Software Archive
Read-only legacy content
Problems installing Intel Parallel Studio XE 2017 Update 1 Cluster Edition for Linux
Ross_G_
I'm trying to install Parallel Studio XE 2017 Update 1 on an Ubuntu 16.04 VM, but am encountering some issues.
The installer tries to execute
wget --secure-protocol=SSLv3 --spider --timeout=20 --tries=1 https://registrationcenter.intel.com
which crashes with the following message:
Spider mode enabled. Check if remote file exists.
--2016-11-20 16:32:18--  https://registrationcenter.intel/
OpenSSL: unimplemented 'secure-protocol' option value 2
Please report this issue to [email protected]
Aborted (core dumped)
This is happening because Ubuntu has disabled SSLv3 (which is now considered insecure) in its OpenSSL build. Probably not a good idea for the installer to be using it.
Then when I get to the 'License activation' step, the installer just stalls at 'activating product'. I tried strace-ing to see if any other wget commands were failing, but I can only see
[pid <pid>] stat("/etc/wgetrc", {st_mode=S_IFREG|0644, st_size=4942, ...}) = 0
being executed repeatedly.
Yuan_C_Intel
Hi, Ross
Have you tried to activate with a license file instead of serial number? This activation does not require internet connection and may work for you.
To get a license file, you may refer to licensing FAQ for
https://software.intel.com/en-us/articles/how-do-i-get-a-license-file-for-an-offline-installation-of-intel-parallel-studio-xe-2016
More licensing FAQs: https://software.intel.com/en-us/faq/licensing
Hope this helps.
