Software Archive
Read-only legacy content
17061 Discussions
Previous Version of Composer Detected after removal
gmiller_w_miller
Because of issues with VS2010 I hade to remove it and Intel Parallel Studio. The restall fails if I include anything with Composer in it because it says there is a version there enven though it was removed. I have cleaned the registry, and made sure the installed software shows nothing for it. I do not know what indication the software has tht there is a current version so I can't fix it. Is there a set of steps to cler the indicstion of the software being installed?
Hubert_H_Intel
Did you look also ontheContral Panel whether thereis still Parallel Studio listed as installed?
If you removedParallel Studio via the'Remove' option from the Parallel Studio installer and double-checked that no Parallel Studio component is visible(e.g. for Windows 7) on the Control Panel > Programs > Programs and Features I'd recommend to run the Parallel Studio installer again and choose option 'Remove'. If this doesn't help the following article might help:
http://software.intel.com/en-us/articles/how-to-change-the-parallel-studio-version-integrated-into-visual-studio/
But this works only if the respective script files are in place. You may also try to run the Parallel Studio installer until it fails and then look at your computer wheter thescript files have already been installed and thenproceed as described in the article.
Please follow up with a more precise error description if you cannot manage to get Parallel Studio installed.
Hubert.
gmiller_w_miller
No entries in control panel, or on the disk but setup from install find a previous version of the software (do not know how) and tries to remove it to install composer. Since it is not there the software crashes.
gmiller_w_miller
I can't attach any files so there is not much detail I can give you. I do have the log from the setup but it is too big to put in a post.
this may be the last part of the log that detects he install, if it will paste:
PSET(i) [19:42:50.726] | (673.176): UpdateNeedforCheck {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: Not Need
PSET(i) [19:42:50.742] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0
PSET(i) [19:42:50.757] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
PSET(i) [19:42:50.757] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0
PSET(i) [19:42:50.757] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0
PSET(i) [19:42:50.757] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0
PSET(i) [19:42:50.757] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0
PSET(i) [19:42:50.757] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\composer_2011_update6_redist_intel64\composer_2011_update6_redist_intel64.msi
PSET(i) [19:42:50.757] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: 2
PSET(i) [19:42:50.757] | (673.176): UpdateNeedforCheck {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: Not Need
PSET(i) [19:42:50.789] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0
PSET(i) [19:42:50.804] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
PSET(i) [19:42:50.804] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0
PSET(i) [19:42:50.804] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0
PSET(i) [19:42:50.804] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0
PSET(i) [19:42:50.804] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0
PSET(i) [19:42:50.804] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\arp_creator\arp_creator.msi
PSET(i) [19:42:50.804] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: 2
PSET(i) [19:42:50.804] | (673.176): UpdateNeedforCheck {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: Not Need
PSET(i) [19:42:50.836] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0
PSET(i) [19:42:50.851] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
PSET(i) [19:42:50.851] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0
PSET(i) [19:42:50.851] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0
PSET(i) [19:42:50.851] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0
PSET(i) [19:42:50.851] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0
PSET(i) [19:42:50.851] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\installer\installer.msi
PSET(i) [19:42:50.851] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: 2
PSET(i) [19:42:50.851] | (673.176): UpdateNeedforCheck {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: Not Need
PSET(i) [19:42:50.882] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0
PSET(i) [19:42:50.898] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
PSET(i) [19:42:50.898] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0
PSET(i) [19:42:50.898] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0
PSET(i) [19:42:50.898] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0
PSET(i) [19:42:50.898] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0
PSET(i) [19:42:50.898] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\pc_indicator\pc_indicator.msi
PSET(i) [19:42:50.898] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: -7
PSET(i) [19:42:50.929] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0
PSET(i) [19:42:50.945] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
PSET(i) [19:42:50.945] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0
PSET(i) [19:42:50.945] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0
PSET(i) [19:42:50.945] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0
