Software Archive
Read-only legacy content
17060 Discussions
Problem with Win Phone Deployment
phil_J_
I've built a very simple start App - and having trouble deploying to the phone.
The Build works fine ...see here ...have the Windows Phone publisher in the settings
My Phone is Unlocked (using the Register tool) - and shows up in my developer account as being registered ....
But when I try to deploy I get the following?
See in Project build - the GUID it refers to I presume is my publisher ID which is there
ANy ideas?
Phil
John_H_Intel2
What phone are you trying to install your app on?
Is it a regular phone or a developer released device?
phil_J_
Hi john - Its a Nokia Lumia 930 ....
John_H_Intel2
Can you try creating a simple demo app from one of the ones we provide and try to install that without modifying it?
phil_J_
will.do in morning ...im on UK time. presume you are USA.
PaulF_IntelCorp
You have two publishers IDs: one for Windows and one for Windows Phone. The one that starts with a CN= is your Windows ID (but you need to remove the CN= before you use it for a build). Try both, one should work.
phil_J_
I built the very simple App framework APP - tried with both Ids, Windows & Windows Mobile...still same problem.
PaulF_IntelCorp
I can't access that link, you need to attach the build log.
According to the build summary you are still including the "CN=" prefix. Please remove that prefix, you should only be putting the GUID in that field in the XDK.
phil_J_
The CN is definitely not in the Project entry - must be getting added during the Build - see here....these from the demo PhotoApp
Also attached the Build log as a text file
477139
PaulF_IntelCorp
The build engineer is working on the issue. Not sure how long it will take to resolve it.
phil_J_
ok thanks for feedback.- presume it would work if from App Store....
