Software Archive
Read-only legacy content
17060 Discussions
Problem with RPG maker MV
Teddy_B_
Hello all,
First of all, i want to tell you that I'm french so please don't make attention about the sentences, I think they are not right enough :)
My problem is when I build with XDK. Intel XDK upload and suddently, an error message appear: http request failed.
How can i Solved this problem?
Thank you :)
Elroy_A_Intel
Can you provide an image illustrating your issue?
Teddy_B_
http://hpics.li/1e65cf6
Here you can see the issue .
Pls help me :(
Teddy_B_
Pls someone help me !
Teddy_B_
xdk:client:[2015-11-16T18:21:30.219Z]: (1447698090220): memlim: 767557632
xdk:client:[2015-11-16T18:21:30.236Z]: (1447698090236): Setting NW crash dump to: C:\Users\Tedd\AppData\Local\XDK
xdk:client:[2015-11-16T18:21:30.488Z]: (1447698090488): Intel XDK: 2673
xdk:client:[2015-11-16T18:21:30.488Z]: (1447698090488): Platform: win32-ia32 (6.3.9600)
xdk:client:[2015-11-16T18:21:30.488Z]: (1447698090488): NW: 0.11.7-rc8
xdk:client:[2015-11-16T18:21:30.552Z]: (1447698090552): Created new theme: base
xdk:client:[2015-11-16T18:21:30.552Z]: (1447698090552): Registered new theme: base
xdk:client:[2015-11-16T18:21:30.553Z]: (1447698090553): Current theme is now: base
xdk:client:[2015-11-16T18:21:30.553Z]: (1447698090553): Loading theme from: ../../public/themes/xdk.json
xdk:client:[2015-11-16T18:21:30.554Z]: (1447698090554): Failed to load theme: xdk { [Error: Cannot find module '../../public/themes/xdk.json'] code: 'MODULE_NOT_FOUND' }
xdk:client:[2015-11-16T18:21:30.610Z]: (1447698090610): Error SyntaxError: Unexpected token
 loading components\client\emulator\locale\root\text-content.json
xdk:client:[2015-11-16T18:21:30.700Z]: (1447698090700): Starting client process initialization
xdk:client:[2015-11-16T18:21:30.727Z]: (1447698090727): NW Cache is up-to-date.
xdk:server:[2015-11-16T18:21:31.229Z]: (1447698091230): memlim: 767557632
xdk:server:[2015-11-16T18:21:31.233Z]: (1447698091233): Setting NW crash dump to: C:\Users\Tedd\AppData\Local\XDK
xdk:server:[2015-11-16T18:21:31.409Z]: (1447698091409): Starting server process initialization
xdk:server:[2015-11-16T18:21:31.561Z]: (1447698091561): Http server started on the standard port 58889
xdk:server:[2015-11-16T18:21:32.584Z]: (1447698092584): Component "core:assert" starting import
xdk:server:[2015-11-16T18:21:32.584Z]: (1447698092584): Component "core:assert" finished initialization
xdk:server:[2015-11-16T18:21:32.584Z]: (1447698092584): Component "core:component-error" starting import
xdk:server:[2015-11-16T18:21:32.584Z]: (1447698092584): Component "core:component-error" finished initialization
xdk:server:[2015-11-16T18:21:32.584Z]: (1447698092584): Component "core:command-line-options" starting import
xdk:server:[2015-11-16T18:21:32.584Z]: (1447698092584): Component "core:command-line-options" finished initialization
xdk:server:[2015-11-16T18:21:32.584Z]: (1447698092584): Component "core:service-error" starting import
xdk:server:[2015-11-16T18:21:32.584Z]: (1447698092584): Component "core:service-error" finished initialization
xdk:server:[2015-11-16T18:21:32.584Z]: (1447698092584): Component "core:buffer" starting import
xdk:server:[2015-11-16T18:21:32.585Z]: (1447698092585): Component "core:buffer" finished initialization
xdk:server:[2015-11-16T18:21:32.585Z]: (1447698092585): Component "core:signaler" starting import
xdk:server:[2015-11-16T18:21:32.587Z]: (1447698092587): Component "core:signaler" finished initialization
xdk:server:[2015-11-16T18:21:32.587Z]: (1447698092587): Component "core:signaler-group" starting import
xdk:server:[2015-11-16T18:21:32.589Z]: (1447698092589): Component "core:signaler-group" finished initialization
xdk:server:[2015-11-16T18:21:32.589Z]: (1447698092589): Component "core:logger" starting import
xdk:server:[2015-11-16T18:21:32.591Z]: (1447698092591): Component "core:logger" finished initialization
xdk:server:[2015-11-16T18:21:32.591Z]: (1447698092591): Component "core:http-request" starting import
xdk:server:[2015-11-16T18:21:32.592Z]: (1447698092592): Component "core:http-request" finished initialization
xdk:server:[2015-11-16T18:21:32.593Z]: (1447698092593): Component "core:database" starting import
xdk:server:[2015-11-16T18:21:32.594Z]: (1447698092594): Component "core:database" finished initialization
xdk:server:[2015-11-16T18:21:32.594Z]: (1447698092594): Component "core:version" starting import
xdk:server:[2015-11-16T18:21:32.594Z]: (1447698092594): Component "core:version" finished initialization
xdk:server:[2015-11-16T18:21:32.594Z]: (1447698092594): Component "core:userfs-name-converter" starting import
xdk:server:[2015-11-16T18:21:32.595Z]: (1447698092595): Component "core:userfs-name-converter" finished initialization
xdk:server:[2015-11-16T18:21:32.595Z]: (1447698092595): Component "core:crash-handler" starting import
xdk:server:[2015-11-16T18:21:32.597Z]: (1447698092597): Component "core:crash-handler" finished initialization
xdk:server:[2015-11-16T18:21:32.597Z]: (1447698092597): Component "core:i18n-support" starting import
xdk:server:[2015-11-16T18:21:32.597Z]: (1447698092597): Component "core:i18n-support" finished initialization
xdk:server:[2015-11-16T18:21:32.597Z]: (1447698092597): Component "core:theme" starting import
xdk:server:[2015-11-16T18:21:32.631Z]: (1447698092631): Component "core:theme" finished initialization
xdk:server:[2015-11-16T18:21:32.632Z]: (1447698092632): Component "server:userfs" starting import
xdk:server:[2015-11-16T18:21:32.640Z]: (1447698092640): Component "server:userfs" calling init()
xdk:server:[2015-11-16T18:21:32.680Z]: (1447698092680): Component "server:userfs" finished initialization
xdk:server:[2015-11-16T18:21:32.680Z]: (1447698092680): Component "server:user-profile" starting import
xdk:server:[2015-11-16T18:21:32.684Z]: (1447698092684): Component "server:user-profile" calling init()
xdk:server:[2015-11-16T18:21:32.684Z]: (1447698092684): Component "server:user-profile" finished initialization
xdk:server:[2015-11-16T18:21:32.684Z]: (1447698092684): Component "server:ui-builder" starting import
xdk:server:[2015-11-16T18:21:32.768Z]: (1447698092768): Component "server:ui-builder" calling init()
xdk:server:[2015-11-16T18:21:32.769Z]: (1447698092769): Component "server:ui-builder" finished initialization
xdk:server:[2015-11-16T18:21:32.769Z]: (1447698092769): Component "server:emulator-notification" starting import
xdk:server:[2015-11-16T18:21:32.773Z]: (1447698092773): Component "server:emulator-notification" calling init()
xdk:server:[2015-11-16T18:21:32.774Z]: (1447698092774): Component "server:emulator-notification" finished initialization
xdk:server:[2015-11-16T18:21:32.774Z]: (1447698092774): Component "server:emulator-webserver" starting import
xdk:server:[2015-11-16T18:21:32.776Z]: (1447698092776): Component "server:emulator-webserver" calling init()
xdk:server:[2015-11-16T18:21:32.777Z]: (1447698092777): Component "server:emulator-webserver" finished initialization
xdk:server:[2015-11-16T18:21:32.777Z]: (1447698092777): Component "server:new-project-creator" starting import
xdk:server:[2015-11-16T18:21:32.782Z]: (1447698092782): Component "server:new-project-creator" calling init()
xdk:server:[2015-11-16T18:21:32.782Z]: (1447698092782): Component "server:new-project-creator" finished initialization
xdk:server:[2015-11-16T18:21:32.782Z]: (1447698092782): Component "server:zip-util" starting import
xdk:server:[2015-11-16T18:21:32.786Z]: (1447698092786): Component "server:zip-util" calling init()
xdk:server:[2015-11-16T18:21:32.786Z]: (1447698092786): Component "server:zip-util" finished initialization
xdk:server:[2015-11-16T18:21:32.786Z]: (1447698092786): Component "server:uuid-server" starting import
xdk:server:[2015-11-16T18:21:32.795Z]: (1447698092795): Component "server:uuid-server" calling init()
xdk:server:[2015-11-16T18:21:32.795Z]: (1447698092795): Component "server:uuid-server" finished initialization
xdk:server:[2015-11-16T18:21:32.795Z]: (1447698092795): Component "server:app-starter" starting import
xdk:server:[2015-11-16T18:21:32.805Z]: (1447698092805): Component "server:app-starter" calling init()
xdk:server:[2015-11-16T18:21:32.807Z]: (1447698092807): Component "server:app-starter" finished initialization
xdk:server:[2015-11-16T18:21:32.807Z]: (1447698092807): Component "server:force-download" starting import
xdk:server:[2015-11-16T18:21:32.810Z]: (1447698092810): Component "server:force-download" calling init()
xdk:server:[2015-11-16T18:21:32.811Z]: (1447698092811): Component "server:force-download" finished initialization
xdk:server:[2015-11-16T18:21:32.811Z]: (1447698092811): Component "server:updater" starting import
xdk:server:[2015-11-16T18:21:32.817Z]: (1447698092817): Component "server:updater" calling init()
server:updater:[2015-11-16T18:21:32.817Z]: (1447698092817): config.base-auto
server:updater:[2015-11-16T18:21:32.817Z]: (1447698092817): url=auto
xdk:server:[2015-11-16T18:21:32.817Z]: (1447698092817): Component "server:updater" finished initialization
xdk:server:[2015-11-16T18:21:32.817Z]: (1447698092817): Component "server:editor-node" starting import
xdk:server:[2015-11-16T18:21:32.851Z]: (1447698092851): Component "server:editor-node" calling init()
xdk:server:[2015-11-16T18:21:32.852Z]: (1447698092852): Component "server:editor-node" waiting for delayed initialization
xdk:server:[2015-11-16T18:21:32.852Z]: (1447698092852): Component "server:cordova-lib" starting import
xdk:server:[2015-11-16T18:21:33.316Z]: (1447698093316): Component "server:cordova-lib" calling init()
xdk:server:[2015-11-16T18:21:33.400Z]: (1447698093400): Component "server:cordova-lib" finished initialization
xdk:server:[2015-11-16T18:21:33.400Z]: (1447698093400): Component "server:api-explorer" starting import
xdk:server:[2015-11-16T18:21:33.408Z]: (1447698093408): Component "server:api-explorer" calling init()
xdk:server:[2015-11-16T18:21:33.464Z]: (1447698093464): Component "server:api-explorer" finished initialization
xdk:server:[2015-11-16T18:21:33.464Z]: (1447698093464): Component "server:plugin-listener" starting import
xdk:server:[2015-11-16T18:21:33.467Z]: (1447698093467): Component "server:plugin-listener" calling init()
xdk:server:[2015-11-16T18:21:33.468Z]: (1447698093468): Component "server:plugin-listener" finished initialization
xdk:server:[2015-11-16T18:21:33.468Z]: (1447698093468): Component "server:git-runner" starting import
xdk:server:[2015-11-16T18:21:33.471Z]: (1447698093471): Component "server:git-runner" calling init()
xdk:server:[2015-11-16T18:21:33.472Z]: (1447698093472): Component "server:git-runner" finished initialization
server:editor-node:[2015-11-16T18:21:33.473Z]: (1447698093473): Starting Brackets node process C:\Users\Tedd\AppData\Local\Intel\XDK\bin\node.exe C:\Users\Tedd\AppData\Local\Intel\XDK\bin\node-core
xdk:server:[2015-11-16T18:21:33.752Z]: (1447698093752): NW Cache is up-to-date.
server:editor-node:[2015-11-16T18:21:33.854Z]: (1447698093854): Brackets node is running on port 61013
xdk:server:[2015-11-16T18:21:33.855Z]: (1447698093855): Component "server:editor-node" finished delayed initialization
xdk:server:[2015-11-16T18:21:33.855Z]: (1447698093855): Component "server:ui-builder" calling start()
xdk:server:[2015-11-16T18:21:33.858Z]: (1447698093858): Component "server:ui-builder" finished start()
xdk:server:[2015-11-16T18:21:33.858Z]: (1447698093858): Component "server:emulator-webserver" calling start()
xdk:server:[2015-11-16T18:21:33.858Z]: (1447698093858): Component "server:emulator-webserver" finished start()
xdk:server:[2015-11-16T18:21:33.858Z]: (1447698093858): Component "server:editor-node" calling start()
xdk:server:[2015-11-16T18:21:33.858Z]: (1447698093858): Component "server:editor-node" finished start()
xdk:server:[2015-11-16T18:21:33.859Z]: (1447698093859): Intel XDK is initialized now
xdk:server:[2015-11-16T18:21:33.859Z]: (1447698093859): Writing to the server data file
xdk:server:[2015-11-16T18:21:33.860Z]: (1447698093860): Wrote server data to "C:\Users\Tedd\AppData\Local\XDK\server-data.txt"
xdk:client:[2015-11-16T18:21:33.980Z]: (1447698093980): Successfully read server data file
xdk:client:[2015-11-16T18:21:34.124Z]: (1447698094124): Component "core:assert" starting import
xdk:client:[2015-11-16T18:21:34.124Z]: (1447698094124): Component "core:assert" finished initialization
xdk:client:[2015-11-16T18:21:34.124Z]: (1447698094124): Component "core:component-error" starting import
xdk:client:[2015-11-16T18:21:34.125Z]: (1447698094125): Component "core:component-error" finished initialization
xdk:client:[2015-11-16T18:21:34.125Z]: (1447698094125): Component "core:command-line-options" starting import
xdk:client:[2015-11-16T18:21:34.125Z]: (1447698094125): Component "core:command-line-options" finished initialization
xdk:client:[2015-11-16T18:21:34.125Z]: (1447698094125): Component "core:service-error" starting import
xdk:client:[2015-11-16T18:21:34.125Z]: (1447698094125): Component "core:service-error" finished initialization
xdk:client:[2015-11-16T18:21:34.125Z]: (1447698094125): Component "core:buffer" starting import
xdk:client:[2015-11-16T18:21:34.125Z]: (1447698094125): Component "core:buffer" finished initialization
xdk:client:[2015-11-16T18:21:34.125Z]: (1447698094125): Component "core:signaler" starting import
xdk:client:[2015-11-16T18:21:34.126Z]: (1447698094126): Component "core:signaler" finished initialization
xdk:client:[2015-11-16T18:21:34.126Z]: (1447698094126): Component "core:signaler-group" starting import
xdk:client:[2015-11-16T18:21:34.127Z]: (1447698094127): Component "core:signaler-group" finished initialization
xdk:client:[2015-11-16T18:21:34.127Z]: (1447698094127): Component "core:logger" starting import
xdk:client:[2015-11-16T18:21:34.128Z]: (1447698094128): Component "core:logger" finished initialization
xdk:client:[2015-11-16T18:21:34.128Z]: (1447698094128): Component "core:http-request" starting import
xdk:client:[2015-11-16T18:21:34.129Z]: (1447698094129): Component "core:http-request" finished initialization
xdk:client:[2015-11-16T18:21:34.129Z]: (1447698094129): Component "core:version" starting import
xdk:client:[2015-11-16T18:21:34.129Z]: (1447698094129): Component "core:version" finished initialization
xdk:client:[2015-11-16T18:21:34.129Z]: (1447698094129): Component "core:exit-notifier" starting import
xdk:client:[2015-11-16T18:21:34.129Z]: (1447698094129): Component "core:exit-notifier" finished initialization
xdk:client:[2015-11-16T18:21:34.129Z]: (1447698094129): Component "core:userfs-name-converter" starting import
xdk:client:[2015-11-16T18:21:34.129Z]: (1447698094129): Component "core:userfs-name-converter" finished initialization
xdk:client:[2015-11-16T18:21:34.129Z]: (1447698094129): Component "core:crash-handler" starting import
xdk:client:[2015-11-16T18:21:34.130Z]: (1447698094130): Component "core:crash-handler" finished initialization
xdk:client:[2015-11-16T18:21:34.130Z]: (1447698094130): Component "core:analytics" starting import
xdk:client:[2015-11-16T18:21:34.130Z]: (1447698094130): Component "core:analytics" finished initialization
xdk:client:[2015-11-16T18:21:34.130Z]: (1447698094130): Component "core:i18n-support" starting import
xdk:client:[2015-11-16T18:21:34.130Z]: (1447698094130): Component "core:i18n-support" finished initialization
xdk:client:[2015-11-16T18:21:34.130Z]: (1447698094130): Component "core:theme" starting import
xdk:client:[2015-11-16T18:21:34.130Z]: (1447698094130): Component "core:theme" finished initialization
xdk:client:[2015-11-16T18:21:34.135Z]: (1447698094135): Analytics ID: 82eddfd5-9631-4103-96ba-e541ca5d7af9
xdk:client:[2015-11-16T18:21:34.149Z]: (1447698094149): Component "client:app" starting import
xdk:client:[2015-11-16T18:21:34.149Z]: (1447698094149): Component "client:help-helper" starting import
xdk:client:[2015-11-16T18:21:34.149Z]: (1447698094149): Component "client:nativefs" starting import
xdk:client:[2015-11-16T18:21:34.149Z]: (1447698094149): Component "client:document-manager" starting import
xdk:client:[2015-11-16T18:21:34.149Z]: (1447698094149): Component "client:project-manager" starting import
xdk:client:[2015-11-16T18:21:34.149Z]: (1447698094149): Component "client:aa-controller" starting import
xdk:client:[2015-11-16T18:21:34.149Z]: (1447698094149): Component "client:projects-renderers" starting import
xdk:client:[2015-11-16T18:21:34.149Z]: (1447698094149): Component "client:projects-renderers-jsapp" starting import
xdk:client:[2015-11-16T18:21:34.149Z]: (1447698094149): Component "client:projects-renderers-webapp" starting import
xdk:client:[2015-11-16T18:21:34.149Z]: (1447698094149): Component "client:projects-renderers-iotapp" starting import
xdk:client:[2015-11-16T18:21:34.149Z]: (1447698094149): Component "client:active-sync" starting import
xdk:client:[2015-11-16T18:21:34.149Z]: (1447698094149): Component "client:apk-installer" starting import
xdk:client:[2015-11-16T18:21:34.149Z]: (1447698094149): Component "client:appcenter-options" starting import
xdk:client:[2015-11-16T18:21:34.149Z]: (1447698094149): Component "client:resource-manager" starting import
xdk:client:[2015-11-16T18:21:34.149Z]: (1447698094149): Component "client:resource-cocos2d" starting import
xdk:client:[2015-11-16T18:21:34.149Z]: (1447698094149): Component "client:resource-cocos2djs" starting import
xdk:client:[2015-11-16T18:21:34.149Z]: (1447698094149): Component "client:resource-phaser" starting import
xdk:client:[2015-11-16T18:21:34.149Z]: (1447698094149): Component "client:resource-pixi" starting import
xdk:client:[2015-11-16T18:21:34.149Z]: (1447698094149): Component "client:resource-easeljs" starting import
xdk:client:[2015-11-16T18:21:34.149Z]: (1447698094149): Component "client:resource-plain" starting import
xdk:client:[2015-11-16T18:21:34.149Z]: (1447698094149): Component "client:resource-render-frame" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:resource-util" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:services-tab" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:editor" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:live-preview" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:backend-services" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:backend-feeds" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:merged-feed" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:backend-services-ext" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:backend-service-utils" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:app-starter" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:ui-builder-client" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:project-meta" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:contenttype-registry" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:editor-registry" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:platform-registry" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:projecttype-registry" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:library-registry" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:cordova-registry" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:service-method" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:settings-db" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:adb" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:iosdb" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:device" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:device-discovery" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:dialog-box" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:test-local-server" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:quick-tour" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:hot-keys" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:persistance" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:tabs" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:hash-utils" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:file-watcher" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:tool-tip" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:cordova" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:settings-ui" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:external-links" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:external-editors-runner" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:project-list-load" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:upload-manager" starting import
xdk:client:[2015-11-16T18:21:34.150Z]: (1447698094150): Component "client:git-manager" starting import
xdk:client:[2015-11-16T18:21:34.167Z]: (1447698094167): Component "client:help-helper" finished initialization
xdk:client:[2015-11-16T18:21:34.168Z]: (1447698094168): Component "client:nativefs" finished initialization
xdk:client:[2015-11-16T18:21:34.194Z]: (1447698094194): Component "client:apk-installer" calling init()
xdk:client:[2015-11-16T18:21:34.194Z]: (1447698094194): Component "client:apk-installer" finished initialization
xdk:client:[2015-11-16T18:21:34.196Z]: (1447698094196): Component "client:active-sync" calling init()
xdk:client:[2015-11-16T18:21:34.196Z]: (1447698094196): Component "client:active-sync" finished initialization