PSET(i) [19:42:50.945] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0
PSET(i) [19:42:50.945] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\pc_indicator_image\pc_indicator_image.msi
PSET(i) [19:42:50.945] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: -7
PSET(i) [19:42:50.961] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0
PSET(i) [19:42:50.992] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
PSET(i) [19:42:50.992] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0
PSET(i) [19:42:50.992] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0
PSET(i) [19:42:50.992] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0
PSET(i) [19:42:50.992] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0
PSET(i) [19:42:50.992] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\pc_indicator_ia32\pc_indicator_ia32.msi
PSET(i) [19:42:50.992] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: -7
PSET(i) [19:42:51.007] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0
PSET(i) [19:42:51.039] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
PSET(i) [19:42:51.039] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0
PSET(i) [19:42:51.039] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0
PSET(i) [19:42:51.039] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0
PSET(i) [19:42:51.039] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0
PSET(i) [19:42:51.039] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\pc_indicator_intel64\pc_indicator_intel64.msi
PSET(i) [19:42:51.039] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: -7
PSET(i) [19:42:51.054] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0
PSET(i) [19:42:51.070] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
PSET(i) [19:42:51.086] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0
PSET(i) [19:42:51.086] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0
PSET(i) [19:42:51.086] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0
PSET(i) [19:42:51.086] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0
PSET(i) [19:42:51.086] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\pc_indicator_all\pc_indicator_all.msi
PSET(i) [19:42:51.086] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: -7
PSET(i) [19:42:51.101] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0
PSET(i) [19:42:51.117] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
PSET(i) [19:42:51.117] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0
PSET(i) [19:42:51.117] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0
PSET(i) [19:42:51.117] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0
PSET(i) [19:42:51.117] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0
PSET(i) [19:42:51.117] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\w_composerc_toplevel_p_12.1.043\w_composerc_toplevel_p_12.1.043.msi
PSET(i) [19:42:51.117] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: 2
PSET(i) [19:42:51.117] | (673.176): UpdateNeedforCheck {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: Not Need
PSET(i) [19:42:51.148] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0
PSET(i) [19:42:51.164] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
PSET(i) [19:42:51.164] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0
PSET(i) [19:42:51.164] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0
PSET(i) [19:42:51.164] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0
PSET(i) [19:42:51.164] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0
PSET(i) [19:42:51.164] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\w_composerc_openmp_ia32_p_12.1.043\w_composerc_openmp_ia32_p_12.1.043.msi
PSET(i) [19:42:51.164] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: 2
PSET(i) [19:42:51.164] | (673.176): UpdateNeedforCheck {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: Not Need
PSET(i) [19:42:51.195] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0
PSET(i) [19:42:51.211] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
PSET(i) [19:42:51.211] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0
PSET(i) [19:42:51.211] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0
PSET(i) [19:42:51.211] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0
PSET(i) [19:42:51.211] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0
PSET(i) [19:42:51.211] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\w_composerc_openmp_em64tcross_p_12.1.043\w_composerc_openmp_em64tcross_p_12.1.043.msi
PSET(i) [19:42:51.211] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: 2
PSET(i) [19:42:51.211] | (673.176): UpdateNeedforCheck {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: Not Need
PSET(i) [19:42:51.242] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0
PSET(i) [19:42:51.257] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
PSET(i) [19:42:51.257] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0
PSET(i) [19:42:51.257] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0
PSET(i) [19:42:51.257] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0
PSET(i) [19:42:51.257] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0
PSET(i) [19:42:51.257] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\w_composerc_ia32_p_12.1.043\w_composerc_ia32_p_12.1.043.msi
PSET(i) [19:42:51.257] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: 2
PSET(i) [19:42:51.257] | (673.176): UpdateNeedforCheck {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: Not Need
