Software Archive
Read-only legacy content
17061 Discussions
Problems with Intel 945GM and 1680x1050 resolution
logix88
I have a Dell 6400, with Intel 945GM 256MB, Windows 7... Recently bought a 22" Philips Monitor, At first it was working well... in fact, it worked well for over 3 months... One day I decided to install a game (Portal) and played it for a while, after the next restart my Monitors resolution was maxed out at 1280x780.
When I played the game it stuttered a lot when at max 1650x1050 resolution, so I switched it off. I also updated Windows 7 with some of their standard update packages. I am not sure what caused the problem...
I reinstalled my PC from scratch, Installed latest driversfrom Intel,but stillno luck... I am trying to flash my BIOS with an update from DELL ( I have the same version ) just in case it changes anything.
I don't know what else to do... pls help...
MonInfo shows four Display IDs...
None of them refer to Philips... It says ABC display and all of them have wrong screen size...
1 of them: ABC0D1D
Monitor
Model name............... ABC 24WDD08
Manufacturer............. ABC
Plug and Play ID......... ABC0D1D
Serial number (numeric).. 1170355343
Manufacture date......... 2008, ISO week 26
PID revision............. 0
DisplayID revision....... 1.0
Product type............. Display device (active)
Extension count.......... 0
DDC/CI................... n/a
Display parameters
Bloc revision............ 0
Native resolution........ 1920x1200 pixels
Screen size.............. 519 x 320 mm (23.7 in)
Audio support............ Not supported
Separate audio inputs.... Not supported
Audio input override..... Not supported
Power management......... Supported
Fixed timing............. Supported
Fixed pixel format....... Not supported
De-interlacing........... Not supported
Gamma.................... 2.20
Aspect ratio............. 1.60:1
Color bit depth.......... 8 bits per primary color
Bits per pixel........... 6 bits
Color characteristics
Color space.............. 1931 CIE (x,y)
No. of white points...... 1
No. of primaries......... 3
Color plane.............. Temporal
White point (default).... Wx 0.452 - Wy 0.331
Red chromaticity......... Rx 0.612 - Ry 0.599
Green chromaticity....... Gx 0.337 - Gy 0.059
Blue chromaticity........ Bx 0.938 - By 0.318
Type I timing - detailed
Detailed timing #1....... 1920x1200p at 60Hz (16:10) [Native]
Modeline............... "1920x1200" 154.000 1920 1968 2000 2080 1200 1203 1209 1235 +hsync -vsync
VESA timing standard
640 x 480p at 60Hz - VESA DMT
640 x 480p at 75Hz - VESA DMT
800 x 600p at 60Hz - VESA DMT
800 x 600p at 75Hz - VESA DMT
1024 x 768p at 60Hz - VESA DMT
1024 x 768p at 75Hz - VESA DMT
1280 x 800p at 60Hz - VESA DMT
1280 x 1024p at 60Hz - VESA DMT
1280 x 1024p at 75Hz - VESA DMT
1600 x 1200p at 60Hz - VESA DMT
1920 x 1200p at 60Hz - VESA DMT
CEA timing standard
640 x 480p at 60Hz - Default (4:3, 1:1)
720 x 480p at 60Hz - EDTV (4:3, 8:9)
720 x 480p at 60Hz - EDTV (16:9, 32:27)
1280 x 720p at 60Hz - HDTV (16:9, 1:1)
1920 x 1080i at 60Hz - HDTV (16:9, 1:1)
720 x 480i at 60Hz - Doublescan (4:3, 8:9)
720 x 480i at 60Hz - Doublescan (16:9, 32:27)
1920 x 1080p at 60Hz - HDTV (16:9, 1:1)
720 x 576p at 50Hz - EDTV (4:3, 16:15)
720 x 576p at 50Hz - EDTV (16:9, 64:45)
1280 x 720p at 50Hz - HDTV (16:9, 1:1)
1920 x 1080i at 50Hz - HDTV (16:9, 1:1)
720 x 576i at 50Hz - Doublescan (4:3, 16:15)
720 x 576i at 50Hz - Doublescan (16:9, 64:45)
1920 x 1080p at 50Hz - HDTV (16:9, 1:1)
NB: NTSC refresh rate = (Hz*1000)/1001
Product serial number
ASCII string............. C9536665178ST
General purpose ASCII string