xdk:client:[2015-11-16T18:21:34.219Z]: (1447698094219): Component "client:resource-render-frame" calling init()
xdk:client:[2015-11-16T18:21:34.219Z]: (1447698094219): Component "client:resource-render-frame" waiting for delayed initialization
xdk:client:[2015-11-16T18:21:34.221Z]: (1447698094222): Component "client:backend-services" calling init()
xdk:client:[2015-11-16T18:21:34.222Z]: (1447698094222): Component "client:backend-services" finished initialization
xdk:client:[2015-11-16T18:21:34.223Z]: (1447698094223): Component "client:resource-util" calling init()
xdk:client:[2015-11-16T18:21:34.223Z]: (1447698094223): Component "client:resource-util" finished initialization
xdk:client:[2015-11-16T18:21:34.224Z]: (1447698094224): Component "client:merged-feed" finished initialization
xdk:client:[2015-11-16T18:21:34.224Z]: (1447698094224): Component "client:backend-services-ext" calling init()
xdk:client:[2015-11-16T18:21:34.225Z]: (1447698094225): Component "client:backend-services-ext" finished initialization
xdk:client:[2015-11-16T18:21:34.225Z]: (1447698094225): Component "client:backend-feeds" calling init()
xdk:client:[2015-11-16T18:21:34.225Z]: (1447698094225): Component "client:backend-feeds" finished initialization
xdk:client:[2015-11-16T18:21:34.226Z]: (1447698094226): Component "client:backend-service-utils" finished initialization
xdk:client:[2015-11-16T18:21:34.227Z]: (1447698094227): Component "client:project-meta" calling init()
xdk:client:[2015-11-16T18:21:34.227Z]: (1447698094227): Component "client:project-meta" finished initialization
xdk:client:[2015-11-16T18:21:34.233Z]: (1447698094233): Component "client:settings-db" calling init()
xdk:client:[2015-11-16T18:21:34.234Z]: (1447698094234): Component "client:settings-db" waiting for delayed initialization
xdk:client:[2015-11-16T18:21:34.234Z]: (1447698094234): Component "client:adb" calling init()
xdk:client:[2015-11-16T18:21:34.243Z]: (1447698094243): Component "client:adb" waiting for delayed initialization
xdk:client:[2015-11-16T18:21:34.244Z]: (1447698094244): Component "client:iosdb" calling init()
xdk:client:[2015-11-16T18:21:34.245Z]: (1447698094245): Component "client:iosdb" finished initialization
xdk:client:[2015-11-16T18:21:34.246Z]: (1447698094246): Component "client:service-method" finished initialization
xdk:client:[2015-11-16T18:21:34.248Z]: (1447698094248): Component "client:device" finished initialization
xdk:client:[2015-11-16T18:21:34.251Z]: (1447698094251): Component "client:persistance" calling init()
xdk:client:[2015-11-16T18:21:34.251Z]: (1447698094251): Component "client:persistance" waiting for delayed initialization
xdk:client:[2015-11-16T18:21:34.253Z]: (1447698094253): Component "client:file-watcher" calling init()
xdk:client:[2015-11-16T18:21:34.253Z]: (1447698094253): Component "client:file-watcher" finished initialization
xdk:client:[2015-11-16T18:21:34.255Z]: (1447698094255): Component "client:external-editors-runner" calling init()
xdk:client:[2015-11-16T18:21:34.255Z]: (1447698094255): Component "client:external-editors-runner" finished initialization
xdk:client:[2015-11-16T18:21:34.255Z]: (1447698094255): Component "client:project-list-load" calling init()
xdk:client:[2015-11-16T18:21:34.255Z]: (1447698094255): Component "client:project-list-load" waiting for delayed initialization
xdk:client:[2015-11-16T18:21:34.256Z]: (1447698094256): Component "client:upload-manager" calling init()
xdk:client:[2015-11-16T18:21:34.256Z]: (1447698094256): Component "client:upload-manager" finished initialization
xdk:client:[2015-11-16T18:21:34.257Z]: (1447698094257): Component "client:external-links" finished initialization
xdk:client:[2015-11-16T18:21:34.259Z]: (1447698094259): Component "client:git-manager" calling init()
client:git-manager:[2015-11-16T18:21:34.260Z]: (1447698094260): git path =  C:\Users\Tedd\AppData\Local\Intel\XDK\bin\git\bin\git.exe
xdk:client:[2015-11-16T18:21:34.260Z]: (1447698094260): Component "client:git-manager" waiting for delayed initialization
xdk:client:[2015-11-16T18:21:34.260Z]: (1447698094260): Component "client:document-manager" calling init()
xdk:client:[2015-11-16T18:21:34.261Z]: (1447698094261): Component "client:document-manager" finished initialization
xdk:client:[2015-11-16T18:21:34.262Z]: (1447698094262): Component "client:app-starter" finished initialization
xdk:client:[2015-11-16T18:21:34.263Z]: (1447698094263): Component "client:hot-keys" calling init()
xdk:client:[2015-11-16T18:21:34.263Z]: (1447698094263): Component "client:hot-keys" finished initialization
xdk:client:[2015-11-16T18:21:34.269Z]: (1447698094269): Component "client:aa-controller" calling init()
xdk:client:[2015-11-16T18:21:34.269Z]: (1447698094269): Component "client:aa-controller" finished initialization
xdk:client:[2015-11-16T18:21:34.275Z]: (1447698094275): Component "client:resource-render-frame" finished delayed initialization
xdk:client:[2015-11-16T18:21:34.284Z]: (1447698094284): Component "client:ui-builder-client" calling init()
xdk:client:[2015-11-16T18:21:34.284Z]: (1447698094284): Component "client:ui-builder-client" finished initialization
xdk:client:[2015-11-16T18:21:34.285Z]: (1447698094285): Component "client:dialog-box" finished initialization
xdk:client:[2015-11-16T18:21:34.287Z]: (1447698094287): Component "client:tool-tip" finished initialization
xdk:client:[2015-11-16T18:21:34.288Z]: (1447698094288): Component "client:settings-ui" finished initialization
xdk:client:[2015-11-16T18:21:34.341Z]: (1447698094341): Component "client:contenttype-registry" calling init()
xdk:client:[2015-11-16T18:21:34.342Z]: (1447698094342): Component "client:contenttype-registry" finished initialization
xdk:client:[2015-11-16T18:21:34.343Z]: (1447698094343): Component "client:editor-registry" finished initialization
xdk:client:[2015-11-16T18:21:34.349Z]: (1447698094349): Component "client:appcenter-options" calling init()
xdk:client:[2015-11-16T18:21:34.349Z]: (1447698094349): Component "client:appcenter-options" waiting for delayed initialization
xdk:client:[2015-11-16T18:21:34.350Z]: (1447698094350): Component "client:services-tab" calling init()
xdk:client:[2015-11-16T18:21:34.351Z]: (1447698094351): Component "client:services-tab" finished initialization
xdk:client:[2015-11-16T18:21:34.353Z]: (1447698094353): Component "client:test-local-server" calling init()
xdk:client:[2015-11-16T18:21:34.380Z]: (1447698094380): Component "client:test-local-server" finished initialization
xdk:client:[2015-11-16T18:21:34.380Z]: (1447698094380): Component "client:tabs" finished initialization
xdk:client:[2015-11-16T18:21:34.383Z]: (1447698094383): Component "client:app" calling init()
xdk:client:[2015-11-16T18:21:34.391Z]: (1447698094391): Component "client:app" finished initialization
xdk:client:[2015-11-16T18:21:34.393Z]: (1447698094393): Component "client:library-registry" calling init()
xdk:client:[2015-11-16T18:21:34.393Z]: (1447698094393): Component "client:library-registry" finished initialization
xdk:client:[2015-11-16T18:21:34.399Z]: (1447698094399): Component "client:device-discovery" calling init()
xdk:client:[2015-11-16T18:21:34.399Z]: (1447698094399): Component "client:device-discovery" waiting for delayed initialization
xdk:client:[2015-11-16T18:21:34.400Z]: (1447698094400): Component "client:hash-utils" finished initialization
xdk:client:[2015-11-16T18:21:34.442Z]: (1447698094442): Component "client:cordova" calling init()
xdk:client:[2015-11-16T18:21:34.442Z]: (1447698094442): Component "client:cordova" waiting for delayed initialization
xdk:client:[2015-11-16T18:21:34.442Z]: (1447698094442): Component "client:navbar" starting import
xdk:client:[2015-11-16T18:21:34.442Z]: (1447698094442): Component "client:tweets" starting import
xdk:client:[2015-11-16T18:21:34.442Z]: (1447698094442): Component "client:projects-tab" starting import
xdk:client:[2015-11-16T18:21:34.443Z]: (1447698094443): Component "client:test-tab" starting import
xdk:client:[2015-11-16T18:21:34.443Z]: (1447698094443): Component "client:profilingTab" starting import
xdk:client:[2015-11-16T18:21:34.443Z]: (1447698094443): Component "client:emulator" starting import
xdk:client:[2015-11-16T18:21:34.443Z]: (1447698094443): Component "client:remote-tab" starting import
xdk:client:[2015-11-16T18:21:34.443Z]: (1447698094443): Component "client:build-tab" starting import
xdk:client:[2015-11-16T18:21:34.443Z]: (1447698094443): Component "client:editor-tab" starting import
xdk:client:[2015-11-16T18:21:34.443Z]: (1447698094443): Component "client:account" starting import
xdk:client:[2015-11-16T18:21:34.443Z]: (1447698094443): Component "client:project-selector" starting import
xdk:client:[2015-11-16T18:21:34.445Z]: (1447698094445): Component "client:device-discovery" finished delayed initialization
client:adb:[2015-11-16T18:21:34.448Z]: (1447698094448): Can't find adb process.
client:adb:[2015-11-16T18:21:34.448Z]: (1447698094448): Using default adb executable at "C:\Users\Tedd\AppData\Local\Intel\XDK\bin\adb\adb"
xdk:client:[2015-11-16T18:21:34.461Z]: (1447698094461): Component "client:resource-manager" calling init()
xdk:client:[2015-11-16T18:21:34.461Z]: (1447698094461): Component "client:resource-manager" waiting for delayed initialization
xdk:client:[2015-11-16T18:21:34.467Z]: (1447698094467): Component "client:resource-cocos2djs" calling init()
xdk:client:[2015-11-16T18:21:34.467Z]: (1447698094467): Component "client:resource-cocos2djs" finished initialization
xdk:client:[2015-11-16T18:21:34.469Z]: (1447698094469): Component "client:resource-phaser" calling init()
xdk:client:[2015-11-16T18:21:34.469Z]: (1447698094469): Component "client:resource-phaser" finished initialization
xdk:client:[2015-11-16T18:21:34.471Z]: (1447698094471): Component "client:resource-easeljs" calling init()
xdk:client:[2015-11-16T18:21:34.471Z]: (1447698094471): Component "client:resource-easeljs" finished initialization
xdk:client:[2015-11-16T18:21:34.472Z]: (1447698094472): Component "client:resource-pixi" calling init()
xdk:client:[2015-11-16T18:21:34.472Z]: (1447698094472): Component "client:resource-pixi" finished initialization
xdk:client:[2015-11-16T18:21:34.473Z]: (1447698094473): Component "client:resource-plain" calling init()
xdk:client:[2015-11-16T18:21:34.473Z]: (1447698094473): Component "client:resource-plain" finished initialization
xdk:client:[2015-11-16T18:21:34.476Z]: (1447698094476): Component "client:cordova-registry" calling init()
xdk:client:[2015-11-16T18:21:34.476Z]: (1447698094476): Component "client:cordova-registry" waiting for delayed initialization
xdk:client:[2015-11-16T18:21:34.480Z]: (1447698094480): Component "client:projects-renderers" calling init()
xdk:client:[2015-11-16T18:21:34.480Z]: (1447698094480): Component "client:projects-renderers" waiting for delayed initialization
xdk:client:[2015-11-16T18:21:34.480Z]: (1447698094480): Component "client:projects-renderers-iotapp" calling init()
xdk:client:[2015-11-16T18:21:34.481Z]: (1447698094481): Component "client:projects-renderers-iotapp" finished initialization
xdk:client:[2015-11-16T18:21:34.485Z]: (1447698094485): Component "client:quick-tour" calling init()
xdk:client:[2015-11-16T18:21:34.485Z]: (1447698094485): Component "client:quick-tour" finished initialization
xdk:client:[2015-11-16T18:21:34.494Z]: (1447698094494): Component "client:resource-cocos2d" calling init()
xdk:client:[2015-11-16T18:21:34.494Z]: (1447698094494): Component "client:resource-cocos2d" waiting for delayed initialization
xdk:client:[2015-11-16T18:21:34.505Z]: (1447698094505): Component "client:project-manager" calling init()
xdk:client:[2015-11-16T18:21:34.505Z]: (1447698094505): Component "client:project-manager" waiting for delayed initialization
xdk:client:[2015-11-16T18:21:34.511Z]: (1447698094511): Component "client:projecttype-registry" calling init()
xdk:client:[2015-11-16T18:21:34.511Z]: (1447698094511): Component "client:projecttype-registry" finished initialization
xdk:client:[2015-11-16T18:21:34.514Z]: (1447698094514): Component "client:platform-registry" calling init()
xdk:client:[2015-11-16T18:21:34.514Z]: (1447698094514): Component "client:platform-registry" finished initialization
xdk:client:[2015-11-16T18:21:34.515Z]: (1447698094515): Component "client:resource-cocos2d" finished delayed initialization
xdk:client:[2015-11-16T18:21:34.516Z]: (1447698094516): Component "client:settings-db" finished delayed initialization
xdk:client:[2015-11-16T18:21:34.549Z]: (1447698094549): Component "client:git-manager" finished delayed initialization
xdk:client:[2015-11-16T18:21:34.569Z]: (1447698094569): Component "client:projects-tab" getting UI region for "project"
xdk:client:[2015-11-16T18:21:34.570Z]: (1447698094570): Component "client:projects-tab" calling init()
xdk:client:[2015-11-16T18:21:34.570Z]: (1447698094570): Component "client:projects-tab" waiting for delayed initialization
xdk:client:[2015-11-16T18:21:34.572Z]: (1447698094572): Component "client:test-tab" getting UI region for "test"
xdk:client:[2015-11-16T18:21:34.572Z]: (1447698094572): Component "client:test-tab" calling init()
xdk:client:[2015-11-16T18:21:34.572Z]: (1447698094572): Component "client:test-tab" waiting for delayed initialization
xdk:client:[2015-11-16T18:21:34.579Z]: (1447698094579): Component "client:emulator" getting UI region for "emulate"
xdk:client:[2015-11-16T18:21:34.579Z]: (1447698094579): Component "client:emulator" calling init()
xdk:client:[2015-11-16T18:21:34.580Z]: (1447698094580): Component "client:emulator" finished initialization
xdk:client:[2015-11-16T18:21:34.588Z]: (1447698094588): Component "client:projects-renderers-webapp" calling init()
xdk:client:[2015-11-16T18:21:34.588Z]: (1447698094588): Component "client:projects-renderers-webapp" finished initialization
xdk:client:[2015-11-16T18:21:34.591Z]: (1447698094591): Component "client:projects-renderers-jsapp" calling init()
xdk:client:[2015-11-16T18:21:34.592Z]: (1447698094592): Component "client:projects-renderers-jsapp" finished initialization
xdk:client:[2015-11-16T18:21:34.592Z]: (1447698094592): Component "client:tweets" finished initialization
xdk:client:[2015-11-16T18:21:34.597Z]: (1447698094597): Component "client:projects-renderers" finished delayed initialization
xdk:client:[2015-11-16T18:21:34.599Z]: (1447698094599): Component "client:build-tab" getting UI region for "build"
xdk:client:[2015-11-16T18:21:34.599Z]: (1447698094599): Component "client:build-tab" calling init()
xdk:client:[2015-11-16T18:21:34.602Z]: (1447698094602): Component "client:build-tab" finished initialization
xdk:client:[2015-11-16T18:21:34.604Z]: (1447698094604): Component "client:cordova" finished delayed initialization
xdk:client:[2015-11-16T18:21:34.609Z]: (1447698094609): Component "client:project-selector" getting UI region for "project-selector"
xdk:client:[2015-11-16T18:21:34.609Z]: (1447698094609): Component "client:project-selector" calling init()
xdk:client:[2015-11-16T18:21:34.609Z]: (1447698094609): Component "client:project-selector" finished initialization
xdk:client:[2015-11-16T18:21:34.610Z]: (1447698094610): Component "client:account" getting UI region for "account"
xdk:client:[2015-11-16T18:21:34.610Z]: (1447698094610): Component "client:account" calling init()
xdk:client:[2015-11-16T18:21:34.613Z]: (1447698094613): Component "client:account" finished initialization
xdk:client:[2015-11-16T18:21:34.616Z]: (1447698094616): Component "client:navbar" getting UI region for "navbar-common"
xdk:client:[2015-11-16T18:21:34.616Z]: (1447698094616): Component "client:navbar" calling init()
client:navbar:[2015-11-16T18:21:34.617Z]: (1447698094617): navbar options: {"common":{"servicesVersion":"release-2015-ww45","xdkVariant":"xdk"},"updatePollingInterval":1800,"forceUpdate":false}
xdk:client:[2015-11-16T18:21:34.617Z]: (1447698094617): Component "client:navbar" finished initialization
xdk:client:[2015-11-16T18:21:34.620Z]: (1447698094620): Component "client:editor" calling init()
xdk:client:[2015-11-16T18:21:34.620Z]: (1447698094620): Component "client:editor" finished initialization
xdk:client:[2015-11-16T18:21:34.620Z]: (1447698094620): Component "client:live-preview" calling init()
xdk:client:[2015-11-16T18:21:34.620Z]: (1447698094620): Component "client:live-preview" finished initialization
xdk:client:[2015-11-16T18:21:34.620Z]: (1447698094620): Component "client:editor-tab" getting UI region for "develop"
xdk:client:[2015-11-16T18:21:34.620Z]: (1447698094620): Component "client:editor-tab" calling init()
xdk:client:[2015-11-16T18:21:34.626Z]: (1447698094626): Component "client:editor-tab" waiting for delayed initialization
xdk:client:[2015-11-16T18:21:34.653Z]: (1447698094653): Component "client:remote-tab" getting UI region for "debug"
xdk:client:[2015-11-16T18:21:34.653Z]: (1447698094653): Component "client:remote-tab" calling init()
xdk:client:[2015-11-16T18:21:34.922Z]: (1447698094922): Component "client:remote-tab" waiting for delayed initialization
xdk:client:[2015-11-16T18:21:34.923Z]: (1447698094923): Component "client:remote-tab" finished delayed initialization
xdk:client:[2015-11-16T18:21:34.955Z]: (1447698094955): Component "client:profilingTab" getting UI region for "profile"
xdk:client:[2015-11-16T18:21:34.955Z]: (1447698094955): Component "client:profilingTab" calling init()
xdk:client:[2015-11-16T18:21:34.956Z]: (1447698094956): Component "client:profilingTab" finished initialization
xdk:client:[2015-11-16T18:21:35.221Z]: (1447698095221): memmrk:    30033388    42403456
client:appcenter-options:[2015-11-16T18:21:35.704Z]: (1447698095704): Fetch Status: 1, Message: Feched latest appcenter-options info because network is available.
xdk:client:[2015-11-16T18:21:35.710Z]: (1447698095710): Component "client:appcenter-options" finished delayed initialization
xdk:client:[2015-11-16T18:21:35.711Z]: (1447698095711): Component "client:test-tab" finished delayed initialization
xdk:client:[2015-11-16T18:21:35.714Z]: (1447698095714): Component "client:cordova-registry" finished delayed initialization
xdk:client:[2015-11-16T18:21:35.722Z]: (1447698095722): Component "client:project-manager" finished delayed initialization
xdk:client:[2015-11-16T18:21:35.749Z]: (1447698095749): Component "client:project-list-load" finished delayed initialization
xdk:client:[2015-11-16T18:21:35.754Z]: (1447698095754): Component "client:persistance" finished delayed initialization
xdk:client:[2015-11-16T18:21:35.754Z]: (1447698095754): Component "client:resource-manager" finished delayed initialization
xdk:client:[2015-11-16T18:21:35.754Z]: (1447698095754): Component "client:projects-tab" finished delayed initialization
xdk:client:[2015-11-16T18:21:35.755Z]: (1447698095755): Component "client:projects-list" starting import
xdk:client:[2015-11-16T18:21:35.755Z]: (1447698095755): Component "client:projects-info" starting import
xdk:client:[2015-11-16T18:21:35.755Z]: (1447698095755): Component "client:projects-create-list" starting import
xdk:client:[2015-11-16T18:21:35.755Z]: (1447698095755): Component "client:projects-create-info" starting import
xdk:client:[2015-11-16T18:21:35.756Z]: (1447698095756): Component "client:adb" finished delayed initialization
xdk:client:[2015-11-16T18:21:35.768Z]: (1447698095768): Component "client:projects-list" getting UI region for "existing-list"
xdk:client:[2015-11-16T18:21:35.768Z]: (1447698095768): Component "client:projects-list" calling init()
xdk:client:[2015-11-16T18:21:35.769Z]: (1447698095769): Component "client:projects-list" finished initialization
xdk:client:[2015-11-16T18:21:35.770Z]: (1447698095770): Component "client:projects-info" getting UI region for "existing-info"
xdk:client:[2015-11-16T18:21:35.770Z]: (1447698095770): Component "client:projects-info" calling init()
xdk:client:[2015-11-16T18:21:35.770Z]: (1447698095770): Component "client:projects-info" finished initialization
xdk:client:[2015-11-16T18:21:35.780Z]: (1447698095780): Component "client:projects-create-info" getting UI region for "create-info"
xdk:client:[2015-11-16T18:21:35.780Z]: (1447698095780): Component "client:projects-create-info" calling init()
xdk:client:[2015-11-16T18:21:35.780Z]: (1447698095780): Component "client:projects-create-info" finished initialization
xdk:client:[2015-11-16T18:21:35.796Z]: (1447698095796): Component "client:projects-create-list" getting UI region for "create-list"
xdk:client:[2015-11-16T18:21:35.797Z]: (1447698095797): Component "client:projects-create-list" calling init()
xdk:client:[2015-11-16T18:21:35.797Z]: (1447698095797): Component "client:projects-create-list" finished initialization
xdk:server:[2015-11-16T18:21:36.232Z]: (1447698096232): memmrk:    27353756    43419136
client:services-tab:[2015-11-16T18:21:36.950Z]: (1447698096951): component:services-tab : Container provided by brackets :
client:services-tab:[2015-11-16T18:21:36.951Z]: (1447698096951): component:services-tab : mainContainer_ = XDKMiniServices-main
client:services-tab:[2015-11-16T18:21:36.951Z]: (1447698096951): component:services-tab : sidebarContainer = XDKMiniServices-list
client:services-tab:[2015-11-16T18:21:36.951Z]: (1447698096951): component:services-tab : Iframes inserted by services-tab : .
