Software Archive
Read-only legacy content
17060 Discussions
VCPU shutdown request
James_C_11
Just moved to a new machine running a 7th gen processor and can't seem to run any emulators that utilize haxm. Most recent version and from what I can tell I have the same settings on my old machine with a 6th gen processor.
Emulators work on hyper v and if I use the arm image but not x86 via the android emulator. The message below repeats over and over.
Hax is enabled
Hax ram_size 0x60000000
HAX is working and emulator runs in fast virt mode.
emulator: Listening for console connections on port: 5554
emulator: Serial number of this emulator (for ADB): emulator-5554
EAX=00748cea EBX=5ffadb60 ECX=00000000 EDX=00000000
ESI=00000000 EDI=00000000 EBP=00000000 ESP=00006d38
EIP=5ffb6921 EFL=00010082 [--S----] CPL=0 II=0 A20=1 SMM=0 HLT=0
ES =0010 00000000 ffffffff 00c09300 DPL=0 DS   [-WA]
Any help would be most appreciated, just spent two days trouble shooting and trying different suggestions.
Cheers,
James
Jun_H_Intel
Here is the bug https://code.google.com/p/android/issues/detail?id=226174 , and we are fixing it. I will notify you as long as it is fixed.
Jun_H_Intel
Before you use intel haxm to launch emulator, eg, x86 or x86_64, make sure "Hyper-V", a Windows feature, is not installed/enabled on your system. See https://software.intel.com/en-us/blogs/2014/03/14/troubleshooting-intel-haxm And Hyper-V sometimes may be re-activated by Windows 10 system update.
James_C_11
Hyper V has been tured off and removed from programs and features.
Jun_H_Intel
Which is your CPU?
Jun_H_Intel
FYI. Make sure all VT features are enabled in the BIOS. A good utility to check your system's capabilities is: Crystal CPUID
Jun_H_Intel
James_C_11
Thanks Jun.
Jun_H_Intel
This is a workaround:
In a Command Prompt window, run:
cd C:\Users\<username>\AppData\Local\Android\Sdk\Tools\
emulator.exe -avd <x86_avd_name> -accel off -verbose -show-kernel -gpu off -qemu -smp 1
'-qemu -smp 1' is equivalent to turning 'multi-core' off in AVD manager.
James_C_11
Thanks Jun but I'm not sure I'd call that a workaround. Using the ARM image is significantly faster yet still horribly slow. Unfortunately we're shelving the 7th gen machines until we get an update...just too slow to operate.
Is there a time frame on when we can expect a fix?
James_C_11
Any updates or a time frame we can work toward? We'd really like to start using the new machines and we're actively advising against fellow developers upgrade until this is resolved.
Jun_H_Intel
It still is under debugging.
James_C_11
Any updates Jun? I'm seeing more and more people struggling with this.
Jun_H_Intel
James_C_11
Can you provide a time frame? Just need to know if we should return 7th gen laptops as 30 day option is coming up.
Jun_H_Intel
After deep investigation, we have already root caused this issue. Then we will do the new release ASAP. See progress here: https://code.google.com/p/android/issues/detail?id=226174
Jun_H_Intel
Jun_H_Intel
We have fixed this bug. HAXM 6.0.5 for Windows is now being tested by Google and should be released later this week. If you can't wait, please download it from https://code.google.com/p/android/issues/detail?id=226174#c51
Jun_H_Intel
HAXM 6.0.5 is release via Google. And it is the same with I gave you before.
