Software Archive
Read-only legacy content
17060 Discussions
Prevent resizing the App view when oppening on-screen keyboard
Vladimir_Z_
I am developing a hybrid video game, i.e javascript inside crosswalk chrome apk file.
The debugging is working well and I managed to use jquery to initiate focus event on html input element to show the android keybord.
The problem I have is when the keyboard appears, it squeezes the application viewport which is not what I want.
Tried to follow this SO question: http://stackoverflow.com/questions/10076148/phonegap-is-there-a-way-to-stop-the-keyboard-from-resizing-the-view
but it doesn't work and I don't know where to find AndroidManifest.xml file inside Intel XDK studio.
If you were to put settings such as:
android:windowSoftInputMode="adjustPan"
android:configChanges="orientation|keyboardHidden"
where would you put them?
Dale_S_Intel
Try adding to the file 'intelxdk.config.additions.xml' in the root directory of your project (same place as the project-name.xdk file and the www directory, which contains index.html).
Dale
PaulF_IntelCorp
There is an option for this that can be used in the intelxdk.config.additions.xml file (see the doc page here > https://software.intel.com/en-us/xdk/docs/cordova-for-android-build-options <) but it is currently not working with our build system. This is actually a PhoneGap Build feature that was implemented in our older build systems but did not get transferred to the new build systems. I recommend you use the Ionic keyboard plugin to get better control of the Android soft keyboard.