client:services-tab:[2015-11-16T18:21:36.951Z]: (1447698096951): component:services-tab : $mainContainer_ = mini-api-explorer
client:services-tab:[2015-11-16T18:21:36.951Z]: (1447698096951): component:services-tab : $sidebarContainer_ = api-sidebar
xdk:client:[2015-11-16T18:21:37.071Z]: (1447698097071): Component "client:editor-tab" finished delayed initialization
xdk:client:[2015-11-16T18:21:37.072Z]: (1447698097072): Component "client:app" calling start()
xdk:client:[2015-11-16T18:21:37.083Z]: (1447698097083): Component "client:app" finished start()
xdk:client:[2015-11-16T18:21:37.083Z]: (1447698097083): Component "client:navbar" calling start()
xdk:client:[2015-11-16T18:21:37.095Z]: (1447698097095): Component "client:navbar" finished start()
xdk:client:[2015-11-16T18:21:37.095Z]: (1447698097095): Component "client:project-manager" calling start()
xdk:client:[2015-11-16T18:21:37.095Z]: (1447698097095): Component "client:project-manager" finished start()
xdk:client:[2015-11-16T18:21:37.095Z]: (1447698097095): Component "client:aa-controller" calling start()
xdk:client:[2015-11-16T18:21:37.095Z]: (1447698097095): Component "client:aa-controller" finished start()
xdk:client:[2015-11-16T18:21:37.095Z]: (1447698097095): Component "client:projects-tab" calling start()
xdk:client:[2015-11-16T18:21:37.100Z]: (1447698097100): Component "client:projects-tab" finished start()
xdk:client:[2015-11-16T18:21:37.100Z]: (1447698097100): Component "client:projects-list" calling start()
xdk:client:[2015-11-16T18:21:37.102Z]: (1447698097102): Component "client:projects-list" finished start()
xdk:client:[2015-11-16T18:21:37.102Z]: (1447698097102): Component "client:projects-info" calling start()
xdk:client:[2015-11-16T18:21:37.213Z]: (1447698097213): Component "client:projects-info" finished start()
xdk:client:[2015-11-16T18:21:37.214Z]: (1447698097214): Component "client:projects-create-list" calling start()
xdk:client:[2015-11-16T18:21:37.235Z]: (1447698097235): Component "client:projects-create-list" finished start()
xdk:client:[2015-11-16T18:21:37.235Z]: (1447698097235): Component "client:projects-create-info" calling start()
xdk:client:[2015-11-16T18:21:37.239Z]: (1447698097239): Component "client:projects-create-info" finished start()
xdk:client:[2015-11-16T18:21:37.239Z]: (1447698097239): Component "client:test-tab" calling start()
xdk:client:[2015-11-16T18:21:37.242Z]: (1447698097242): Component "client:test-tab" finished start()
xdk:client:[2015-11-16T18:21:37.242Z]: (1447698097242): Component "client:profilingTab" calling start()
xdk:client:[2015-11-16T18:21:37.277Z]: (1447698097277): Component "client:profilingTab" finished start()
xdk:client:[2015-11-16T18:21:37.277Z]: (1447698097277): Component "client:emulator" calling start()
xdk:client:[2015-11-16T18:21:37.278Z]: (1447698097278): Component "client:emulator" finished start()
xdk:client:[2015-11-16T18:21:37.278Z]: (1447698097278): Component "client:remote-tab" calling start()
xdk:client:[2015-11-16T18:21:37.282Z]: (1447698097282): Component "client:remote-tab" finished start()
xdk:client:[2015-11-16T18:21:37.282Z]: (1447698097282): Component "client:build-tab" calling start()
xdk:client:[2015-11-16T18:21:37.284Z]: (1447698097284): Component "client:build-tab" finished start()
xdk:client:[2015-11-16T18:21:37.285Z]: (1447698097285): Component "client:active-sync" calling start()
xdk:client:[2015-11-16T18:21:37.285Z]: (1447698097285): Component "client:active-sync" finished start()
xdk:client:[2015-11-16T18:21:37.285Z]: (1447698097285): Component "client:apk-installer" calling start()
xdk:client:[2015-11-16T18:21:37.285Z]: (1447698097285): Component "client:apk-installer" finished start()
xdk:client:[2015-11-16T18:21:37.285Z]: (1447698097285): Component "client:resource-manager" calling start()
xdk:client:[2015-11-16T18:21:37.286Z]: (1447698097286): Component "client:resource-manager" finished start()
xdk:client:[2015-11-16T18:21:37.286Z]: (1447698097286): Component "client:resource-cocos2d" calling start()
xdk:client:[2015-11-16T18:21:37.286Z]: (1447698097286): Component "client:resource-cocos2d" finished start()
xdk:client:[2015-11-16T18:21:37.286Z]: (1447698097286): Component "client:resource-cocos2djs" calling start()
xdk:client:[2015-11-16T18:21:37.286Z]: (1447698097286): Component "client:resource-cocos2djs" finished start()
xdk:client:[2015-11-16T18:21:37.286Z]: (1447698097286): Component "client:resource-phaser" calling start()
xdk:client:[2015-11-16T18:21:37.286Z]: (1447698097286): Component "client:resource-phaser" finished start()
xdk:client:[2015-11-16T18:21:37.286Z]: (1447698097286): Component "client:resource-pixi" calling start()
xdk:client:[2015-11-16T18:21:37.286Z]: (1447698097286): Component "client:resource-pixi" finished start()
xdk:client:[2015-11-16T18:21:37.286Z]: (1447698097286): Component "client:resource-easeljs" calling start()
xdk:client:[2015-11-16T18:21:37.286Z]: (1447698097286): Component "client:resource-easeljs" finished start()
xdk:client:[2015-11-16T18:21:37.286Z]: (1447698097286): Component "client:resource-plain" calling start()
xdk:client:[2015-11-16T18:21:37.286Z]: (1447698097286): Component "client:resource-plain" finished start()
xdk:client:[2015-11-16T18:21:37.286Z]: (1447698097286): Component "client:resource-render-frame" calling start()
xdk:client:[2015-11-16T18:21:37.286Z]: (1447698097286): Component "client:resource-render-frame" finished start()
xdk:client:[2015-11-16T18:21:37.286Z]: (1447698097286): Component "client:resource-util" calling start()
xdk:client:[2015-11-16T18:21:37.286Z]: (1447698097286): Component "client:resource-util" finished start()
xdk:client:[2015-11-16T18:21:37.287Z]: (1447698097287): Component "client:editor" calling start()
xdk:client:[2015-11-16T18:21:37.287Z]: (1447698097287): Component "client:editor" finished start()
xdk:client:[2015-11-16T18:21:37.287Z]: (1447698097287): Component "client:editor-tab" calling start()
xdk:client:[2015-11-16T18:21:37.302Z]: (1447698097302): Component "client:editor-tab" finished start()
xdk:client:[2015-11-16T18:21:37.302Z]: (1447698097302): Component "client:live-preview" calling start()
xdk:client:[2015-11-16T18:21:37.302Z]: (1447698097302): Component "client:live-preview" finished start()
xdk:client:[2015-11-16T18:21:37.302Z]: (1447698097302): Component "client:account" calling start()
xdk:client:[2015-11-16T18:21:37.303Z]: (1447698097303): Component "client:account" finished start()
xdk:client:[2015-11-16T18:21:37.303Z]: (1447698097303): Component "client:project-selector" calling start()
xdk:client:[2015-11-16T18:21:37.303Z]: (1447698097303): Component "client:project-selector" finished start()
xdk:client:[2015-11-16T18:21:37.304Z]: (1447698097304): Component "client:app-starter" calling start()
xdk:client:[2015-11-16T18:21:37.304Z]: (1447698097304): Component "client:app-starter" finished start()
xdk:client:[2015-11-16T18:21:37.304Z]: (1447698097304): Component "client:ui-builder-client" calling start()
xdk:client:[2015-11-16T18:21:37.304Z]: (1447698097304): Component "client:ui-builder-client" finished start()
xdk:client:[2015-11-16T18:21:37.305Z]: (1447698097305): Component "client:project-meta" calling start()
xdk:client:[2015-11-16T18:21:37.305Z]: (1447698097305): Component "client:project-meta" finished start()
xdk:client:[2015-11-16T18:21:37.305Z]: (1447698097305): Component "client:cordova-registry" calling start()
xdk:client:[2015-11-16T18:21:37.305Z]: (1447698097305): Component "client:cordova-registry" finished start()
xdk:client:[2015-11-16T18:21:37.305Z]: (1447698097305): Component "client:adb" calling start()
xdk:client:[2015-11-16T18:21:37.305Z]: (1447698097305): Component "client:adb" finished start()
xdk:client:[2015-11-16T18:21:37.305Z]: (1447698097305): Component "client:iosdb" calling start()
xdk:client:[2015-11-16T18:21:37.306Z]: (1447698097306): Component "client:iosdb" finished start()
xdk:client:[2015-11-16T18:21:37.306Z]: (1447698097306): Component "client:device-discovery" calling start()
xdk:client:[2015-11-16T18:21:37.307Z]: (1447698097307): Component "client:device-discovery" finished start()
xdk:client:[2015-11-16T18:21:37.307Z]: (1447698097307): Component "client:test-local-server" calling start()
xdk:client:[2015-11-16T18:21:37.308Z]: (1447698097308): Component "client:test-local-server" finished start()
xdk:client:[2015-11-16T18:21:37.308Z]: (1447698097308): Component "client:quick-tour" calling start()
xdk:client:[2015-11-16T18:21:37.308Z]: (1447698097308): Component "client:quick-tour" finished start()
xdk:client:[2015-11-16T18:21:37.308Z]: (1447698097308): Component "client:hot-keys" calling start()
xdk:client:[2015-11-16T18:21:37.309Z]: (1447698097309): Component "client:hot-keys" finished start()
xdk:client:[2015-11-16T18:21:37.309Z]: (1447698097309): Component "client:persistance" calling start()
xdk:client:[2015-11-16T18:21:37.310Z]: (1447698097310): Component "client:persistance" finished start()
xdk:client:[2015-11-16T18:21:37.310Z]: (1447698097310): Component "client:file-watcher" calling start()
xdk:client:[2015-11-16T18:21:37.310Z]: (1447698097310): Component "client:file-watcher" finished start()
xdk:client:[2015-11-16T18:21:37.310Z]: (1447698097310): Component "client:cordova" calling start()
xdk:client:[2015-11-16T18:21:37.310Z]: (1447698097310): Component "client:cordova" finished start()
xdk:client:[2015-11-16T18:21:37.310Z]: (1447698097310): Component "client:external-editors-runner" calling start()
xdk:client:[2015-11-16T18:21:37.311Z]: (1447698097311): Component "client:external-editors-runner" finished start()
xdk:client:[2015-11-16T18:21:37.311Z]: (1447698097311): Component "client:upload-manager" calling start()
xdk:client:[2015-11-16T18:21:37.311Z]: (1447698097311): Component "client:upload-manager" finished start()
xdk:client:[2015-11-16T18:21:37.312Z]: (1447698097312): Intel XDK is initialized now
client:navbar:[2015-11-16T18:21:37.429Z]: (1447698097429): pollForUpdates called
client:navbar:[2015-11-16T18:21:38.935Z]: (1447698098935): polling up-to-date
xdk:client:[2015-11-16T18:21:40.222Z]: (1447698100222): memmrk:    48343700    77408640
client:services-tab:[2015-11-16T18:21:40.752Z]: (1447698100752): Iframe onLoad resolved for : http://127.0.0.1:58889/http-services/api-explorer/iodocs/sidebar?
client:services-tab:[2015-11-16T18:21:40.890Z]: (1447698100890): Iframe onLoad resolved for : http://127.0.0.1:58889/http-services/api-explorer/iodocs/index?
client:services-tab:[2015-11-16T18:21:40.896Z]: (1447698100896): Both iframes loaded promise resolved.
client:services-tab:[2015-11-16T18:21:40.909Z]: (1447698100909): Calling postmessage for user refresh.
client:services-tab:[2015-11-16T18:21:40.910Z]: (1447698100910): main container window : true
client:services-tab:[2015-11-16T18:21:40.910Z]: (1447698100910): main container document : true
client:services-tab:[2015-11-16T18:21:40.910Z]: (1447698100910): component:services-tab:postMessageToWindow target = user
xdk:server:[2015-11-16T18:21:41.232Z]: (1447698101232): memmrk:    46443400    69757952
uib-client:[2015-11-16T18:21:43.638Z]: (1447698103638): gradeHTMLFile 1 /C/Users/Tedd/Documents/test/www/index.html
client:services-tab:[2015-11-16T18:21:43.640Z]: (1447698103640): Calling postmessage for project refresh.
client:services-tab:[2015-11-16T18:21:43.640Z]: (1447698103640): sidebar container window : true
client:services-tab:[2015-11-16T18:21:43.640Z]: (1447698103640): sidebar container document : true
client:services-tab:[2015-11-16T18:21:43.640Z]: (1447698103640): main container window : true
client:services-tab:[2015-11-16T18:21:43.640Z]: (1447698103640): main container document : true
client:services-tab:[2015-11-16T18:21:43.640Z]: (1447698103640): component:services-tab:postMessageToWindow target = project
xdk:client:[2015-11-16T18:21:45.443Z]: (1447698105443): memmrk:    49088380    88105856
client:services-tab:[2015-11-16T18:21:45.465Z]: (1447698105465): Calling postmessage for project refresh.
client:services-tab:[2015-11-16T18:21:45.466Z]: (1447698105466): sidebar container window : true
client:services-tab:[2015-11-16T18:21:45.466Z]: (1447698105466): sidebar container document : true
client:services-tab:[2015-11-16T18:21:45.466Z]: (1447698105466): main container window : true
client:services-tab:[2015-11-16T18:21:45.466Z]: (1447698105466): main container document : true
client:services-tab:[2015-11-16T18:21:45.466Z]: (1447698105466): component:services-tab:postMessageToWindow target = project
xdk:server:[2015-11-16T18:21:46.232Z]: (1447698106232): memmrk:    58330864    84932224
client:services-tab:[2015-11-16T18:21:47.940Z]: (1447698107940): Calling postmessage for project refresh.
client:services-tab:[2015-11-16T18:21:47.940Z]: (1447698107940): sidebar container window : true
client:services-tab:[2015-11-16T18:21:47.940Z]: (1447698107940): sidebar container document : true
client:services-tab:[2015-11-16T18:21:47.940Z]: (1447698107940): main container window : true
client:services-tab:[2015-11-16T18:21:47.940Z]: (1447698107940): main container document : true
client:services-tab:[2015-11-16T18:21:47.940Z]: (1447698107940): component:services-tab:postMessageToWindow target = project
xdk:client:[2015-11-16T18:21:50.444Z]: (1447698110444): memmrk:    57684448    95162880
xdk:server:[2015-11-16T18:21:51.232Z]: (1447698111232): memmrk:    75120472    97607936
xdk:client:[2015-11-16T18:21:55.447Z]: (1447698115447): memmrk:    59410480    95162880
xdk:server:[2015-11-16T18:21:56.233Z]: (1447698116233): memmrk:    75874408    97607936
xdk:client:[2015-11-16T18:22:00.447Z]: (1447698120447): memmrk:    60710644    95162880
xdk:server:[2015-11-16T18:22:01.233Z]: (1447698121233): memmrk:    76252012    97607936
xdk:client:[2015-11-16T18:22:05.448Z]: (1447698125448): memmrk:    61469860    95162880
xdk:server:[2015-11-16T18:22:06.233Z]: (1447698126233): memmrk:    26945364    89076096
xdk:client:[2015-11-16T18:22:10.448Z]: (1447698130448): memmrk:    61655892    95162880
xdk:server:[2015-11-16T18:22:11.233Z]: (1447698131233): memmrk:    22663336    49044096
xdk:client:[2015-11-16T18:22:15.449Z]: (1447698135449): memmrk:    63760048    95162880
xdk:server:[2015-11-16T18:22:16.233Z]: (1447698136234): memmrk:    22671784    49044096
xdk:client:[2015-11-16T18:22:20.449Z]: (1447698140449): memmrk:    64085144    95162880
xdk:server:[2015-11-16T18:22:21.234Z]: (1447698141234): memmrk:    22540244    34824576
xdk:client:[2015-11-16T18:22:25.644Z]: (1447698145644): memmrk:    60623436    95162880
uib-client:[2015-11-16T18:22:25.878Z]: (1447698145878): gradeHTMLFile 1 /C/Users/Tedd/Documents/Test/www/index.html
client:services-tab:[2015-11-16T18:22:25.878Z]: (1447698145878): Calling postmessage for project refresh.
client:services-tab:[2015-11-16T18:22:25.879Z]: (1447698145879): sidebar container window : true
client:services-tab:[2015-11-16T18:22:25.879Z]: (1447698145879): sidebar container document : true
client:services-tab:[2015-11-16T18:22:25.879Z]: (1447698145879): main container window : true
client:services-tab:[2015-11-16T18:22:25.879Z]: (1447698145879): main container document : true
client:services-tab:[2015-11-16T18:22:25.879Z]: (1447698145879): component:services-tab:postMessageToWindow target = project
xdk:server:[2015-11-16T18:22:26.489Z]: (1447698146490): memmrk:    47827952    65723520
xdk:client:[2015-11-16T18:22:30.645Z]: (1447698150645): memmrk:    72124028    100728832
xdk:server:[2015-11-16T18:22:31.490Z]: (1447698151490): memmrk:    47873696    65723520
xdk:client:[2015-11-16T18:22:35.650Z]: (1447698155650): memmrk:    73325072    101732352
xdk:server:[2015-11-16T18:22:36.490Z]: (1447698156490): memmrk:    48555996    65723520
xdk:client:[2015-11-16T18:22:40.651Z]: (1447698160651): memmrk:    75866908    101732352
xdk:server:[2015-11-16T18:22:41.490Z]: (1447698161490): memmrk:    48939168    65723520
xdk:client:[2015-11-16T18:22:45.651Z]: (1447698165651): memmrk:    76475400    101732352
xdk:server:[2015-11-16T18:22:46.491Z]: (1447698166491): memmrk:    25478116    62717056
xdk:client:[2015-11-16T18:22:50.653Z]: (1447698170653): memmrk:    73401560    102748032
xdk:server:[2015-11-16T18:22:51.491Z]: (1447698171491): memmrk:    25490996    62717056
xdk:client:[2015-11-16T18:22:55.653Z]: (1447698175653): memmrk:    73573276    102748032
xdk:server:[2015-11-16T18:22:56.492Z]: (1447698176492): memmrk:    22878796    34800256
xdk:client:[2015-11-16T18:23:00.653Z]: (1447698180653): memmrk:    61141988    100757248
xdk:server:[2015-11-16T18:23:01.492Z]: (1447698181492): memmrk:    23613268    34923264
client:emulator:[2015-11-16T18:23:01.667Z]: (1447698181667): Device Emulator :: Environment Warming Up (Tea. Earl Gray. Hot.)
client:emulator:[2015-11-16T18:23:01.816Z]: (1447698181816): appmobi_plus_cordova :: Emulator changing to project Test
server:emulator-webserver:[2015-11-16T18:23:01.833Z]: (1447698181833): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:01.833Z]: (1447698181833): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/index.html
server:emulator-webserver:[2015-11-16T18:23:01.833Z]: (1447698181833): Main html fullPath = /C/Users/Tedd/Documents/Test/www/index.html
client:emulator:[2015-11-16T18:23:01.820Z]: (1447698181820): appmobi_plus_cordova :: _xdkLoad for project Test
client:emulator:[2015-11-16T18:23:01.830Z]: (1447698181830): appmobi_plus_cordova :: Emulator changing to project Test
client:emulator:[2015-11-16T18:23:01.831Z]: (1447698181831): appmobi_plus_cordova :: Initialization Finished (Make it so.)
client:emulator:[2015-11-16T18:23:01.831Z]: (1447698181831): appmobi_plus_cordova :: frame appended to document
client:emulator:[2015-11-16T18:23:01.948Z]: (1447698181948): appmobi_plus_cordova :: Emulation frame loaded
client:emulator:[2015-11-16T18:23:01.951Z]: (1447698181951): appmobi_plus_cordova :: fired appMobi.device.ready event!
client:emulator:[2015-11-16T18:23:01.980Z]: (1447698181980): appmobi_plus_cordova :: tinyHipposLoaded cleared _loading/_delayedproject
client:emulator:[2015-11-16T18:23:01.980Z]: (1447698181980): appmobi_plus_cordova :: [emulator] file watcher started
xdk:client:[2015-11-16T18:23:05.653Z]: (1447698185653): memmrk:    76274300    100757248
xdk:server:[2015-11-16T18:23:06.492Z]: (1447698186492): memmrk:    22660580    34923264
xdk:client:[2015-11-16T18:23:10.654Z]: (1447698190654): memmrk:    64726560    100757248
xdk:server:[2015-11-16T18:23:11.493Z]: (1447698191493): memmrk:    22670680    34923264
xdk:client:[2015-11-16T18:23:15.654Z]: (1447698195654): memmrk:    64884036    100757248
xdk:server:[2015-11-16T18:23:16.493Z]: (1447698196493): memmrk:    22677720    34923264
xdk:client:[2015-11-16T18:23:20.655Z]: (1447698200655): memmrk:    70968372    100757248
xdk:server:[2015-11-16T18:23:21.493Z]: (1447698201493): memmrk:    22689756    34923264
xdk:client:[2015-11-16T18:23:25.656Z]: (1447698205656): memmrk:    87740748    107867008
xdk:server:[2015-11-16T18:23:26.493Z]: (1447698206493): memmrk:    22698000    34923264
xdk:client:[2015-11-16T18:23:30.656Z]: (1447698210656): memmrk:    79204304    109410816
xdk:server:[2015-11-16T18:23:31.494Z]: (1447698211494): memmrk:    22709328    34923264
xdk:client:[2015-11-16T18:23:35.656Z]: (1447698215656): memmrk:    94609344    117536256
xdk:server:[2015-11-16T18:23:36.496Z]: (1447698216496): memmrk:    22717208    34923264
xdk:client:[2015-11-16T18:23:40.656Z]: (1447698220657): memmrk:    97396836    117536256
xdk:server:[2015-11-16T18:23:41.497Z]: (1447698221497): memmrk:    22725084    34923264
client:emulator:[2015-11-16T18:23:43.832Z]: (1447698223832): emulator is shown for the project
client:emulator:[2015-11-16T18:23:43.832Z]: (1447698223832): Test
client:emulator:[2015-11-16T18:23:44.052Z]: (1447698224052): Device Emulator :: Environment Warming Up (Tea. Earl Gray. Hot.)
