Software Archive
Read-only legacy content
17060 Discussions
Problem in build app size
Shakib_H_
Hello everyone,
I've built some apps with Intel XDK few months ago. These app working correctly and the app sizes an thin. But now I've upgraded my Intel XDK to build 3240. After upgrading I've created an app and the app files size are 2.5mb but after building I got an APK. And the apk size is more than 23mb.
I think it is a problem that happends on build server. Please help me.
PaulF_IntelCorp
Your previous apps were probably build WITHOUT Crosswalk, and your new apps have been built WITH Crosswalk. See the "optimize with Crosswalk" option in the Build Settings section of the Projects tab. Unchecking it will likely get you what you used to have. We recommend you use Crosswalk for your Android builds, it provides superior performance on Android 4.x devices and insures consistent runtime behavior over all versions of Android.
PaulF_IntelCorp
Shakib_H_
Thanks my problem is solved.
Namık_Zafer_E_
Shakib H.
If you build your application+crosswalk with Cordova CLI, before adding Android platform and building the application, run install command at the below link
https://www.npmjs.com/package/cordova-minify