PSET(i) [19:42:51.257] | (673.176): UpdateNeedforCheck {9D354C6B-24BC-4131-A987-34CD77B5A906}: Not Need
PSET(i) [19:42:51.257] | (673.118): Check Dependency for {9D354C6B-24BC-4131-A987-34CD77B5A906}: 0
PSET(i) [19:42:51.273] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0
PSET(i) [19:42:51.304] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
PSET(i) [19:42:51.304] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0
PSET(i) [19:42:51.304] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0
PSET(i) [19:42:51.304] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0
PSET(i) [19:42:51.304] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0
PSET(i) [19:42:51.304] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\w_composerc_em64tcross_p_12.1.043\w_composerc_em64tcross_p_12.1.043.msi
PSET(i) [19:42:51.304] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: 2
PSET(i) [19:42:51.304] | (673.176): UpdateNeedforCheck {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: Not Need
PSET(i) [19:42:51.304] | (673.176): UpdateNeedforCheck {4FC2DB66-9437-4b9e-BE2F-AC5633268565}: Not Need
PSET(i) [19:42:51.304] | (673.118): Check Dependency for {4FC2DB66-9437-4b9e-BE2F-AC5633268565}: 0
PSET(i) [19:42:51.304] | (673.118): Check Dependency for {9D354C6B-24BC-4131-A987-34CD77B5A906}: 0
PSET(i) [19:42:51.320] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0
PSET(i) [19:42:51.351] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
PSET(i) [19:42:51.351] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0
PSET(i) [19:42:51.351] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0
PSET(i) [19:42:51.351] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0
PSET(i) [19:42:51.351] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0
PSET(i) [19:42:51.351] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\w_composeripp_ia32_p_7.0.043\w_composeripp_ia32_p_7.0.043.msi
PSET(i) [19:42:51.351] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: 2
PSET(i) [19:42:51.351] | (673.176): UpdateNeedforCheck {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: Not Need
PSET(i) [19:42:51.351] | (673.176): UpdateNeedforCheck {9D354C6B-24BC-4131-A987-34CD77B5A906}: Not Need
PSET(i) [19:42:51.351] | (673.118): Check Dependency for {4FC2DB66-9437-4b9e-BE2F-AC5633268565}: 0
PSET(i) [19:42:51.351] | (673.118): Check Dependency for {9D354C6B-24BC-4131-A987-34CD77B5A906}: 0
PSET(i) [19:42:51.367] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0
PSET(i) [19:42:51.414] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
PSET(i) [19:42:51.414] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0
PSET(i) [19:42:51.414] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0
PSET(i) [19:42:51.414] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0
PSET(i) [19:42:51.414] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0
PSET(i) [19:42:51.414] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\w_composeripp_em64t_p_7.0.043\w_composeripp_em64t_p_7.0.043.msi
PSET(i) [19:42:51.414] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: 2
PSET(i) [19:42:51.414] | (673.176): UpdateNeedforCheck {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: Not Need
PSET(i) [19:42:51.414] | (673.118): Check Dependency for {4FC2DB66-9437-4b9e-BE2F-AC5633268565}: 0
PSET(i) [19:42:51.414] | (673.118): Check Dependency for {9D354C6B-24BC-4131-A987-34CD77B5A906}: 0
PSET(i) [19:42:51.445] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0
PSET(i) [19:42:51.476] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
PSET(i) [19:42:51.476] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0
PSET(i) [19:42:51.476] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0
PSET(i) [19:42:51.476] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0
PSET(i) [19:42:51.476] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0
PSET(i) [19:42:51.476] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\w_composertbb_p_4.0.043\w_composertbb_p_4.0.043.msi
PSET(i) [19:42:51.476] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: 2
PSET(i) [19:42:51.476] | (673.176): UpdateNeedforCheck {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: Not Need
PSET(i) [19:42:51.476] | (673.118): Check Dependency for {4FC2DB66-9437-4b9e-BE2F-AC5633268565}: 0
PSET(i) [19:42:51.476] | (673.118): Check Dependency for {9D354C6B-24BC-4131-A987-34CD77B5A906}: 0
PSET(i) [19:42:51.523] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0
PSET(i) [19:42:51.554] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
PSET(i) [19:42:51.554] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0
PSET(i) [19:42:51.554] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0
PSET(i) [19:42:51.554] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0
PSET(i) [19:42:51.554] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0
PSET(i) [19:42:51.554] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\w_composerc_ide_unique_p_12.1.043\w_composerc_ide_unique_p_12.1.043.msi
PSET(i) [19:42:51.554] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: 2
PSET(i) [19:42:51.554] | (673.176): UpdateNeedforCheck {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: Not Need
PSET(i) [19:42:51.554] | (673.176): UpdateNeedforCheck {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: Not Need
PSET(i) [19:42:51.554] | (673.118): Check Dependency for {4FC2DB66-9437-4b9e-BE2F-AC5633268565}: 0
PSET(i) [19:42:51.554] | (673.118): Check Dependency for {9D354C6B-24BC-4131-A987-34CD77B5A906}: 0