client:emulator:[2015-11-16T18:23:44.157Z]: (1447698224157): appmobi_plus_cordova :: Emulator changing to project Test
server:emulator-webserver:[2015-11-16T18:23:44.165Z]: (1447698224165): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.165Z]: (1447698224165): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/index.html
server:emulator-webserver:[2015-11-16T18:23:44.166Z]: (1447698224166): Main html fullPath = /C/Users/Tedd/Documents/Test/www/index.html
client:emulator:[2015-11-16T18:23:44.158Z]: (1447698224158): appmobi_plus_cordova :: _xdkLoad for project Test
client:emulator:[2015-11-16T18:23:44.159Z]: (1447698224159): appmobi_plus_cordova :: Emulator changing to project Test
client:emulator:[2015-11-16T18:23:44.161Z]: (1447698224161): appmobi_plus_cordova :: Initialization Finished (Make it so.)
client:emulator:[2015-11-16T18:23:44.163Z]: (1447698224163): appmobi_plus_cordova :: frame appended to document
server:emulator-webserver:[2015-11-16T18:23:44.284Z]: (1447698224284): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.284Z]: (1447698224284): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/fonts/gamefont.css
server:emulator-webserver:[2015-11-16T18:23:44.284Z]: (1447698224284): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/fonts/gamefont.css
server:emulator-webserver:[2015-11-16T18:23:44.287Z]: (1447698224287): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.287Z]: (1447698224287): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/js/libs/pixi.js
server:emulator-webserver:[2015-11-16T18:23:44.287Z]: (1447698224287): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/js/libs/pixi.js
server:emulator-webserver:[2015-11-16T18:23:44.289Z]: (1447698224289): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.289Z]: (1447698224289): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/js/libs/fpsmeter.js
server:emulator-webserver:[2015-11-16T18:23:44.289Z]: (1447698224289): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/js/libs/fpsmeter.js
server:emulator-webserver:[2015-11-16T18:23:44.290Z]: (1447698224290): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.290Z]: (1447698224290): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/js/libs/lz-string.js
server:emulator-webserver:[2015-11-16T18:23:44.290Z]: (1447698224290): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/js/libs/lz-string.js
server:emulator-webserver:[2015-11-16T18:23:44.299Z]: (1447698224299): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.299Z]: (1447698224299): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/js/rpg_core.js
server:emulator-webserver:[2015-11-16T18:23:44.299Z]: (1447698224299): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/js/rpg_core.js
server:emulator-webserver:[2015-11-16T18:23:44.300Z]: (1447698224300): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.300Z]: (1447698224300): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/js/rpg_managers.js
server:emulator-webserver:[2015-11-16T18:23:44.300Z]: (1447698224300): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/js/rpg_managers.js
server:emulator-webserver:[2015-11-16T18:23:44.301Z]: (1447698224301): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.301Z]: (1447698224301): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/js/rpg_objects.js
server:emulator-webserver:[2015-11-16T18:23:44.301Z]: (1447698224301): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/js/rpg_objects.js
server:emulator-webserver:[2015-11-16T18:23:44.307Z]: (1447698224307): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.307Z]: (1447698224307): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/js/rpg_scenes.js
server:emulator-webserver:[2015-11-16T18:23:44.307Z]: (1447698224307): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/js/rpg_scenes.js
server:emulator-webserver:[2015-11-16T18:23:44.311Z]: (1447698224311): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.311Z]: (1447698224311): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/js/rpg_sprites.js
server:emulator-webserver:[2015-11-16T18:23:44.311Z]: (1447698224311): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/js/rpg_sprites.js
server:emulator-webserver:[2015-11-16T18:23:44.313Z]: (1447698224313): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.313Z]: (1447698224313): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/js/rpg_windows.js
server:emulator-webserver:[2015-11-16T18:23:44.313Z]: (1447698224313): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/js/rpg_windows.js
server:emulator-webserver:[2015-11-16T18:23:44.318Z]: (1447698224318): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.318Z]: (1447698224318): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/js/plugins.js
server:emulator-webserver:[2015-11-16T18:23:44.318Z]: (1447698224318): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/js/plugins.js
server:emulator-webserver:[2015-11-16T18:23:44.322Z]: (1447698224323): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.323Z]: (1447698224323): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/js/main.js
server:emulator-webserver:[2015-11-16T18:23:44.323Z]: (1447698224323): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/js/main.js
server:emulator-webserver:[2015-11-16T18:23:44.543Z]: (1447698224543): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.543Z]: (1447698224543): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/js/main.js
server:emulator-webserver:[2015-11-16T18:23:44.543Z]: (1447698224543): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/js/main.js
client:emulator:[2015-11-16T18:23:44.552Z]: (1447698224552): appmobi_plus_cordova :: Emulation frame loaded
server:emulator-webserver:[2015-11-16T18:23:44.555Z]: (1447698224555): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.555Z]: (1447698224555): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/img/system/Loading.png
server:emulator-webserver:[2015-11-16T18:23:44.555Z]: (1447698224555): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/img/system/Loading.png
server:emulator-webserver:[2015-11-16T18:23:44.559Z]: (1447698224559): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.559Z]: (1447698224559): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/fonts/mplus-1m-regular.ttf
server:emulator-webserver:[2015-11-16T18:23:44.559Z]: (1447698224559): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/fonts/mplus-1m-regular.ttf
client:emulator:[2015-11-16T18:23:44.556Z]: (1447698224556): appmobi_plus_cordova :: fired appMobi.device.ready event!
server:emulator-webserver:[2015-11-16T18:23:44.568Z]: (1447698224568): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.568Z]: (1447698224568): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/data/Actors.json
server:emulator-webserver:[2015-11-16T18:23:44.568Z]: (1447698224568): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/data/Actors.json
server:emulator-webserver:[2015-11-16T18:23:44.571Z]: (1447698224571): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.571Z]: (1447698224571): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/data/Classes.json
server:emulator-webserver:[2015-11-16T18:23:44.571Z]: (1447698224571): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/data/Classes.json
server:emulator-webserver:[2015-11-16T18:23:44.572Z]: (1447698224572): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.572Z]: (1447698224572): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/data/Skills.json
server:emulator-webserver:[2015-11-16T18:23:44.572Z]: (1447698224572): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/data/Skills.json
server:emulator-webserver:[2015-11-16T18:23:44.577Z]: (1447698224577): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.577Z]: (1447698224577): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/data/Items.json
server:emulator-webserver:[2015-11-16T18:23:44.577Z]: (1447698224577): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/data/Items.json
server:emulator-webserver:[2015-11-16T18:23:44.581Z]: (1447698224581): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.581Z]: (1447698224581): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/data/Weapons.json
server:emulator-webserver:[2015-11-16T18:23:44.581Z]: (1447698224581): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/data/Weapons.json
server:emulator-webserver:[2015-11-16T18:23:44.582Z]: (1447698224582): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.582Z]: (1447698224582): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/data/Armors.json
server:emulator-webserver:[2015-11-16T18:23:44.582Z]: (1447698224582): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/data/Armors.json
server:emulator-webserver:[2015-11-16T18:23:44.587Z]: (1447698224587): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.587Z]: (1447698224587): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/data/Enemies.json
server:emulator-webserver:[2015-11-16T18:23:44.587Z]: (1447698224587): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/data/Enemies.json
server:emulator-webserver:[2015-11-16T18:23:44.591Z]: (1447698224591): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.591Z]: (1447698224591): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/data/Troops.json
server:emulator-webserver:[2015-11-16T18:23:44.591Z]: (1447698224591): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/data/Troops.json
server:emulator-webserver:[2015-11-16T18:23:44.593Z]: (1447698224593): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.593Z]: (1447698224593): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/data/States.json
server:emulator-webserver:[2015-11-16T18:23:44.593Z]: (1447698224593): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/data/States.json
server:emulator-webserver:[2015-11-16T18:23:44.600Z]: (1447698224600): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.600Z]: (1447698224600): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/data/Animations.json
server:emulator-webserver:[2015-11-16T18:23:44.600Z]: (1447698224600): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/data/Animations.json
server:emulator-webserver:[2015-11-16T18:23:44.606Z]: (1447698224606): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.606Z]: (1447698224606): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/data/Tilesets.json
server:emulator-webserver:[2015-11-16T18:23:44.606Z]: (1447698224606): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/data/Tilesets.json
server:emulator-webserver:[2015-11-16T18:23:44.608Z]: (1447698224608): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.608Z]: (1447698224608): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/data/CommonEvents.json
server:emulator-webserver:[2015-11-16T18:23:44.608Z]: (1447698224608): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/data/CommonEvents.json
server:emulator-webserver:[2015-11-16T18:23:44.616Z]: (1447698224616): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.616Z]: (1447698224616): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/data/System.json
server:emulator-webserver:[2015-11-16T18:23:44.616Z]: (1447698224616): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/data/System.json
server:emulator-webserver:[2015-11-16T18:23:44.620Z]: (1447698224620): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.620Z]: (1447698224620): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/data/MapInfos.json
server:emulator-webserver:[2015-11-16T18:23:44.620Z]: (1447698224620): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/data/MapInfos.json
server:emulator-webserver:[2015-11-16T18:23:44.626Z]: (1447698224626): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.626Z]: (1447698224626): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/img/system/Window.png
server:emulator-webserver:[2015-11-16T18:23:44.626Z]: (1447698224626): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/img/system/Window.png
server:emulator-webserver:[2015-11-16T18:23:44.634Z]: (1447698224634): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.634Z]: (1447698224634): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/img/system/IconSet.png
server:emulator-webserver:[2015-11-16T18:23:44.634Z]: (1447698224634): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/img/system/IconSet.png
server:emulator-webserver:[2015-11-16T18:23:44.640Z]: (1447698224640): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.640Z]: (1447698224640): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/img/system/Balloon.png
server:emulator-webserver:[2015-11-16T18:23:44.640Z]: (1447698224641): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/img/system/Balloon.png
server:emulator-webserver:[2015-11-16T18:23:44.647Z]: (1447698224647): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.647Z]: (1447698224647): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/img/system/Shadow1.png
server:emulator-webserver:[2015-11-16T18:23:44.647Z]: (1447698224647): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/img/system/Shadow1.png
server:emulator-webserver:[2015-11-16T18:23:44.658Z]: (1447698224658): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.658Z]: (1447698224658): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/img/system/Shadow2.png
server:emulator-webserver:[2015-11-16T18:23:44.658Z]: (1447698224658): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/img/system/Shadow2.png
server:emulator-webserver:[2015-11-16T18:23:44.660Z]: (1447698224660): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.660Z]: (1447698224660): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/img/system/Damage.png
server:emulator-webserver:[2015-11-16T18:23:44.660Z]: (1447698224660): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/img/system/Damage.png
server:emulator-webserver:[2015-11-16T18:23:44.666Z]: (1447698224666): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.666Z]: (1447698224666): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/img/system/States.png
server:emulator-webserver:[2015-11-16T18:23:44.667Z]: (1447698224667): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/img/system/States.png
server:emulator-webserver:[2015-11-16T18:23:44.675Z]: (1447698224675): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.675Z]: (1447698224675): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/img/system/Weapons1.png
server:emulator-webserver:[2015-11-16T18:23:44.675Z]: (1447698224675): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/img/system/Weapons1.png
server:emulator-webserver:[2015-11-16T18:23:44.679Z]: (1447698224679): emulator-webserver: got a request for userapp.
client:emulator:[2015-11-16T18:23:44.690Z]: (1447698224690): appmobi_plus_cordova :: tinyHipposLoaded cleared _loading/_delayedproject
client:emulator:[2015-11-16T18:23:44.690Z]: (1447698224690): appmobi_plus_cordova :: [emulator] file watcher started
server:emulator-webserver:[2015-11-16T18:23:44.679Z]: (1447698224679): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/img/system/Weapons2.png
server:emulator-webserver:[2015-11-16T18:23:44.679Z]: (1447698224679): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/img/system/Weapons2.png
server:emulator-webserver:[2015-11-16T18:23:44.694Z]: (1447698224694): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.694Z]: (1447698224694): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/img/system/Weapons3.png
server:emulator-webserver:[2015-11-16T18:23:44.694Z]: (1447698224694): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/img/system/Weapons3.png
server:emulator-webserver:[2015-11-16T18:23:44.697Z]: (1447698224697): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.697Z]: (1447698224697): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/img/system/ButtonSet.png
server:emulator-webserver:[2015-11-16T18:23:44.697Z]: (1447698224697): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/img/system/ButtonSet.png
server:emulator-webserver:[2015-11-16T18:23:44.908Z]: (1447698224908): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.909Z]: (1447698224909): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/audio/se/Cursor2.m4a
server:emulator-webserver:[2015-11-16T18:23:44.909Z]: (1447698224909): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/audio/se/Cursor2.m4a
server:emulator-webserver:[2015-11-16T18:23:44.913Z]: (1447698224913): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.913Z]: (1447698224913): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/audio/se/Decision1.m4a
server:emulator-webserver:[2015-11-16T18:23:44.913Z]: (1447698224913): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/audio/se/Decision1.m4a
server:emulator-webserver:[2015-11-16T18:23:44.915Z]: (1447698224915): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.915Z]: (1447698224915): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/audio/se/Cancel2.m4a
server:emulator-webserver:[2015-11-16T18:23:44.916Z]: (1447698224916): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/audio/se/Cancel2.m4a
server:emulator-webserver:[2015-11-16T18:23:44.920Z]: (1447698224920): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.920Z]: (1447698224920): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/audio/se/Buzzer1.m4a
server:emulator-webserver:[2015-11-16T18:23:44.920Z]: (1447698224920): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/audio/se/Buzzer1.m4a
server:emulator-webserver:[2015-11-16T18:23:44.973Z]: (1447698224973): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:44.973Z]: (1447698224973): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/img/titles1/Castle.png
server:emulator-webserver:[2015-11-16T18:23:44.973Z]: (1447698224973): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/img/titles1/Castle.png
server:emulator-webserver:[2015-11-16T18:23:45.022Z]: (1447698225022): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:45.022Z]: (1447698225022): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/audio/bgm/Theme6.m4a
server:emulator-webserver:[2015-11-16T18:23:45.022Z]: (1447698225022): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/audio/bgm/Theme6.m4a
xdk:client:[2015-11-16T18:23:45.658Z]: (1447698225658): memmrk:    107127744    125649536
xdk:server:[2015-11-16T18:23:46.497Z]: (1447698226497): memmrk:    26774544    40133248
server:emulator-webserver:[2015-11-16T18:23:47.075Z]: (1447698227075): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:47.075Z]: (1447698227075): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/data/Map001.json
server:emulator-webserver:[2015-11-16T18:23:47.075Z]: (1447698227075): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/data/Map001.json
server:emulator-webserver:[2015-11-16T18:23:47.122Z]: (1447698227122): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:47.122Z]: (1447698227122): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/img/tilesets/World_A1.png
server:emulator-webserver:[2015-11-16T18:23:47.122Z]: (1447698227122): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/img/tilesets/World_A1.png
server:emulator-webserver:[2015-11-16T18:23:47.123Z]: (1447698227123): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:47.123Z]: (1447698227123): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/img/tilesets/World_A2.png
server:emulator-webserver:[2015-11-16T18:23:47.123Z]: (1447698227123): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/img/tilesets/World_A2.png
