Software Archive
Read-only legacy content
17060 Discussions
Problems installing MPSS on Centos 6.5
Choonghun_S_
I am trying to install driver to setup my intel xeon phi on centos 6.5.
I followed the getting started guide, installing MPSS-3.5.
but when I run "modprobe mic", I am getting the following message:
  1. [root@WS mpss-3.5]# modprobe mic
  2. Message from syslogd@WS at May 31 00:57:39 ...
  3. kernel:BUG: soft lockup - CPU#0 stuck for 67s! [work_for_cpu:6250]
Any idea what is going on? any clue about what is happening?
JJK
New Contributor III
which exact kernel version are you using (uname -a) ?
Try running 2.6.32-504-* at the very least.
Also, you might be bitten by a power supply issue, where the power supply is not capable of powering both the motherboard and the Xeon Phi (which can draw up to 300W) - install the sensors package and check the mobo voltages when powering up the card.
Choonghun_S_
Hello JJK
Thank you for your reply
I was try again latest kernel version. But Same problem appeared.
  1. [root@WS mpss-3.5]# uname -a
  2. Linux localhost.localdomain 2.6.32-504.16.2.el6.x86_64 #1 SMP Wed Apr 22 06:48:29 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
  3. [root@WS mpss-3.5]# modprobe mic
  4. Message from syslogd@WS at June 01 01:37:59 ...
  5. kernel:BUG: soft lockup - CPU#0 stuck for 67s! [work_for_cpu:6220]
It is power supply problem?
May be power supplier is insufficient?
Frances_R_Intel
Could you please run the script /usr/bin/micdebug.sh and send us the tar file it produces? If you wish, you may sanitize it to change things like machine names and network addresses to something generic. I don't believe those will be relevant here, but I will especially want to see the log files, the rpm listing and the lscpi outputs. You can send this as an attachment to a private message by clicking on the "Send Author A Message" link at the top of my post.