Serial number............ ABC 24" LCD Display 1920x1200
Interface power sequencing
T1 range................. 0.8 to 16 ms
T2 range................. 0 to 64 ms
T3 range................. 0 to 64 ms
T4 range................. 0 to 640 ms
T5 range................. 0 to 320 ms
T6 range................. 0 to 320 ms
Transfer characteristics
White transfer curves.... Supported
Primary color curves..... Not supported
Color curve #1........... 15 samples
Luminence point 1...... 0.588
Luminence point 2...... 3.234
Luminence point 3...... 7.546
Luminence point 4...... 12.642
Luminence point 5...... 18.816
Luminence point 6...... 24.696
Luminence point 7...... 34.104
Luminence point 8...... 40.670
Luminence point 9...... 48.020
Luminence point 10..... 58.604
Luminence point 11..... 65.268
Luminence point 12..... 78.008
Luminence point 13..... 85.554
Luminence point 14..... 91.336
Luminence point 15..... 97.804
Report information
Date generated........... 04/06/2010
Software revision........ 2.51.0.853
Operating system......... 6.1.7600.2
Raw data
10,B5,03,00,00,00,17,41,42,43,1D,0D,8F,34,C2,45,1A,08,0B,41,42,43,20,32,34,57,44,44,30,38,01,00,
0C,07,02,40,01,80,07,B0,04,18,78,3C,75,02,00,0D,B1,3D,A7,54,CC,49,99,66,25,0F,00,5F,51,03,00,14,
27,3C,00,85,7F,07,9F,00,2F,80,1F,00,AF,04,22,00,02,00,05,00,07,00,0A,28,85,02,08,0C,00,04,00,10,
00,08,00,08,7F,80,3F,40,00,00,00,00,0A,00,0D,43,39,35,33,36,36,36,35,31,37,38,53,54,0B,00,1D,41,
42,43,20,32,34,22,20,4C,43,44,20,44,69,73,70,6C,61,79,20,31,39,32,30,78,31,32,30,30,0D,00,06,88,
20,20,40,20,20,0E,00,12,80,10,06,1B,2C,34,3F,3C,60,43,4B,6C,44,82,4D,3B,42,F0,8B,00,00,00,00,00,
00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,
Doraisamy_G_Intel
What exact problem are you seeing? Is it the game stuttering at a high resolution?
Have you tried reducing the other graphics settings, like model detail, shadows, and such to Low? If you are still seeing slow frame rate, your game probably needs higher end hardware to play.
On the other hand, if you are seeing Windows stutter or desktop or any of the standard browser / office apps stutter, then a driver or BIOS upgrade should fix it.
antonio_barbalace
I have a similar problem with a
-> Mobile Intel 945 Express Chipset Family <-
on a Toshiba Satellite U200 (Italian market model)
On Linux with kernel 2.6.25 I have no problems at all but using
-> Windows XP* Home Edition, Service Pack 2 (5.1.2600) <-
with your updated drivers
-> Intel Graphics Media Accelerator Driver for Mobile (6.14.10.4926) <-
when I connect an external monitor with 16:9 geometry the 1600x900 resolution is not recognized!!!
Cut&Past of the Information Tab of you setup/configuration application (the external monitor):
* Monitor *
Monitor Name: ACER X203H
Display Type: Analog
Gamma Value: 2.20
DDC2 Protocol: Supported
Maximum Image Size: Horizontal: 17.0 inches
Vertical: 9.0 inches
Monitor Supported Modes:
640 x 480 (60 Hz)
640 x 480 (67 Hz)
640 x 480 (72 Hz)
640 x 480 (75 Hz)
720 x 400 (70 Hz)
800 x 600 (56 Hz)
800 x 600 (60 Hz)
800 x 600 (72 Hz)
800 x 600 (75 Hz)
1024 x 768 (60 Hz)
1024 x 768 (70 Hz)
1024 x 768 (75 Hz)
1152 x 864 (75 Hz)
1152 x 870 (75 Hz)
1280 x 720 (60 Hz)
1280 x 960 (60 Hz)
1280 x 1024 (60 Hz)
1280 x 1024 (75 Hz)
1280 x 1280 (60 Hz)
1600 x 900 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Supported
What I have to do to use the 1600*900 mode on the external monitor?
I have also tried with strange tool that will reinterpret the EDID but without any result.
Did you plan a new release of the drivers also for XP?
Thanks a lot for your consideration,
regards,
Antonio Barbalace