server:emulator-webserver:[2015-11-16T18:23:47.124Z]: (1447698227124): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:47.124Z]: (1447698227124): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/img/tilesets/World_B.png
server:emulator-webserver:[2015-11-16T18:23:47.124Z]: (1447698227124): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/img/tilesets/World_B.png
server:emulator-webserver:[2015-11-16T18:23:47.125Z]: (1447698227125): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:47.125Z]: (1447698227125): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/img/tilesets/World_C.png
server:emulator-webserver:[2015-11-16T18:23:47.125Z]: (1447698227125): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/img/tilesets/World_C.png
server:emulator-webserver:[2015-11-16T18:23:47.141Z]: (1447698227141): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:47.141Z]: (1447698227141): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/img/characters/Vehicle.png
server:emulator-webserver:[2015-11-16T18:23:47.141Z]: (1447698227141): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/img/characters/Vehicle.png
server:emulator-webserver:[2015-11-16T18:23:47.143Z]: (1447698227143): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:47.143Z]: (1447698227143): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/img/characters/Actor2.png
server:emulator-webserver:[2015-11-16T18:23:47.143Z]: (1447698227143): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/img/characters/Actor2.png
server:emulator-webserver:[2015-11-16T18:23:47.149Z]: (1447698227149): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:47.149Z]: (1447698227149): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/img/characters/Actor3.png
server:emulator-webserver:[2015-11-16T18:23:47.149Z]: (1447698227149): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/img/characters/Actor3.png
server:emulator-webserver:[2015-11-16T18:23:47.153Z]: (1447698227153): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:47.153Z]: (1447698227153): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/img/characters/Actor1.png
server:emulator-webserver:[2015-11-16T18:23:47.153Z]: (1447698227153): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/img/characters/Actor1.png
xdk:client:[2015-11-16T18:23:50.657Z]: (1447698230657): memmrk:    80400620    125649536
xdk:server:[2015-11-16T18:23:51.497Z]: (1447698231497): memmrk:    28408688    40133248
server:emulator-webserver:[2015-11-16T18:23:51.558Z]: (1447698231558): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:51.558Z]: (1447698231558): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/img/faces/Actor1.png
server:emulator-webserver:[2015-11-16T18:23:51.558Z]: (1447698231558): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/img/faces/Actor1.png
server:emulator-webserver:[2015-11-16T18:23:51.562Z]: (1447698231562): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:51.562Z]: (1447698231562): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/img/faces/Actor3.png
server:emulator-webserver:[2015-11-16T18:23:51.562Z]: (1447698231562): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/img/faces/Actor3.png
server:emulator-webserver:[2015-11-16T18:23:51.563Z]: (1447698231563): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:51.563Z]: (1447698231563): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/img/faces/Actor2.png
server:emulator-webserver:[2015-11-16T18:23:51.563Z]: (1447698231563): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/img/faces/Actor2.png
server:emulator-webserver:[2015-11-16T18:23:51.839Z]: (1447698231839): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:51.839Z]: (1447698231839): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/data/Map001.json
server:emulator-webserver:[2015-11-16T18:23:51.839Z]: (1447698231839): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/data/Map001.json
server:emulator-webserver:[2015-11-16T18:23:52.921Z]: (1447698232921): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:52.921Z]: (1447698232921): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/data/Map001.json
server:emulator-webserver:[2015-11-16T18:23:52.921Z]: (1447698232921): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/data/Map001.json
server:emulator-webserver:[2015-11-16T18:23:55.054Z]: (1447698235054): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:55.054Z]: (1447698235054): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/data/Map001.json
server:emulator-webserver:[2015-11-16T18:23:55.054Z]: (1447698235054): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/data/Map001.json
xdk:client:[2015-11-16T18:23:55.658Z]: (1447698235658): memmrk:    83519520    125649536
xdk:server:[2015-11-16T18:23:56.498Z]: (1447698236498): memmrk:    26246808    40133248
server:emulator-webserver:[2015-11-16T18:23:57.405Z]: (1447698237405): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:23:57.406Z]: (1447698237406): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/data/Map001.json
server:emulator-webserver:[2015-11-16T18:23:57.406Z]: (1447698237406): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/data/Map001.json
server:emulator-webserver:[2015-11-16T18:24:00.404Z]: (1447698240404): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2015-11-16T18:24:00.404Z]: (1447698240404): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/Tedd/Documents/Test/www/data/Map001.json
server:emulator-webserver:[2015-11-16T18:24:00.404Z]: (1447698240404): Other file request, fullPath = /C/Users/Tedd/Documents/Test/www/data/Map001.json
xdk:client:[2015-11-16T18:24:00.659Z]: (1447698240659): memmrk:    69521476    125649536
xdk:server:[2015-11-16T18:24:01.498Z]: (1447698241498): memmrk:    26756552    40133248
xdk:client:[2015-11-16T18:24:05.659Z]: (1447698245659): memmrk:    73772736    125649536
xdk:server:[2015-11-16T18:24:06.497Z]: (1447698246497): memmrk:    41744744    62729216
xdk:client:[2015-11-16T18:24:10.660Z]: (1447698250660): memmrk:    83066392    125649536
xdk:server:[2015-11-16T18:24:11.497Z]: (1447698251497): memmrk:    38533692    62729216
xdk:client:[2015-11-16T18:24:15.661Z]: (1447698255661): memmrk:    83379452    125649536
xdk:server:[2015-11-16T18:24:16.498Z]: (1447698256498): memmrk:    53956604    70854656
xdk:client:[2015-11-16T18:24:20.662Z]: (1447698260662): memmrk:    83423108    125649536
xdk:server:[2015-11-16T18:24:21.499Z]: (1447698261499): memmrk:    35093724    71870336
xdk:client:[2015-11-16T18:24:25.662Z]: (1447698265662): memmrk:    83544720    125649536
xdk:server:[2015-11-16T18:24:26.499Z]: (1447698266499): memmrk:    35065752    71870336
xdk:client:[2015-11-16T18:24:30.662Z]: (1447698270662): memmrk:    74969536    126665216
xdk:server:[2015-11-16T18:24:31.498Z]: (1447698271498): memmrk:    34224812    71870336
xdk:client:[2015-11-16T18:24:35.663Z]: (1447698275663): memmrk:    81255132    126665216
xdk:server:[2015-11-16T18:24:36.531Z]: (1447698276531): memmrk:    35173876    71870336
xdk:client:[2015-11-16T18:24:40.663Z]: (1447698280663): memmrk:    80612800    126665216
xdk:server:[2015-11-16T18:24:41.532Z]: (1447698281532): memmrk:    31736644    71870336
xdk:client:[2015-11-16T18:24:45.664Z]: (1447698285664): memmrk:    74852720    126665216
xdk:server:[2015-11-16T18:24:46.532Z]: (1447698286532): memmrk:    29899060    71870336
xdk:client:[2015-11-16T18:24:50.665Z]: (1447698290665): memmrk:    74178224    126665216
xdk:server:[2015-11-16T18:24:51.533Z]: (1447698291533): memmrk:    30645576    71870336
xdk:client:[2015-11-16T18:24:55.665Z]: (1447698295665): memmrk:    80448880    126665216
xdk:server:[2015-11-16T18:24:56.533Z]: (1447698296533): memmrk:    30409228    71870336
xdk:client:[2015-11-16T18:25:00.667Z]: (1447698300667): memmrk:    73627176    126665216
xdk:server:[2015-11-16T18:25:01.537Z]: (1447698301537): memmrk:    30987716    71870336
xdk:client:[2015-11-16T18:25:05.666Z]: (1447698305666): memmrk:    75661588    126665216
xdk:server:[2015-11-16T18:25:06.547Z]: (1447698306547): memmrk:    30422096    71870336
xdk:client:[2015-11-16T18:25:10.668Z]: (1447698310668): memmrk:    75974616    126665216
xdk:server:[2015-11-16T18:25:11.547Z]: (1447698311547): memmrk:    33133220    71870336
xdk:client:[2015-11-16T18:25:15.671Z]: (1447698315671): memmrk:    74223068    126665216
xdk:server:[2015-11-16T18:25:16.547Z]: (1447698316547): memmrk:    31103416    71870336
xdk:client:[2015-11-16T18:25:20.672Z]: (1447698320672): memmrk:    80519628    126665216
xdk:server:[2015-11-16T18:25:21.548Z]: (1447698321548): memmrk:    32057312    71870336
xdk:client:[2015-11-16T18:25:25.672Z]: (1447698325672): memmrk:    80799812    126665216
xdk:server:[2015-11-16T18:25:26.547Z]: (1447698326547): memmrk:    32072836    71870336
xdk:client:[2015-11-16T18:25:30.671Z]: (1447698330671): memmrk:    80909476    126665216
xdk:server:[2015-11-16T18:25:31.548Z]: (1447698331548): memmrk:    25355976    71870336
xdk:client:[2015-11-16T18:25:35.672Z]: (1447698335672): memmrk:    80926548    126665216
xdk:server:[2015-11-16T18:25:36.548Z]: (1447698336548): memmrk:    25369524    71870336
xdk:client:[2015-11-16T18:25:40.673Z]: (1447698340673): memmrk:    80963012    126665216
xdk:server:[2015-11-16T18:25:41.548Z]: (1447698341548): memmrk:    23944936    38887296
xdk:client:[2015-11-16T18:25:45.673Z]: (1447698345673): memmrk:    81078876    126665216
xdk:server:[2015-11-16T18:25:46.548Z]: (1447698346548): memmrk:    23952528    38887296
xdk:client:[2015-11-16T18:25:50.673Z]: (1447698350673): memmrk:    81149720    127680896
xdk:server:[2015-11-16T18:25:51.548Z]: (1447698351548): memmrk:    23988560    38887296
xdk:client:[2015-11-16T18:25:55.674Z]: (1447698355674): memmrk:    71009624    127680896
xdk:server:[2015-11-16T18:25:56.549Z]: (1447698356549): memmrk:    23789296    32805376
xdk:client:[2015-11-16T18:26:00.675Z]: (1447698360675): memmrk:    70450972    127680896
xdk:server:[2015-11-16T18:26:01.549Z]: (1447698361549): memmrk:    23320384    32805376
xdk:client:[2015-11-16T18:26:05.675Z]: (1447698365675): memmrk:    76656520    127680896
xdk:server:[2015-11-16T18:26:06.549Z]: (1447698366549): memmrk:    23294676    32805376
xdk:client:[2015-11-16T18:26:10.676Z]: (1447698370676): memmrk:    76881624    127680896
xdk:server:[2015-11-16T18:26:11.550Z]: (1447698371550): memmrk:    23388376    32838272
xdk:client:[2015-11-16T18:26:15.675Z]: (1447698375675): memmrk:    76868828    127680896
xdk:server:[2015-11-16T18:26:16.550Z]: (1447698376550): memmrk:    23398672    32838272
xdk:client:[2015-11-16T18:26:20.675Z]: (1447698380675): memmrk:    76906132    127680896
xdk:server:[2015-11-16T18:26:21.550Z]: (1447698381550): memmrk:    22737172    32838272
xdk:client:[2015-11-16T18:26:25.676Z]: (1447698385676): memmrk:    76901164    127680896
xdk:server:[2015-11-16T18:26:26.550Z]: (1447698386550): memmrk:    22744908    32838272
xdk:client:[2015-11-16T18:26:30.677Z]: (1447698390677): memmrk:    77015932    127680896
xdk:server:[2015-11-16T18:26:31.550Z]: (1447698391550): memmrk:    22751884    32838272
xdk:client:[2015-11-16T18:26:35.677Z]: (1447698395677): memmrk:    77045028    128696576
xdk:server:[2015-11-16T18:26:36.550Z]: (1447698396550): memmrk:    22758876    32838272
xdk:client:[2015-11-16T18:26:40.679Z]: (1447698400679): memmrk:    83439664    128696576
xdk:server:[2015-11-16T18:26:41.550Z]: (1447698401550): memmrk:    22765868    32838272
xdk:client:[2015-11-16T18:26:45.684Z]: (1447698405684): memmrk:    83472560    129712256
xdk:server:[2015-11-16T18:26:46.550Z]: (1447698406550): memmrk:    22772860    32838272
xdk:client:[2015-11-16T18:26:50.685Z]: (1447698410685): memmrk:    83596616    130727936
xdk:server:[2015-11-16T18:26:51.551Z]: (1447698411551): memmrk:    22779852    32838272
xdk:client:[2015-11-16T18:26:55.685Z]: (1447698415685): memmrk:    83585940    131743616
xdk:server:[2015-11-16T18:26:56.551Z]: (1447698416551): memmrk:    22786860    32838272
xdk:client:[2015-11-16T18:27:00.685Z]: (1447698420685): memmrk:    83623160    132759296
xdk:server:[2015-11-16T18:27:01.551Z]: (1447698421551): memmrk:    22793852    32838272
xdk:client:[2015-11-16T18:27:05.686Z]: (1447698425686): memmrk:    83696220    133774976
xdk:server:[2015-11-16T18:27:06.551Z]: (1447698426551): memmrk:    22800860    32838272
xdk:client:[2015-11-16T18:27:10.687Z]: (1447698430687): memmrk:    83760652    134790656
xdk:server:[2015-11-16T18:27:11.550Z]: (1447698431550): memmrk:    22807852    32838272
xdk:client:[2015-11-16T18:27:15.687Z]: (1447698435687): memmrk:    89968680    134790656
xdk:server:[2015-11-16T18:27:16.551Z]: (1447698436551): memmrk:    22814828    32838272
xdk:client:[2015-11-16T18:27:20.688Z]: (1447698440688): memmrk:    90022548    134790656
xdk:server:[2015-11-16T18:27:21.551Z]: (1447698441551): memmrk:    22821804    32838272
xdk:client:[2015-11-16T18:27:25.688Z]: (1447698445688): memmrk:    90111464    135806336
xdk:server:[2015-11-16T18:27:26.551Z]: (1447698446551): memmrk:    22828780    32838272
xdk:client:[2015-11-16T18:27:30.689Z]: (1447698450689): memmrk:    90158912    136822016
xdk:server:[2015-11-16T18:27:31.552Z]: (1447698451552): memmrk:    22835756    32838272
xdk:client:[2015-11-16T18:27:35.689Z]: (1447698455689): memmrk:    90146072    137837696
xdk:server:[2015-11-16T18:27:36.551Z]: (1447698456551): memmrk:    22844344    32838272
xdk:client:[2015-11-16T18:27:40.690Z]: (1447698460690): memmrk:    90249248    138853376
xdk:server:[2015-11-16T18:27:41.552Z]: (1447698461552): memmrk:    22850396    32838272
xdk:client:[2015-11-16T18:27:45.690Z]: (1447698465690): memmrk:    90286180    139869056
xdk:server:[2015-11-16T18:27:46.552Z]: (1447698466552): memmrk:    22857372    32838272
xdk:client:[2015-11-16T18:27:50.691Z]: (1447698470691): memmrk:    96547820    139869056
xdk:server:[2015-11-16T18:27:51.552Z]: (1447698471552): memmrk:    22864348    32838272
xdk:client:[2015-11-16T18:27:55.692Z]: (1447698475692): memmrk:    96540560    140884736
xdk:server:[2015-11-16T18:27:56.552Z]: (1447698476552): memmrk:    22871324    32838272
xdk:client:[2015-11-16T18:28:00.692Z]: (1447698480692): memmrk:    96598208    141900416
xdk:server:[2015-11-16T18:28:01.552Z]: (1447698481552): memmrk:    22878324    32838272
xdk:client:[2015-11-16T18:28:05.692Z]: (1447698485692): memmrk:    96662428    142916096
xdk:server:[2015-11-16T18:28:06.553Z]: (1447698486553): memmrk:    22888848    32838272
xdk:client:[2015-11-16T18:28:10.692Z]: (1447698490692): memmrk:    96707360    143931776
xdk:server:[2015-11-16T18:28:11.552Z]: (1447698491552): memmrk:    22895856    32838272
xdk:client:[2015-11-16T18:28:15.692Z]: (1447698495692): memmrk:    96695856    144947456
xdk:server:[2015-11-16T18:28:16.552Z]: (1447698496552): memmrk:    22902832    32838272
xdk:client:[2015-11-16T18:28:20.696Z]: (1447698500696): memmrk:    96827956    145963136
xdk:server:[2015-11-16T18:28:21.553Z]: (1447698501553): memmrk:    22909808    32838272
xdk:client:[2015-11-16T18:28:25.697Z]: (1447698505697): memmrk:    103033456    145963136
xdk:server:[2015-11-16T18:28:26.553Z]: (1447698506553): memmrk:    22916784    32838272
xdk:client:[2015-11-16T18:28:30.698Z]: (1447698510698): memmrk:    103096600    145963136
xdk:server:[2015-11-16T18:28:31.553Z]: (1447698511553): memmrk:    22923760    32838272
xdk:client:[2015-11-16T18:28:35.701Z]: (1447698515701): memmrk:    103094160    146978816
xdk:server:[2015-11-16T18:28:36.553Z]: (1447698516553): memmrk:    22930736    32838272
xdk:client:[2015-11-16T18:28:40.702Z]: (1447698520702): memmrk:    103266028    147994496
xdk:server:[2015-11-16T18:28:41.554Z]: (1447698521554): memmrk:    22937712    32838272
xdk:client:[2015-11-16T18:28:45.703Z]: (1447698525703): memmrk:    103256012    149010176
xdk:server:[2015-11-16T18:28:46.553Z]: (1447698526553): memmrk:    22944704    32838272
xdk:client:[2015-11-16T18:28:50.704Z]: (1447698530704): memmrk:    103330344    150025856
xdk:server:[2015-11-16T18:28:51.554Z]: (1447698531554): memmrk:    22951680    32838272
xdk:client:[2015-11-16T18:28:55.704Z]: (1447698535704): memmrk:    109541968    150025856
xdk:server:[2015-11-16T18:28:56.554Z]: (1447698536554): memmrk:    22958656    32838272
xdk:client:[2015-11-16T18:29:00.704Z]: (1447698540704): memmrk:    109662848    151041536
xdk:server:[2015-11-16T18:29:01.554Z]: (1447698541554): memmrk:    22965632    32838272
xdk:client:[2015-11-16T18:29:05.704Z]: (1447698545704): memmrk:    109637368    152057216
xdk:server:[2015-11-16T18:29:06.554Z]: (1447698546554): memmrk:    22972640    32838272
xdk:client:[2015-11-16T18:29:10.705Z]: (1447698550705): memmrk:    109671596    153072896
xdk:server:[2015-11-16T18:29:11.554Z]: (1447698551554): memmrk:    22979632    32838272
xdk:client:[2015-11-16T18:29:15.705Z]: (1447698555705): memmrk:    109769804    154088576
xdk:server:[2015-11-16T18:29:16.554Z]: (1447698556554): memmrk:    22986608    32838272
xdk:client:[2015-11-16T18:29:20.706Z]: (1447698560706): memmrk:    109827976    155104256
xdk:server:[2015-11-16T18:29:21.554Z]: (1447698561554): memmrk:    22993584    32838272
xdk:client:[2015-11-16T18:29:25.706Z]: (1447698565706): memmrk:    109812436    156119936
xdk:server:[2015-11-16T18:29:26.555Z]: (1447698566555): memmrk:    23000560    32838272
xdk:client:[2015-11-16T18:29:30.713Z]: (1447698570713): memmrk:    116080368    156119936
xdk:server:[2015-11-16T18:29:31.555Z]: (1447698571555): memmrk:    23007552    32838272
xdk:client:[2015-11-16T18:29:35.714Z]: (1447698575714): memmrk:    116133664    157135616
xdk:server:[2015-11-16T18:29:36.555Z]: (1447698576555): memmrk:    23014528    32838272
xdk:client:[2015-11-16T18:29:40.714Z]: (1447698580714): memmrk:    116205456    158151296
xdk:server:[2015-11-16T18:29:41.555Z]: (1447698581555): memmrk:    23021504    32838272
xdk:client:[2015-11-16T18:29:45.716Z]: (1447698585716): memmrk:    116191420    158151296
xdk:server:[2015-11-16T18:29:46.555Z]: (1447698586555): memmrk:    23028480    32838272
xdk:client:[2015-11-16T18:29:50.716Z]: (1447698590716): memmrk:    116264292    159166976
xdk:server:[2015-11-16T18:29:51.556Z]: (1447698591556): memmrk:    23035456    32838272
xdk:client:[2015-11-16T18:29:55.716Z]: (1447698595716): memmrk:    116315120    160182656
xdk:server:[2015-11-16T18:29:56.556Z]: (1447698596556): memmrk:    23042448    32838272
xdk:client:[2015-11-16T18:30:00.717Z]: (1447698600717): memmrk:    116347616    161198336
xdk:server:[2015-11-16T18:30:01.556Z]: (1447698601556): memmrk:    23049424    32838272
xdk:client:[2015-11-16T18:30:05.717Z]: (1447698605717): memmrk:    122552968    161198336
xdk:server:[2015-11-16T18:30:06.556Z]: (1447698606556): memmrk:    23060856    32838272
xdk:client:[2015-11-16T18:30:10.718Z]: (1447698610718): memmrk:    122594620    162214016
xdk:server:[2015-11-16T18:30:11.556Z]: (1447698611556): memmrk:    23067848    32838272
xdk:client:[2015-11-16T18:30:15.718Z]: (1447698615718): memmrk:    122654112    163229696
xdk:server:[2015-11-16T18:30:16.556Z]: (1447698616556): memmrk:    23155524    32838272
xdk:client:[2015-11-16T18:30:20.719Z]: (1447698620719): memmrk:    122706392    164245376
xdk:server:[2015-11-16T18:30:21.556Z]: (1447698621556): memmrk:    23163852    32838272
xdk:client:[2015-11-16T18:30:25.724Z]: (1447698625724): memmrk:    122711088    165261056
xdk:server:[2015-11-16T18:30:26.556Z]: (1447698626556): memmrk:    23170828    32838272
xdk:client:[2015-11-16T18:30:30.724Z]: (1447698630724): memmrk:    122823944    166276736
xdk:server:[2015-11-16T18:30:31.557Z]: (1447698631557): memmrk:    23177804    32838272