PSET(i) [19:42:51.601] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0
PSET(i) [19:42:51.648] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
PSET(i) [19:42:51.648] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0
PSET(i) [19:42:51.648] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0
PSET(i) [19:42:51.648] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0
PSET(i) [19:42:51.648] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0
PSET(i) [19:42:51.648] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\w_composerc_ide_common_p_12.1.043\w_composerc_ide_common_p_12.1.043.msi
PSET(i) [19:42:51.648] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: 2
PSET(i) [19:42:51.648] | (673.176): UpdateNeedforCheck {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: Not Need
PSET(i) [19:42:51.648] | (673.176): UpdateNeedforCheck {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: Not Need
PSET(i) [19:42:51.648] | (673.118): Check Dependency for {4FC2DB66-9437-4b9e-BE2F-AC5633268565}: 0
PSET(i) [19:42:51.648] | (673.118): Check Dependency for {9D354C6B-24BC-4131-A987-34CD77B5A906}: 0
PSET(i) [19:42:51.679] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0
PSET(i) [19:42:51.711] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
PSET(i) [19:42:51.711] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0
PSET(i) [19:42:51.711] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0
PSET(i) [19:42:51.711] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0
PSET(i) [19:42:51.711] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0
PSET(i) [19:42:51.711] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\w_composeridb_vs_p_12.1.043\w_composeridb_vs_p_12.1.043.msi
PSET(i) [19:42:51.711] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: 2
PSET(i) [19:42:51.711] | (673.176): UpdateNeedforCheck {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: Not Need
PSET(i) [19:42:51.711] | (673.176): UpdateNeedforCheck {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: Not Need
PSET(i) [19:42:51.711] | (673.118): Check Dependency for {4FC2DB66-9437-4b9e-BE2F-AC5633268565}: 0
PSET(i) [19:42:51.711] | (673.118): Check Dependency for {9D354C6B-24BC-4131-A987-34CD77B5A906}: 0
PSET(i) [19:42:51.742] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0
PSET(i) [19:42:51.773] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
PSET(i) [19:42:51.773] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0
PSET(i) [19:42:51.773] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0
PSET(i) [19:42:51.773] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0
PSET(i) [19:42:51.773] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0
PSET(i) [19:42:51.773] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\w_composerdoc_vs_2005_p_12.1.043\w_composerdoc_vs_2005_p_12.1.043.msi
PSET(i) [19:42:51.773] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: 2
PSET(i) [19:42:51.773] | (673.176): UpdateNeedforCheck {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: Not Need
PSET(i) [19:42:51.773] | (673.176): UpdateNeedforCheck {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: Not Need
PSET(i) [19:42:51.773] | (673.118): Check Dependency for {4FC2DB66-9437-4b9e-BE2F-AC5633268565}: 0
PSET(i) [19:42:51.773] | (673.118): Check Dependency for {9D354C6B-24BC-4131-A987-34CD77B5A906}: 0
PSET(i) [19:42:51.789] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0
PSET(i) [19:42:51.820] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
PSET(i) [19:42:51.820] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0
PSET(i) [19:42:51.820] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0
PSET(i) [19:42:51.820] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0
PSET(i) [19:42:51.820] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0
PSET(i) [19:42:51.820] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\w_composerdoc_vs_2008_p_12.1.043\w_composerdoc_vs_2008_p_12.1.043.msi
PSET(i) [19:42:51.820] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: 2
PSET(i) [19:42:51.820] | (673.176): UpdateNeedforCheck {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: Not Need
PSET(i) [19:42:51.820] | (673.176): UpdateNeedforCheck {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: Not Need
PSET(i) [19:42:51.820] | (673.118): Check Dependency for {4FC2DB66-9437-4b9e-BE2F-AC5633268565}: 0
PSET(i) [19:42:51.820] | (673.118): Check Dependency for {9D354C6B-24BC-4131-A987-34CD77B5A906}: 0
PSET(i) [19:42:51.836] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0
PSET(i) [19:42:51.867] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
PSET(i) [19:42:51.867] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0
PSET(i) [19:42:51.867] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0
PSET(i) [19:42:51.867] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0
PSET(i) [19:42:51.867] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0
PSET(i) [19:42:51.867] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\w_composerdoc_vs_p_12.1.043\w_composerdoc_vs_p_12.1.043.msi
PSET(i) [19:42:51.867] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: 2
PSET(i) [19:42:51.867] | (673.176): UpdateNeedforCheck {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: Not Need
PSET(i) [19:42:51.867] | (673.176): UpdateNeedforCheck {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: Not Need
PSET(i) [19:42:51.867] | (673.118): Check Dependency for {4FC2DB66-9437-4b9e-BE2F-AC5633268565}: 0
