Software Archive
Read-only legacy content
17060 Discussions
Plugin com.telerik.plugins.wkwebview build error.
Dariusz_W_
Plugin: com.telerik.plugins.wkwebview
Platform: iOS
Issue: com.telerik.plugins.wkwebview/MyMainViewController.m:4:9: fatal error: 'Cordova/CDVLocalStorage.h' file not found
#import <Cordova/CDVLocalStorage.h>
How can I fix this?
SithLord
Looks like you may have a blocking problem if you cant downgrade cordova.
https://www.bountysource.com/issues/29609623-build-fails-with-error-code-65-on-cordova-ios-4-0-1
Dariusz_W_
How can I downgrade cordova-ios on IntelXDK?
SithLord
Try changing the Cordova CLI version in build settings to 5.1.1, the specs says it's pinned to cordova-ios 3.8.0.
If this is the problem then you should currently be at CLI Ver 5.4.1
https://software.intel.com/en-us/xdk/articles/system-support