xdk:client:[2015-11-16T18:30:35.725Z]: (1447698635725): memmrk:    122821072    167292416
xdk:server:[2015-11-16T18:30:36.557Z]: (1447698636557): memmrk:    23184796    32838272
xdk:client:[2015-11-16T18:30:40.725Z]: (1447698640725): memmrk:    129073172    167292416
xdk:server:[2015-11-16T18:30:41.557Z]: (1447698641557): memmrk:    23191772    32838272
xdk:client:[2015-11-16T18:30:45.725Z]: (1447698645725): memmrk:    129023208    168308096
xdk:server:[2015-11-16T18:30:46.557Z]: (1447698646557): memmrk:    23198732    32838272
xdk:client:[2015-11-16T18:30:50.726Z]: (1447698650726): memmrk:    129064892    169323776
xdk:server:[2015-11-16T18:30:51.557Z]: (1447698651557): memmrk:    23205628    32838272
xdk:client:[2015-11-16T18:30:55.726Z]: (1447698655726): memmrk:    129070868    169323776
xdk:server:[2015-11-16T18:30:56.557Z]: (1447698656557): memmrk:    23212572    32838272
xdk:client:[2015-11-16T18:31:00.727Z]: (1447698660727): memmrk:    129076000    170339456
xdk:server:[2015-11-16T18:31:01.557Z]: (1447698661557): memmrk:    23219548    32838272
xdk:client:[2015-11-16T18:31:05.726Z]: (1447698665726): memmrk:    129001960    171355136
xdk:server:[2015-11-16T18:31:06.557Z]: (1447698666557): memmrk:    23226540    32838272
xdk:client:[2015-11-16T18:31:10.728Z]: (1447698670728): memmrk:    129024776    172370816
xdk:server:[2015-11-16T18:31:11.557Z]: (1447698671557): memmrk:    23233532    32838272
xdk:client:[2015-11-16T18:31:15.728Z]: (1447698675728): memmrk:    135170548    172370816
xdk:server:[2015-11-16T18:31:16.558Z]: (1447698676558): memmrk:    23240508    32838272
xdk:client:[2015-11-16T18:31:20.728Z]: (1447698680728): memmrk:    135224348    173386496
xdk:server:[2015-11-16T18:31:21.558Z]: (1447698681558): memmrk:    23247484    32838272
xdk:client:[2015-11-16T18:31:25.729Z]: (1447698685729): memmrk:    135230500    174402176
xdk:server:[2015-11-16T18:31:26.558Z]: (1447698686558): memmrk:    23263524    32838272
xdk:client:[2015-11-16T18:31:30.729Z]: (1447698690729): memmrk:    135211424    175417856
xdk:server:[2015-11-16T18:31:31.559Z]: (1447698691559): memmrk:    23270500    32838272
xdk:client:[2015-11-16T18:31:35.729Z]: (1447698695729): memmrk:    135137268    176433536
xdk:server:[2015-11-16T18:31:36.559Z]: (1447698696559): memmrk:    23277476    32838272
xdk:client:[2015-11-16T18:31:40.729Z]: (1447698700729): memmrk:    135236784    177449216
xdk:server:[2015-11-16T18:31:41.560Z]: (1447698701560): memmrk:    23291896    32838272
xdk:client:[2015-11-16T18:31:45.729Z]: (1447698705729): memmrk:    141384236    177449216
xdk:server:[2015-11-16T18:31:46.559Z]: (1447698706559): memmrk:    23299660    32838272
xdk:client:[2015-11-16T18:31:50.730Z]: (1447698710730): memmrk:    141437636    178464896
xdk:server:[2015-11-16T18:31:51.560Z]: (1447698711560): memmrk:    23306636    32838272
xdk:client:[2015-11-16T18:31:55.730Z]: (1447698715730): memmrk:    141440560    179480576
xdk:server:[2015-11-16T18:31:56.560Z]: (1447698716560): memmrk:    23313612    32838272
xdk:client:[2015-11-16T18:32:00.731Z]: (1447698720731): memmrk:    141415268    180496256
xdk:server:[2015-11-16T18:32:01.560Z]: (1447698721560): memmrk:    23320588    32838272
xdk:client:[2015-11-16T18:32:05.731Z]: (1447698725731): memmrk:    141341180    181511936
xdk:server:[2015-11-16T18:32:06.560Z]: (1447698726560): memmrk:    23329880    32838272
xdk:client:[2015-11-16T18:32:10.732Z]: (1447698730732): memmrk:    141394968    182527616
xdk:server:[2015-11-16T18:32:11.560Z]: (1447698731560): memmrk:    23336872    32838272
xdk:client:[2015-11-16T18:32:15.732Z]: (1447698735732): memmrk:    141400416    182527616
xdk:server:[2015-11-16T18:32:16.560Z]: (1447698736560): memmrk:    23343848    32838272
xdk:client:[2015-11-16T18:32:20.737Z]: (1447698740737): memmrk:    147613364    182527616
xdk:server:[2015-11-16T18:32:21.560Z]: (1447698741560): memmrk:    23350824    32838272
xdk:client:[2015-11-16T18:32:25.738Z]: (1447698745738): memmrk:    147594608    183543296
xdk:server:[2015-11-16T18:32:26.561Z]: (1447698746561): memmrk:    23359892    32838272
xdk:client:[2015-11-16T18:32:30.738Z]: (1447698750738): memmrk:    147578816    184558976
xdk:server:[2015-11-16T18:32:31.560Z]: (1447698751560): memmrk:    23370392    32838272
xdk:client:[2015-11-16T18:32:35.739Z]: (1447698755739): memmrk:    147529836    185574656
xdk:server:[2015-11-16T18:32:36.560Z]: (1447698756560): memmrk:    23388892    32838272
xdk:client:[2015-11-16T18:32:40.739Z]: (1447698760739): memmrk:    147584388    186590336
xdk:server:[2015-11-16T18:32:41.560Z]: (1447698761560): memmrk:    23395708    32838272
xdk:client:[2015-11-16T18:32:45.740Z]: (1447698765740): memmrk:    147589792    187606016
xdk:server:[2015-11-16T18:32:46.560Z]: (1447698766560): memmrk:    23402524    32838272
xdk:client:[2015-11-16T18:32:50.740Z]: (1447698770740): memmrk:    147592876    188621696
xdk:server:[2015-11-16T18:32:51.561Z]: (1447698771561): memmrk:    23409340    32838272
xdk:client:[2015-11-16T18:32:55.866Z]: (1447698775866): memmrk:    151692312    188621696
xdk:server:[2015-11-16T18:32:56.561Z]: (1447698776561): memmrk:    23416156    32838272
xdk:client:[2015-11-16T18:33:00.866Z]: (1447698780866): memmrk:    71354180    188621696
xdk:server:[2015-11-16T18:33:01.561Z]: (1447698781561): memmrk:    23422972    32838272
xdk:client:[2015-11-16T18:33:05.867Z]: (1447698785867): memmrk:    71621976    188621696
xdk:server:[2015-11-16T18:33:06.561Z]: (1447698786561): memmrk:    23429820    32838272
xdk:client:[2015-11-16T18:33:10.867Z]: (1447698790867): memmrk:    71170260    116075776
xdk:server:[2015-11-16T18:33:11.561Z]: (1447698791561): memmrk:    23436652    32838272
xdk:client:[2015-11-16T18:33:15.867Z]: (1447698795867): memmrk:    70269184    98857856
xdk:server:[2015-11-16T18:33:16.562Z]: (1447698796562): memmrk:    23443468    32838272
xdk:client:[2015-11-16T18:33:20.867Z]: (1447698800867): memmrk:    69928452    88701056
xdk:server:[2015-11-16T18:33:21.562Z]: (1447698801562): memmrk:    23450284    32838272
xdk:client:[2015-11-16T18:33:25.866Z]: (1447698805866): memmrk:    70197756    82639872
xdk:server:[2015-11-16T18:33:26.562Z]: (1447698806562): memmrk:    23457100    32838272
xdk:client:[2015-11-16T18:33:30.867Z]: (1447698810867): memmrk:    67667964    82639872
xdk:server:[2015-11-16T18:33:31.563Z]: (1447698811563): memmrk:    23463916    32838272
xdk:client:[2015-11-16T18:33:35.866Z]: (1447698815866): memmrk:    67828996    82639872
xdk:server:[2015-11-16T18:33:36.563Z]: (1447698816563): memmrk:    23470732    32838272
xdk:client:[2015-11-16T18:33:40.867Z]: (1447698820867): memmrk:    67935316    82639872
xdk:server:[2015-11-16T18:33:41.564Z]: (1447698821564): memmrk:    23477548    32838272
xdk:client:[2015-11-16T18:33:45.866Z]: (1447698825866): memmrk:    68091812    82639872
xdk:server:[2015-11-16T18:33:46.564Z]: (1447698826564): memmrk:    23484364    32838272
xdk:client:[2015-11-16T18:33:50.866Z]: (1447698830866): memmrk:    68198116    82639872
xdk:server:[2015-11-16T18:33:51.564Z]: (1447698831564): memmrk:    23491180    32838272
xdk:client:[2015-11-16T18:33:55.866Z]: (1447698835866): memmrk:    68356044    82639872
xdk:server:[2015-11-16T18:33:56.564Z]: (1447698836564): memmrk:    23497996    32838272
xdk:client:[2015-11-16T18:34:00.866Z]: (1447698840866): memmrk:    68462348    82639872
xdk:server:[2015-11-16T18:34:01.565Z]: (1447698841565): memmrk:    23504812    32838272
xdk:client:[2015-11-16T18:34:05.867Z]: (1447698845867): memmrk:    68629296    82639872
xdk:server:[2015-11-16T18:34:06.565Z]: (1447698846565): memmrk:    23511660    32838272
xdk:client:[2015-11-16T18:34:10.865Z]: (1447698850865): memmrk:    68736580    82639872
xdk:server:[2015-11-16T18:34:11.565Z]: (1447698851565): memmrk:    23518492    32838272
xdk:client:[2015-11-16T18:34:15.867Z]: (1447698855867): memmrk:    68153564    82639872
xdk:server:[2015-11-16T18:34:16.565Z]: (1447698856565): memmrk:    23525308    32838272
xdk:client:[2015-11-16T18:34:20.867Z]: (1447698860867): memmrk:    68259788    82639872
xdk:server:[2015-11-16T18:34:21.565Z]: (1447698861565): memmrk:    23532124    32838272
xdk:client:[2015-11-16T18:34:25.867Z]: (1447698865867): memmrk:    68417500    82639872
xdk:server:[2015-11-16T18:34:26.565Z]: (1447698866565): memmrk:    23538940    32838272
xdk:client:[2015-11-16T18:34:30.866Z]: (1447698870866): memmrk:    68525660    82639872
xdk:server:[2015-11-16T18:34:31.565Z]: (1447698871565): memmrk:    23545756    32838272
xdk:client:[2015-11-16T18:34:35.866Z]: (1447698875866): memmrk:    68684048    82639872
xdk:server:[2015-11-16T18:34:36.564Z]: (1447698876564): memmrk:    23552572    32838272
xdk:client:[2015-11-16T18:34:40.867Z]: (1447698880867): memmrk:    68804032    82639872
xdk:server:[2015-11-16T18:34:41.564Z]: (1447698881564): memmrk:    23559388    32838272
xdk:client:[2015-11-16T18:34:45.866Z]: (1447698885866): memmrk:    68408140    82639872
xdk:server:[2015-11-16T18:34:46.565Z]: (1447698886565): memmrk:    23566204    32838272
xdk:client:[2015-11-16T18:34:50.866Z]: (1447698890866): memmrk:    68519588    82639872
xdk:server:[2015-11-16T18:34:51.565Z]: (1447698891565): memmrk:    23573020    32838272
xdk:client:[2015-11-16T18:34:55.867Z]: (1447698895867): memmrk:    68675948    82639872
xdk:server:[2015-11-16T18:34:56.565Z]: (1447698896565): memmrk:    23579836    32838272
xdk:client:[2015-11-16T18:35:00.866Z]: (1447698900866): memmrk:    68782156    82639872
xdk:server:[2015-11-16T18:35:01.565Z]: (1447698901565): memmrk:    23586652    32838272
xdk:client:[2015-11-16T18:35:05.867Z]: (1447698905867): memmrk:    68939256    82639872
xdk:server:[2015-11-16T18:35:06.566Z]: (1447698906566): memmrk:    23593500    32838272
xdk:client:[2015-11-16T18:35:10.866Z]: (1447698910866): memmrk:    69045480    82639872
xdk:server:[2015-11-16T18:35:11.566Z]: (1447698911566): memmrk:    23600332    32838272
xdk:client:[2015-11-16T18:35:15.867Z]: (1447698915867): memmrk:    69201840    82639872
xdk:server:[2015-11-16T18:35:16.566Z]: (1447698916566): memmrk:    23619944    32838272
xdk:client:[2015-11-16T18:35:20.866Z]: (1447698920866): memmrk:    68687700    82639872
xdk:server:[2015-11-16T18:35:21.566Z]: (1447698921566): memmrk:    23626760    32838272
xdk:client:[2015-11-16T18:35:25.867Z]: (1447698925867): memmrk:    68844060    82639872
xdk:server:[2015-11-16T18:35:26.566Z]: (1447698926566): memmrk:    23633576    32838272
xdk:client:[2015-11-16T18:35:30.867Z]: (1447698930867): memmrk:    68950268    82639872
xdk:server:[2015-11-16T18:35:31.567Z]: (1447698931567): memmrk:    23640392    32838272
xdk:client:[2015-11-16T18:35:35.866Z]: (1447698935866): memmrk:    69106628    82639872
xdk:server:[2015-11-16T18:35:36.567Z]: (1447698936567): memmrk:    23647208    32838272
xdk:client:[2015-11-16T18:35:40.867Z]: (1447698940867): memmrk:    69212836    82639872
xdk:server:[2015-11-16T18:35:41.567Z]: (1447698941567): memmrk:    23654024    32838272
xdk:client:[2015-11-16T18:35:45.867Z]: (1447698945867): memmrk:    69369196    82639872
xdk:server:[2015-11-16T18:35:46.568Z]: (1447698946568): memmrk:    23672996    32838272
xdk:client:[2015-11-16T18:35:50.868Z]: (1447698950868): memmrk:    69475404    82639872
xdk:server:[2015-11-16T18:35:51.568Z]: (1447698951568): memmrk:    23679812    32838272
xdk:client:[2015-11-16T18:35:55.868Z]: (1447698955868): memmrk:    69027792    84737024
xdk:server:[2015-11-16T18:35:56.568Z]: (1447698956568): memmrk:    23686628    32838272
xdk:client:[2015-11-16T18:36:00.867Z]: (1447698960867): memmrk:    69134020    84737024
xdk:server:[2015-11-16T18:36:01.568Z]: (1447698961568): memmrk:    23693444    32838272
xdk:client:[2015-11-16T18:36:05.868Z]: (1447698965868): memmrk:    69291880    84737024
xdk:server:[2015-11-16T18:36:06.568Z]: (1447698966568): memmrk:    23700276    32838272
xdk:client:[2015-11-16T18:36:10.868Z]: (1447698970868): memmrk:    69398104    84737024
xdk:server:[2015-11-16T18:36:11.568Z]: (1447698971568): memmrk:    23708224    32838272
xdk:client:[2015-11-16T18:36:15.867Z]: (1447698975867): memmrk:    69554464    84737024
xdk:server:[2015-11-16T18:36:16.568Z]: (1447698976568): memmrk:    23715040    32838272
xdk:client:[2015-11-16T18:36:20.868Z]: (1447698980868): memmrk:    69663436    84737024
xdk:server:[2015-11-16T18:36:21.568Z]: (1447698981568): memmrk:    23721856    32838272
xdk:client:[2015-11-16T18:36:25.868Z]: (1447698985868): memmrk:    69820576    84737024
xdk:server:[2015-11-16T18:36:26.569Z]: (1447698986569): memmrk:    23728672    32838272
xdk:client:[2015-11-16T18:36:30.867Z]: (1447698990867): memmrk:    69926800    84737024
xdk:server:[2015-11-16T18:36:31.568Z]: (1447698991568): memmrk:    23735488    32838272
xdk:client:[2015-11-16T18:36:35.867Z]: (1447698995867): memmrk:    70084412    84737024
xdk:server:[2015-11-16T18:36:36.568Z]: (1447698996568): memmrk:    23742304    32838272
xdk:client:[2015-11-16T18:36:40.867Z]: (1447699000867): memmrk:    71117396    84737024
xdk:server:[2015-11-16T18:36:41.568Z]: (1447699001568): memmrk:    23761276    32838272
xdk:client:[2015-11-16T18:36:45.868Z]: (1447699005868): memmrk:    73897892    88931328
xdk:server:[2015-11-16T18:36:46.571Z]: (1447699006571): memmrk:    23768092    32838272
xdk:client:[2015-11-16T18:36:50.880Z]: (1447699010880): memmrk:    70643872    88931328
xdk:server:[2015-11-16T18:36:51.571Z]: (1447699011571): memmrk:    23774908    32838272
xdk:server:[2015-11-16T18:36:56.572Z]: (1447699016572): memmrk:    23781724    32838272
xdk:client:[2015-11-16T18:36:56.866Z]: (1447699016866): memmrk:    69948924    81591296
xdk:server:[2015-11-16T18:37:01.572Z]: (1447699021572): memmrk:    23788540    32838272
xdk:client:[2015-11-16T18:37:01.866Z]: (1447699021866): memmrk:    70200240    81591296
xdk:server:[2015-11-16T18:37:06.571Z]: (1447699026571): memmrk:    23795388    32838272
xdk:client:[2015-11-16T18:37:06.866Z]: (1447699026866): memmrk:    70056636    81591296
xdk:server:[2015-11-16T18:37:11.573Z]: (1447699031573): memmrk:    23802220    32838272
xdk:client:[2015-11-16T18:37:11.867Z]: (1447699031867): memmrk:    69942776    81591296
xdk:server:[2015-11-16T18:37:16.573Z]: (1447699036573): memmrk:    23809036    32838272
xdk:client:[2015-11-16T18:37:16.865Z]: (1447699036865): memmrk:    70211628    82639872
xdk:server:[2015-11-16T18:37:21.572Z]: (1447699041572): memmrk:    23815852    32838272
xdk:client:[2015-11-16T18:37:21.866Z]: (1447699041866): memmrk:    67742408    82639872
xdk:server:[2015-11-16T18:37:26.574Z]: (1447699046574): memmrk:    23822668    32838272
xdk:client:[2015-11-16T18:37:26.866Z]: (1447699046866): memmrk:    67850516    82639872
xdk:server:[2015-11-16T18:37:31.575Z]: (1447699051575): memmrk:    23829484    32838272
xdk:client:[2015-11-16T18:37:31.866Z]: (1447699051866): memmrk:    68007012    82639872
xdk:server:[2015-11-16T18:37:36.575Z]: (1447699056575): memmrk:    23836300    32838272
xdk:client:[2015-11-16T18:37:36.866Z]: (1447699056866): memmrk:    68113316    82639872
xdk:server:[2015-11-16T18:37:41.575Z]: (1447699061575): memmrk:    23843116    32838272
xdk:client:[2015-11-16T18:37:41.867Z]: (1447699061867): memmrk:    68269812    82639872
xdk:server:[2015-11-16T18:37:46.575Z]: (1447699066575): memmrk:    23849932    32838272
xdk:client:[2015-11-16T18:37:46.866Z]: (1447699066866): memmrk:    68377504    82639872
xdk:server:[2015-11-16T18:37:51.576Z]: (1447699071576): memmrk:    23856748    32838272
xdk:client:[2015-11-16T18:37:51.866Z]: (1447699071866): memmrk:    68536484    82639872
xdk:server:[2015-11-16T18:37:56.576Z]: (1447699076576): memmrk:    23863580    32838272
xdk:client:[2015-11-16T18:37:56.866Z]: (1447699076866): memmrk:    68655468    82639872
xdk:server:[2015-11-16T18:38:01.576Z]: (1447699081576): memmrk:    23870396    32838272
xdk:client:[2015-11-16T18:38:01.865Z]: (1447699081865): memmrk:    68093544    82639872
xdk:server:[2015-11-16T18:38:06.577Z]: (1447699086577): memmrk:    23877244    32838272
xdk:client:[2015-11-16T18:38:06.867Z]: (1447699086867): memmrk:    68199800    82639872
xdk:server:[2015-11-16T18:38:11.577Z]: (1447699091577): memmrk:    22921888    32838272
xdk:client:[2015-11-16T18:38:11.866Z]: (1447699091866): memmrk:    68356176    82639872
xdk:server:[2015-11-16T18:38:16.577Z]: (1447699096577): memmrk:    22928704    32838272
xdk:client:[2015-11-16T18:38:16.866Z]: (1447699096866): memmrk:    68465000    82639872
xdk:server:[2015-11-16T18:38:21.577Z]: (1447699101577): memmrk:    22935580    32838272
xdk:client:[2015-11-16T18:38:21.866Z]: (1447699101866): memmrk:    68621360    82639872
xdk:server:[2015-11-16T18:38:26.577Z]: (1447699106577): memmrk:    22942456    32838272
xdk:client:[2015-11-16T18:38:26.866Z]: (1447699106866): memmrk:    68729428    82639872
xdk:server:[2015-11-16T18:38:31.577Z]: (1447699111577): memmrk:    22949332    32838272
xdk:client:[2015-11-16T18:38:31.866Z]: (1447699111866): memmrk:    68327236    82639872
xdk:server:[2015-11-16T18:38:36.577Z]: (1447699116577): memmrk:    22956208    32838272
xdk:client:[2015-11-16T18:38:36.866Z]: (1447699116866): memmrk:    68433444    82639872
xdk:server:[2015-11-16T18:38:41.577Z]: (1447699121577): memmrk:    22963084    32838272
xdk:client:[2015-11-16T18:38:41.866Z]: (1447699121866): memmrk:    68589804    82639872
xdk:server:[2015-11-16T18:38:46.577Z]: (1447699126577): memmrk:    22969960    32838272
xdk:client:[2015-11-16T18:38:46.870Z]: (1447699126870): memmrk:    69367828    84737024
xdk:server:[2015-11-16T18:38:51.578Z]: (1447699131578): memmrk:    22976836    32838272
xdk:client:[2015-11-16T18:38:51.866Z]: (1447699131866): memmrk:    69502256    84737024
xdk:server:[2015-11-16T18:38:56.578Z]: (1447699136578): memmrk:    22983712    32838272
xdk:client:[2015-11-16T18:38:56.866Z]: (1447699136866): memmrk:    69608468    84737024
xdk:server:[2015-11-16T18:39:01.578Z]: (1447699141578): memmrk:    22990588    32838272
xdk:client:[2015-11-16T18:39:01.866Z]: (1447699141866): memmrk:    69764828    84737024
xdk:server:[2015-11-16T18:39:06.579Z]: (1447699146579): memmrk:    22997496    32838272
xdk:client:[2015-11-16T18:39:06.866Z]: (1447699146866): memmrk:    69871068    84737024
xdk:server:[2015-11-16T18:39:11.578Z]: (1447699151578): memmrk:    23004388    32838272
xdk:client:[2015-11-16T18:39:11.867Z]: (1447699151867): memmrk:    70031024    84737024
xdk:server:[2015-11-16T18:39:16.579Z]: (1447699156579): memmrk:    23011264    32838272
xdk:client:[2015-11-16T18:39:16.865Z]: (1447699156865): memmrk:    70137232    84737024
xdk:server:[2015-11-16T18:39:21.579Z]: (1447699161579): memmrk:    23018140    32838272
xdk:client:[2015-11-16T18:39:21.866Z]: (1447699161866): memmrk:    70293592    84737024
xdk:server:[2015-11-16T18:39:26.579Z]: (1447699166579): memmrk:    23025016    32838272
xdk:client:[2015-11-16T18:39:26.870Z]: (1447699166870): memmrk:    70304360    84737024
xdk:server:[2015-11-16T18:39:31.580Z]: (1447699171581): memmrk:    23031892    32838272
xdk:client:[2015-11-16T18:39:31.870Z]: (1447699171870): memmrk:    73452084    88931328
xdk:server:[2015-11-16T18:39:36.581Z]: (1447699176581): memmrk:    23038768    32838272
xdk:client:[2015-11-16T18:39:36.871Z]: (1447699176871): memmrk:    73200796    88931328
xdk:server:[2015-11-16T18:39:41.581Z]: (1447699181581): memmrk:    23045644    32838272
xdk:client:[2015-11-16T18:39:41.871Z]: (1447699181871): memmrk:    75850768    89947008
xdk:server:[2015-11-16T18:39:46.581Z]: (1447699186581): memmrk:    23052520    32838272
xdk:client:[2015-11-16T18:39:46.872Z]: (1447699186872): memmrk:    78946964    99351296
