Software Archive
Read-only legacy content
17060 Discussions
Printing problem (Failed to change the settings)
Tony_T_
Intex XDK 3759.
Printing was working fine using cordova-plugin-printer version number 0.7.2.
This still works on Android version 5.1.1
Device running Android version 6.0.1 does not work.The cordova-plugin-printer connects with my google cloud print plugin. My printers are then displayed for me to make selection. Whether I choose a printer I get same error message. --Failed to change the settings. Try again. --
I do not believe this is a XDK problem. I am hoping you know of a work around. The same error shows up when I try to print my email. It must be something to do with update of android.
I tried couple of recommendations found on web but did not fix problem for me.
Tony_T_
Without changing any code.
Installed PrinterShare app from playstore. Then configured it to use my Cloud Print service to locate my printers. Now I can print from my Intel XDK APK, email, s notes and pictures.
Note: I tried HP print and HP ePrint since I am using a HP Printer to no avail.
notresponding__hppri
HP Printer has printing troubleshooter that help to identify problems click to fix button download and run the program. after that open the control panel and right click on the printer icon and troubleshoot.
https://notresponding.net/hp-printer-not-working/
