Software Archive
Read-only legacy content
17060 Discussions
Problem with UPLOAD CERTIFICATE in Cordova iOS Build
Hamilton_Tenório_da_
Valued Contributor I
I´m trying today to build an APP in iOS Cordova Build, the same that I have builded several times before (Apple is very dificult to aprove an APP...).
I don´t know why, but the XDK asked me about the CSR file (it was provided before normally).
When I upload the ios_distribution.cer it show me this message:
The certificate was not created with the Certificate Signing Request.
What happen? I need to recreate the certificate? Is there any modification on the process?
Brandon_K_Intel
I would attempt to recreate the certificate using the CSR that is provided in the build tab.
I am not sure what the issue is given the details you have provided. There hasn't been any modification to this process recently. If you still have issues then try posting some screenshots to allow us to help you better.
I don´t understand. I tryied again and now it does not show the message about error CSR file. Then I clicked to build.
It runs, but failed to buid. Now, the same message of the other post that I did just now: https://software.intel.com/en-us/comment/1823922#comment-1823922 .
The log of this case is attached.
Amrita_C_Intel
Did you include your provisioning profile? In both the places( Inside your project's WWW directory and in ios build settings)? Which kind of build procedure are you using Legacy one or the newer one? If you are using newer one follow the steps as stated  to the below  mentioned document link.
https://software.intel.com/en-us/xdk/docs/building-cordova-ios-apps-intel-xdk
Yes, I generated this provisioning file today. Yesterday I publish this same APP in Google Play (crosswalk = https://play.google.com/store/apps/details?id=com.hamiltonhtsnet.com.br.faleparaowhatsapp) and now I am handling to publish the same APP in Apple Store.
The file is in XDK\Fale para o WhatsApp\www\assets\Apple folder.
I set this same path in both field of build settings.
I am using the Cordova iOS Build (Hybrid Mobile APP).
In log is there any valuable information?
Brandon_K_Intel
The log says the application was failed to be signed correctly with the certificate and/or provisioning profiles that were given to the XDK. Please refer to the link that Amrita has provided to generate your certificate and provisioning profile. If you have any further issues, please don't hesitate to ask!