PSET(i) [19:42:51.867] | (673.118): Check Dependency for {9D354C6B-24BC-4131-A987-34CD77B5A906}: 0
PSET(i) [19:42:51.882] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0
PSET(i) [19:42:51.898] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0
PSET(i) [19:42:51.898] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0
PSET(i) [19:42:51.898] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0
PSET(i) [19:42:51.898] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0
PSET(i) [19:42:51.898] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0
P
PSET(i) [19:42:50.726] | (673.176): UpdateNeedforCheck {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: Not NeedPSET(i) [19:42:50.742] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0PSET(i) [19:42:50.757] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0PSET(i) [19:42:50.757] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0PSET(i) [19:42:50.757] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0PSET(i) [19:42:50.757] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0PSET(i) [19:42:50.757] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0PSET(i) [19:42:50.757] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\composer_2011_update6_redist_intel64\composer_2011_update6_redist_intel64.msiPSET(i) [19:42:50.757] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: 2PSET(i) [19:42:50.757] | (673.176): UpdateNeedforCheck {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: Not NeedPSET(i) [19:42:50.789] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0PSET(i) [19:42:50.804] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0PSET(i) [19:42:50.804] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0PSET(i) [19:42:50.804] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0PSET(i) [19:42:50.804] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0PSET(i) [19:42:50.804] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0PSET(i) [19:42:50.804] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\arp_creator\arp_creator.msiPSET(i) [19:42:50.804] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: 2PSET(i) [19:42:50.804] | (673.176): UpdateNeedforCheck {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: Not NeedPSET(i) [19:42:50.836] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0PSET(i) [19:42:50.851] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0PSET(i) [19:42:50.851] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0PSET(i) [19:42:50.851] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0PSET(i) [19:42:50.851] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0PSET(i) [19:42:50.851] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0PSET(i) [19:42:50.851] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\installer\installer.msiPSET(i) [19:42:50.851] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: 2PSET(i) [19:42:50.851] | (673.176): UpdateNeedforCheck {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: Not NeedPSET(i) [19:42:50.882] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0PSET(i) [19:42:50.898] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0PSET(i) [19:42:50.898] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0PSET(i) [19:42:50.898] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0PSET(i) [19:42:50.898] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0PSET(i) [19:42:50.898] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0PSET(i) [19:42:50.898] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\pc_indicator\pc_indicator.msiPSET(i) [19:42:50.898] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: -7PSET(i) [19:42:50.929] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0PSET(i) [19:42:50.945] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0PSET(i) [19:42:50.945] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0PSET(i) [19:42:50.945] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0PSET(i) [19:42:50.945] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0PSET(i) [19:42:50.945] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0PSET(i) [19:42:50.945] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\pc_indicator_image\pc_indicator_image.msiPSET(i) [19:42:50.945] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: -7PSET(i) [19:42:50.961] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0PSET(i) [19:42:50.992] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0PSET(i) [19:42:50.992] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0PSET(i) [19:42:50.992] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0PSET(i) [19:42:50.992] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0PSET(i) [19:42:50.992] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0PSET(i) [19:42:50.992] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\pc_indicator_ia32\pc_indicator_ia32.msiPSET(i) [19:42:50.992] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: -7PSET(i) [19:42:51.007] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0PSET(i) [19:42:51.039] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0PSET(i) [19:42:51.039] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0PSET(i) [19:42:51.039] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0PSET(i) [19:42:51.039] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0PSET(i) [19:42:51.039] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0PSET(i) [19:42:51.039] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\pc_indicator_intel64\pc_indicator_intel64.msiPSET(i) [19:42:51.039] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: -7PSET(i) [19:42:51.054] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0PSET(i) [19:42:51.070] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0PSET(i) [19:42:51.086] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0PSET(i) [19:42:51.086] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0PSET(i) [19:42:51.086] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0PSET(i) [19:42:51.086] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0PSET(i) [19:42:51.086] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\pc_indicator_all\pc_indicator_all.msiPSET(i) [19:42:51.086] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: -7PSET(i) [19:42:51.101] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0PSET(i) [19:42:51.117] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0PSET(i) [19:42:51.117] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0PSET(i) [19:42:51.117] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0PSET(i) [19:42:51.117] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0PSET(i) [19:42:51.117] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0PSET(i) [19:42:51.117] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\w_composerc_toplevel_p_12.1.043\w_composerc_toplevel_p_12.1.043.msiPSET(i) [19:42:51.117] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: 2PSET(i) [19:42:51.117] | (673.176): UpdateNeedforCheck {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: Not NeedPSET(i) [19:42:51.148] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0PSET(i) [19:42:51.164] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0PSET(i) [19:42:51.164] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0PSET(i) [19:42:51.164] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0PSET(i) [19:42:51.164] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0PSET(i) [19:42:51.164] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0PSET(i) [19:42:51.164] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\w_composerc_openmp_ia32_p_12.1.043\w_composerc_openmp_ia32_p_12.1.043.msiPSET(i) [19:42:51.164] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: 2PSET(i) [19:42:51.164] | (673.176): UpdateNeedforCheck {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: Not NeedPSET(i) [19:42:51.195] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0PSET(i) [19:42:51.211] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0PSET(i) [19:42:51.211] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0PSET(i) [19:42:51.211] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0PSET(i) [19:42:51.211] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0PSET(i) [19:42:51.211] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0PSET(i) [19:42:51.211] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\w_composerc_openmp_em64tcross_p_12.1.043\w_composerc_openmp_em64tcross_p_12.1.043.msiPSET(i) [19:42:51.211] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: 2PSET(i) [19:42:51.211] | (673.176): UpdateNeedforCheck {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: Not NeedPSET(i) [19:42:51.242] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0PSET(i) [19:42:51.257] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0PSET(i) [19:42:51.257] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0PSET(i) [19:42:51.257] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0PSET(i) [19:42:51.257] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0PSET(i) [19:42:51.257] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0PSET(i) [19:42:51.257] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\w_composerc_ia32_p_12.1.043\w_composerc_ia32_p_12.1.043.msiPSET(i) [19:42:51.257] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: 2PSET(i) [19:42:51.257] | (673.176): UpdateNeedforCheck {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: Not NeedPSET(i) [19:42:51.257] | (673.176): UpdateNeedforCheck {9D354C6B-24BC-4131-A987-34CD77B5A906}: Not NeedPSET(i) [19:42:51.257] | (673.118): Check Dependency for {9D354C6B-24BC-4131-A987-34CD77B5A906}: 0PSET(i) [19:42:51.273] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0PSET(i) [19:42:51.304] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0PSET(i) [19:42:51.304] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0PSET(i) [19:42:51.304] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0PSET(i) [19:42:51.304] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0PSET(i) [19:42:51.304] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0PSET(i) [19:42:51.304] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\w_composerc_em64tcross_p_12.1.043\w_composerc_em64tcross_p_12.1.043.msiPSET(i) [19:42:51.304] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: 2PSET(i) [19:42:51.304] | (673.176): UpdateNeedforCheck {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: Not NeedPSET(i) [19:42:51.304] | (673.176): UpdateNeedforCheck {4FC2DB66-9437-4b9e-BE2F-AC5633268565}: Not NeedPSET(i) [19:42:51.304] | (673.118): Check Dependency for {4FC2DB66-9437-4b9e-BE2F-AC5633268565}: 0PSET(i) [19:42:51.304] | (673.118): Check Dependency for {9D354C6B-24BC-4131-A987-34CD77B5A906}: 