client:adb:[2015-11-16T18:39:50.897Z]: (1447699190897): Rejected adb command with stderr  "C:\Users\Tedd\AppData\Local\Intel\XDK\bin\adb\adb" devices
client:device-discovery:[2015-11-16T18:39:50.898Z]: (1447699190898): ADB device detector failed...  { code: 3221225794, output: '' }
xdk:server:[2015-11-16T18:39:51.581Z]: (1447699191581): memmrk:    23059396    32838272
xdk:client:[2015-11-16T18:39:51.873Z]: (1447699191873): memmrk:    78428908    99351296
xdk:server:[2015-11-16T18:39:56.581Z]: (1447699196581): memmrk:    23066272    32838272
xdk:client:[2015-11-16T18:39:56.873Z]: (1447699196873): memmrk:    78392604    100366976
xdk:server:[2015-11-16T18:40:01.582Z]: (1447699201582): memmrk:    23073148    32838272
xdk:client:[2015-11-16T18:40:01.873Z]: (1447699201873): memmrk:    67945868    100366976
xdk:server:[2015-11-16T18:40:06.582Z]: (1447699206582): memmrk:    23080056    32838272
xdk:client:[2015-11-16T18:40:06.874Z]: (1447699206874): memmrk:    73902060    100366976
xdk:server:[2015-11-16T18:40:11.582Z]: (1447699211583): memmrk:    23086948    32838272
xdk:client:[2015-11-16T18:40:11.874Z]: (1447699211874): memmrk:    72888540    100366976
xdk:server:[2015-11-16T18:40:16.582Z]: (1447699216582): memmrk:    23093824    32838272
xdk:client:[2015-11-16T18:40:16.874Z]: (1447699216874): memmrk:    72824984    100366976
xdk:server:[2015-11-16T18:40:21.583Z]: (1447699221583): memmrk:    23100700    32838272
xdk:client:[2015-11-16T18:40:21.875Z]: (1447699221875): memmrk:    72652164    100366976
xdk:server:[2015-11-16T18:40:26.583Z]: (1447699226583): memmrk:    23107576    32838272
xdk:client:[2015-11-16T18:40:26.876Z]: (1447699226876): memmrk:    72480140    100366976
xdk:server:[2015-11-16T18:40:31.582Z]: (1447699231582): memmrk:    23114452    32838272
xdk:client:[2015-11-16T18:40:31.876Z]: (1447699231876): memmrk:    78517572    100366976
xdk:server:[2015-11-16T18:40:36.582Z]: (1447699236582): memmrk:    23121328    32838272
xdk:client:[2015-11-16T18:40:36.877Z]: (1447699236877): memmrk:    78345564    100366976
xdk:server:[2015-11-16T18:40:41.582Z]: (1447699241582): memmrk:    23128204    32838272
xdk:client:[2015-11-16T18:40:41.877Z]: (1447699241877): memmrk:    78185092    100366976
xdk:server:[2015-11-16T18:40:46.582Z]: (1447699246582): memmrk:    23135080    32838272
xdk:client:[2015-11-16T18:40:46.878Z]: (1447699246878): memmrk:    78013564    101382656
xdk:server:[2015-11-16T18:40:51.582Z]: (1447699251582): memmrk:    23141956    32838272
xdk:client:[2015-11-16T18:40:51.878Z]: (1447699251878): memmrk:    77841604    102398336
xdk:server:[2015-11-16T18:40:56.583Z]: (1447699256583): memmrk:    23148832    32838272
xdk:client:[2015-11-16T18:40:56.883Z]: (1447699256883): memmrk:    77698320    103414016
xdk:server:[2015-11-16T18:41:01.583Z]: (1447699261583): memmrk:    23155708    32838272
xdk:client:[2015-11-16T18:41:01.883Z]: (1447699261883): memmrk:    83735028    103414016
xdk:server:[2015-11-16T18:41:06.583Z]: (1447699266583): memmrk:    23162600    32838272
xdk:client:[2015-11-16T18:41:06.884Z]: (1447699266884): memmrk:    83586292    104429696
xdk:server:[2015-11-16T18:41:11.583Z]: (1447699271583): memmrk:    23169492    32838272
xdk:client:[2015-11-16T18:41:11.885Z]: (1447699271885): memmrk:    83438540    105445376
xdk:server:[2015-11-16T18:41:16.583Z]: (1447699276583): memmrk:    23176368    32838272
xdk:client:[2015-11-16T18:41:16.885Z]: (1447699276885): memmrk:    83291920    106461056
xdk:server:[2015-11-16T18:41:21.583Z]: (1447699281583): memmrk:    23183244    32838272
xdk:client:[2015-11-16T18:41:21.886Z]: (1447699281886): memmrk:    83144132    107476736
xdk:server:[2015-11-16T18:41:26.584Z]: (1447699286584): memmrk:    23190120    32838272
xdk:client:[2015-11-16T18:41:26.886Z]: (1447699286886): memmrk:    82997364    108492416
xdk:server:[2015-11-16T18:41:31.584Z]: (1447699291584): memmrk:    23196996    32838272
xdk:client:[2015-11-16T18:41:31.886Z]: (1447699291886): memmrk:    89034788    108492416
xdk:server:[2015-11-16T18:41:36.585Z]: (1447699296585): memmrk:    23203872    32838272
xdk:client:[2015-11-16T18:41:36.887Z]: (1447699296887): memmrk:    88882360    109508096
xdk:server:[2015-11-16T18:41:41.585Z]: (1447699301585): memmrk:    23210748    32838272
xdk:client:[2015-11-16T18:41:41.888Z]: (1447699301888): memmrk:    88875792    110523776
xdk:server:[2015-11-16T18:41:46.585Z]: (1447699306585): memmrk:    23217624    32838272
xdk:client:[2015-11-16T18:41:46.887Z]: (1447699306887): memmrk:    88731276    111539456
xdk:server:[2015-11-16T18:41:51.585Z]: (1447699311585): memmrk:    23224500    32838272
xdk:client:[2015-11-16T18:41:51.888Z]: (1447699311888): memmrk:    88579944    112555136
xdk:server:[2015-11-16T18:41:56.585Z]: (1447699316585): memmrk:    23231376    32838272
xdk:client:[2015-11-16T18:41:56.889Z]: (1447699316889): memmrk:    88417160    113570816
xdk:server:[2015-11-16T18:42:01.585Z]: (1447699321585): memmrk:    23238252    32838272
xdk:client:[2015-11-16T18:42:01.889Z]: (1447699321889): memmrk:    94454016    113570816
xdk:server:[2015-11-16T18:42:06.585Z]: (1447699326585): memmrk:    23245160    32838272
xdk:client:[2015-11-16T18:42:06.890Z]: (1447699326890): memmrk:    94282080    114586496
xdk:server:[2015-11-16T18:42:11.586Z]: (1447699331586): memmrk:    23252052    32838272
xdk:client:[2015-11-16T18:42:11.889Z]: (1447699331889): memmrk:    94110072    115602176
xdk:server:[2015-11-16T18:42:16.586Z]: (1447699336586): memmrk:    23258928    32838272
xdk:client:[2015-11-16T18:42:16.890Z]: (1447699336890): memmrk:    93937992    116617856
xdk:server:[2015-11-16T18:42:21.586Z]: (1447699341586): memmrk:    23265804    32838272
xdk:client:[2015-11-16T18:42:21.890Z]: (1447699341890): memmrk:    93765464    117633536
xdk:server:[2015-11-16T18:42:26.586Z]: (1447699346586): memmrk:    23272680    32838272
xdk:client:[2015-11-16T18:42:26.890Z]: (1447699346890): memmrk:    99802888    117633536
xdk:server:[2015-11-16T18:42:31.585Z]: (1447699351585): memmrk:    23279556    32838272
xdk:client:[2015-11-16T18:42:31.890Z]: (1447699351890): memmrk:    99631020    118649216
xdk:server:[2015-11-16T18:42:36.585Z]: (1447699356585): memmrk:    23286432    32838272
xdk:client:[2015-11-16T18:42:36.890Z]: (1447699356890): memmrk:    99459176    118649216
xdk:server:[2015-11-16T18:42:41.585Z]: (1447699361585): memmrk:    23293308    32838272
xdk:client:[2015-11-16T18:42:41.891Z]: (1447699361891): memmrk:    99286540    119664896
xdk:server:[2015-11-16T18:42:46.585Z]: (1447699366585): memmrk:    23300184    32838272
xdk:client:[2015-11-16T18:42:46.895Z]: (1447699366895): memmrk:    99130192    120680576
xdk:server:[2015-11-16T18:42:51.586Z]: (1447699371586): memmrk:    23307060    32838272
xdk:client:[2015-11-16T18:42:51.896Z]: (1447699371896): memmrk:    98958460    121696256
xdk:server:[2015-11-16T18:42:56.585Z]: (1447699376585): memmrk:    23313936    32838272
xdk:client:[2015-11-16T18:42:56.896Z]: (1447699376896): memmrk:    104995292    121696256
xdk:server:[2015-11-16T18:43:01.586Z]: (1447699381586): memmrk:    23320812    32838272
xdk:client:[2015-11-16T18:43:01.897Z]: (1447699381897): memmrk:    104823536    122711936
xdk:server:[2015-11-16T18:43:06.586Z]: (1447699386586): memmrk:    23327720    32838272
xdk:client:[2015-11-16T18:43:06.897Z]: (1447699386897): memmrk:    104651172    123727616
xdk:server:[2015-11-16T18:43:11.586Z]: (1447699391586): memmrk:    23334612    32838272
xdk:client:[2015-11-16T18:43:11.897Z]: (1447699391897): memmrk:    104479460    124743296
xdk:server:[2015-11-16T18:43:16.586Z]: (1447699396586): memmrk:    23341488    32838272
xdk:client:[2015-11-16T18:43:16.898Z]: (1447699396898): memmrk:    104307652    125758976
xdk:server:[2015-11-16T18:43:21.586Z]: (1447699401586): memmrk:    23348364    32838272
xdk:client:[2015-11-16T18:43:21.899Z]: (1447699401899): memmrk:    104139704    126774656
xdk:server:[2015-11-16T18:43:26.586Z]: (1447699406586): memmrk:    23355240    32838272
xdk:client:[2015-11-16T18:43:26.899Z]: (1447699406899): memmrk:    110176460    126774656
xdk:server:[2015-11-16T18:43:31.587Z]: (1447699411587): memmrk:    23362140    32838272
xdk:client:[2015-11-16T18:43:31.899Z]: (1447699411899): memmrk:    110024640    127790336
xdk:server:[2015-11-16T18:43:36.587Z]: (1447699416587): memmrk:    23369016    32838272
xdk:client:[2015-11-16T18:43:36.899Z]: (1447699416899): memmrk:    109878864    128806016
xdk:server:[2015-11-16T18:43:41.587Z]: (1447699421587): memmrk:    23375892    32838272
xdk:client:[2015-11-16T18:43:41.900Z]: (1447699421900): memmrk:    109730816    129821696
xdk:server:[2015-11-16T18:43:46.587Z]: (1447699426587): memmrk:    23382768    32838272
xdk:client:[2015-11-16T18:43:46.902Z]: (1447699426902): memmrk:    109583920    130837376
xdk:server:[2015-11-16T18:43:51.587Z]: (1447699431587): memmrk:    23389644    32838272
xdk:client:[2015-11-16T18:43:51.903Z]: (1447699431903): memmrk:    109436580    131853056
xdk:server:[2015-11-16T18:43:56.587Z]: (1447699436587): memmrk:    23396520    32838272
xdk:client:[2015-11-16T18:43:56.903Z]: (1447699436903): memmrk:    115474128    131853056
xdk:server:[2015-11-16T18:44:01.587Z]: (1447699441587): memmrk:    23403396    32838272
xdk:client:[2015-11-16T18:44:01.903Z]: (1447699441903): memmrk:    115326056    132868736
xdk:server:[2015-11-16T18:44:06.588Z]: (1447699446588): memmrk:    23410304    32838272
xdk:client:[2015-11-16T18:44:06.903Z]: (1447699446903): memmrk:    115164568    133884416
xdk:server:[2015-11-16T18:44:11.588Z]: (1447699451588): memmrk:    23417196    32838272
xdk:client:[2015-11-16T18:44:11.904Z]: (1447699451904): memmrk:    114997716    134900096
xdk:server:[2015-11-16T18:44:16.588Z]: (1447699456588): memmrk:    23424072    32838272
xdk:client:[2015-11-16T18:44:16.904Z]: (1447699456904): memmrk:    114826280    135915776
xdk:server:[2015-11-16T18:44:21.588Z]: (1447699461588): memmrk:    23430948    32838272
xdk:client:[2015-11-16T18:44:21.910Z]: (1447699461910): memmrk:    114669900    136931456
xdk:server:[2015-11-16T18:44:26.588Z]: (1447699466588): memmrk:    23437824    32838272
xdk:client:[2015-11-16T18:44:26.911Z]: (1447699466911): memmrk:    120707756    136931456
xdk:server:[2015-11-16T18:44:31.589Z]: (1447699471589): memmrk:    23444700    32838272
xdk:client:[2015-11-16T18:44:31.912Z]: (1447699471912): memmrk:    120535960    136931456
xdk:server:[2015-11-16T18:44:36.588Z]: (1447699476588): memmrk:    23451576    32838272
xdk:client:[2015-11-16T18:44:36.912Z]: (1447699476912): memmrk:    120364096    137947136
xdk:server:[2015-11-16T18:44:41.589Z]: (1447699481589): memmrk:    23458452    32838272
xdk:client:[2015-11-16T18:44:41.912Z]: (1447699481912): memmrk:    120192248    138962816
xdk:server:[2015-11-16T18:44:46.589Z]: (1447699486589): memmrk:    23465328    32838272
xdk:client:[2015-11-16T18:44:46.912Z]: (1447699486912): memmrk:    120019768    139978496
xdk:server:[2015-11-16T18:44:51.589Z]: (1447699491589): memmrk:    23472204    32838272
xdk:client:[2015-11-16T18:44:51.912Z]: (1447699491912): memmrk:    119848016    140994176
xdk:server:[2015-11-16T18:44:56.589Z]: (1447699496589): memmrk:    23479080    32838272
xdk:client:[2015-11-16T18:44:56.913Z]: (1447699496913): memmrk:    125885468    140994176
xdk:server:[2015-11-16T18:45:01.589Z]: (1447699501589): memmrk:    23485956    32838272
xdk:client:[2015-11-16T18:45:01.913Z]: (1447699501913): memmrk:    125713684    142009856
xdk:server:[2015-11-16T18:45:06.590Z]: (1447699506590): memmrk:    23492864    32838272
xdk:client:[2015-11-16T18:45:06.914Z]: (1447699506914): memmrk:    125541312    143025536
xdk:server:[2015-11-16T18:45:11.589Z]: (1447699511590): memmrk:    23499756    32838272
xdk:client:[2015-11-16T18:45:11.914Z]: (1447699511914): memmrk:    125369620    144041216
xdk:server:[2015-11-16T18:45:16.590Z]: (1447699516590): memmrk:    23506632    32838272
xdk:client:[2015-11-16T18:45:16.914Z]: (1447699516914): memmrk:    125197860    145056896
xdk:server:[2015-11-16T18:45:21.590Z]: (1447699521590): memmrk:    23513508    32838272
xdk:client:[2015-11-16T18:45:21.915Z]: (1447699521915): memmrk:    125026172    146072576
xdk:server:[2015-11-16T18:45:26.590Z]: (1447699526590): memmrk:    23520384    32838272
xdk:client:[2015-11-16T18:45:26.915Z]: (1447699526915): memmrk:    131062860    146072576
xdk:server:[2015-11-16T18:45:31.591Z]: (1447699531591): memmrk:    23527260    32838272
xdk:client:[2015-11-16T18:45:31.915Z]: (1447699531915): memmrk:    130891164    147088256
xdk:server:[2015-11-16T18:45:36.591Z]: (1447699536591): memmrk:    23534136    32838272
xdk:client:[2015-11-16T18:45:36.915Z]: (1447699536915): memmrk:    130735716    148103936
xdk:server:[2015-11-16T18:45:41.592Z]: (1447699541592): memmrk:    23541012    32838272
xdk:client:[2015-11-16T18:45:41.915Z]: (1447699541915): memmrk:    130589796    149119616
xdk:server:[2015-11-16T18:45:46.592Z]: (1447699546592): memmrk:    23547888    32838272
xdk:client:[2015-11-16T18:45:46.916Z]: (1447699546916): memmrk:    130440992    150135296
xdk:server:[2015-11-16T18:45:51.592Z]: (1447699551592): memmrk:    23554764    32838272
xdk:client:[2015-11-16T18:45:51.916Z]: (1447699551916): memmrk:    130294592    151150976
xdk:server:[2015-11-16T18:45:56.592Z]: (1447699556592): memmrk:    23561640    32838272
xdk:client:[2015-11-16T18:45:56.916Z]: (1447699556916): memmrk:    136332120    151150976
xdk:server:[2015-11-16T18:46:01.592Z]: (1447699561592): memmrk:    23568516    32838272
xdk:client:[2015-11-16T18:46:01.921Z]: (1447699561921): memmrk:    136198928    152166656
xdk:server:[2015-11-16T18:46:06.592Z]: (1447699566592): memmrk:    23575408    32838272
xdk:client:[2015-11-16T18:46:06.921Z]: (1447699566921): memmrk:    135745512    153182336
xdk:server:[2015-11-16T18:46:11.592Z]: (1447699571592): memmrk:    23582300    32838272
xdk:client:[2015-11-16T18:46:11.921Z]: (1447699571921): memmrk:    135560092    154198016
xdk:server:[2015-11-16T18:46:16.593Z]: (1447699576593): memmrk:    23589176    32838272
xdk:client:[2015-11-16T18:46:16.921Z]: (1447699576921): memmrk:    135387384    154198016
xdk:server:[2015-11-16T18:46:21.592Z]: (1447699581592): memmrk:    23596052    32838272
xdk:client:[2015-11-16T18:46:21.922Z]: (1447699581922): memmrk:    141424764    154198016
xdk:server:[2015-11-16T18:46:26.593Z]: (1447699586593): memmrk:    23602928    32838272
xdk:client:[2015-11-16T18:46:26.922Z]: (1447699586922): memmrk:    141280292    156229376
xdk:server:[2015-11-16T18:46:31.593Z]: (1447699591593): memmrk:    23609804    32838272
xdk:client:[2015-11-16T18:46:31.923Z]: (1447699591923): memmrk:    141112536    157245056
xdk:server:[2015-11-16T18:46:36.593Z]: (1447699596593): memmrk:    23616680    32838272
xdk:client:[2015-11-16T18:46:36.923Z]: (1447699596923): memmrk:    140940556    158260736
xdk:server:[2015-11-16T18:46:41.593Z]: (1447699601593): memmrk:    23623556    32838272
xdk:client:[2015-11-16T18:46:41.923Z]: (1447699601923): memmrk:    140823216    159276416
xdk:server:[2015-11-16T18:46:46.593Z]: (1447699606593): memmrk:    23630432    32838272
xdk:client:[2015-11-16T18:46:46.925Z]: (1447699606925): memmrk:    140660540    160292096
xdk:server:[2015-11-16T18:46:51.593Z]: (1447699611593): memmrk:    23637308    32838272
xdk:client:[2015-11-16T18:46:51.925Z]: (1447699611925): memmrk:    146698064    160292096
xdk:server:[2015-11-16T18:46:56.594Z]: (1447699616594): memmrk:    23644184    32838272
xdk:client:[2015-11-16T18:46:56.925Z]: (1447699616925): memmrk:    146526316    161307776
xdk:server:[2015-11-16T18:47:01.594Z]: (1447699621594): memmrk:    23651060    32838272
xdk:client:[2015-11-16T18:47:01.926Z]: (1447699621926): memmrk:    146354508    162323456
xdk:server:[2015-11-16T18:47:06.594Z]: (1447699626594): memmrk:    23657968    32838272
xdk:client:[2015-11-16T18:47:06.927Z]: (1447699626927): memmrk:    146181912    163339136
xdk:server:[2015-11-16T18:47:11.594Z]: (1447699631594): memmrk:    23664860    32838272
xdk:client:[2015-11-16T18:47:11.928Z]: (1447699631928): memmrk:    146009932    164354816
xdk:server:[2015-11-16T18:47:16.594Z]: (1447699636594): memmrk:    23676908    32838272
xdk:client:[2015-11-16T18:47:16.928Z]: (1447699636928): memmrk:    145838088    165370496
xdk:server:[2015-11-16T18:47:21.595Z]: (1447699641595): memmrk:    23683784    32838272
xdk:client:[2015-11-16T18:47:21.929Z]: (1447699641929): memmrk:    151875724    166386176
xdk:server:[2015-11-16T18:47:26.594Z]: (1447699646594): memmrk:    23690660    32838272
xdk:client:[2015-11-16T18:47:26.933Z]: (1447699646933): memmrk:    151718596    167401856
xdk:server:[2015-11-16T18:47:31.594Z]: (1447699651594): memmrk:    23697536    32838272
xdk:client:[2015-11-16T18:47:31.934Z]: (1447699651934): memmrk:    151546920    168417536
xdk:server:[2015-11-16T18:47:36.594Z]: (1447699656594): memmrk:    23704412    32838272
xdk:client:[2015-11-16T18:47:36.935Z]: (1447699656935): memmrk:    151375088    169433216
xdk:server:[2015-11-16T18:47:41.594Z]: (1447699661594): memmrk:    23711288    32838272
xdk:client:[2015-11-16T18:47:41.936Z]: (1447699661936): memmrk:    151203228    170448896
xdk:server:[2015-11-16T18:47:46.594Z]: (1447699666594): memmrk:    23718164    32838272
xdk:client:[2015-11-16T18:47:46.937Z]: (1447699666937): memmrk:    151030624    171464576
xdk:server:[2015-11-16T18:47:51.594Z]: (1447699671594): memmrk:    23725040    32838272
xdk:client:[2015-11-16T18:47:51.937Z]: (1447699671937): memmrk:    157068124    171464576
xdk:server:[2015-11-16T18:47:56.595Z]: (1447699676595): memmrk:    23731916    32838272
xdk:client:[2015-11-16T18:47:56.938Z]: (1447699676938): memmrk:    156896420    172480256
xdk:server:[2015-11-16T18:48:01.596Z]: (1447699681596): memmrk:    23738792    32838272
xdk:client:[2015-11-16T18:48:01.939Z]: (1447699681939): memmrk:    156725484    173495936
xdk:server:[2015-11-16T18:48:06.596Z]: (1447699686596): memmrk:    23745700    32838272
xdk:client:[2015-11-16T18:48:06.939Z]: (1447699686939): memmrk:    156573608    173495936
xdk:server:[2015-11-16T18:48:11.597Z]: (1447699691597): memmrk:    23752592    32838272
xdk:client:[2015-11-16T18:48:11.940Z]: (1447699691940): memmrk:    156429068    174511616
xdk:server:[2015-11-16T18:48:16.597Z]: (1447699696597): memmrk:    23759468    32838272
xdk:client:[2015-11-16T18:48:16.939Z]: (1447699696939): memmrk:    156280248    176542976
xdk:server:[2015-11-16T18:48:21.597Z]: (1447699701597): memmrk:    23766344    32838272
xdk:client:[2015-11-16T18:48:21.941Z]: (1447699701941): memmrk:    162317680    176542976
xdk:server:[2015-11-16T18:48:26.597Z]: (1447699706597): memmrk:    23773220    32838272
xdk:client:[2015-11-16T18:48:26.942Z]: (1447699706942): memmrk:    162169824    177558656
xdk:server:[2015-11-16T18:48:31.598Z]: (1447699711598): memmrk:    23780096    32838272
xdk:client:[2015-11-16T18:48:31.942Z]: (1447699711942): memmrk:    162021720    178574336
xdk:server:[2015-11-16T18:48:36.599Z]: (1447699716599): memmrk:    23786972    32838272
xdk:client:[2015-11-16T18:48:36.942Z]: (1447699716942): memmrk:    161875644    179590016
xdk:server:[2015-11-16T18:48:41.598Z]: (1447699721598): memmrk:    23793864    32838272
xdk:client:[2015-11-16T18:48:41.942Z]: (1447699721942): memmrk:    161715676    180605696
xdk:server:[2015-11-16T18:48:46.599Z]: (1447699726599): memmrk:    23800740    32838272
xdk:client:[2015-11-16T18:48:46.942Z]: (1447699726942): memmrk:    161543124    181621376
xdk:server:[2015-11-16T18:48:51.599Z]: (1447699731599): memmrk:    23807616    32838272
