Software Archive
Read-only legacy content
17060 Discussions
Problems with UPnPSmartControlPoint
crashingsucks
I am evaluating the UPnP API and have written a small console app to test it. I am using the UPnPSmartControlPoint object and have added a device handler to receive acknowlegements from the network devices. My handler subroutine fires as expected for each device it finds but the device is not added to the control points device collection. What am I doing wrong? The following is my code. Thanks for any responses.
Imports
Intel.UPNP
Module
Module1
Dim cp As New UPnPSmartControlPoint
Sub Main()
AddHandler cp.OnAddedDevice, AddressOf doit
cp.Rescan()
System.Threading.Thread.Sleep(5000)
End Sub
Sub doit(ByVal sender As Intel.UPNP.UPnPSmartControlPoint, ByVal device As Intel.UPNP.UPnPDevice)
End Sub
End
Module
BRYAN_R_Intel
I noticed that the other overloads of the constructor for the UPnPSmartControlPoint object, uses the "DevicePartialMatchFilter" parameter. I also just noticed that the overload that only takes the OnAdded delegate calls the constructor that takes a delegate, and the DevicePartialMatchFilter, and passes in "upnp:rootdevice".
You can rectify the problem, by using that contructor instead of the default constructor. I can have this fixed in the next release of the tools.
As a side note, you should be using the contructor that takes in delegates as parameters, because otherwise you will miss callbacks between the time you construct the object, and when you set the callbacks later. I see you worked around that by calling rescan(), but that is just making the callbacks take longer then they need to.
If you do choose to use those contructors, then you can use "upnp:rootdevice" as the filter, if you are interested in all devices.
