Software Archive
Read-only legacy content
17060 Discussions
Principle of the RealSense (Questions need an answer)
alex_f_2
Hello, i am looking for any documentations that explain how the RealSense Camera work.
it the camera based on the same technique of the kinect (structured-light)?? what is the difference between the kinect and the realsense?
why the realsense max range is only 120cm, when the kinect range is about 5m when they work with the same technique and principal??
is there any documentation of how does it work like this kinect documentation?
samontab
Valued Contributor II
RealSense is based on structured light. Similar to how the Kinect 1 works. The newer Kinect 2 uses time of flight, which is a different technique.
You can think of RealSense as a small, easier to use mobile version of the Kinect 1. (Oversimplification of course).
You can read more about how the F200 works here:
https://software.intel.com/en-us/forums/realsense/topic/537872
The R200 works in a different way though.
alex_f_2
Thanx samontab for the quick answer!
