Software Archive
Read-only legacy content
17060 Discussions
Problem with MPD call
Mostafa_N_
I have a corrupted MPD on my machine. Whenever I call any of the commands "mpdtrace" or "mpdallexit" I get the following message:
mpdroot: cannot connect to local mpd at: /tmp/mpd2.console_root
probable cause: no mpd daemon on this machine
possible cause: unix socket /tmp/mpd2.console_root has been removed
mpdtrace (__init__ 1524): forked process failed; status=255
I have my mpd running:
mpd&
ps -ef | grep mpd
Note: I am running on my own machine! Single Node, Quad core (intel i7 core)
Any helps would be appreciated.
Georg_Z_Intel
Hello, MPD and the commands have to be run as the same user. The error message you see typically occurs if MPD is running as a different user as the one who executes the commands. Best regards, Georg Zitzlsberger
