Software Archive
Read-only legacy content
17060 Discussions
ios building Error code 65
Manas_S_
hello,i have problem in intel xdk ios build i am showing log file below .
** BUILD FAILED **
The following build commands failed:
	Check dependencies
(1 failure)
ERROR building one of the platforms: Error code 65 for command: xcodebuild with args: -xcconfig,.../cordova_project/platforms/ios/cordova/build-release.xcconfig,-project,babysigning.xcodeproj,ARCHS=armv7 arm64,-target,babysigning,-configuration,Release,-sdk,iphoneos,build,VALID_ARCHS=armv7 arm64,CONFIGURATION_BUILD_DIR=.../cordova_project/platforms/ios/build/device,SHARED_PRECOMPS_DIR=.../cordova_project/platforms/ios/build/sharedpch
You may not have the required environment or OS to build this project
Error: Error code 65 for command: xcodebuild with args: -xcconfig,.../cordova_project/platforms/ios/cordova/build-release.xcconfig,-project,babysigning.xcodeproj,ARCHS=armv7 arm64,-target,babysigning,-configuration,Release,-sdk,iphoneos,build,VALID_ARCHS=armv7 arm64,CONFIGURATION_BUILD_DIR=.../cordova_project/platforms/ios/build/device,SHARED_PRECOMPS_DIR=.../cordova_project/platforms/ios/build/sharedpch
PaulF_IntelCorp
Manas -- please attach the entire detailed build log as a TXT file to your post. Also, if you could post the summary build log, that may be helpful.