0PSET(i) [19:42:51.320] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0PSET(i) [19:42:51.351] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0PSET(i) [19:42:51.351] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0PSET(i) [19:42:51.351] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0PSET(i) [19:42:51.351] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0PSET(i) [19:42:51.351] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0PSET(i) [19:42:51.351] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\w_composeripp_ia32_p_7.0.043\w_composeripp_ia32_p_7.0.043.msiPSET(i) [19:42:51.351] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: 2PSET(i) [19:42:51.351] | (673.176): UpdateNeedforCheck {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: Not NeedPSET(i) [19:42:51.351] | (673.176): UpdateNeedforCheck {9D354C6B-24BC-4131-A987-34CD77B5A906}: Not NeedPSET(i) [19:42:51.351] | (673.118): Check Dependency for {4FC2DB66-9437-4b9e-BE2F-AC5633268565}: 0PSET(i) [19:42:51.351] | (673.118): Check Dependency for {9D354C6B-24BC-4131-A987-34CD77B5A906}: 0PSET(i) [19:42:51.367] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0PSET(i) [19:42:51.414] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0PSET(i) [19:42:51.414] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0PSET(i) [19:42:51.414] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0PSET(i) [19:42:51.414] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0PSET(i) [19:42:51.414] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0PSET(i) [19:42:51.414] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\w_composeripp_em64t_p_7.0.043\w_composeripp_em64t_p_7.0.043.msiPSET(i) [19:42:51.414] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: 2PSET(i) [19:42:51.414] | (673.176): UpdateNeedforCheck {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: Not NeedPSET(i) [19:42:51.414] | (673.118): Check Dependency for {4FC2DB66-9437-4b9e-BE2F-AC5633268565}: 0PSET(i) [19:42:51.414] | (673.118): Check Dependency for {9D354C6B-24BC-4131-A987-34CD77B5A906}: 0PSET(i) [19:42:51.445] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0PSET(i) [19:42:51.476] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0PSET(i) [19:42:51.476] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0PSET(i) [19:42:51.476] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0PSET(i) [19:42:51.476] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0PSET(i) [19:42:51.476] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0PSET(i) [19:42:51.476] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\w_composertbb_p_4.0.043\w_composertbb_p_4.0.043.msiPSET(i) [19:42:51.476] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: 2PSET(i) [19:42:51.476] | (673.176): UpdateNeedforCheck {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: Not NeedPSET(i) [19:42:51.476] | (673.118): Check Dependency for {4FC2DB66-9437-4b9e-BE2F-AC5633268565}: 0PSET(i) [19:42:51.476] | (673.118): Check Dependency for {9D354C6B-24BC-4131-A987-34CD77B5A906}: 0PSET(i) [19:42:51.523] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0PSET(i) [19:42:51.554] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0PSET(i) [19:42:51.554] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0PSET(i) [19:42:51.554] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0PSET(i) [19:42:51.554] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0PSET(i) [19:42:51.554] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0PSET(i) [19:42:51.554] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\w_composerc_ide_unique_p_12.1.043\w_composerc_ide_unique_p_12.1.043.msiPSET(i) [19:42:51.554] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: 2PSET(i) [19:42:51.554] | (673.176): UpdateNeedforCheck {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: Not NeedPSET(i) [19:42:51.554] | (673.176): UpdateNeedforCheck {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: Not NeedPSET(i) [19:42:51.554] | (673.118): Check Dependency for {4FC2DB66-9437-4b9e-BE2F-AC5633268565}: 0PSET(i) [19:42:51.554] | (673.118): Check Dependency for {9D354C6B-24BC-4131-A987-34CD77B5A906}: 0PSET(i) [19:42:51.601] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0PSET(i) [19:42:51.648] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0PSET(i) [19:42:51.648] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0PSET(i) [19:42:51.648] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0PSET(i) [19:42:51.648] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0PSET(i) [19:42:51.648] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0PSET(i) [19:42:51.648] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\w_composerc_ide_common_p_12.1.043\w_composerc_ide_common_p_12.1.043.msiPSET(i) [19:42:51.648] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: 2PSET(i) [19:42:51.648] | (673.176): UpdateNeedforCheck {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: Not NeedPSET(i) [19:42:51.648] | (673.176): UpdateNeedforCheck {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: Not NeedPSET(i) [19:42:51.648] | (673.118): Check Dependency for {4FC2DB66-9437-4b9e-BE2F-AC5633268565}: 0PSET(i) [19:42:51.648] | (673.118): Check Dependency for {9D354C6B-24BC-4131-A987-34CD77B5A906}: 0PSET(i) [19:42:51.679] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0PSET(i) [19:42:51.711] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0PSET(i) [19:42:51.711] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0PSET(i) [19:42:51.711] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0PSET(i) [19:42:51.711] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0PSET(i) [19:42:51.711] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0PSET(i) [19:42:51.711] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\w_composeridb_vs_p_12.1.043\w_composeridb_vs_p_12.1.043.msiPSET(i) [19:42:51.711] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: 