Software Archive
Read-only legacy content
17060 Discussions
Problems building and iOS App
Alex_B_8
I'm trying to build and iOS App but the build fail and in the log file show:
Verify your build assets and try again (full log build attached)
** BUILD FAILED **
The following build commands failed:
	Check dependencies
(1 failure)
Command finished with error code 65: .../TipsFinancieros/platforms/ios/cordova/build --release,--device
Error: .../TipsFinancieros/platforms/ios/cordova/build: Command failed with exit code 65
    at ChildProcess.whenDone (/Developer/cordova/3.5.0-0.2.7/node_modules/cordova/node_modules/cordova-lib/src/cordova/superspawn.js:135:23)
    at ChildProcess.EventEmitter.emit (events.js:98:17)
    at maybeClose (child_process.js:753:16)
    at Process.ChildProcess._handle.onexit (child_process.js:820:5)
I have all the iOS certificates files charged
Alex_B_8
Solved!!!, it was a problem with the Production Provisioning File. Now i can biuld the app.
John_H_Intel2
I like seeing posts where users figure it out themselves (and help other users!)  :)
