Software Archive
Read-only legacy content
17060 Discussions
Printing in Quickwin
ivomar
Hello all,
We've developed a program in Fortran that plots 2D/3D graphs, but when we want to print it using the quickwin intrinsic function winprint the printing is not good. The graphs are printed broken, not smooth. What advice you guys could give me to help us solve this printing problem?
Greetings,
Ivomar
Jugoslav_Dujic
Valued Contributor II
I'm afraid that you've hit the wall with this. What you see on the paper is the same you see on the screen -- but that's a bitmap which doesn't look smooth when printed. Basically, what you'd have to do is to repeat all drawing code using Win32 drawing functions instead of QuickWin ones. If I recall correctly, this thread gave some framework for that.
HTH
Jugoslav
david_jones
You might be able to gain a quick improvement by chaging your screen resolution to the finest possible befiore starting your program This would produce a finer detailed bit map, but it would still be fairly poor visually.
David Jones
