Software Archive
Read-only legacy content
17060 Discussions
Problem to open the dialing screen
Leandro_M_1
Good day,
In an application return data from some restaurants
I would like to create a function that when you click on the phone number automatically dialed this number.
With the function below, is working on intel XDK, but to compile and install on Android, is not calling the dialer screen.
function call (number) {
var str = numero.trim (); window.open ('tel:' + str, '_SYSTEM');
thank's
Swati_S_Intel1
Hi Leandro,
Before you build the application do the following:
On the Projects page, under Build Settings for the platform you are building for:
1. Check the box "Allow external application to launch from this domain?"
2. In the Domain List input box, put tel:*
Swati
Leandro_M_1
Hi
Thank you, now is working perfectly.
I appreciate the help.
Rethinavel_M_
Thank you so much... its working..!!!!