xdk:client:[2015-11-16T18:48:51.942Z]: (1447699731942): memmrk:    167580616    181621376
xdk:server:[2015-11-16T18:48:56.599Z]: (1447699736599): memmrk:    23814492    32838272
xdk:client:[2015-11-16T18:48:56.947Z]: (1447699736947): memmrk:    167424276    182637056
xdk:server:[2015-11-16T18:49:01.599Z]: (1447699741599): memmrk:    23821368    32838272
xdk:client:[2015-11-16T18:49:01.948Z]: (1447699741948): memmrk:    167252592    183652736
xdk:server:[2015-11-16T18:49:06.599Z]: (1447699746599): memmrk:    23828276    32838272
xdk:client:[2015-11-16T18:49:06.948Z]: (1447699746948): memmrk:    167080876    184668416
xdk:server:[2015-11-16T18:49:11.599Z]: (1447699751599): memmrk:    23835168    32838272
xdk:client:[2015-11-16T18:49:11.948Z]: (1447699751948): memmrk:    166908228    186699776
xdk:server:[2015-11-16T18:49:16.599Z]: (1447699756599): memmrk:    23842044    32838272
xdk:client:[2015-11-16T18:49:16.949Z]: (1447699756949): memmrk:    166736508    187715456
xdk:server:[2015-11-16T18:49:21.600Z]: (1447699761600): memmrk:    23848920    32838272
xdk:client:[2015-11-16T18:49:21.949Z]: (1447699761949): memmrk:    172773976    187715456
xdk:server:[2015-11-16T18:49:26.600Z]: (1447699766600): memmrk:    23855796    32838272
xdk:client:[2015-11-16T18:49:26.950Z]: (1447699766950): memmrk:    172602124    188731136
xdk:server:[2015-11-16T18:49:31.599Z]: (1447699771599): memmrk:    23862672    32838272
xdk:client:[2015-11-16T18:49:31.950Z]: (1447699771950): memmrk:    172429752    189746816
xdk:server:[2015-11-16T18:49:36.599Z]: (1447699776599): memmrk:    23869548    32838272
xdk:client:[2015-11-16T18:49:36.950Z]: (1447699776950): memmrk:    172258024    190762496
xdk:server:[2015-11-16T18:49:41.599Z]: (1447699781599): memmrk:    23876424    32838272
xdk:client:[2015-11-16T18:49:41.951Z]: (1447699781951): memmrk:    172086340    191778176
xdk:server:[2015-11-16T18:49:46.599Z]: (1447699786599): memmrk:    23883300    32838272
xdk:client:[2015-11-16T18:49:46.951Z]: (1447699786951): memmrk:    178123780    191778176
xdk:server:[2015-11-16T18:49:51.600Z]: (1447699791600): memmrk:    23890176    32838272
xdk:client:[2015-11-16T18:49:51.952Z]: (1447699791952): memmrk:    177951384    192793856
xdk:server:[2015-11-16T18:49:56.600Z]: (1447699796600): memmrk:    23897052    32838272
xdk:client:[2015-11-16T18:49:56.952Z]: (1447699796952): memmrk:    177779636    193809536
xdk:server:[2015-11-16T18:50:01.600Z]: (1447699801600): memmrk:    22942396    32838272
xdk:client:[2015-11-16T18:50:01.952Z]: (1447699801952): memmrk:    177607868    193809536
xdk:server:[2015-11-16T18:50:06.600Z]: (1447699806600): memmrk:    22949304    32838272
xdk:client:[2015-11-16T18:50:06.953Z]: (1447699806953): memmrk:    177436104    195840896
xdk:server:[2015-11-16T18:50:11.600Z]: (1447699811600): memmrk:    22956196    32838272
xdk:client:[2015-11-16T18:50:11.953Z]: (1447699811953): memmrk:    177280856    196856576
xdk:server:[2015-11-16T18:50:16.601Z]: (1447699816601): memmrk:    22963072    32838272
xdk:client:[2015-11-16T18:50:16.954Z]: (1447699816954): memmrk:    183318252    196856576
xdk:server:[2015-11-16T18:50:21.601Z]: (1447699821601): memmrk:    22969948    32838272
xdk:client:[2015-11-16T18:50:21.954Z]: (1447699821954): memmrk:    183171192    197872256
xdk:server:[2015-11-16T18:50:26.601Z]: (1447699826601): memmrk:    22976824    32838272
xdk:client:[2015-11-16T18:50:26.955Z]: (1447699826955): memmrk:    183022376    198887936
xdk:server:[2015-11-16T18:50:31.601Z]: (1447699831601): memmrk:    22983700    32838272
xdk:client:[2015-11-16T18:50:31.960Z]: (1447699831960): memmrk:    182891260    199903616
xdk:server:[2015-11-16T18:50:36.601Z]: (1447699836601): memmrk:    22990576    32838272
xdk:client:[2015-11-16T18:50:36.961Z]: (1447699836961): memmrk:    182743816    200919296
xdk:server:[2015-11-16T18:50:41.602Z]: (1447699841602): memmrk:    22997452    32838272
xdk:client:[2015-11-16T18:50:41.961Z]: (1447699841961): memmrk:    182597352    201934976
xdk:server:[2015-11-16T18:50:46.602Z]: (1447699846602): memmrk:    23004328    32838272
xdk:client:[2015-11-16T18:50:46.961Z]: (1447699846961): memmrk:    188634804    201934976
xdk:server:[2015-11-16T18:50:51.602Z]: (1447699851602): memmrk:    23011204    32838272
xdk:client:[2015-11-16T18:50:51.963Z]: (1447699851963): memmrk:    188476572    202950656
xdk:server:[2015-11-16T18:50:56.602Z]: (1447699856602): memmrk:    23018080    32838272
xdk:client:[2015-11-16T18:50:56.963Z]: (1447699856963): memmrk:    188308008    203966336
xdk:server:[2015-11-16T18:51:01.603Z]: (1447699861603): memmrk:    23024956    32838272
xdk:client:[2015-11-16T18:51:01.964Z]: (1447699861964): memmrk:    188143448    205997696
xdk:server:[2015-11-16T18:51:06.602Z]: (1447699866603): memmrk:    23036272    32838272
xdk:client:[2015-11-16T18:51:06.965Z]: (1447699866965): memmrk:    187971736    207013376
xdk:server:[2015-11-16T18:51:11.603Z]: (1447699871603): memmrk:    23043164    32838272
xdk:client:[2015-11-16T18:51:11.965Z]: (1447699871965): memmrk:    187799060    208029056
xdk:server:[2015-11-16T18:51:16.603Z]: (1447699876603): memmrk:    23050732    32838272
xdk:client:[2015-11-16T18:51:16.966Z]: (1447699876966): memmrk:    193836512    208029056
xdk:server:[2015-11-16T18:51:21.603Z]: (1447699881603): memmrk:    23057608    32838272
xdk:client:[2015-11-16T18:51:21.966Z]: (1447699881966): memmrk:    193664856    209044736
xdk:server:[2015-11-16T18:51:26.604Z]: (1447699886604): memmrk:    23064484    32838272
xdk:client:[2015-11-16T18:51:26.966Z]: (1447699886966): memmrk:    193493116    210060416
xdk:server:[2015-11-16T18:51:31.604Z]: (1447699891604): memmrk:    23071360    32838272
xdk:client:[2015-11-16T18:51:31.967Z]: (1447699891967): memmrk:    193320420    211076096
xdk:server:[2015-11-16T18:51:36.604Z]: (1447699896604): memmrk:    23079648    32838272
xdk:client:[2015-11-16T18:51:36.968Z]: (1447699896968): memmrk:    193148304    212091776
client:navbar:[2015-11-16T18:51:38.941Z]: (1447699898941): pollForUpdates called
client:navbar:[2015-11-16T18:51:40.679Z]: (1447699900679): polling up-to-date
xdk:server:[2015-11-16T18:51:41.605Z]: (1447699901605): memmrk:    23505832    32838272
xdk:client:[2015-11-16T18:51:41.968Z]: (1447699901968): memmrk:    193180716    213107456
xdk:server:[2015-11-16T18:51:46.605Z]: (1447699906605): memmrk:    23512708    32838272
xdk:client:[2015-11-16T18:51:46.969Z]: (1447699906969): memmrk:    199218940    213107456
xdk:server:[2015-11-16T18:51:51.605Z]: (1447699911606): memmrk:    23519584    32838272
xdk:client:[2015-11-16T18:51:51.974Z]: (1447699911974): memmrk:    199099636    214123136
xdk:server:[2015-11-16T18:51:56.606Z]: (1447699916606): memmrk:    23536888    32838272
xdk:client:[2015-11-16T18:51:56.974Z]: (1447699916974): memmrk:    198927980    215138816
xdk:server:[2015-11-16T18:52:01.606Z]: (1447699921606): memmrk:    23543676    32838272
xdk:client:[2015-11-16T18:52:01.974Z]: (1447699921974): memmrk:    198756104    216154496
xdk:server:[2015-11-16T18:52:06.606Z]: (1447699926606): memmrk:    23550496    32838272
xdk:client:[2015-11-16T18:52:06.975Z]: (1447699926975): memmrk:    198584112    217170176
xdk:server:[2015-11-16T18:52:11.606Z]: (1447699931606): memmrk:    23557300    32838272
xdk:client:[2015-11-16T18:52:11.975Z]: (1447699931975): memmrk:    198411532    218185856
xdk:server:[2015-11-16T18:52:16.606Z]: (1447699936607): memmrk:    23564088    32838272
xdk:client:[2015-11-16T18:52:16.975Z]: (1447699936975): memmrk:    204448944    218185856
xdk:server:[2015-11-16T18:52:21.606Z]: (1447699941606): memmrk:    23570876    32838272
xdk:client:[2015-11-16T18:52:21.975Z]: (1447699941975): memmrk:    204276956    219201536
xdk:server:[2015-11-16T18:52:26.607Z]: (1447699946607): memmrk:    23577664    32838272
xdk:client:[2015-11-16T18:52:26.975Z]: (1447699946975): memmrk:    204104924    220217216
Node Webkit Error log:
[9196:1116/192130:INFO:CONSOLE(17)] ""xdk:client:[2015-11-16T18:21:30.554Z]: (1447698090554): Failed to load theme: xdk" {"code":"MODULE_NOT_FOUND"}", source: C:\Users\Tedd\AppData\Local\Intel\XDK\xdk\core-modules\private\logger.js (17)
[9196:1116/192130:INFO:CONSOLE(17)] ""xdk:client:[2015-11-16T18:21:30.610Z]: (1447698090610): Error SyntaxError: Unexpected token \r loading components\\client\\emulator\\locale\\root\\text-content.json"", source: C:\Users\Tedd\AppData\Local\Intel\XDK\xdk\core-modules\private\logger.js (17)
[9196:1116/192130:INFO:CONSOLE(989)] "" Unhandled rejection reasons (should be empty):" ["(no stack) [object Object]"]", source: file:///C:/Users/Tedd/AppData/Local/Intel/XDK/xdk/node_modules/q/q.js (989)
[9196:1116/192136:INFO:CONSOLE(90)] ""PreferencesManager.convertPreferences() has been deprecated. Please upgrade to the current Preferences system (https://github.com/adobe/brackets/wiki/Preferences-System#conversion-from-the-pre-36-preferences-system).\n    at Object.convertPreferences (/preferences/PreferencesManager.js:325:28)\n    at Object.eval (/utils/Resizer.js:548:24)"", source: /utils/DeprecationWarning.js (90)
[9196:1116/192136:INFO:CONSOLE(217)] ""NW proxy string: DIRECT"", source: /brackets.js (217)
[9196:1116/192136:INFO:CONSOLE(989)] "" Unhandled rejection reasons (should be empty):" ["(no stack) ERROR: no user is logged in\nError\n    at new ComponentError (C:\\Users\\Tedd\\AppData\\Local\\Intel\\XDK\\xdk\\core-modules\\public\\component-error.js:17:1122)\n    at makeError (file:///C:/Users/Tedd/AppData/Local/Intel/XDK/xdk/components/client/backend-service-utils/backend-service-utils.js:17:187)\n    at file:///C:/Users/Tedd/AppData/Local/Intel/XDK/xdk/components/client/backend-service-utils/backend-service-utils.js:17:1258\n    at _fulfilled (C:\\Users\\Tedd\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:797:54)\n    at self.promiseDispatch.done (C:\\Users\\Tedd\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:826:30)\n    at Promise.promise.promiseDispatch (C:\\Users\\Tedd\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:759:13)\n    at C:\\Users\\Tedd\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:573:44\n    at flush (C:\\Users\\Tedd\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:108:17)\n    at process._tickCallback (node.js:393:11)"]", source: C:\Users\Tedd\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js (989)
[9196:1116/192137:INFO:CONSOLE(90)] ""Deprecated: Do not use $().on/off() on Brackets modules and model objects. Call on()/off() directly on the object without a $() wrapper.\n    at new jQuery.fn.init (/brackets.js:441:36)\n    at n (file:///C:/Users/Tedd/AppData/Local/Intel/XDK/xdk/brackets/b/thirdparty/thirdparty.min.js:556:405)\n    at file:///C:/Users/Tedd/AppData/Local/XDK/editor/extensions/user/camden.jshint/main.js:174:9\n    at _callHandler (/utils/AppInit.js:94:13)\n    at Object._dispatchReady (/utils/AppInit.js:114:13)\n    at Object.ready (file:///C:/Users/Tedd/AppData/Local/Intel/XDK/xdk/brackets/b/extensions/default/XDK/main.js:505:21)\n    at j (file:///C:/Users/Tedd/AppData/Local/Intel/XDK/xdk/brackets/b/thirdparty/thirdparty.min.js:556:26911)\n    at Object.k.fireWith [as resolveWith] (file:///C:/Users/Tedd/AppData/Local/Intel/XDK/xdk/brackets/b/thirdparty/thirdparty.min.js:556:27724)\n    at Object.e.(anonymous function) (file:///C:/Users/Tedd/AppData/Local/Intel/XDK/xdk/brackets/b/thirdparty/thirdparty.min.js:556:28704)"", source: /utils/DeprecationWarning.js (90)
[9196:1116/192137:INFO:CONSOLE(90)] ""Deprecated: Do not use $().on/off() on Brackets modules and model objects. Call on()/off() directly on the object without a $() wrapper.\n    at new jQuery.fn.init (/brackets.js:441:36)\n    at n (file:///C:/Users/Tedd/AppData/Local/Intel/XDK/xdk/brackets/b/thirdparty/thirdparty.min.js:556:405)\n    at file:///C:/Users/Tedd/AppData/Local/XDK/editor/extensions/user/camden.jshint/main.js:183:9\n    at _callHandler (/utils/AppInit.js:94:13)\n    at Object._dispatchReady (/utils/AppInit.js:114:13)\n    at Object.ready (file:///C:/Users/Tedd/AppData/Local/Intel/XDK/xdk/brackets/b/extensions/default/XDK/main.js:505:21)\n    at j (file:///C:/Users/Tedd/AppData/Local/Intel/XDK/xdk/brackets/b/thirdparty/thirdparty.min.js:556:26911)\n    at Object.k.fireWith [as resolveWith] (file:///C:/Users/Tedd/AppData/Local/Intel/XDK/xdk/brackets/b/thirdparty/thirdparty.min.js:556:27724)\n    at Object.e.(anonymous function) (file:///C:/Users/Tedd/AppData/Local/Intel/XDK/xdk/brackets/b/thirdparty/thirdparty.min.js:556:28704)"", source: /utils/DeprecationWarning.js (90)
[9196:1116/192137:INFO:CONSOLE(90)] ""Deprecated: Do not use $().on/off() on Brackets modules and model objects. Call on()/off() directly on the object without a $() wrapper.\n    at new jQuery.fn.init (/brackets.js:441:36)\n    at n (file:///C:/Users/Tedd/AppData/Local/Intel/XDK/xdk/brackets/b/thirdparty/thirdparty.min.js:556:405)\n    at file:///C:/Users/Tedd/AppData/Local/XDK/editor/extensions/user/intelxdk.xlint/main.js:366:9\n    at _callHandler (/utils/AppInit.js:94:13)\n    at Object._dispatchReady (/utils/AppInit.js:114:13)\n    at Object.ready (file:///C:/Users/Tedd/AppData/Local/Intel/XDK/xdk/brackets/b/extensions/default/XDK/main.js:505:21)\n    at j (file:///C:/Users/Tedd/AppData/Local/Intel/XDK/xdk/brackets/b/thirdparty/thirdparty.min.js:556:26911)\n    at Object.k.fireWith [as resolveWith] (file:///C:/Users/Tedd/AppData/Local/Intel/XDK/xdk/brackets/b/thirdparty/thirdparty.min.js:556:27724)\n    at Object.e.(anonymous function) (file:///C:/Users/Tedd/AppData/Local/Intel/XDK/xdk/brackets/b/thirdparty/thirdparty.min.js:556:28704)"", source: /utils/DeprecationWarning.js (90)
[9196:1116/192137:INFO:CONSOLE(90)] ""Deprecated: Do not use $().on/off() on Brackets modules and model objects. Call on()/off() directly on the object without a $() wrapper.\n    at new jQuery.fn.init (/brackets.js:441:36)\n    at n (file:///C:/Users/Tedd/AppData/Local/Intel/XDK/xdk/brackets/b/thirdparty/thirdparty.min.js:556:405)\n    at file:///C:/Users/Tedd/AppData/Local/XDK/editor/extensions/user/intelxdk.xlint/main.js:375:9\n    at _callHandler (/utils/AppInit.js:94:13)\n    at Object._dispatchReady (/utils/AppInit.js:114:13)\n    at Object.ready (file:///C:/Users/Tedd/AppData/Local/Intel/XDK/xdk/brackets/b/extensions/default/XDK/main.js:505:21)\n    at j (file:///C:/Users/Tedd/AppData/Local/Intel/XDK/xdk/brackets/b/thirdparty/thirdparty.min.js:556:26911)\n    at Object.k.fireWith [as resolveWith] (file:///C:/Users/Tedd/AppData/Local/Intel/XDK/xdk/brackets/b/thirdparty/thirdparty.min.js:556:27724)\n    at Object.e.(anonymous function) (file:///C:/Users/Tedd/AppData/Local/Intel/XDK/xdk/brackets/b/thirdparty/thirdparty.min.js:556:28704)"", source: /utils/DeprecationWarning.js (90)
[9196:1116/192157:INFO:CONSOLE(989)] "" Unhandled rejection reasons (should be empty):" ["(no stack) ERROR (1): A project with the same name already exists\nError\n    at ComponentError (C:\\Users\\Tedd\\AppData\\Local\\Intel\\XDK\\xdk\\core-modules\\public\\component-error.js:17:1122)\n    at new ServiceError (C:\\Users\\Tedd\\AppData\\Local\\Intel\\XDK\\xdk\\core-modules\\public\\service-error.js:17:317)\n    at C:\\Users\\Tedd\\AppData\\Local\\Intel\\XDK\\xdk\\components\\server\\new-project-creator\\new-project-creator.js:17:5267\n    at _fulfilled (C:\\Users\\Tedd\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:797:54)\n    at self.promiseDispatch.done (C:\\Users\\Tedd\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:826:30)\n    at Promise.promise.promiseDispatch (C:\\Users\\Tedd\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:759:13)\n    at C:\\Users\\Tedd\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:573:44\n    at flush (C:\\Users\\Tedd\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:108:17)\n    at process._tickCallback (node.js:393:11)"]", source: C:\Users\Tedd\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js (989)
[9196:1116/192344:ERROR:audio_low_latency_output_win.cc(181)] Bailing out due to non-perfect timing.  Buffer size of 480 is not an even divisor of 1056
[9196:1116/193251:INFO:raw_input_data_fetcher_win.cc(101)] RegisterRawInputDevices() failed for RIDEV_REMOVE: Param�tre incorrect. (0x57)
[9196:1116/193643:INFO:raw_input_data_fetcher_win.cc(101)] RegisterRawInputDevices() failed for RIDEV_REMOVE: Param�tre incorrect. (0x57)
[9196:1116/193845:INFO:raw_input_data_fetcher_win.cc(101)] RegisterRawInputDevices() failed for RIDEV_REMOVE: Param�tre incorrect. (0x57)
[9196:1116/193950:INFO:CONSOLE(17)] ""client:device-discovery:[2015-11-16T18:39:50.898Z]: (1447699190898): ADB device detector failed... " {"code":3221225794,"output":""}", source: C:\Users\Tedd\AppData\Local\Intel\XDK\xdk\core-modules\private\logger.js (17)
[9196:1116/195228:INFO:dispatcher_host.cc(151)] [NW.JS]RenderProcessCrashed
[9196:1116/195228:INFO:raw_input_data_fetcher_win.cc(101)] RegisterRawInputDevices() failed for RIDEV_REMOVE: Param�tre incorrect. (0x57)
[9196:1116/195228:WARNING:raw_channel_win.cc(473)] WriteFile: Le canal de communication est sur le point d��tre ferm�. (0xE8)
[9196:1116/195228:WARNING:channel.cc(331)] RawChannel write error
[9196:1116/195228:FATAL:render_process_host_impl.cc(479)] Check failed: !g_exited_main_message_loop.
XDK exit code & signal: 2147483651, null
Crash minidump not found in XDK data folder. Falling back to TEMP...
Crash Minidump File: C:\Users\Tedd\AppData\Local\Temp\f891de77-1a33-47e4-823f-58cc192c0d1a.dmp Mon Nov 16 2015 19:52:28 GMT+0100 (Paris, Madrid)
Size in bytes: 558166
NW Crash Detected.
Elroy_A_Intel
Are you able to upload a blank project under the Build tab? Which build target are  you experiencing this issue with?
Teddy_B_
I can build a blank project.
I'm trying to build : Crosswalk for Android.
Elite_P_
Salut ! J'écris en français car tu as dit que tu l'étais plus haut ^^
Alors j'ai le même problème que toi depuis 2/3 jours et j'avais la rage x") J'ai cherché cherché cherché et j'ai réussi.
Alors pour la première étape le build, J'avais la même erreur que toi puis j'ai regarder sur des vidéos, et dessus c'était préciser de bien virer les fichiers inutiles.
Mon dossier faisait facilement 300 mo alors j'ai virer tout ce qui me servait a rien dans le dossier www créer par RPG Maker puis mon jeu faisais plus que 70 mo ^^'
Ensuite j'ai réessayais puis ... MIRACLE ! Puis...Et bah non. Sur le bouton ou il dit build de nouveau il me met une nouvelle erreur
 "Intel XDK The build failed. An error occurred while building the application. Verify your build assets are correct and try again."
J'avais la rage puis j'ai chercher un peu, et la solution était toute simple. J'ai simplement redémarrer mon Intel XDK et ça a marcher !!!
J'espère t'avoir aidé !
Je réecris en Anglais en dessous pour les Anglais qui aurait le même problème que toi.
(Au passage quelque conseil, utilise deux doigt en même temps pour ouvrir le menu sur téléphone, et pareil pour retourner en arrière)
Hey how you doing ?
I got exactly the same problem as you and i just resolved it !
You said that you use RPG Maker MV.
When you export your project, ALL the files of RPG Maker are exported too, so your folder 'www' will be easily "300mb".
I deleted all the files that was useless and my folder was back to 70mb and then when i reclick 'build' it worked !
But after i got another probleme : "Intel XDK The build failed. An error occurred while building the application. Verify your build assets are correct and try again."
The only thing i did was restart my Intel XDK and it worked !
Hope i helped you.
(Sorry for my English)