2PSET(i) [19:42:51.711] | (673.176): UpdateNeedforCheck {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: Not NeedPSET(i) [19:42:51.711] | (673.176): UpdateNeedforCheck {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: Not NeedPSET(i) [19:42:51.711] | (673.118): Check Dependency for {4FC2DB66-9437-4b9e-BE2F-AC5633268565}: 0PSET(i) [19:42:51.711] | (673.118): Check Dependency for {9D354C6B-24BC-4131-A987-34CD77B5A906}: 0PSET(i) [19:42:51.742] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0PSET(i) [19:42:51.773] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0PSET(i) [19:42:51.773] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0PSET(i) [19:42:51.773] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0PSET(i) [19:42:51.773] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0PSET(i) [19:42:51.773] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0PSET(i) [19:42:51.773] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\w_composerdoc_vs_2005_p_12.1.043\w_composerdoc_vs_2005_p_12.1.043.msiPSET(i) [19:42:51.773] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: 2PSET(i) [19:42:51.773] | (673.176): UpdateNeedforCheck {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: Not NeedPSET(i) [19:42:51.773] | (673.176): UpdateNeedforCheck {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: Not NeedPSET(i) [19:42:51.773] | (673.118): Check Dependency for {4FC2DB66-9437-4b9e-BE2F-AC5633268565}: 0PSET(i) [19:42:51.773] | (673.118): Check Dependency for {9D354C6B-24BC-4131-A987-34CD77B5A906}: 0PSET(i) [19:42:51.789] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0PSET(i) [19:42:51.820] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0PSET(i) [19:42:51.820] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0PSET(i) [19:42:51.820] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0PSET(i) [19:42:51.820] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0PSET(i) [19:42:51.820] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0PSET(i) [19:42:51.820] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\w_composerdoc_vs_2008_p_12.1.043\w_composerdoc_vs_2008_p_12.1.043.msiPSET(i) [19:42:51.820] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: 2PSET(i) [19:42:51.820] | (673.176): UpdateNeedforCheck {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: Not NeedPSET(i) [19:42:51.820] | (673.176): UpdateNeedforCheck {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: Not NeedPSET(i) [19:42:51.820] | (673.118): Check Dependency for {4FC2DB66-9437-4b9e-BE2F-AC5633268565}: 0PSET(i) [19:42:51.820] | (673.118): Check Dependency for {9D354C6B-24BC-4131-A987-34CD77B5A906}: 0PSET(i) [19:42:51.836] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0PSET(i) [19:42:51.867] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0PSET(i) [19:42:51.867] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0PSET(i) [19:42:51.867] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0PSET(i) [19:42:51.867] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0PSET(i) [19:42:51.867] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0PSET(i) [19:42:51.867] | (4225.1118): msi package: C:\Program Files\Intel\Download\parallel_studio_2011_sp1\Installs\Composer\Installs\1033\w_composerdoc_vs_p_12.1.043\w_composerdoc_vs_p_12.1.043.msiPSET(i) [19:42:51.867] | (4225.1119): LicIsValid: 1 InstallOnCurrentArch: 1 Installed State: -1 Pending Action: 2PSET(i) [19:42:51.867] | (673.176): UpdateNeedforCheck {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: Not NeedPSET(i) [19:42:51.867] | (673.176): UpdateNeedforCheck {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: Not NeedPSET(i) [19:42:51.867] | (673.118): Check Dependency for {4FC2DB66-9437-4b9e-BE2F-AC5633268565}: 0PSET(i) [19:42:51.867] | (673.118): Check Dependency for {9D354C6B-24BC-4131-A987-34CD77B5A906}: 0PSET(i) [19:42:51.882] | (673.118): Check Dependency for {27156C8E-8C1C-4c49-B401-DE89A9092C5E}: 0PSET(i) [19:42:51.898] | (673.118): Check Dependency for {ACD97E2A-090D-46ea-9983-6E44BCA28575}: 0PSET(i) [19:42:51.898] | (673.118): Check Dependency for {DDF033B2-02EC-4046-A064-D55C07CDBC9D}: 0PSET(i) [19:42:51.898] | (673.118): Check Dependency for {F72ECA82-EC84-4ce5-9CF0-6021AFAF6293}: 0PSET(i) [19:42:51.898] | (673.118): Check Dependency for {F3CE10E5-7F75-4356-A379-05F5D6B04FB6}: 0PSET(i) [19:42:51.898] | (673.118): Check Dependency for {3AE471C7-8858-472a-8D7C-48B871B5EBDF}: 0P
Hubert_H_Intel
I guessthe problem is that you installed several versions of Parallel Studio 2011, but when trying to install the latest Parallel Studio Version 2011 the installer still sees parts of previous installations or outdated registry information that prevent from installing a full new version. I'm still trying to get more information.
Regards, Hubert.
_heinz
I had have a similar situation, after I deinstalled a Beta Compilermy previous installed Intel Compiler did not work.
I used the program "Revo Uninstaller Pro" from http://www.revouninstallerpro.com/
to deinstall all Compiler and Visual Studio completly.
Then I started with a new install of Visual Studio.
Maybe this can help here too. It's worth to give a try.
_heinz
Hubert_H_Intel
Did you try to install the Intel Composer XE Update 10 which was released recently?
