Software Archive
Read-only legacy content
17060 Discussions
Keyboard Problem - Crosswalk
ali_v_
Keyboard doesn't show up(constantly coming and going) when input is in focus
Screenshot 1: http://i.imgur.com/aKE125H.png
Screenshot 2: http://i.imgur.com/In5MDHz.png
How can I fix? Thanks.
intel xdk 2366
crosswalk 14 (11)
min. android api 14
android 4.0.3 - htc evo3d
John_H_Intel2
Does your device have an update available?
HTC's are notorious for making custom modifications to their OS's that lead to issues like this.
Do you have another device to test it on?
Are you building your apk or testing with app preview?
ali_v_
The last update I could get for evo3d is just 4.0.3
I tried my software that l compiled on HTC and all of the other brands, and it worked on all of them. Worked without any problems but none of them were 4.0.3. l couldn't tried on a 4.0.3. phone.
l think the problem is 4.0.x version..
John_H_Intel2
It would not be the first time that we have seen a very particular issue only on a specific OS...
PaulF_IntelCorp
What do you mean by "crosswalk 14 (11)"? Are you building with Crosswalk 14 or Crosswalk 11? Use 14.
ali_v_
I didn't try Crosswalk 7, but I tried each of Crosswalk 11, 12, and 14 seperately. I had the same problem in each trial. If I build the Android version without any Crosswalk, I don't experience this problem.
PaulF_IntelCorp
We're going to have a CW15 build option in the near future that uses a different technique to build the CW app, which is more compatible with the standard Android build process. Assuming that the CW15 build will make a difference is a long shot, but it will be worth trying when that update release happens. In the meantime, I suggest you file a Jira with the Crosswalk project, because I think that's where the issue lies, somewhere in the Crosswalk runtime and how it works with the HTC hardware. You can report Crosswalk issues here: https://crosswalk-project.org/jira/secure/Dashboard.jspa
