insonsistency
Zsolt_E_
Can someone explain to me what is the rationale behind half the functions requiring >= PXC_STATUS_NO_ERROR while the other half < PXC_STATUS_NO_ERROR for the valid operation?
Jonathan_M_Intel
The pxcStatus is used to return some warning information along with failure information.  In some cases, the function will return appropriately, but the SDK wants to warn the user/developer that something inappropriate, but not code-breaking has happened.  Check the value definitions in pxcstatus.h for a listing of all the codes.
Basically, if your function returns a negative value (pxcStatus < PXC_STATUS_NO_ERROR) means that the code should not continue, and you as a developer should include some error handling that defines how you want the app to degrade, or restart, or close.  There shouldn't be any cases where a negative status value means the app is behaving correctly, can you point out anything you've found where that's the case?
Zsolt_E_
Hi Jonatan,
Thanks for the explanation, I've double checked all occurrences in the samples and you are right indeed. < is always used for error and >= is used for ok.
I'm still a bit puzzled about when should I use == and when should I use >=, both are used in the samples (as well as != actually). Do you have a recommendation on == vs >=?
Jonathan_M_Intel
The documentation should tell you whether or not a given function will ever return one of the warning messages.  In those cases you need to be sure to use >=, but otherwise in most cases == will be best.  Here is an example of one of the audio processing functions that warns about a too-large time gap between audio samples.  The rest are likely reserved for future implementation.
