Software Archive
Read-only legacy content
17060 Discussions
Possible error in SDM 3A
hellfire
Suddenly found a little error in manual.
http://www.intel.com/Assets/PDF/manual/253668.pdf
Order Number: 253668-031US
June 2009
Page 4-34:
U/S (bit2).
If a supervisor-mode (CPL< 3) access caused the page-fault exception, this flag is 1; it is 0 if a user-mode (CPL= 3) access did so. This bit describes the acces
causing the page-fault exception, not the access rights specified by paging.
Right way should be like this, afaik:
U/S (bit2).
If a supervisor-mode (CPL< 3) access caused the page-fault exception, this flag is 0; it is 1 if a user-mode (CPL= 3) access did so. This bit describes the acces
David_O_Intel1
Thanks for pointing this out. I've been working internally to verify and then get the change put into the manual.
Again, much appreciated.
David Ott
David_O_Intel1
David Ott
